rusgrafx
  1. Just a quick note.. I just discovered that my Amazon FireTV (the latest model) can also talk to ISY through voice remote - sweet!
  2. Worked great for me too! Initial discovery added all of my 100+ devices. I removed them all and added back only selected scenes and a couple of devices. All work fast and smooth. Much better experience than the skill - it was very painful as I have multiple devices with similar names, but different suffixes - ex: Bar Light (master), Bar Light (slave), Bar Light (scene), so Alexa couldn't figure out which one to use. Benoit, Michel and the UDI team - great job! Thanks a lot!
  3. @Wrdarnel Thanks for your reply. I have a bunch of services on my lan (ip cams, media streamers, etc). The last time I tried using ssl on Isy my HP server went bezerk - it lost its ip settings and ssl cert. But I'll give it another try. Maybe I'll just take it offline while configuring Isy.
  4. Thanks for the app! It works fine on my Droid X (2.1). One question (actually two): 1) I'm not quite sure how to switch from local (WiFi) settings to mobile (SSL). Currently, I have to go to Settings and update local IP with DDNS server name (and port) to connect while on the go. Even when WiFi is turned OFF, it still tries to use local IP to connect. 2) My remote ISY connection is not SSL (just HTTP) due to certificate conflicts with my other SSL server running at home (HP MediaSmart). So, can I connect remotely with wdISY without using SSL for ISY? Thanks again.
  5. Thanks, Rand. That worked and it appears nothing got lost (with exception of configured email address). Now I'm a happy camper again. Riding on 2.7.15 firmware. Thanks again.
  6. I was trying to update ISY99i v 2.7.6 to the latest firmware, but keep getting an error during Backup. The error message is: Could Not Retrieve File /CONF/23.PRP Telnet shows that this file is 0 byte. The result - broken backup zip. I don't want to lose any settings. What could I do? Any suggestions? Thanks. P.S. Programs export without any errors.
