3-way switch question
Hey guys,
I have a few questions about setting up a 3 way switch.
I still have to figure out the wiring in the house but was wondering about how things would work in the end..
If I want to have the light "dimmable", do both controlling switches have to be dimmers or just the controlling one on the load?
And if I can mix and match, will the dimmer status show correctly on a linked on/off switchlinc?
"If I want to have the light "dimmable", do both controlling switches have to be dimmers or just the controlling one on the load?"
Only the switch physically controlling the load needs to be a Dimmer.
"And if I can mix and match, will the dimmer status show correctly on a linked on/off switchlinc?"
No. SwitchLinc Relay devices do not have all the status LEDs installed as a dimmer has. It cannot show mid point status because there are no LEDs in the mid points.
Ah you're right! I never really looked closely at the circuit board until you mentioned that!
Hmm, I wonder if I soldered on LEDs if they would work...
