dpark Posted January 29, 2013 Posted January 29, 2013 Hi, I am trying to program so that the light is always ON From - To time. So if someones turns off, it would turn back ON automatically. I was able to accomplish this with two programs but is it possible to do this in one program? Thanks!
Xathros Posted January 29, 2013 Posted January 29, 2013 Hi dpark- Try this: If From 6:00 pm To 8:00 pm And Status MyLight is not On Then Set MyLight On Edit as necessary. The reason for "is not On" is just in case this is a dimmer. Anything less than full on will make this program set the light full on. If this is a relay type switch, you could say "is Off" instead. -Xathros
dpark Posted January 29, 2013 Author Posted January 29, 2013 Yes, that is basically what I did but I would also like to turn the light off automatically after 8:00pm. If I add Else statement there to turn the light off, it just loops - on and off when I hit off switch. So I created another program for "off hours" and added Then to turn it off. I was hoping to do this in one program. Thanks!
Xathros Posted January 29, 2013 Posted January 29, 2013 dpark- We COULD do it in one program: If From 6:00 pm To 8:00 pm And ( Status MyLight is not On or Status MyLight is On ) Then Set MyLight On Else Set MyLight Off * * * BUT * * * This program will run True (Then) at 6pm and anytime between 6pm and 7:59:59 when the switch status changes forcing the light ON and False (Else) at 8pm and anytime the switch status changes between 8pm and 5:59:59pm the next day forcing the light off. I actually do something like this for my back yard flood lights. It they are turned on during daylight hours I force them right back off. During dark hours I have a 15 minute timer (Optional - disable with a Fast On - re-enable with an Off) to turn them back off. -Xathros
dpark Posted January 29, 2013 Author Posted January 29, 2013 I'm doing this for my porch lights so this will work! Thanks!
