sunset to sunrise program
Hello forum-
I'm new to making my home smart and need a simple fix:
I need a program to turn carriage lights on 30 min after sunset and off 30 min before sunrise.
This is what I have but it only works to turn on but not off:
From Sunset +30min
To Sunrise -30 min (next day)
Set Scene 'FRONT_LIGHTS' On
Thanks in advance.
Alfa
At Sunrise -30 min (next day) the If statement becomes false so you need to turn the Scene off in the Else Statement.
Set Scene 'FRONT_LIGHTS' Off
~Mike
  • 1 month later...
I'm also a newbie and am creating the same scene, but implemented it with 2 separate programs.
SunsetOn
If sunset+30
then porchlight on
SunriseOff
If sunrise - 30
then porchlight off
Is there a benefit to this coding style (e.g. less "off" commands over the network) over the single program
If sunset+30 to sunrise -30
then porchlight on
else porchlight off
timster
No difference in the Insteon commands executed whether one Program or two in this example.
Coding one Program that uses both Then and Else keeps related logic in the same Program and uses the least number of Programs. I prefer the single Program because it keeps related logic in one Program. There are times where two Programs (or more) are needed to avoid If reevaluation problems so having multiple Programs is fine when needed.
There is a 300 Max Programs limits for the non-Pro ISY versus a 1000 Max Programs for the Pro ISY.
