Programming 3-way and 4-way switches into ISY
Hello,
I have one set of 4-way switches (3 switches) and one set of 3-way switches (2 switches). They are all Dual-band Switchlincs. I am a bit confused on how to add them to the ISY. Do I add all three (or two) switches or do I only add one?
On the 4-way and 3-way, I "grouped" them together so when I turn the switch on the top of the stairs shows the same "status" as the switch at the bottom. What I am confused about is adding them to the ISY. Do I add all 3 and 2 switches to the ISY or only one in the group?
One of the guiding general-purpose principles involving ISY is that you should use the ISY to manage your "scenes". If you have linked these switches prior to adding them to the ISY, I suggest factory resetting them. While it is not absolutely necessary to reset them, I believe this to be good practice in all cases. Best to start with a known clean device.
Once factory reset, add ALL individual devices to the ISY. Once added, create two scenes, calling it whatever you want, representing the four-way and three-way circuit. Add the three devices to the four-way scene, defining each as a "controller". Add two devices to the three-way scene, defining each as a controller. At this point everything should be working great!
Sorry for the delay in reply. I have been out of town...
Anyways, this worked great! The reason I programmed them into groups right from the keypads themselves is because that is what the directions that came with them said to do... I forgot the part where I have an ISY to do it all for me.
Thanks so much!
Yes, it is not always obvious that the introduction of the ISY renders a good part of the instructions obsolete. Once you figure that out, things are mucheasier.
Don't forget to check out the universal devices wiki. There is also an ISY user manual.
