palayman
  1. Rebooted again. Didn't fix the problem for me.
  2. Me too! I checked the ISY portal and it was there but when I tried web access it said "error, Loading: /config/" Then I rebooted the ISY. It still is available in my local network, but it doesn't appear on the ISY portal. Paul
  3. Answer provided in another thread. It worked for me.
  4. Still offline as of 10:22 EST, so I guess it's not directly related to the Portal.
  5. Is this somehow related to the ISY Portal issue which now seems to be resolved? Paul
  6. I'm in an even more comical situation. Built a new house a few years ago just when Polisy was coming out. None were available so I bought an ISY. Then ISY stop supporting the latest version of nodeservers on a Raspberry Pi, so I bought a Polisy and installed some nodeservers (that would have run on the the RPi) with intention of moving the ISY to Polisy and updating the the new nodeserver version a short time later. Unfortunately a couple of the nodeservers I needed wern't yet ported so I never moved. Instead I started using Home Assistant on a Small PC and integrated with the ISY to get the functionality I wanted, with the intention of moving everything once the nodeservers were available. Well I never did move and found that only two of the five nodeservers were something I needed/used and one of the two I used went away - myQ. So I plan to move the one I use, envisalink, over to Home Assistant and turn off the Polisy. No point in moving to Eisy at this point. Besides it might be superseded before I have time to integrate. Is there a market for lightly used Polisy's?
  7. I also had a strange admin console problem. This fixed it.
  8. Thanks!!! It worked and the console loaded so much faster. You're a life saver. Paul
  9. firmware 5.3.4. Not sure where you find UI version.
  10. Already did this. Cleared cache and installed fresh Java. Also used used a fresh start.jlnp from the same link. Didn't work. Paul
  11. Hi, Have an ISY with no updates for several years. Tried to go in and edit a program. Console loaded, but every time I go to the programs tab it locks up showing a popup saying "loading scene widgets". Have rebooted the laptop, checked java version, and rebooted the isy to no avail. Any ideas? Paul
  12. Is there an ETA on the new solution? Unfortunate that you didn't warn us until June 6 and submit new code until a couple of days ago, even though the announcement was made by Google almost a year ago. We rely heavily on this interface. Paul
  13. Yea, it is cloud based.
  14. Filed a ticket and was guided to add a "hint" for the device to work correctly. You might want to file a ticket to get it working. '
