Kpl button only needs to go to 70%
I have a kpl button controlling a lamp which I only want to go on at 70%
I have the kpl button as a controller in a scene and the lamp module as responder
I've set the lamp module at 70% but the kpl button can only be set on
The result is that when I press the button the lamp goes on at 100% instead of the desired 70%
Any suggestions?
Highlight the KPL in the scene. (Point to and highlight the red line that lists the KPL in the scene.)
Then adjust the lamp module's on level and/or ramp speed by using the sliders.
(It can be different from what the scene itself shows - so you have probably set the lamp's on level when the scene name was highlighted. You have to highlight the KPL controller IN the scene, then set the lamp's on level.)
By the way, the KPL button that can only be set to on/100% is the button light itself. That's why it's either on or off. Nothing to do with the lamp or how that KPL button controls the lamp.
