[PROGRAMMING] Always On From - To
Hi,
I am trying to program so that the light is always ON From - To time. So if someones turns off, it would turn back ON automatically. I was able to accomplish this with two programs but is it possible to do this in one program?
Hi dpark-
Try this:
    From 6:00 pm
    To 8:00 pm
 And
     Status MyLight is not On
  Set MyLight On
Edit as necessary. The reason for "is not On" is just in case this is a dimmer. Anything less than full on will make this program set the light full on. If this is a relay type switch, you could say "is Off" instead.
-Xathros
Yes, that is basically what I did but I would also like to turn the light off automatically after 8:00pm.
If I add Else statement there to turn the light off, it just loops - on and off when I hit off switch. :)
So I created another program for "off hours" and added Then to turn it off. I was hoping to do this in one program.
dpark-
We COULD do it in one program:
    From 6:00 pm
    To 8:00 pm
 And
      or
     Status MyLight is On
  Set MyLight On
  Set MyLight Off
* * * BUT * * *
This program will run True (Then) at 6pm and anytime between 6pm and 7:59:59 when the switch status changes forcing the light ON and False (Else) at 8pm and anytime the switch status changes between 8pm and 5:59:59pm the next day forcing the light off.
I actually do something like this for my back yard flood lights. It they are turned on during daylight hours I force them right back off. During dark hours I have a 15 minute timer (Optional - disable with a Fast On - re-enable with an Off) to turn them back off.
-Xathros
I'm doing this for my porch lights so this will work!
