mullercentral
  1. It took a "long time" (maybe an hour or two?) but I finally got a pop-up in the admin UI that it was done. Would be nice if there was some sort of ongoing status.
  2. cleaned cache again, but this time, I rebooted my laptop first, and then ran https://isy.universal-devices.com/start.jnlp, rather than my previous local download of it. All good now.
  3. After my last "Upgrade packages" attempt required me to reflash my eisy, I figured I would try again, having the latest version. When I select it, I get a popup warning to wait until it's done before restarting the eisy... but then that's it. No other status. How do I know it's actually doing anything, or when it's done? Every time I launch the UI, it warns me again that an upgrade is in progress, but that's not especially useful. I saw in another post that reccommended sshing in, and I get this: [admin@eisy ~]$ sudo tail -f /var/udx/logs/log Fri Dec 26 11:40:04 EST 2025|/usr/local/etc/udx.d/static/udxops_main.sh: udi.conf no signature is AOK ... Fri Dec 26 11:40:04 EST 2025|/usr/local/etc/udx.d/static/udxops_main.sh: udi.conf is AOK ... Fri Dec 26 11:40:07 EST 2025|/usr/local/etc/udx.d/static/udxops_main.sh: making sure we have the right pkg version ... Fri Dec 26 11:40:07 EST 2025|/usr/local/etc/udx.d/static/udxops_main.sh: pkg pkg is current ... Fri Dec 26 11:40:07 EST 2025|/usr/local/etc/udx.d/static/udxops_main.sh: checking whether or not we have a new version for udx ... Fri Dec 26 11:40:07 EST 2025|/usr/local/etc/udx.d/static/udxops_main.sh: need to upgrade to 4.4.0 ... Fri Dec 26 11:40:10 EST 2025|/usr/local/etc/rc.d/udx_cmd_processor: emptying command processor ... Fri Dec 26 11:40:10 EST 2025|/usr/local/etc/udx.d/static/udx.utils: wifi.ops is not being called as a comamnd Fri Dec 26 11:40:12 EST 2025|/usr/local/etc/udx.d/static/udxops_main.sh: restarting after udx restarts ... Fri Dec 26 11:47:04 EST 2025|/usr/local/etc/udx.d/static/udxops.sh: command discarded since udx_cmd_processor service is not running ...which hasn't changed in almost the last hour. Any suggestions?
  4. It would be nice to be able to specify a calendar date or date-range in the programs in addition to the time/range. Like, for the "holiday season", have the holiday light programs enabled, and then don't worry about them the rest of the year. Or something special for birthdays and anniversaries. Just an idea.
  5. So whenever I start my IoX Finder, it finds my eisy, but then I always get a pop-up that says "Not found". I completely cleared my Java cache (all 3 check-boxes), and it still happens. Any ideas? Not a big deal, but it's annoying.
  6. Michel just helped me too. Mine was prompting me to update packages, so I did... and then it went offline. Unfortunately, I ended up having to re-flash it, but that's an easy process. My backup was a couple of years old, though, so I lost a few minor changes to my setup. Note to self (and everyone else): Every time you change anything, be sure to create a backup!!!
  7. Would be nice to be able to control scenes with either ISY web interface or hub apps. Is it possible to create "links" between the two types of scenes? Are scenes just controller/responder entries in each of those devices? Even if so, is it possible/easy to discover the names of the scenes. Even if technically possible, I imagine that each of the devices management apps aren't geared towards doing such a thing. Thanks, Jeff
