Insteon Motion Sensor
I am trying to link a skylink insteon motion sensor into the ISY99i. First time trying to link one of these (my outside motions are Dakotas). The box indicates model 2842-222 and the sensor itself indicates model 2420M.
My error is "cannot determine insteon engine". I have tried to link it several ways, new insteon device, naming it, choosing the motion sensor, tried auto discover, nothing works. Once hitting the "set" button on the motion, I am placing right next to an access point (actually I've tried two different access points).
Am I missing a step? Any suggestions on how to get this thing linked would be most appreciated.
The 2842-222 and 2420M are the same device. The 2842-222 is Smarthome new Item number Scheme for RF devices. The -222 suffix indicates it uses an RF frequency for the US. Do not specify a Device Type. Use New INSTEON Device, enter Insteon Address of Motion Sensor, Name of choice, leave Device Type set to default Auto Discover. BEFORE clicking Ok, put the Motion Sensor into linking mode by pressing the MS Set button until the Red LED blinks continuously. Then click Ok on New INSTEON Device. Be sure the Motion Sensor is near a Dual Band device.
Nope, same message. I peeled the device address "sticker" up (on the back of the motion) and there was another device address?? I tried that address also and received same message. I tried putting it near two different access points. Do I have the most recent version of admin console 3.3.4 and does that matter?
ISY 3.3.9 (RC6) is the latest image.
If the Insteon address of the Motion Sensor is in question it can be manually linked to some responder such as a LampLinc or ApplianceLinc. Press the Motion Sensor Set button putting it into linking mode. Press the Set button on a LampLinc or ApplianceLinc to link it as a Responder to the Motion Sensor. Then do a Show Device Links Table on the LampLinc/ApplianceLinc. Unless there were deleted link records in the device the Motion Sensor address will be in the last link record.
The LampLinc/ApplianceLinc requires a Restore Device to get rid of the Set button link.
If the ISY PLM is a 2413 the Access Point closest to the Motion Sensor can have the 4 tap Set button test initiated. Then look at the 2413 PLM status LED to see if it can hear the Access Point. A few days ago a user found a dead spot in his RF coverage was responsible for a thermostat problem. Seems like a space between two Access Points had no RF coverage. Can also try moving the Motion Sensor to a different location to see if better RF coverage is obtained.
Okay, linked motion to lamplinc, device link table showed the new motion's address (3rd from the bottom), which is the one I've been using in link management.
4 tapped the access point (the one I have the motion sitting next to) and my PLM led was flashing green.
Next step is to run Tools | Diagnostics | Event Viewer with LEVEL 3. Use New INSTEON Device as previously described to attempt to add Motion Sensor. Post the event trace. From the message I think there will be no communication from with the Motion Sensor. The event trace will confirm that.
Okay, did the next steps, but not sure how to "post" the trace. I saved the file to my desktop.
Tue 01/15/2013 07:07:46 PM : [ 13 74 23 1] ERR 0
Tue 01/15/2013 07:07:46 PM : [ 13 74 23 1] ST 255
Tue 01/15/2013 07:07:52 PM : [ 13 74 23 1] ERR 1
Tue 01/15/2013 07:08:41 PM : [ 13 74 23 1] ERR 0
Tue 01/15/2013 07:08:49 PM : [ 13 74 23 1] ERR 1
Tue 01/15/2013 07:09:06 PM : [ 13 74 23 1] ERR 0
Tue 01/15/2013 07:09:06 PM : [ 13 74 23 1] ST 0
Tue 01/15/2013 07:14:51 PM : [ 13 74 23 1] Preparing Device 'Office Wall Unit' for Restore
Tue 01/15/2013 07:14:51 PM : [ 13 74 23 1] Removing link to unknown device '11 C3 F6 1'
Tue 01/15/2013 07:14:51 PM : [ 13 74 23 1] Device 'Office Wall Unit' ready for Full Restore
Tue 01/15/2013 07:14:51 PM : [13 74 23 0 ] May not fully support i2, reverting to i1
Tue 01/15/2013 07:15:20 PM : [ 17 CC 8 1] DON 0
Tue 01/15/2013 07:15:20 PM : [ 17 CC 8 1] ST 255
Tue 01/15/2013 07:16:08 PM : [ 17 CC 8 1] DOF 0
Tue 01/15/2013 07:16:08 PM : [ 17 CC 8 1] ST 0
Tue 01/15/2013 07:17:23 PM : [ 11 E2 73 5] DON 0
Tue 01/15/2013 07:17:23 PM : [ 1B 45 94 1] ST 255
Tue 01/15/2013 07:17:23 PM : [ 11 E2 73 5] ST 255
Tue 01/15/2013 07:17:45 PM : [ 1B 45 94 1] DOF 0
Tue 01/15/2013 07:17:45 PM : [ 1B 45 94 1] ST 0
Tue 01/15/2013 07:17:46 PM : [ 11 E2 73 5] ST 0
Tue 01/15/2013 07:17:50 PM : [ 1D 94 F 1] DON 0
Tue 01/15/2013 07:17:50 PM : [ 1D 94 F 1] ST 255
Tue 01/15/2013 07:17:50 PM : [ 1B 41 51 1] ST 255
Tue 01/15/2013 07:18:20 PM : [21 d9 e2 ] Added to list of devices to link to ISY
Tue 01/15/2013 07:18:44 PM : [21 D9 E2 0 ] Cannot determine device type
Tue 01/15/2013 07:18:44 PM : [21 D9 E2 0 ] Failed to add device
Tue 01/15/2013 07:19:48 PM : [ 1D 94 F 1] ST 0
Tue 01/15/2013 07:19:48 PM : [ 1B 41 51 1] ST 0
Tue 01/15/2013 07:20:18 PM : [ 1D 93 2C 1] DON 0
Tue 01/15/2013 07:20:55 PM : [ 1D 93 2C 1] DOF 0
Tue 01/15/2013 07:20:55 PM : [ 1D 93 2C 1] ST 0
Tue 01/15/2013 07:27:21 PM : [ IR] 012A Press
Tue 01/15/2013 07:46:12 PM : [iNST-SRX ] 02 50 1D.94.0F 00.00.01 C7 11 00 LTONRR (00)
Tue 01/15/2013 07:46:12 PM : [std-Group ] 1D.94.0F-->Group=1, Max Hops=3, Hops Left=1
Tue 01/15/2013 07:46:12 PM : [ 1D 94 F 1] DON 0
Tue 01/15/2013 07:46:12 PM : [ 1D 94 F 1] ST 255
Tue 01/15/2013 07:46:12 PM : [ 1B 41 51 1] ST 255
Tue 01/15/2013 07:46:12 PM : [iNST-SRX ] 02 50 1D.94.0F 11.00.01 C7 06 00 (00)
Tue 01/15/2013 07:46:12 PM : [std-Group ] 1D.94.0F-->11.00.01, Max Hops=3, Hops Left=1
Tue 01/15/2013 07:46:22 PM : [iNST-SRX ] 02 50 1D.94.0F 00.00.01 C7 13 00 LTOFFRR(00)
Tue 01/15/2013 07:46:22 PM : [std-Group ] 1D.94.0F-->Group=1, Max Hops=3, Hops Left=1
Tue 01/15/2013 07:46:22 PM : [ 1D 94 F 1] DOF 0
Tue 01/15/2013 07:46:22 PM : [ 1D 94 F 1] ST 0
Tue 01/15/2013 07:46:22 PM : [ 1B 41 51 1] ST 0
Tue 01/15/2013 07:46:22 PM : [iNST-SRX ] 02 50 1D.94.0F 13.00.01 C3 06 00 (00)
Tue 01/15/2013 07:46:22 PM : [std-Group ] 1D.94.0F-->13.00.01, Max Hops=3, Hops Left=0
Tue 01/15/2013 07:47:06 PM : [21 d9 e2 ] Added to list of devices to link to ISY
Tue 01/15/2013 07:47:06 PM : [iNST-TX-I1 ] 02 62 21 D9 E2 0F 0D 00
Tue 01/15/2013 07:47:06 PM : [iNST-ACK ] 02 62 21.D9.E2 0F 0D 00 06 (00)
Tue 01/15/2013 07:47:08 PM : [iNST-SRX ] 02 50 21.D9.E2 19.72.7C 23 0D 02 (02)
Tue 01/15/2013 07:47:08 PM : [std-Direct Ack] 21.D9.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Tue 01/15/2013 07:47:08 PM : [iNST-TX-I1 ] 02 62 21 D9 E2 0F 10 00
Tue 01/15/2013 07:47:08 PM : [iNST-ACK ] 02 62 21.D9.E2 0F 10 00 06 ID-REQ (00)
Tue 01/15/2013 07:47:08 PM : [iNST-SRX ] 02 50 21.D9.E2 19.72.7C 23 10 00 ID-REQ (00)
Tue 01/15/2013 07:47:17 PM : [iNST-TX-I1 ] 02 62 21 D9 E2 0F 10 00
Tue 01/15/2013 07:47:17 PM : [iNST-ACK ] 02 62 21.D9.E2 0F 10 00 06 ID-REQ (00)
Tue 01/15/2013 07:47:17 PM : [iNST-SRX ] 02 50 21.D9.E2 19.72.7C 23 10 00 ID-REQ (00)
Tue 01/15/2013 07:47:17 PM : [std-Direct Ack] 21.D9.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Tue 01/15/2013 07:47:26 PM : [iNST-TX-I1 ] 02 62 21 D9 E2 0F 10 00
Tue 01/15/2013 07:47:26 PM : [iNST-ACK ] 02 62 21.D9.E2 0F 10 00 06 ID-REQ (00)
Tue 01/15/2013 07:47:30 PM : [21 D9 E2 0 ] Cannot determine device type
Tue 01/15/2013 07:47:30 PM : [21 D9 E2 0 ] Failed to add device
Tue 01/15/2013 07:47:40 PM : [iNST-SRX ] 02 50 1A.31.C2 00.00.01 C7 11 00 LTONRR (00)
Tue 01/15/2013 07:47:40 PM : [std-Group ] 1A.31.C2-->Group=1, Max Hops=3, Hops Left=1
Tue 01/15/2013 07:47:40 PM : [ 1A 31 C2 1] DON 0
Tue 01/15/2013 07:47:40 PM : [ 1A 31 C2 1] ST 255
Tue 01/15/2013 07:47:41 PM : [iNST-SRX ] 02 50 1A.31.C2 19.72.7C 43 11 01 LTONRR (01)
Tue 01/15/2013 07:47:41 PM : [std-Cleanup ] 1A.31.C2-->ISY/PLM Group=1, Max Hops=3, Hops Left=0
Tue 01/15/2013 07:47:41 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 07:48:32 PM : [iNST-SRX ] 02 50 1D.77.F9 00.00.09 C7 11 00 LTONRR (00)
Tue 01/15/2013 07:48:32 PM : [std-Group ] 1D.77.F9-->Group=9, Max Hops=3, Hops Left=1
Tue 01/15/2013 07:48:32 PM : [ 1D 77 F9 9] DON 0
Tue 01/15/2013 07:48:32 PM : [iNST-SRX ] 02 50 1D.77.F9 19.72.7C 42 11 09 LTONRR (09)
Tue 01/15/2013 07:48:32 PM : [std-Cleanup ] 1D.77.F9-->ISY/PLM Group=9, Max Hops=2, Hops Left=0
Tue 01/15/2013 07:48:32 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 07:48:33 PM : [iNST-TX-I1 ] 02 62 00 00 49 CF 11 00
Tue 01/15/2013 07:48:33 PM : [iNST-TX-I1 ] 02 62 1D 91 71 0F 11 FF
Tue 01/15/2013 07:48:33 PM : [iNST-TX-I1 ] 02 62 00 00 15 CF 12 00
Tue 01/15/2013 07:48:33 PM : [iNST-ACK ] 02 62 00.00.49 CF 11 00 06 LTONRR (00)
Tue 01/15/2013 07:48:33 PM : [iNST-ACK ] 02 62 1D.91.71 0F 11 FF 06 LTONRR (FF)
Tue 01/15/2013 07:48:34 PM : [iNST-SRX ] 02 50 1D.91.71 19.72.7C 23 11 FF LTONRR (FF)
Tue 01/15/2013 07:48:34 PM : [std-Direct Ack] 1D.91.71-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Tue 01/15/2013 07:48:34 PM : [iNST-ACK ] 02 62 00.00.15 CF 12 00 06 LTON-F (00)
Tue 01/15/2013 07:48:34 PM : [iNST-TX-I1 ] 02 62 00 00 22 CF 12 00
Tue 01/15/2013 07:48:34 PM : [ 1D 77 F9 9] ST 255
Tue 01/15/2013 07:48:34 PM : [iNST-ACK ] 02 62 00.00.22 CF 12 00 06 LTON-F (00)
Tue 01/15/2013 07:48:35 PM : [iNST-TX-I1 ] 02 62 00 00 15 CF 14 00
Tue 01/15/2013 07:48:35 PM : [iNST-TX-I1 ] 02 62 00 00 22 CF 14 00
Tue 01/15/2013 07:48:35 PM : [ 1D 91 71 1] ST 255
Tue 01/15/2013 07:48:35 PM : [iNST-ACK ] 02 62 00.00.15 CF 14 00 06 LTOFF-F(00)
Tue 01/15/2013 07:48:35 PM : [ 16 95 73 1] ST 0
Tue 01/15/2013 07:48:35 PM : [ 17 CD B6 1] ST 0
Tue 01/15/2013 07:48:35 PM : [ 13 6B 7F 6] ST 0
Tue 01/15/2013 07:48:35 PM : [iNST-ACK ] 02 62 00.00.22 CF 14 00 06 LTOFF-F(00)
Tue 01/15/2013 07:48:35 PM : [ 1D 91 77 1] ST 0
Tue 01/15/2013 07:48:36 PM : [iNST-SRX ] 02 50 1D.77.F9 00.00.09 C7 13 00 LTOFFRR(00)
Tue 01/15/2013 07:48:36 PM : [std-Group ] 1D.77.F9-->Group=9, Max Hops=3, Hops Left=1
Tue 01/15/2013 07:48:36 PM : [ 1D 77 F9 9] DOF 0
Tue 01/15/2013 07:48:36 PM : [ 1D 77 F9 9] ST 0
Tue 01/15/2013 07:48:37 PM : [iNST-SRX ] 02 50 1D.77.F9 19.72.7C 41 13 09 LTOFFRR(09)
Tue 01/15/2013 07:48:37 PM : [std-Cleanup ] 1D.77.F9-->ISY/PLM Group=9, Max Hops=1, Hops Left=0
Tue 01/15/2013 07:48:37 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 07:48:37 PM : [iNST-SRX ] 02 50 1D.77.F9 19.72.7C 42 13 09 LTOFFRR(09)
Tue 01/15/2013 07:48:37 PM : [std-Cleanup ] 1D.77.F9-->ISY/PLM Group=9, Max Hops=2, Hops Left=0
Tue 01/15/2013 07:49:35 PM : [iNST-SRX ] 02 50 13.6B.7F 00.00.06 C7 13 00 LTOFFRR(00)
Tue 01/15/2013 07:49:35 PM : [std-Group ] 13.6B.7F-->Group=6, Max Hops=3, Hops Left=1
Tue 01/15/2013 07:49:35 PM : [ 13 6B 7F 6] DOF 0
Tue 01/15/2013 07:49:36 PM : [iNST-SRX ] 02 50 13.6B.7F 19.72.7C 42 13 06 LTOFFRR(06)
Tue 01/15/2013 07:49:36 PM : [std-Cleanup ] 13.6B.7F-->ISY/PLM Group=6, Max Hops=2, Hops Left=0
Tue 01/15/2013 07:49:36 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 07:49:37 PM : [iNST-SRX ] 02 50 13.6B.7F 00.00.06 C7 11 00 LTONRR (00)
Tue 01/15/2013 07:49:37 PM : [std-Group ] 13.6B.7F-->Group=6, Max Hops=3, Hops Left=1
Tue 01/15/2013 07:49:37 PM : [ 13 6B 7F 6] DON 0
Tue 01/15/2013 07:49:38 PM : [ 16 95 73 1] ST 255
Tue 01/15/2013 07:49:38 PM : [ 17 CD B6 1] ST 255
Tue 01/15/2013 07:49:38 PM : [ 13 6B 7F 6] ST 255
Tue 01/15/2013 07:49:38 PM : [iNST-SRX ] 02 50 13.6B.7F 19.72.7C 41 11 06 LTONRR (06)
Tue 01/15/2013 07:49:38 PM : [std-Cleanup ] 13.6B.7F-->ISY/PLM Group=6, Max Hops=1, Hops Left=0
Tue 01/15/2013 07:49:38 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 07:52:51 PM : [iNST-SRX ] 02 50 1D.77.F9 00.00.09 C7 11 00 LTONRR (00)
Tue 01/15/2013 07:52:51 PM : [std-Group ] 1D.77.F9-->Group=9, Max Hops=3, Hops Left=1
Tue 01/15/2013 07:52:51 PM : [ 1D 77 F9 9] DON 0
Tue 01/15/2013 07:52:51 PM : [iNST-SRX ] 02 50 1D.77.F9 19.72.7C 41 11 09 LTONRR (09)
Tue 01/15/2013 07:52:51 PM : [std-Cleanup ] 1D.77.F9-->ISY/PLM Group=9, Max Hops=1, Hops Left=0
Tue 01/15/2013 07:52:51 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 07:52:52 PM : [iNST-TX-I1 ] 02 62 00 00 49 CF 11 00
Tue 01/15/2013 07:52:52 PM : [iNST-TX-I1 ] 02 62 1D 91 71 0F 11 FF
Tue 01/15/2013 07:52:52 PM : [iNST-ACK ] 02 62 00.00.49 CF 11 00 06 LTONRR (00)
Tue 01/15/2013 07:52:52 PM : [iNST-TX-I1 ] 02 62 00 00 15 CF 12 00
Tue 01/15/2013 07:52:52 PM : [iNST-TX-I1 ] 02 62 00 00 22 CF 12 00
Tue 01/15/2013 07:52:52 PM : [ 1D 77 F9 9] ST 255
Tue 01/15/2013 07:52:52 PM : [iNST-ACK ] 02 62 1D.91.71 0F 11 FF 06 LTONRR (FF)
Tue 01/15/2013 07:52:52 PM : [iNST-SRX ] 02 50 1D.91.71 19.72.7C 23 11 FF LTONRR (FF)
Tue 01/15/2013 07:52:52 PM : [std-Direct Ack] 1D.91.71-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Tue 01/15/2013 07:52:53 PM : [iNST-ACK ] 02 62 00.00.15 CF 12 00 06 LTON-F (00)
Tue 01/15/2013 07:52:53 PM : [iNST-TX-I1 ] 02 62 00 00 15 CF 14 00
Tue 01/15/2013 07:52:53 PM : [iNST-TX-I1 ] 02 62 00 00 22 CF 14 00
Tue 01/15/2013 07:52:53 PM : [iNST-ACK ] 02 62 00.00.22 CF 12 00 06 LTON-F (00)
Tue 01/15/2013 07:52:53 PM : [ 1D 91 77 1] ST 255
Tue 01/15/2013 07:52:54 PM : [iNST-ACK ] 02 62 00.00.15 CF 14 00 06 LTOFF-F(00)
Tue 01/15/2013 07:52:54 PM : [ 16 95 73 1] ST 0
Tue 01/15/2013 07:52:54 PM : [ 17 CD B6 1] ST 0
Tue 01/15/2013 07:52:54 PM : [ 13 6B 7F 6] ST 0
Tue 01/15/2013 07:52:54 PM : [iNST-ACK ] 02 62 00.00.22 CF 14 00 06 LTOFF-F(00)
Tue 01/15/2013 07:52:54 PM : [ 1D 91 77 1] ST 0
Tue 01/15/2013 07:52:56 PM : [iNST-SRX ] 02 50 1D.77.F9 00.00.09 C3 13 00 LTOFFRR(00)
Tue 01/15/2013 07:52:56 PM : [std-Group ] 1D.77.F9-->Group=9, Max Hops=3, Hops Left=0
Tue 01/15/2013 07:52:56 PM : [ 1D 77 F9 9] DOF 0
Tue 01/15/2013 07:52:56 PM : [ 1D 77 F9 9] ST 0
Tue 01/15/2013 07:52:56 PM : [iNST-SRX ] 02 50 1D.77.F9 19.72.7C 41 13 09 LTOFFRR(09)
Tue 01/15/2013 07:52:56 PM : [std-Cleanup ] 1D.77.F9-->ISY/PLM Group=9, Max Hops=1, Hops Left=0
Tue 01/15/2013 07:52:56 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 07:54:56 PM : [iNST-SRX ] 02 50 13.6B.7F 00.00.06 C7 11 00 LTONRR (00)
Tue 01/15/2013 07:54:56 PM : [std-Group ] 13.6B.7F-->Group=6, Max Hops=3, Hops Left=1
Tue 01/15/2013 07:54:56 PM : [ 13 6B 7F 6] DON 0
Tue 01/15/2013 07:54:56 PM : [ 16 95 73 1] ST 255
Tue 01/15/2013 07:54:56 PM : [ 17 CD B6 1] ST 255
Tue 01/15/2013 07:54:56 PM : [ 13 6B 7F 6] ST 255
Tue 01/15/2013 07:54:56 PM : [iNST-SRX ] 02 50 13.6B.7F 19.72.7C 41 11 06 LTONRR (06)
Tue 01/15/2013 07:54:56 PM : [std-Cleanup ] 13.6B.7F-->ISY/PLM Group=6, Max Hops=1, Hops Left=0
Tue 01/15/2013 07:54:56 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 07:57:51 PM : [21 d9 e2 ] Added to list of devices to link to ISY
Tue 01/15/2013 07:57:51 PM : [iNST-TX-I1 ] 02 62 21 D9 E2 0F 0D 00
Tue 01/15/2013 07:57:51 PM : [iNST-ACK ] 02 62 21.D9.E2 0F 0D 00 06 (00)
Tue 01/15/2013 07:58:00 PM : [iNST-TX-I1 ] 02 62 21 D9 E2 0F 0D 00
Tue 01/15/2013 07:58:00 PM : [iNST-ACK ] 02 62 21.D9.E2 0F 0D 00 06 (00)
Tue 01/15/2013 07:58:00 PM : [iNST-SRX ] 02 50 21.D9.E2 19.72.7C 23 0D 02 (02)
Tue 01/15/2013 07:58:00 PM : [std-Direct Ack] 21.D9.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Tue 01/15/2013 07:58:00 PM : [iNST-TX-I1 ] 02 62 21 D9 E2 0F 10 00
Tue 01/15/2013 07:58:00 PM : [iNST-ACK ] 02 62 21.D9.E2 0F 10 00 06 ID-REQ (00)
Tue 01/15/2013 07:58:02 PM : [iNST-SRX ] 02 50 21.D9.E2 19.72.7C 23 10 00 ID-REQ (00)
Tue 01/15/2013 07:58:02 PM : [std-Direct Ack] 21.D9.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Tue 01/15/2013 07:58:11 PM : [iNST-TX-I1 ] 02 62 21 D9 E2 0F 10 00
Tue 01/15/2013 07:58:11 PM : [iNST-ACK ] 02 62 21.D9.E2 0F 10 00 06 ID-REQ (00)
Tue 01/15/2013 07:58:20 PM : [iNST-TX-I1 ] 02 62 21 D9 E2 0F 10 00
Tue 01/15/2013 07:58:20 PM : [iNST-ACK ] 02 62 21.D9.E2 0F 10 00 06 ID-REQ (00)
Tue 01/15/2013 07:58:21 PM : [iNST-SRX ] 02 50 21.D9.E2 19.72.7C 23 10 00 ID-REQ (00)
Tue 01/15/2013 07:58:21 PM : [std-Direct Ack] 21.D9.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Tue 01/15/2013 07:58:25 PM : [21 D9 E2 0 ] Cannot determine device type
Tue 01/15/2013 07:58:25 PM : [21 D9 E2 0 ] Failed to add device
Thanks. The trace is very helpful. A few commands to the Motion Sensor worked but at the very extreme. Several commands got no response which eventually terminated the device add.
A new battery could be installed
Move the Motion Sensor to the ISY PLM location to eliminate the rest of the Insteon network. Repeat the device add with the Event Viewer running at LEVEL 3 with the Motion Sensor near the 2413 PLM.
Installed new battery and tried again with motion next to PLM.
Tue 01/15/2013 08:04:48 PM : [ Time] 20:05:36 0(0)
Tue 01/15/2013 08:06:45 PM : [iNST-SRX ] 02 50 1D.77.F9 00.00.09 C7 11 00 LTONRR (00)
Tue 01/15/2013 08:06:45 PM : [std-Group ] 1D.77.F9-->Group=9, Max Hops=3, Hops Left=1
Tue 01/15/2013 08:06:45 PM : [ 1D 77 F9 9] DON 0
Tue 01/15/2013 08:06:45 PM : [iNST-SRX ] 02 50 1D.77.F9 19.72.7C 42 11 09 LTONRR (09)
Tue 01/15/2013 08:06:45 PM : [std-Cleanup ] 1D.77.F9-->ISY/PLM Group=9, Max Hops=2, Hops Left=0
Tue 01/15/2013 08:06:45 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 08:06:45 PM : [iNST-SRX ] 02 50 1D.77.F9 19.72.7C 47 11 09 LTONRR (09)
Tue 01/15/2013 08:06:45 PM : [std-Cleanup ] 1D.77.F9-->ISY/PLM Group=9, Max Hops=3, Hops Left=1
Tue 01/15/2013 08:06:46 PM : [iNST-TX-I1 ] 02 62 00 00 49 CF 11 00
Tue 01/15/2013 08:06:46 PM : [iNST-TX-I1 ] 02 62 1D 91 71 0F 11 FF
Tue 01/15/2013 08:06:46 PM : [iNST-TX-I1 ] 02 62 00 00 15 CF 12 00
Tue 01/15/2013 08:06:46 PM : [iNST-TX-I1 ] 02 62 00 00 22 CF 12 00
Tue 01/15/2013 08:06:46 PM : [ 1D 77 F9 9] ST 255
Tue 01/15/2013 08:06:46 PM : [iNST-ACK ] 02 62 00.00.49 CF 11 00 06 LTONRR (00)
Tue 01/15/2013 08:06:46 PM : [iNST-ACK ] 02 62 1D.91.71 0F 11 FF 06 LTONRR (FF)
Tue 01/15/2013 08:06:47 PM : [iNST-SRX ] 02 50 1D.91.71 19.72.7C 23 11 FF LTONRR (FF)
Tue 01/15/2013 08:06:47 PM : [std-Direct Ack] 1D.91.71-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Tue 01/15/2013 08:06:47 PM : [iNST-ACK ] 02 62 00.00.15 CF 12 00 06 LTON-F (00)
Tue 01/15/2013 08:06:47 PM : [iNST-TX-I1 ] 02 62 00 00 15 CF 14 00
Tue 01/15/2013 08:06:47 PM : [iNST-TX-I1 ] 02 62 00 00 22 CF 14 00
Tue 01/15/2013 08:06:47 PM : [iNST-ACK ] 02 62 00.00.22 CF 12 00 06 LTON-F (00)
Tue 01/15/2013 08:06:47 PM : [ 1D 91 77 1] ST 255
Tue 01/15/2013 08:06:48 PM : [iNST-ACK ] 02 62 00.00.15 CF 14 00 06 LTOFF-F(00)
Tue 01/15/2013 08:06:48 PM : [ 16 95 73 1] ST 0
Tue 01/15/2013 08:06:48 PM : [ 17 CD B6 1] ST 0
Tue 01/15/2013 08:06:48 PM : [ 13 6B 7F 6] ST 0
Tue 01/15/2013 08:06:48 PM : [iNST-ACK ] 02 62 00.00.22 CF 14 00 06 LTOFF-F(00)
Tue 01/15/2013 08:06:48 PM : [ 1D 91 77 1] ST 0
Tue 01/15/2013 08:06:49 PM : [iNST-SRX ] 02 50 1D.77.F9 00.00.09 C7 13 00 LTOFFRR(00)
Tue 01/15/2013 08:06:49 PM : [std-Group ] 1D.77.F9-->Group=9, Max Hops=3, Hops Left=1
Tue 01/15/2013 08:06:49 PM : [ 1D 77 F9 9] DOF 0
Tue 01/15/2013 08:06:49 PM : [ 1D 77 F9 9] ST 0
Tue 01/15/2013 08:06:49 PM : [iNST-SRX ] 02 50 1D.77.F9 19.72.7C 41 13 09 LTOFFRR(09)
Tue 01/15/2013 08:06:49 PM : [std-Cleanup ] 1D.77.F9-->ISY/PLM Group=9, Max Hops=1, Hops Left=0
Tue 01/15/2013 08:06:49 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 08:13:13 PM : [iNST-SRX ] 02 50 17.CC.08 00.00.01 CB 11 00 LTONRR (00)
Tue 01/15/2013 08:13:13 PM : [std-Group ] 17.CC.08-->Group=1, Max Hops=3, Hops Left=2
Tue 01/15/2013 08:13:13 PM : [ 17 CC 8 1] DON 0
Tue 01/15/2013 08:13:13 PM : [ 17 CC 8 1] ST 255
Tue 01/15/2013 08:13:13 PM : [iNST-SRX ] 02 50 17.CC.08 19.72.7C 41 11 01 LTONRR (01)
Tue 01/15/2013 08:13:13 PM : [std-Cleanup ] 17.CC.08-->ISY/PLM Group=1, Max Hops=1, Hops Left=0
Tue 01/15/2013 08:13:13 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 08:13:16 PM : [iNST-SRX ] 02 50 17.CC.08 00.00.01 CB 13 00 LTOFFRR(00)
Tue 01/15/2013 08:13:16 PM : [std-Group ] 17.CC.08-->Group=1, Max Hops=3, Hops Left=2
Tue 01/15/2013 08:13:16 PM : [ 17 CC 8 1] DOF 0
Tue 01/15/2013 08:13:16 PM : [ 17 CC 8 1] ST 0
Tue 01/15/2013 08:13:16 PM : [iNST-SRX ] 02 50 17.CC.08 19.72.7C 41 13 01 LTOFFRR(01)
Tue 01/15/2013 08:13:16 PM : [std-Cleanup ] 17.CC.08-->ISY/PLM Group=1, Max Hops=1, Hops Left=0
Tue 01/15/2013 08:13:16 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 08:13:16 PM : [iNST-TX-I1 ] 02 62 00 00 2D CF 13 00
Tue 01/15/2013 08:13:16 PM : [iNST-ACK ] 02 62 00.00.2D CF 13 00 06 LTOFFRR(00)
Tue 01/15/2013 08:14:32 PM : [iNST-SRX ] 02 50 1D.77.F9 00.00.09 C7 11 00 LTONRR (00)
Tue 01/15/2013 08:14:32 PM : [std-Group ] 1D.77.F9-->Group=9, Max Hops=3, Hops Left=1
Tue 01/15/2013 08:14:32 PM : [ 1D 77 F9 9] DON 0
Tue 01/15/2013 08:14:32 PM : [iNST-SRX ] 02 50 1D.77.F9 19.72.7C 41 11 09 LTONRR (09)
Tue 01/15/2013 08:14:32 PM : [std-Cleanup ] 1D.77.F9-->ISY/PLM Group=9, Max Hops=1, Hops Left=0
Tue 01/15/2013 08:14:32 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 08:14:32 PM : [iNST-TX-I1 ] 02 62 00 00 49 CF 11 00
Tue 01/15/2013 08:14:32 PM : [iNST-TX-I1 ] 02 62 1D 91 71 0F 11 FF
Tue 01/15/2013 08:14:32 PM : [iNST-TX-I1 ] 02 62 00 00 15 CF 12 00
Tue 01/15/2013 08:14:32 PM : [iNST-TX-I1 ] 02 62 00 00 22 CF 12 00
Tue 01/15/2013 08:14:32 PM : [ 1D 77 F9 9] ST 255
Tue 01/15/2013 08:14:32 PM : [iNST-ACK ] 02 62 00.00.49 CF 11 00 06 LTONRR (00)
Tue 01/15/2013 08:14:33 PM : [iNST-ACK ] 02 62 1D.91.71 0F 11 FF 06 LTONRR (FF)
Tue 01/15/2013 08:14:33 PM : [iNST-SRX ] 02 50 1D.91.71 19.72.7C 23 11 FF LTONRR (FF)
Tue 01/15/2013 08:14:33 PM : [std-Direct Ack] 1D.91.71-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Tue 01/15/2013 08:14:33 PM : [iNST-ACK ] 02 62 00.00.15 CF 12 00 06 LTON-F (00)
Tue 01/15/2013 08:14:33 PM : [ 16 95 73 1] ST 255
Tue 01/15/2013 08:14:33 PM : [ 17 CD B6 1] ST 255
Tue 01/15/2013 08:14:33 PM : [ 13 6B 7F 6] ST 255
Tue 01/15/2013 08:14:34 PM : [iNST-ACK ] 02 62 00.00.22 CF 12 00 06 LTON-F (00)
Tue 01/15/2013 08:14:34 PM : [ 1D 91 77 1] ST 255
Tue 01/15/2013 08:14:34 PM : [iNST-TX-I1 ] 02 62 00 00 15 CF 14 00
Tue 01/15/2013 08:14:34 PM : [iNST-TX-I1 ] 02 62 00 00 22 CF 14 00
Tue 01/15/2013 08:14:34 PM : [iNST-ACK ] 02 62 00.00.15 CF 14 00 06 LTOFF-F(00)
Tue 01/15/2013 08:14:34 PM : [ 16 95 73 1] ST 0
Tue 01/15/2013 08:14:34 PM : [ 17 CD B6 1] ST 0
Tue 01/15/2013 08:14:34 PM : [ 13 6B 7F 6] ST 0
Tue 01/15/2013 08:14:35 PM : [iNST-ACK ] 02 62 00.00.22 CF 14 00 06 LTOFF-F(00)
Tue 01/15/2013 08:14:35 PM : [ 1D 91 77 1] ST 0
Tue 01/15/2013 08:14:36 PM : [iNST-SRX ] 02 50 1D.77.F9 00.00.09 C7 13 00 LTOFFRR(00)
Tue 01/15/2013 08:14:36 PM : [std-Group ] 1D.77.F9-->Group=9, Max Hops=3, Hops Left=1
Tue 01/15/2013 08:14:36 PM : [ 1D 77 F9 9] DOF 0
Tue 01/15/2013 08:14:36 PM : [ 1D 77 F9 9] ST 0
Tue 01/15/2013 08:14:36 PM : [iNST-SRX ] 02 50 1D.77.F9 19.72.7C 41 13 09 LTOFFRR(09)
Tue 01/15/2013 08:14:36 PM : [std-Cleanup ] 1D.77.F9-->ISY/PLM Group=9, Max Hops=1, Hops Left=0
Tue 01/15/2013 08:14:36 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 08:21:21 PM : [iNST-SRX ] 02 50 1A.2D.B6 19.72.7C 41 11 01 LTONRR (01)
Tue 01/15/2013 08:21:21 PM : [std-Cleanup ] 1A.2D.B6-->ISY/PLM Group=1, Max Hops=1, Hops Left=0
Tue 01/15/2013 08:21:21 PM : [ 1A 2D B6 1] DON 0
Tue 01/15/2013 08:21:21 PM : [ 1A 2D B6 1] ST 255
Tue 01/15/2013 08:21:21 PM : [iNST-SRX ] 02 50 1A.2D.B6 19.72.7C 42 11 01 LTONRR (01)
Tue 01/15/2013 08:21:21 PM : [std-Cleanup ] 1A.2D.B6-->ISY/PLM Group=1, Max Hops=2, Hops Left=0
Tue 01/15/2013 08:21:21 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 08:21:47 PM : [iNST-SRX ] 02 50 19.61.99 00.00.01 C7 11 00 LTONRR (00)
Tue 01/15/2013 08:21:47 PM : [std-Group ] 19.61.99-->Group=1, Max Hops=3, Hops Left=1
Tue 01/15/2013 08:21:47 PM : [ 19 61 99 1] DON 0
Tue 01/15/2013 08:21:48 PM : [iNST-TX-I1 ] 02 62 00 00 2E CF 11 00
Tue 01/15/2013 08:21:48 PM : [ 13 85 42 8] ST 255
Tue 01/15/2013 08:21:48 PM : [iNST-ACK ] 02 62 00.00.2E CF 11 00 06 LTONRR (00)
Tue 01/15/2013 08:21:48 PM : [ 19 61 99 1] ST 255
Tue 01/15/2013 08:21:48 PM : [ 11 E2 73 6] ST 255
Tue 01/15/2013 08:21:48 PM : [ 1B 45 94 1] ST 255
Tue 01/15/2013 08:21:48 PM : [ 11 E2 73 5] ST 255
Tue 01/15/2013 08:21:48 PM : [iNST-SRX ] 02 50 19.61.99 19.72.7C 42 11 01 LTONRR (01)
Tue 01/15/2013 08:21:48 PM : [std-Cleanup ] 19.61.99-->ISY/PLM Group=1, Max Hops=2, Hops Left=0
Tue 01/15/2013 08:21:48 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 08:23:13 PM : [iNST-SRX ] 02 50 1A.2D.B6 00.00.01 C7 13 00 LTOFFRR(00)
Tue 01/15/2013 08:23:13 PM : [std-Group ] 1A.2D.B6-->Group=1, Max Hops=3, Hops Left=1
Tue 01/15/2013 08:23:13 PM : [ 1A 2D B6 1] DOF 0
Tue 01/15/2013 08:23:13 PM : [ 1A 2D B6 1] ST 0
Tue 01/15/2013 08:23:13 PM : [iNST-SRX ] 02 50 1A.2D.B6 19.72.7C 41 13 01 LTOFFRR(01)
Tue 01/15/2013 08:23:13 PM : [std-Cleanup ] 1A.2D.B6-->ISY/PLM Group=1, Max Hops=1, Hops Left=0
Tue 01/15/2013 08:23:13 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 08:23:13 PM : [iNST-TX-I1 ] 02 62 00 00 26 CF 13 00
Tue 01/15/2013 08:23:13 PM : [iNST-ACK ] 02 62 00.00.26 CF 13 00 06 LTOFFRR(00)
Tue 01/15/2013 08:23:14 PM : [iNST-ACK ] 02 62 00.00.26 CF 13 00 06 LTOFFRR(00)
Tue 01/15/2013 08:23:19 PM : [iNST-SRX ] 02 50 1D.91.71 00.00.01 C7 13 00 LTOFFRR(00)
Tue 01/15/2013 08:23:19 PM : [std-Group ] 1D.91.71-->Group=1, Max Hops=3, Hops Left=1
Tue 01/15/2013 08:23:19 PM : [ 1D 91 71 1] DOF 0
Tue 01/15/2013 08:23:19 PM : [ 1D 91 71 1] ST 0
Tue 01/15/2013 08:23:19 PM : [iNST-SRX ] 02 50 1D.91.71 13.00.01 C3 06 00 (00)
Tue 01/15/2013 08:23:19 PM : [std-Group ] 1D.91.71-->13.00.01, Max Hops=3, Hops Left=0
Tue 01/15/2013 08:25:23 PM : [iNST-SRX ] 02 50 1D.77.F9 00.00.09 C7 11 00 LTONRR (00)
Tue 01/15/2013 08:25:23 PM : [std-Group ] 1D.77.F9-->Group=9, Max Hops=3, Hops Left=1
Tue 01/15/2013 08:25:23 PM : [ 1D 77 F9 9] DON 0
Tue 01/15/2013 08:25:23 PM : [iNST-SRX ] 02 50 1D.77.F9 19.72.7C 41 11 09 LTONRR (09)
Tue 01/15/2013 08:25:23 PM : [std-Cleanup ] 1D.77.F9-->ISY/PLM Group=9, Max Hops=1, Hops Left=0
Tue 01/15/2013 08:25:23 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 08:25:24 PM : [iNST-TX-I1 ] 02 62 00 00 49 CF 11 00
Tue 01/15/2013 08:25:24 PM : [iNST-TX-I1 ] 02 62 1D 91 71 0F 11 FF
Tue 01/15/2013 08:25:24 PM : [iNST-ACK ] 02 62 00.00.49 CF 11 00 06 LTONRR (00)
Tue 01/15/2013 08:25:24 PM : [iNST-TX-I1 ] 02 62 00 00 15 CF 12 00
Tue 01/15/2013 08:25:24 PM : [iNST-ACK ] 02 62 1D.91.71 0F 11 FF 06 LTONRR (FF)
Tue 01/15/2013 08:25:25 PM : [iNST-TX-I1 ] 02 62 00 00 22 CF 12 00
Tue 01/15/2013 08:25:25 PM : [ 1D 77 F9 9] ST 255
Tue 01/15/2013 08:25:25 PM : [iNST-ACK ] 02 62 00.00.15 CF 12 00 06 LTON-F (00)
Tue 01/15/2013 08:25:25 PM : [iNST-TX-I1 ] 02 62 00 00 15 CF 14 00
Tue 01/15/2013 08:25:25 PM : [iNST-TX-I1 ] 02 62 00 00 22 CF 14 00
Tue 01/15/2013 08:25:25 PM : [ 16 95 73 1] ST 255
Tue 01/15/2013 08:25:25 PM : [ 17 CD B6 1] ST 255
Tue 01/15/2013 08:25:25 PM : [ 13 6B 7F 6] ST 255
Tue 01/15/2013 08:25:26 PM : [iNST-SRX ] 02 50 1D.91.71 19.72.7C 23 11 FF LTONRR (FF)
Tue 01/15/2013 08:25:26 PM : [std-Direct Ack] 1D.91.71-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Tue 01/15/2013 08:25:26 PM : [ 1D 91 71 1] ST 255
Tue 01/15/2013 08:25:26 PM : [iNST-ACK ] 02 62 00.00.22 CF 14 00 06 LTOFF-F(00)
Tue 01/15/2013 08:25:27 PM : [iNST-SRX ] 02 50 1D.77.F9 00.00.09 C7 13 00 LTOFFRR(00)
Tue 01/15/2013 08:25:27 PM : [std-Group ] 1D.77.F9-->Group=9, Max Hops=3, Hops Left=1
Tue 01/15/2013 08:25:27 PM : [ 1D 77 F9 9] DOF 0
Tue 01/15/2013 08:25:27 PM : [ 1D 77 F9 9] ST 0
Tue 01/15/2013 08:25:28 PM : [iNST-SRX ] 02 50 1D.77.F9 19.72.7C 42 13 09 LTOFFRR(09)
Tue 01/15/2013 08:25:28 PM : [std-Cleanup ] 1D.77.F9-->ISY/PLM Group=9, Max Hops=2, Hops Left=0
Tue 01/15/2013 08:25:28 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 08:28:27 PM : [iNST-SRX ] 02 50 1B.44.EF 00.00.01 C3 11 00 LTONRR (00)
Tue 01/15/2013 08:28:27 PM : [std-Group ] 1B.44.EF-->Group=1, Max Hops=3, Hops Left=0
Tue 01/15/2013 08:28:27 PM : [ 1B 44 EF 1] DON 0
Tue 01/15/2013 08:28:27 PM : [ 13 6B 7F 2] ST 255
Tue 01/15/2013 08:28:27 PM : [iNST-SRX ] 02 50 1B.44.EF 19.72.7C 41 11 01 LTONRR (01)
Tue 01/15/2013 08:28:27 PM : [std-Cleanup ] 1B.44.EF-->ISY/PLM Group=1, Max Hops=1, Hops Left=0
Tue 01/15/2013 08:28:27 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 08:28:27 PM : [ 1B 44 EF 1] ST 255
Tue 01/15/2013 08:38:19 PM : [ Time] 20:38:34 0(0)
Tue 01/15/2013 08:47:50 PM : [iNST-SRX ] 02 50 1B.45.94 00.00.01 C7 11 00 LTONRR (00)
Tue 01/15/2013 08:47:50 PM : [std-Group ] 1B.45.94-->Group=1, Max Hops=3, Hops Left=1
Tue 01/15/2013 08:47:50 PM : [ 1B 45 94 1] DON 0
Tue 01/15/2013 08:47:50 PM : [iNST-SRX ] 02 50 1B.45.94 19.72.7C 41 11 01 LTONRR (01)
Tue 01/15/2013 08:47:50 PM : [std-Cleanup ] 1B.45.94-->ISY/PLM Group=1, Max Hops=1, Hops Left=0
Tue 01/15/2013 08:47:50 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 08:47:50 PM : [iNST-SRX ] 02 50 1B.45.94 19.72.7C 42 11 01 LTONRR (01)
Tue 01/15/2013 08:47:50 PM : [std-Cleanup ] 1B.45.94-->ISY/PLM Group=1, Max Hops=2, Hops Left=0
Tue 01/15/2013 08:47:51 PM : [iNST-SRX ] 02 50 1B.45.94 19.72.7C 47 11 01 LTONRR (01)
Tue 01/15/2013 08:47:51 PM : [std-Cleanup ] 1B.45.94-->ISY/PLM Group=1, Max Hops=3, Hops Left=1
Tue 01/15/2013 08:47:51 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 08:47:59 PM : [iNST-SRX ] 02 50 1B.45.94 00.00.01 C7 13 00 LTOFFRR(00)
Tue 01/15/2013 08:47:59 PM : [std-Group ] 1B.45.94-->Group=1, Max Hops=3, Hops Left=1
Tue 01/15/2013 08:47:59 PM : [ 1B 45 94 1] DOF 0
Tue 01/15/2013 08:47:59 PM : [ 1B 45 94 1] ST 0
Tue 01/15/2013 08:47:59 PM : [iNST-SRX ] 02 50 1B.45.94 19.72.7C 41 13 01 LTOFFRR(01)
Tue 01/15/2013 08:47:59 PM : [std-Cleanup ] 1B.45.94-->ISY/PLM Group=1, Max Hops=1, Hops Left=0
Tue 01/15/2013 08:47:59 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 08:47:59 PM : [iNST-TX-I1 ] 02 62 00 00 2E CF 13 00
Tue 01/15/2013 08:47:59 PM : [ 11 E2 73 5] ST 0
Tue 01/15/2013 08:47:59 PM : [iNST-ACK ] 02 62 00.00.2E CF 13 00 06 LTOFFRR(00)
Tue 01/15/2013 08:48:02 PM : [iNST-SRX ] 02 50 11.E2.73 00.00.06 C7 13 00 LTOFFRR(00)
Tue 01/15/2013 08:48:02 PM : [std-Group ] 11.E2.73-->Group=6, Max Hops=3, Hops Left=1
Tue 01/15/2013 08:48:02 PM : [ 11 E2 73 6] DOF 0
Tue 01/15/2013 08:48:02 PM : [ 13 85 42 8] ST 0
Tue 01/15/2013 08:48:02 PM : [ 11 E2 73 6] ST 0
Tue 01/15/2013 08:48:03 PM : [iNST-SRX ] 02 50 11.E2.73 19.72.7C 41 13 06 LTOFFRR(06)
Tue 01/15/2013 08:48:03 PM : [std-Cleanup ] 11.E2.73-->ISY/PLM Group=6, Max Hops=1, Hops Left=0
Tue 01/15/2013 08:48:03 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 08:48:03 PM : [iNST-SRX ] 02 50 11.E2.73 19.72.7C 47 13 06 LTOFFRR(06)
Tue 01/15/2013 08:48:03 PM : [std-Cleanup ] 11.E2.73-->ISY/PLM Group=6, Max Hops=3, Hops Left=1
Tue 01/15/2013 08:48:03 PM : [iNST-SRX ] 02 50 11.E2.73 19.72.7C 43 13 06 LTOFFRR(06)
Tue 01/15/2013 08:48:03 PM : [std-Cleanup ] 11.E2.73-->ISY/PLM Group=6, Max Hops=3, Hops Left=0
Tue 01/15/2013 08:48:20 PM : [iNST-SRX ] 02 50 19.61.99 00.00.01 C3 13 00 LTOFFRR(00)
Tue 01/15/2013 08:48:20 PM : [std-Group ] 19.61.99-->Group=1, Max Hops=3, Hops Left=0
Tue 01/15/2013 08:48:20 PM : [ 19 61 99 1] DOF 0
Tue 01/15/2013 08:48:21 PM : [iNST-SRX ] 02 50 19.61.99 19.72.7C 46 13 01 LTOFFRR(01)
Tue 01/15/2013 08:48:21 PM : [std-Cleanup ] 19.61.99-->ISY/PLM Group=1, Max Hops=2, Hops Left=1
Tue 01/15/2013 08:48:21 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 08:48:21 PM : [iNST-TX-I1 ] 02 62 00 00 2E CF 13 00
Tue 01/15/2013 08:48:21 PM : [ 19 61 99 1] ST 0
Tue 01/15/2013 08:48:21 PM : [iNST-ACK ] 02 62 00.00.2E CF 13 00 06 LTOFFRR(00)
Tue 01/15/2013 08:58:13 PM : [ Time] 20:58:45 0(0)
Tue 01/15/2013 09:00:27 PM : [ Time] 21:01:00 0(0)
Tue 01/15/2013 09:00:27 PM : [ Time] 21:01:01 0(0)
Tue 01/15/2013 09:00:27 PM : [iNST-TX-I1 ] 02 62 00 00 14 CF 13 00
Tue 01/15/2013 09:00:27 PM : [iNST-ACK ] 02 62 00.00.14 CF 13 00 06 LTOFFRR(00)
Tue 01/15/2013 09:00:27 PM : [ 13 6B 7F 5] ST 0
Tue 01/15/2013 09:00:27 PM : [ 13 72 BD 1] ST 0
Tue 01/15/2013 09:02:35 PM : [iNST-SRX ] 02 50 1D.91.71 00.00.01 C3 13 00 LTOFFRR(00)
Tue 01/15/2013 09:02:35 PM : [std-Group ] 1D.91.71-->Group=1, Max Hops=3, Hops Left=0
Tue 01/15/2013 09:02:35 PM : [ 1D 91 71 1] DOF 0
Tue 01/15/2013 09:02:35 PM : [ 1D 91 71 1] ST 0
Tue 01/15/2013 09:02:35 PM : [iNST-SRX ] 02 50 1D.91.71 13.00.01 C3 06 00 (00)
Tue 01/15/2013 09:02:35 PM : [std-Group ] 1D.91.71-->13.00.01, Max Hops=3, Hops Left=0
Tue 01/15/2013 09:04:12 PM : [iNST-SRX ] 02 50 1D.93.D9 00.00.01 C3 11 00 LTONRR (00)
Tue 01/15/2013 09:04:12 PM : [std-Group ] 1D.93.D9-->Group=1, Max Hops=3, Hops Left=0
Tue 01/15/2013 09:04:12 PM : [ 1D 93 D9 1] DON 0
Tue 01/15/2013 09:04:12 PM : [ 1D 93 D9 1] ST 255
Tue 01/15/2013 09:04:12 PM : [ 11 E2 73 3] ST 255
Tue 01/15/2013 09:04:12 PM : [iNST-SRX ] 02 50 1D.93.D9 11.00.01 C3 06 00 (00)
Tue 01/15/2013 09:04:12 PM : [std-Group ] 1D.93.D9-->11.00.01, Max Hops=3, Hops Left=0
Tue 01/15/2013 09:04:14 PM : [iNST-SRX ] 02 50 1D.94.0F 00.00.01 C7 11 00 LTONRR (00)
Tue 01/15/2013 09:04:14 PM : [std-Group ] 1D.94.0F-->Group=1, Max Hops=3, Hops Left=1
Tue 01/15/2013 09:04:14 PM : [ 1D 94 F 1] DON 0
Tue 01/15/2013 09:04:14 PM : [ 1D 94 F 1] ST 255
Tue 01/15/2013 09:04:14 PM : [ 1B 41 51 1] ST 255
Tue 01/15/2013 09:04:14 PM : [iNST-SRX ] 02 50 1D.94.0F 11.00.01 C3 06 00 (00)
Tue 01/15/2013 09:04:14 PM : [std-Group ] 1D.94.0F-->11.00.01, Max Hops=3, Hops Left=0
Tue 01/15/2013 09:04:21 PM : [iNST-SRX ] 02 50 1D.94.0F 00.00.01 C3 13 00 LTOFFRR(00)
Tue 01/15/2013 09:04:21 PM : [std-Group ] 1D.94.0F-->Group=1, Max Hops=3, Hops Left=0
Tue 01/15/2013 09:04:21 PM : [ 1D 94 F 1] DOF 0
Tue 01/15/2013 09:04:21 PM : [ 1D 94 F 1] ST 0
Tue 01/15/2013 09:04:21 PM : [ 1B 41 51 1] ST 0
Tue 01/15/2013 09:04:21 PM : [iNST-SRX ] 02 50 1D.94.0F 13.00.01 C3 06 00 (00)
Tue 01/15/2013 09:04:21 PM : [std-Group ] 1D.94.0F-->13.00.01, Max Hops=3, Hops Left=0
Tue 01/15/2013 09:04:23 PM : [iNST-SRX ] 02 50 1D.93.D9 00.00.01 C3 13 00 LTOFFRR(00)
Tue 01/15/2013 09:04:23 PM : [std-Group ] 1D.93.D9-->Group=1, Max Hops=3, Hops Left=0
Tue 01/15/2013 09:04:23 PM : [ 1D 93 D9 1] DOF 0
Tue 01/15/2013 09:04:23 PM : [ 1D 93 D9 1] ST 0
Tue 01/15/2013 09:04:23 PM : [ 11 E2 73 3] ST 0
Tue 01/15/2013 09:04:23 PM : [iNST-SRX ] 02 50 1D.93.D9 13.00.01 C3 06 00 (00)
Tue 01/15/2013 09:04:23 PM : [std-Group ] 1D.93.D9-->13.00.01, Max Hops=3, Hops Left=0
Tue 01/15/2013 09:09:48 PM : [iNST-TX-I1 ] 02 62 1D 93 D9 0F 13 00
Tue 01/15/2013 09:09:48 PM : [iNST-ACK ] 02 62 1D.93.D9 0F 13 00 06 LTOFFRR(00)
Tue 01/15/2013 09:09:48 PM : [iNST-SRX ] 02 50 1D.93.D9 19.72.7C 23 13 00 LTOFFRR(00)
Tue 01/15/2013 09:09:48 PM : [std-Direct Ack] 1D.93.D9-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Tue 01/15/2013 09:13:07 PM : [iNST-SRX ] 02 50 1D.94.0F 00.00.01 C7 11 00 LTONRR (00)
Tue 01/15/2013 09:13:07 PM : [std-Group ] 1D.94.0F-->Group=1, Max Hops=3, Hops Left=1
Tue 01/15/2013 09:13:07 PM : [ 1D 94 F 1] DON 0
Tue 01/15/2013 09:13:07 PM : [ 1D 94 F 1] ST 255
Tue 01/15/2013 09:13:07 PM : [ 1B 41 51 1] ST 255
Tue 01/15/2013 09:13:07 PM : [iNST-SRX ] 02 50 1D.94.0F 11.00.01 C7 06 00 (00)
Tue 01/15/2013 09:13:07 PM : [std-Group ] 1D.94.0F-->11.00.01, Max Hops=3, Hops Left=1
Tue 01/15/2013 09:13:14 PM : [iNST-SRX ] 02 50 1D.94.0F 00.00.01 C7 13 00 LTOFFRR(00)
Tue 01/15/2013 09:13:14 PM : [std-Group ] 1D.94.0F-->Group=1, Max Hops=3, Hops Left=1
Tue 01/15/2013 09:13:14 PM : [ 1D 94 F 1] DOF 0
Tue 01/15/2013 09:13:14 PM : [ 1D 94 F 1] ST 0
Tue 01/15/2013 09:13:14 PM : [ 1B 41 51 1] ST 0
Tue 01/15/2013 09:13:14 PM : [iNST-SRX ] 02 50 1D.94.0F 13.00.01 C3 06 00 (00)
Tue 01/15/2013 09:13:14 PM : [std-Group ] 1D.94.0F-->13.00.01, Max Hops=3, Hops Left=0
Tue 01/15/2013 09:23:06 PM : [ Time] 21:23:18 0(0)
Tue 01/15/2013 09:23:10 PM : [iNST-SRX ] 02 50 19.5C.52 00.00.01 C7 11 00 LTONRR (00)
Tue 01/15/2013 09:23:10 PM : [std-Group ] 19.5C.52-->Group=1, Max Hops=3, Hops Left=1
Tue 01/15/2013 09:23:10 PM : [ 19 5C 52 1] DON 0
Tue 01/15/2013 09:23:10 PM : [iNST-SRX ] 02 50 19.5C.52 19.72.7C 42 11 01 LTONRR (01)
Tue 01/15/2013 09:23:10 PM : [std-Cleanup ] 19.5C.52-->ISY/PLM Group=1, Max Hops=2, Hops Left=0
Tue 01/15/2013 09:23:10 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 09:23:11 PM : [iNST-TX-I1 ] 02 62 00 00 10 CF 11 00
Tue 01/15/2013 09:23:11 PM : [ 19 5C 52 1] ST 255
Tue 01/15/2013 09:23:11 PM : [iNST-ACK ] 02 62 00.00.10 CF 11 00 06 LTONRR (00)
Tue 01/15/2013 09:23:11 PM : [ 13 6B 7F 8] ST 255
Tue 01/15/2013 09:23:11 PM : [ 19 A3 F3 1] ST 255
Tue 01/15/2013 09:23:11 PM : [ 13 6B 7F 7] ST 255
Tue 01/15/2013 09:27:02 PM : [iNST-SRX ] 02 50 1A.2C.96 00.00.01 C3 11 00 LTONRR (00)
Tue 01/15/2013 09:27:02 PM : [std-Group ] 1A.2C.96-->Group=1, Max Hops=3, Hops Left=0
Tue 01/15/2013 09:27:02 PM : [ 1A 2C 96 1] DON 0
Tue 01/15/2013 09:27:02 PM : [ 1A 31 D0 1] ST 255
Tue 01/15/2013 09:27:02 PM : [iNST-SRX ] 02 50 1A.2C.96 19.72.7C 41 11 01 LTONRR (01)
Tue 01/15/2013 09:27:02 PM : [std-Cleanup ] 1A.2C.96-->ISY/PLM Group=1, Max Hops=1, Hops Left=0
Tue 01/15/2013 09:27:02 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 09:27:02 PM : [ 1A 2C 96 1] ST 255
Tue 01/15/2013 09:27:02 PM : [ 1A 35 40 1] ST 255
Tue 01/15/2013 09:27:03 PM : [iNST-SRX ] 02 50 1A.2C.96 19.72.7C 4B 11 01 LTONRR (01)
Tue 01/15/2013 09:27:03 PM : [std-Cleanup ] 1A.2C.96-->ISY/PLM Group=1, Max Hops=3, Hops Left=2
Tue 01/15/2013 09:27:03 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 09:30:02 PM : [iNST-SRX ] 02 50 1D.77.F9 00.00.09 C7 11 00 LTONRR (00)
Tue 01/15/2013 09:30:02 PM : [std-Group ] 1D.77.F9-->Group=9, Max Hops=3, Hops Left=1
Tue 01/15/2013 09:30:02 PM : [ 1D 77 F9 9] DON 0
Tue 01/15/2013 09:30:02 PM : [iNST-SRX ] 02 50 1D.77.F9 19.72.7C 41 11 09 LTONRR (09)
Tue 01/15/2013 09:30:02 PM : [std-Cleanup ] 1D.77.F9-->ISY/PLM Group=9, Max Hops=1, Hops Left=0
Tue 01/15/2013 09:30:02 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 09:30:02 PM : [iNST-TX-I1 ] 02 62 00 00 49 CF 11 00
Tue 01/15/2013 09:30:02 PM : [iNST-ACK ] 02 62 00.00.49 CF 11 00 06 LTONRR (00)
Tue 01/15/2013 09:30:03 PM : [iNST-TX-I1 ] 02 62 1D 91 71 0F 11 FF
Tue 01/15/2013 09:30:03 PM : [iNST-TX-I1 ] 02 62 00 00 15 CF 12 00
Tue 01/15/2013 09:30:03 PM : [iNST-ACK ] 02 62 1D.91.71 0F 11 FF 06 LTONRR (FF)
Tue 01/15/2013 09:30:03 PM : [iNST-TX-I1 ] 02 62 00 00 22 CF 12 00
Tue 01/15/2013 09:30:03 PM : [ 1D 77 F9 9] ST 255
Tue 01/15/2013 09:30:03 PM : [iNST-ACK ] 02 62 00.00.15 CF 12 00 06 LTON-F (00)
Tue 01/15/2013 09:30:04 PM : [iNST-SRX ] 02 50 1D.91.71 19.72.7C 23 11 FF LTONRR (FF)
Tue 01/15/2013 09:30:04 PM : [std-Direct Ack] 1D.91.71-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Tue 01/15/2013 09:30:04 PM : [iNST-ACK ] 02 62 00.00.22 CF 12 00 06 LTON-F (00)
Tue 01/15/2013 09:30:04 PM : [iNST-TX-I1 ] 02 62 00 00 15 CF 14 00
Tue 01/15/2013 09:30:04 PM : [iNST-TX-I1 ] 02 62 00 00 22 CF 14 00
Tue 01/15/2013 09:30:04 PM : [iNST-ACK ] 02 62 00.00.15 CF 14 00 06 LTOFF-F(00)
Tue 01/15/2013 09:30:04 PM : [ 1D 91 71 1] ST 255
Tue 01/15/2013 09:30:04 PM : [ 1D 91 77 1] ST 255
Tue 01/15/2013 09:30:04 PM : [ 16 95 73 1] ST 0
Tue 01/15/2013 09:30:04 PM : [ 17 CD B6 1] ST 0
Tue 01/15/2013 09:30:04 PM : [ 13 6B 7F 6] ST 0
Tue 01/15/2013 09:30:05 PM : [iNST-ACK ] 02 62 00.00.22 CF 14 00 06 LTOFF-F(00)
Tue 01/15/2013 09:30:05 PM : [ 1D 91 77 1] ST 0
Tue 01/15/2013 09:30:06 PM : [iNST-SRX ] 02 50 1D.77.F9 00.00.09 C7 13 00 LTOFFRR(00)
Tue 01/15/2013 09:30:06 PM : [std-Group ] 1D.77.F9-->Group=9, Max Hops=3, Hops Left=1
Tue 01/15/2013 09:30:06 PM : [ 1D 77 F9 9] DOF 0
Tue 01/15/2013 09:30:06 PM : [ 1D 77 F9 9] ST 0
Tue 01/15/2013 09:30:06 PM : [iNST-SRX ] 02 50 1D.77.F9 19.72.7C 41 13 09 LTOFFRR(09)
Tue 01/15/2013 09:30:06 PM : [std-Cleanup ] 1D.77.F9-->ISY/PLM Group=9, Max Hops=1, Hops Left=0
Tue 01/15/2013 09:30:06 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 09:30:07 PM : [iNST-SRX ] 02 50 1C.FE.D9 00.00.01 C3 13 00 LTOFFRR(00)
Tue 01/15/2013 09:30:07 PM : [std-Group ] 1C.FE.D9-->Group=1, Max Hops=3, Hops Left=0
Tue 01/15/2013 09:30:07 PM : [ 1C FE D9 1] DOF 0
Tue 01/15/2013 09:30:07 PM : [ 1C FE D9 1] ST 0
Tue 01/15/2013 09:30:07 PM : [iNST-SRX ] 02 50 1C.FE.D9 13.00.01 C3 06 00 (00)
Tue 01/15/2013 09:30:07 PM : [std-Group ] 1C.FE.D9-->13.00.01, Max Hops=3, Hops Left=0
Tue 01/15/2013 09:30:07 PM : [iNST-SRX ] 02 50 1C.FE.D9 00.00.01 C3 11 00 LTONRR (00)
Tue 01/15/2013 09:30:07 PM : [ 1C FE D9 1] DON 0
Tue 01/15/2013 09:30:07 PM : [iNST-SRX ] 02 50 1C.FE.D9 11.00.01 C3 06 00 (00)
Tue 01/15/2013 09:30:07 PM : [std-Group ] 1C.FE.D9-->11.00.01, Max Hops=3, Hops Left=0
Tue 01/15/2013 09:30:08 PM : [iNST-SRX ] 02 50 1C.FE.D9 00.00.01 C3 13 00 LTOFFRR(00)
Tue 01/15/2013 09:30:08 PM : [std-Group ] 1C.FE.D9-->Group=1, Max Hops=3, Hops Left=0
Tue 01/15/2013 09:30:08 PM : [iNST-TX-I1 ] 02 62 00 00 49 CF 11 00
Tue 01/15/2013 09:30:08 PM : [iNST-TX-I1 ] 02 62 00 00 48 CF 12 00
Tue 01/15/2013 09:30:08 PM : [iNST-ACK ] 02 62 00.00.49 CF 11 00 06 LTONRR (00)
Tue 01/15/2013 09:30:09 PM : [iNST-TX-I1 ] 02 62 00 00 3B CF 14 00
Tue 01/15/2013 09:30:09 PM : [iNST-TX-I1 ] 02 62 00 00 3B CF 12 00
Tue 01/15/2013 09:30:09 PM : [ 1C FE D9 1] ST 255
Tue 01/15/2013 09:30:09 PM : [iNST-ACK ] 02 62 00.00.48 CF 12 00 06 LTON-F (00)
Tue 01/15/2013 09:30:09 PM : [ 1C FE D9 1] DOF 0
Tue 01/15/2013 09:30:09 PM : [ 1C FE D9 1] ST 0
Tue 01/15/2013 09:30:09 PM : [iNST-ACK ] 02 62 00.00.3B CF 14 00 06 LTOFF-F(00)
Tue 01/15/2013 09:30:09 PM : [ 1A 31 C2 1] ST 0
Tue 01/15/2013 09:30:10 PM : [iNST-ACK ] 02 62 00.00.3B CF 12 00 06 LTON-F (00)
Tue 01/15/2013 09:30:10 PM : [iNST-TX-I1 ] 02 62 00 00 3B CF 14 00
Tue 01/15/2013 09:30:10 PM : [ 13 6D FE 1] ST 0
Tue 01/15/2013 09:30:10 PM : [iNST-ACK ] 02 62 00.00.3B CF 14 00 06 LTOFF-F(00)
Tue 01/15/2013 09:30:12 PM : [iNST-TX-I1 ] 02 62 00 00 3B CF 12 00
Tue 01/15/2013 09:30:12 PM : [ 13 6B 7F 1] ST 255
Tue 01/15/2013 09:30:12 PM : [iNST-ACK ] 02 62 00.00.3B CF 12 00 06 LTON-F (00)
Tue 01/15/2013 09:30:12 PM : [ 16 95 73 1] ST 255
Tue 01/15/2013 09:30:12 PM : [ 17 CD B6 1] ST 255
Tue 01/15/2013 09:30:12 PM : [ 1A 31 C2 1] ST 255
Tue 01/15/2013 09:30:12 PM : [ 1D 91 77 1] ST 255
Tue 01/15/2013 09:30:12 PM : [ 1A 2D B6 1] ST 255
Tue 01/15/2013 09:30:12 PM : [ 13 6D FE 1] ST 255
Tue 01/15/2013 09:30:12 PM : [ 13 6D 5F 1] ST 255
Tue 01/15/2013 09:30:12 PM : [ 13 6B 7F 6] ST 255
Tue 01/15/2013 09:30:12 PM : [ 13 6B 7F 1] ST 0
Tue 01/15/2013 09:30:12 PM : [ 16 95 73 1] ST 0
Tue 01/15/2013 09:30:12 PM : [ 17 CD B6 1] ST 0
Tue 01/15/2013 09:30:12 PM : [ 1A 31 C2 1] ST 0
Tue 01/15/2013 09:30:12 PM : [ 1D 91 77 1] ST 0
Tue 01/15/2013 09:30:12 PM : [ 1A 2D B6 1] ST 0
Tue 01/15/2013 09:30:12 PM : [iNST-TX-I1 ] 02 62 00 00 26 CF 13 00
Tue 01/15/2013 09:30:12 PM : [ 13 6D FE 1] ST 0
Tue 01/15/2013 09:30:12 PM : [iNST-ACK ] 02 62 00.00.26 CF 13 00 06 LTOFFRR(00)
Tue 01/15/2013 09:30:12 PM : [ 13 6D 5F 1] ST 0
Tue 01/15/2013 09:30:12 PM : [ 13 6B 7F 6] ST 0
Tue 01/15/2013 09:30:13 PM : [iNST-TX-I1 ] 02 62 00 00 3B CF 14 00
Tue 01/15/2013 09:30:13 PM : [iNST-TX-I1 ] 02 62 00 00 15 CF 12 00
Tue 01/15/2013 09:30:13 PM : [iNST-TX-I1 ] 02 62 00 00 22 CF 12 00
Tue 01/15/2013 09:30:13 PM : [iNST-ACK ] 02 62 00.00.3B CF 14 00 06 LTOFF-F(00)
Tue 01/15/2013 09:30:13 PM : [ 13 6D FE 1] ST 255
Tue 01/15/2013 09:30:13 PM : [ 13 6D 5F 1] ST 255
Tue 01/15/2013 09:30:13 PM : [ 13 6B 7F 6] ST 255
Tue 01/15/2013 09:30:13 PM : [ 1A 2D B6 1] ST 0
Tue 01/15/2013 09:30:13 PM : [iNST-ACK ] 02 62 00.00.15 CF 12 00 06 LTON-F (00)
Tue 01/15/2013 09:30:14 PM : [iNST-TX-I1 ] 02 62 00 00 26 CF 13 00
Tue 01/15/2013 09:30:14 PM : [iNST-ACK ] 02 62 00.00.22 CF 12 00 06 LTON-F (00)
Tue 01/15/2013 09:30:14 PM : [ 13 6B 7F 1] ST 0
Tue 01/15/2013 09:30:14 PM : [ 16 95 73 1] ST 0
Tue 01/15/2013 09:30:14 PM : [ 17 CD B6 1] ST 0
Tue 01/15/2013 09:30:14 PM : [ 1A 31 C2 1] ST 0
Tue 01/15/2013 09:30:14 PM : [ 1D 91 77 1] ST 0
Tue 01/15/2013 09:30:14 PM : [ 13 6D FE 1] ST 0
Tue 01/15/2013 09:30:14 PM : [ 13 6D 5F 1] ST 0
Tue 01/15/2013 09:30:14 PM : [ 13 6B 7F 6] ST 0
Tue 01/15/2013 09:30:14 PM : [ 16 95 73 1] ST 255
Tue 01/15/2013 09:30:14 PM : [ 17 CD B6 1] ST 255
Tue 01/15/2013 09:30:14 PM : [ 13 6B 7F 6] ST 255
Tue 01/15/2013 09:30:14 PM : [ 1D 91 77 1] ST 255
Tue 01/15/2013 09:30:14 PM : [iNST-ACK ] 02 62 00.00.26 CF 13 00 06 LTOFFRR(00)
Tue 01/15/2013 09:30:15 PM : [iNST-ACK ] 02 62 00.00.26 CF 13 00 06 LTOFFRR(00)
Tue 01/15/2013 09:34:14 PM : [iNST-SRX ] 02 50 1B.45.94 00.00.01 C7 11 00 LTONRR (00)
Tue 01/15/2013 09:34:14 PM : [std-Group ] 1B.45.94-->Group=1, Max Hops=3, Hops Left=1
Tue 01/15/2013 09:34:14 PM : [iNST-SRX ] 02 50 1B.45.94 19.72.7C 41 11 01 LTONRR (01)
Tue 01/15/2013 09:34:14 PM : [std-Cleanup ] 1B.45.94-->ISY/PLM Group=1, Max Hops=1, Hops Left=0
Tue 01/15/2013 09:34:14 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 09:34:14 PM : [ 1B 45 94 1] DON 0
Tue 01/15/2013 09:34:14 PM : [ 1B 45 94 1] ST 255
Tue 01/15/2013 09:34:14 PM : [ 11 E2 73 5] ST 255
Tue 01/15/2013 09:34:29 PM : [iNST-SRX ] 02 50 1D.77.F9 00.00.09 C7 11 00 LTONRR (00)
Tue 01/15/2013 09:34:29 PM : [std-Group ] 1D.77.F9-->Group=9, Max Hops=3, Hops Left=1
Tue 01/15/2013 09:34:29 PM : [ 1D 77 F9 9] DON 0
Tue 01/15/2013 09:34:29 PM : [iNST-SRX ] 02 50 1D.77.F9 19.72.7C 41 11 09 LTONRR (09)
Tue 01/15/2013 09:34:29 PM : [std-Cleanup ] 1D.77.F9-->ISY/PLM Group=9, Max Hops=1, Hops Left=0
Tue 01/15/2013 09:34:29 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 09:34:30 PM : [iNST-TX-I1 ] 02 62 00 00 49 CF 11 00
Tue 01/15/2013 09:34:30 PM : [iNST-TX-I1 ] 02 62 1D 91 71 0F 11 FF
Tue 01/15/2013 09:34:30 PM : [iNST-ACK ] 02 62 00.00.49 CF 11 00 06 LTONRR (00)
Tue 01/15/2013 09:34:30 PM : [iNST-TX-I1 ] 02 62 00 00 15 CF 12 00
Tue 01/15/2013 09:34:30 PM : [iNST-TX-I1 ] 02 62 00 00 22 CF 12 00
Tue 01/15/2013 09:34:30 PM : [ 1D 77 F9 9] ST 255
Tue 01/15/2013 09:34:30 PM : [iNST-ACK ] 02 62 1D.91.71 0F 11 FF 06 LTONRR (FF)
Tue 01/15/2013 09:34:31 PM : [iNST-SRX ] 02 50 1D.91.71 19.72.7C 27 11 FF LTONRR (FF)
Tue 01/15/2013 09:34:31 PM : [std-Direct Ack] 1D.91.71-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Tue 01/15/2013 09:34:31 PM : [iNST-ACK ] 02 62 00.00.15 CF 12 00 06 LTON-F (00)
Tue 01/15/2013 09:34:31 PM : [iNST-TX-I1 ] 02 62 00 00 15 CF 14 00
Tue 01/15/2013 09:34:31 PM : [iNST-TX-I1 ] 02 62 00 00 22 CF 14 00
Tue 01/15/2013 09:34:31 PM : [iNST-ACK ] 02 62 00.00.22 CF 12 00 06 LTON-F (00)
Tue 01/15/2013 09:34:32 PM : [iNST-ACK ] 02 62 00.00.15 CF 14 00 06 LTOFF-F(00)
Tue 01/15/2013 09:34:32 PM : [ 16 95 73 1] ST 0
Tue 01/15/2013 09:34:32 PM : [ 17 CD B6 1] ST 0
Tue 01/15/2013 09:34:32 PM : [ 13 6B 7F 6] ST 0
Tue 01/15/2013 09:34:32 PM : [iNST-ACK ] 02 62 00.00.22 CF 14 00 06 LTOFF-F(00)
Tue 01/15/2013 09:34:32 PM : [ 1D 91 77 1] ST 0
Tue 01/15/2013 09:34:34 PM : [iNST-SRX ] 02 50 1D.77.F9 00.00.09 C7 13 00 LTOFFRR(00)
Tue 01/15/2013 09:34:34 PM : [std-Group ] 1D.77.F9-->Group=9, Max Hops=3, Hops Left=1
Tue 01/15/2013 09:34:34 PM : [ 1D 77 F9 9] DOF 0
Tue 01/15/2013 09:34:34 PM : [ 1D 77 F9 9] ST 0
Tue 01/15/2013 09:34:34 PM : [iNST-SRX ] 02 50 1D.77.F9 19.72.7C 41 13 09 LTOFFRR(09)
Tue 01/15/2013 09:34:34 PM : [std-Cleanup ] 1D.77.F9-->ISY/PLM Group=9, Max Hops=1, Hops Left=0
Tue 01/15/2013 09:34:34 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 09:36:27 PM : [iNST-SRX ] 02 50 1D.93.D9 11.00.01 C3 06 00 (00)
Tue 01/15/2013 09:36:27 PM : [std-Group ] 1D.93.D9-->11.00.01, Max Hops=3, Hops Left=0
Tue 01/15/2013 09:36:39 PM : [iNST-SRX ] 02 50 1B.45.94 00.00.01 C7 13 00 LTOFFRR(00)
Tue 01/15/2013 09:36:39 PM : [std-Group ] 1B.45.94-->Group=1, Max Hops=3, Hops Left=1
Tue 01/15/2013 09:36:39 PM : [ 1B 45 94 1] DOF 0
Tue 01/15/2013 09:36:39 PM : [ 1B 45 94 1] ST 0
Tue 01/15/2013 09:36:39 PM : [iNST-SRX ] 02 50 1B.45.94 19.72.7C 41 13 01 LTOFFRR(01)
Tue 01/15/2013 09:36:39 PM : [std-Cleanup ] 1B.45.94-->ISY/PLM Group=1, Max Hops=1, Hops Left=0
Tue 01/15/2013 09:36:39 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 09:36:40 PM : [iNST-TX-I1 ] 02 62 00 00 2E CF 13 00
Tue 01/15/2013 09:36:40 PM : [ 11 E2 73 5] ST 0
Tue 01/15/2013 09:36:40 PM : [iNST-ACK ] 02 62 00.00.2E CF 13 00 06 LTOFFRR(00)
Tue 01/15/2013 09:36:48 PM : [iNST-SRX ] 02 50 1D.93.D9 00.00.01 C3 13 00 LTOFFRR(00)
Tue 01/15/2013 09:36:48 PM : [std-Group ] 1D.93.D9-->Group=1, Max Hops=3, Hops Left=0
Tue 01/15/2013 09:36:48 PM : [ 1D 93 D9 1] DOF 0
Tue 01/15/2013 09:36:48 PM : [iNST-SRX ] 02 50 1D.93.D9 13.00.01 C7 06 00 (00)
Tue 01/15/2013 09:36:48 PM : [std-Group ] 1D.93.D9-->13.00.01, Max Hops=3, Hops Left=1
Tue 01/15/2013 09:36:49 PM : [iNST-TX-I1 ] 02 62 00 00 13 CF 13 00
Tue 01/15/2013 09:36:49 PM : [iNST-ACK ] 02 62 00.00.13 CF 13 00 06 LTOFFRR(00)
Tue 01/15/2013 09:37:58 PM : [iNST-SRX ] 02 50 13.6B.7F 00.00.07 C3 13 00 LTOFFRR(00)
Tue 01/15/2013 09:37:58 PM : [std-Group ] 13.6B.7F-->Group=7, Max Hops=3, Hops Left=0
Tue 01/15/2013 09:37:58 PM : [ 13 6B 7F 7] DOF 0
Tue 01/15/2013 09:37:58 PM : [ 19 A3 F3 1] ST 0
Tue 01/15/2013 09:37:58 PM : [iNST-SRX ] 02 50 13.6B.7F 19.72.7C 41 13 07 LTOFFRR(07)
Tue 01/15/2013 09:37:58 PM : [std-Cleanup ] 13.6B.7F-->ISY/PLM Group=7, Max Hops=1, Hops Left=0
Tue 01/15/2013 09:37:58 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 09:37:59 PM : [iNST-TX-I1 ] 02 62 00 00 10 CF 13 00
Tue 01/15/2013 09:37:59 PM : [ 13 6B 7F 7] ST 0
Tue 01/15/2013 09:37:59 PM : [iNST-ACK ] 02 62 00.00.10 CF 13 00 06 LTOFFRR(00)
Tue 01/15/2013 09:38:00 PM : [iNST-SRX ] 02 50 13.6B.7F 00.00.08 C3 13 00 LTOFFRR(00)
Tue 01/15/2013 09:38:00 PM : [std-Group ] 13.6B.7F-->Group=8, Max Hops=3, Hops Left=0
Tue 01/15/2013 09:38:00 PM : [ 13 6B 7F 8] DOF 0
Tue 01/15/2013 09:38:00 PM : [ 13 6B 7F 8] ST 0
Tue 01/15/2013 09:38:01 PM : [iNST-SRX ] 02 50 13.6B.7F 19.72.7C 42 13 08 LTOFFRR(08)
Tue 01/15/2013 09:38:01 PM : [std-Cleanup ] 13.6B.7F-->ISY/PLM Group=8, Max Hops=2, Hops Left=0
Tue 01/15/2013 09:38:01 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 09:38:19 PM : [iNST-SRX ] 02 50 19.5C.52 00.00.01 C7 13 00 LTOFFRR(00)
Tue 01/15/2013 09:38:19 PM : [std-Group ] 19.5C.52-->Group=1, Max Hops=3, Hops Left=1
Tue 01/15/2013 09:38:19 PM : [ 19 5C 52 1] DOF 0
Tue 01/15/2013 09:38:19 PM : [iNST-SRX ] 02 50 19.5C.52 19.72.7C 41 13 01 LTOFFRR(01)
Tue 01/15/2013 09:38:19 PM : [std-Cleanup ] 19.5C.52-->ISY/PLM Group=1, Max Hops=1, Hops Left=0
Tue 01/15/2013 09:38:19 PM : [iNST-DUP ] Previous message ignored.
Tue 01/15/2013 09:38:19 PM : [iNST-SRX ] 02 50 19.5C.52 19.72.7C 46 13 01 LTOFFRR(01)
Tue 01/15/2013 09:38:19 PM : [std-Cleanup ] 19.5C.52-->ISY/PLM Group=1, Max Hops=2, Hops Left=1
Tue 01/15/2013 09:38:19 PM : [iNST-SRX ] 02 50 19.5C.52 19.72.7C 47 13 01 LTOFFRR(01)
Tue 01/15/2013 09:38:19 PM : [std-Cleanup ] 19.5C.52-->ISY/PLM Group=1, Max Hops=3, Hops Left=1
Tue 01/15/2013 09:38:20 PM : [iNST-TX-I1 ] 02 62 00 00 10 CF 13 00
Tue 01/15/2013 09:38:20 PM : [ 19 5C 52 1] ST 0
Tue 01/15/2013 09:38:20 PM : [iNST-ACK ] 02 62 00.00.10 CF 13 00 06 LTOFFRR(00)
Tue 01/15/2013 09:43:22 PM : [iNST-SRX ] 02 50 1D.93.2C 00.00.01 CB 11 00 LTONRR (00)
Tue 01/15/2013 09:43:22 PM : [std-Group ] 1D.93.2C-->Group=1, Max Hops=3, Hops Left=2
Tue 01/15/2013 09:43:22 PM : [ 1D 93 2C 1] DON 0
Tue 01/15/2013 09:43:22 PM : [ 1D 93 2C 1] ST 255
Tue 01/15/2013 09:43:22 PM : [iNST-SRX ] 02 50 1D.93.2C 11.00.01 CB 06 00 (00)
Tue 01/15/2013 09:43:22 PM : [std-Group ] 1D.93.2C-->11.00.01, Max Hops=3, Hops Left=2
Tue 01/15/2013 09:43:45 PM : [21 D9 E2 ] Added to list of devices to link to ISY
Tue 01/15/2013 09:43:45 PM : [iNST-TX-I1 ] 02 62 21 D9 E2 0F 0D 00
Tue 01/15/2013 09:43:45 PM : [iNST-ACK ] 02 62 21.D9.E2 0F 0D 00 06 (00)
Tue 01/15/2013 09:43:54 PM : [iNST-TX-I1 ] 02 62 21 D9 E2 0F 0D 00
Tue 01/15/2013 09:43:54 PM : [iNST-ACK ] 02 62 21.D9.E2 0F 0D 00 06 (00)
Tue 01/15/2013 09:44:02 PM : [iNST-TX-I1 ] 02 62 21 D9 E2 0F 0D 00
Tue 01/15/2013 09:44:02 PM : [iNST-ACK ] 02 62 21.D9.E2 0F 0D 00 06 (00)
Tue 01/15/2013 09:44:06 PM : [21 D9 E2 0 ] Failed to add device
There is a Clear button on the Event Viewer. It should be used to clear out old entries when starting a new trace.
The trace entries at 09:43:45 which I think reflect the attempt to add with the Motion Sensor when at the PLM location show no device response at all. This can happen if the device times out of linking mode before the device add was attempted.
Suggest trying once more. Click Clear on the Event Viewer to clear old trace entries. Place the Motion Sensor near the PLM and put into linking mode. The motion sensor will remain in linking mode for approx 4 minutes before timing out. The device add has to be initiated before the 4 minute timeout.
I linked up one of these same motion sensors yesterday with the new part numbers on them. No problem.
One would think with the sensor sitting right next to the PLM, that you would not be seeing 1 hop left and 0 hope left.
The trace entries with Hops Left=0 were the old trace entries from when the motion sensor was positioned near an Access Point on the opposite 120v leg (phase). The trace entries at the very end of the last post, which I think reflect the attempt at the PLM location, got no response at all which makes me think the motion sensor timed out of linking mode before the device add was attempted.
Here is new trace log from this morning. Set up "new insteon device", placed new motion in linking mode and set 4 inches below PLM, less than 30 seconds later started process, while process was running, went back to PLM to make sure motion was still "flashing". Here is new log.
Wed 01/16/2013 08:06:35 AM : [21 D9 E2 ] Added to list of devices to link to ISY
Wed 01/16/2013 08:06:35 AM : [iNST-TX-I1 ] 02 62 21 D9 E2 0F 0D 00
Wed 01/16/2013 08:06:35 AM : [iNST-ACK ] 02 62 21.D9.E2 0F 0D 00 06 (00)
Wed 01/16/2013 08:06:44 AM : [iNST-TX-I1 ] 02 62 21 D9 E2 0F 0D 00
Wed 01/16/2013 08:06:44 AM : [iNST-ACK ] 02 62 21.D9.E2 0F 0D 00 06 (00)
Wed 01/16/2013 08:06:53 AM : [iNST-TX-I1 ] 02 62 21 D9 E2 0F 0D 00
Wed 01/16/2013 08:06:53 AM : [iNST-ACK ] 02 62 21.D9.E2 0F 0D 00 06 (00)
Wed 01/16/2013 08:06:57 AM : [21 D9 E2 0 ] Failed to add device
Wed 01/16/2013 08:09:41 AM : [ Time] 08:09:51 1(0)
This is a 2413 Dual Band PLM?
Sorry, I think my suggestion about being positioned close to the PLM was unclear. Set the Motion Sensor 6' from PLM within line of site. Not sure how well the RF will work when sitting inches apart. The trace shows no response from the motion sensor. This is actually worse than when using an Access Point. Makes me wonder if the PLM is Dual Band.
Documentation on PLM indicates Model 2413S serial interface dual band. I placed the motion 6' to the right of the PLM with direct line of sight (could not place directly in front of PLM as it is located in a media closet). From what I could tell on the new trace log, it looked exactly as the previous one I posted.
Without any tools from SmartLabs to diagnosis RF specifically the things to do next are somewhat limited. I would try another RF device such as another motion sensor, triggerlinc, remotelinc2 to see of the issue is isolated to this specific motion sensor or all RF devices.
It appears the RF aspects of the PLM are not working. Could try power cycling the PLM. Could try a factory reset of the motion sensor. At this point it is just trying things until a pattern develops across multiple devices.
The last trace shows the motion sensor did not respond to any of the command requests. I guess the motion sensor could be moved back to an access point location to see if any communication is still possible with the motion sensor. The event trace will show inbound Insteon messages which start with 02 5x when the RF aspect of the Insteon Mesh Network is working. Applications such as the ISY have no control over the RF aspects of Insteon. It is suppose to work as soon as the devices are plugged in.
I was finally able to link the motion literally holding it 1 inch away from another access point (I have 4 access points). This is what ISY is showing:
motion-sensor
motion-dusk.dawn
motion-low bat
I was able to add the motion to a scene, again, holding the motion at the access point while it wrote the updates to device. I then moved the motion to the living room and it had absolutely no problems turning the lights on/off in the scene
I have one remotelinc2 installed on a wall in a closet. I had to install an access point at the closest outlet in that room in order for it to work. I had 3 old remotelincs that I removed from my system, as although, they worked fine turning stuff on and off, if I had to make a change to them, in order for them to receive "updates to device", I had to take them all and place them right at an access point and hold my breath that they would update, sometimes taking 4-5 times trying. Instead I just integrated the ISY IR with my Harmony Remote.
Not sure how to "power cycle" the PLM (just unplug?), as I will do that next, but I honestly don't think the "dual band" part of the PLM ever worked properly.
It does sound like there is an RF problem. Something in the 900 MHz band could be interfering. Anything that operates wirelessly. Speakers, baby monitor, some appliances like a washer/dryer have a remote device that signals when cycles complete. Not sure if the RF part of the PLM itself is working or there is some interference from the other electronics that are found in a media closet.
Power cycle the PLM is simply unplugging for 30 seconds or so to give the power supply a chance to drain off before plugging it back in.
Are there any "wired" insteon motions available? The PLM was located in another location when I had the remotelinc problems, but I do have several cordless phones that are probably 900mhz.
Would a signalinc help at all?
Thanks for all your assistance.
No wired Insteon motion sensors that are functional equivalents to the 2420M. There are outdoor Insteon floods that use a 120v powered motion head. It does seem like there is another 915 MHz source when the motion sensor will add when a few inches from an AP but not a few feet.
Why is it after the device is finally linked, that it works fine as far as sending the sensor signals, as they are being recorded in the ISY flawlessly, turning lights on/off, etc? It is just the linking and device updating that there is the problems with communication? Would a signalinc help at all with the interference?
I don't have a good answer why some command sequences physically work and some do not. The initial trace of the motion sensor add when near an Access Point has some commands getting responses but those responses are at the very outer edge of working. Other commands got no response. One logical difference is a device add requires a whole series of commands to work. If there is an error that a retry does not resolve the add has to terminate. Can't add a device when only some of the information is known or only some of the setup information completed.
A Motion On or Motion Off message is an Insteon Group protocol sequence which can have multiple messages all with the same intent. Notify the PLM that motion has been sensed. If the first message fails to arrive it is followed by up to three additional attempts with a different message type, all indicating motion On or Off. The messages associated with device add and configuration do not have the redundancy of a Group Protocol sequence.
The assumption is an Insteon Mesh Network will be working reliably with only sporadic interference which is compensated for by the redundancy of the Group Protocol for device control. The RF aspects are marginal right from the beginning so the device add and configuration has much less chance of being successful.
The wired SignaLinc coupler is passive. It will not be affected by RF interference. It does not have an active repeater so the message on the opposite 120v leg will likely start off at a lower signal level. I don’t believe it can hurt to have one. I prefer Access Points as they repeat the signal on the opposite 120v leg at a full signal level.
So, if the signalinc is not affected by RF interference, which I obviously have, then would adding one to my environment be able to "ease some of my pain" when initially "linking" up new RF devices to the ISY? (Sorry for asking so many questions.)
