Stagehand
Everything posted by Stagehand
  1. I am installing a Tuya Zigbee Smart Sprinkler Timer to my Polisy. I am running Version 5.9.1. After the installation process is complete, I have no functionality in the device's page. Please see attached image. I have tried uninstalling and reinstalling a few times. I have reset the Zigbee dongle. All with the same results. All suggestions are welcomed. Thanks
  2. Thank you very much Guy for having the patience to explain, to me, a very simple concept that I could not grasp on my own. I have created the exact garage door program that I wanted. All the best,
  3. Thanks Guy. I think I understand. I'm a bit slow at these things. I'm going to explore the portal a little more.
  4. Thank you Guy for your quick response. I am looking through the Universal Devices Administrative Console and cannot find any sort of condition for "Alexa close door command". Where is that located? Thanks again
  5. Hello, I am in need of help creating a garage door program in my Polisy. I have a garage door with a ZWave tilt sensor on it. The Garage door opener is a Chamberlain brand opener with a pushbutton wall switch. I have a Zooz Zen16 relay wired directly to the pushbutton wall switch. My Polisy is connected to Alexa and I have a simple program that momentarily closes contact to the pushbutton wall switch in both "Then' and "Else" fields. I can use the commands "Alexa, open the garage door." or "Alexa close the garage door". Here is my problem. In reality, it does not matter if I command Alexa to "open" or "close" the garage door. Essentially the pushbutton wall switch is activated and the garage door will travel to the opposite of it's current position. Therefore, if I forget that the garage door is closed and I command Alexa to "Close" the door, it will open. I have set up the tilt sensor to create a state variable. "Off" if the door is closed and "On" if the door is open. Here is where I am stuck. I want to command Alexa to "Close" the garage door and in the program check to see if the door is open or closed. If it is already close it should do nothing. If it is "open" then it activates the pushbutton. And I want the same to happen if I command Alexa to "Close" the garage door. I would greatly appreciate any help. Thanks for your time.
  6. I have a reliability issue with the ZEN31 LED dimmer. I have six of them on the top and bottom my kitchen cabinets. (I am working with Zooz support on this issue as well) At sunset a program turns on and sets various intensity levels to four Z-Wave switches and two Insteon switches. It also triggers the "Then" of a separate program that sets six ZEN31 dimmers as such: Red-0, Green-0 ,Blue-0, Warm White-255, Intensity-50%. At 9:00pm a program turns off one Z-Wave switch and then sets the six ZEN31 dinners as such: Red-0, Blue-255, Green-0, Warm White-0, Intensity 25%. My problem is that intermittently some the ZEN31 dimmers do not respond correctly. I have been tracking it for nearly a year and the issue is random throughout the six ZEN31 and not in any sort of recognizable pattern. However, the Z-Wave and Insteon devices work flawlessly. I have ruled out distance as an issue. My system is a Polisy with a new ZMatter board. (the previous was a Zooz Zwave dongle) IoX version 5.5.9 Has anyone experienced this kind of issue? Thank you
  7. Thank you Asbril. I checked to see if my thermostats are addressed as ZY and they are. I decided to try again. So I deleted the Thermostats from the Alexa app. Then deleted the devices from the ISY portal connected to Alexa. I did not exclude the Thermostats from the ZWave system as everything is working fine there. I re-added the thermostats in Alexa. Ran discovery in Alexa. They were both discovered by Alexa, but I get a message from Alexa that the Thermostats are not responding. I am happy to try any other suggestions. I'm sorry that I am unable do offer you any suggestions with your issue. I am not experienced with using Variables and routines through Alexa. All the best,
  8. A few days ago I migrated to Zmatter. I first upgraded to version 5.5.3. Struggled through the devices that did not successfully migrate. Now the only issue I cannot resolve is to regain control of my Go Control Zwave thermostat through Alexa. I have two of the thermostats in my home and they both do not respond to Alexa. They do respond perfectly through the IoX system. This is what I have done. Deleted old thermostats in Alexa App. Deleted thermostat connection to Alexa in the ISY Portal Un-included and re-included the thermostats 3 times. Factory reset both thermostats twice. Alexa seems to discover the thermostats but says that they are not responding when asked to perform a command. Does anyone have any suggestion? Thank you.
  9. Thank you Mr. Bill. That makes perfect sense to me and explains it all. Thank you Getty for your efforts.
  10. Thank you for your quick reply. I have followed the process in the wiki that you suggested many times in the past and just now in case I overlooked something. No Change. I'm running Windows 11 Browser is Chrome Both computers are on WiFi. When I try to access Polyglot V2 it sends me directly to the Portal Login website. When I try to access Polyglot V3 it will not connect to address https://my.isy.io:3000 I am curranty using computer #2 away from home and connecting to the IoP via internet. I do not know about VLAN but I suspect not. It is a simple home network. Thank you,
  11. I have a Polisy Pro and two computers. One computer I can access Polyglot V2 and V3. The other computer will not access either Polyglot versions. Both computers are able to run the IoP software version 5.4.4. The second computer is newer and I take it with me when I am away from the house. The first computer stays home and is always on. I have been accessing the Polyglot V2 and V3 when I am away from home through the first computer by using the remote software Teamviewer. I would like to finally resolve my problem. I have looked through the forums and help sites and clicked around the IoP software with no luck. Please help walk me through the setup. Thanks
  12. I am slowly switching over from my ISY994i to ISY on Polisy. I found a posting on this topic posted on 12/13/21 and followed the direction (or so I thought). Somewhere along the line I made a few errors and now I have confused myself. Here is what I did. Polyglot Settings: Address/Hostname - Changed IP address the the Polisy address. 192.168.1.144 Port - Changed to 8080 Username - Entered username Password - Entered Password Use HTTPS - unchecked MYQTT Setting: Address/Hostname - localhost (Already set. I did not need to change) (Here is where I believe I went wrong) MQTT Port - ****** I changed it to 8080. (I cant remember the original port number.)****** Reset Ran Putty command sudo rm -rf/var/isy/FILES/CONF Noticed that I probably should not have changed MYQTT port and changed it to 8083 (That is possibly the original port number might be but am not sure) Reset Ran Putty I get message that ISY automatically detected needs Username and password. I have entered the info with no success. And Polisy does not show up on ISY Finder App
  13. I Just found the issue... Under the "My Programs" folder I had an erroneous "If" condition. I deleted that condition and.... Voila!! It worked just fine. Sorry for the false alarm.
  14. Hello, I have just upgraded my Polisy to ISY 5.4.3. I wrote my first program that included a command to send a text and email notification. When I tested this by executing the "Run Then" command I did not get any notifications. If I go to the Configurations - Setting/Groups and run a Test, I get a correct test notification on both Text and Email. Here is the program: If - Attic Leak Sensor / ZW002 Water Detected 1 Status is On Then - Send Notification 'Tom Text and Email' Content 'Attic Leak Sensor'
  15. I'm sorry I am replying so late. I just noticed your question. No, I did not have any issues pairing. My ISY is one floor away approximately 30 feet away from the ZEN31 and I am using six of them.
  16. I have a very similar situation (to this post). I have updated my ISY to version 5.3.4 about two weeks ago. Since then I have received the "Cannot Communicate with..." messages on more than 10 devices wired and battery operated. For the most part these same devices seem to respond to programs properly but occasionally they do not. In my case these are all Zwave devices. I have only a few Insteon devices and these do not seem to be affected. I have run the "Zwave Synchronize Nodes" command for all of the nodes. This has not solved the problem. I am hoping to avoid excluding and then re-including these devices so I don't have to spend hours adjusting the many programs I have running. I do have a Polisy Pro running with my ISY. I would like to run ISY on Polisy but I do not fully understand it yet. I am not apposed to simply moving everything to the Polisy and retire my 994i ZW/IR Pro. Any suggestion? Thank you.
  17. I resolved the issue. Not only was my DNS servers incorrect as suggested by kzboray but I discovered that the IPv4 Gateway was incorrect. The error message has gone away and I successfully installed the node. Thanks for everyone's help.
  18. I still have the issue but my DNS servers were indeed somehow changed to. 0.0.0.0. I made the correction but I still get the error code even after rebooting the Polisy and re-confirming I have the proper DNS servers. I think that was definitely part of the problem. Thank you for the suggestion.
  19. Thank you for your reply. Please give more specific instructions. I do not know what a terminal program is. Thanks
  20. This is an ISY994i ZW/IR PRO and a Polisy Pro.
  21. I have updated my ISY software to version 5.3.4 from 5.3.0 and Polisy Pro to version 5.2.0. Since then MyQ node has stopped working. I deleted it and uninstalled it. Then I tried to reinstall and received the message. cloneRepo: Non-zero exit code 128. I have tried installing a few times and rebooting the ISY and Polisy with no success. I could not find pertinent help on the forum. Any suggestions? Thank you
  22. Now that makes perfect sense to me. Thank you hart2hart, llaryllix, MrBill and apostolakisl.
  23. Hello, I have been using the following program to keep an update on the battery status of my Insteon Leak Sensor 2852-222 by blind faith since 2018. I trust that the program logic is correct because I have seen postings of similar programs, but I just don't understand it. I would be grateful if someone could explain it in terms a simpleton like me can understand. The following is the program.Control 'Sensor-Heartbeat' is Switched OnThenWait 25 hoursSend notification 'low battery' It seems to me that I should get a "low Battery" notification every 25 hours and if the Heartbeat is not On, then the battery is actually low and I will get no notification. By the way, I do not get a "low battery" notification every 25 hours. Thank you
  24. That makes perfect sense to me. I think I understand better. Thank you
  25. Thank you for your replies MrBill and Techman. I now understand how to write a program using the Battery Level node. I still would like to know how to use a specific parameter. For example, on the Zooz Leak Sensor ZSE42, "Parameter 4 : Decide when the sensor should report low battery to the Hub. Values 10-50 (% battery Life). Default 20 Size 1 byte dec" That means to me that there is some sort of command or message sent to the hub when the battery reaches 20%. So my question is how does the ISY handle Parameter 4 and how to I single out Parameter 4 and insert it into a program? Some of the other sensors I use have a similar low battery warning features. It seams to me that it would be more efficient to use the feature designed in the device. It is entirely possible that with the ISY the only way to deal with a low battery warning is to write a program similar to what Techman described. But if there is a way to single out an individual parameter and use it in writing programs that would create a great potential for some very good programs other than just low battery warnings. Does any body know what they mean when they refer to "Group 1 and Group 2 -5" ? Thank you
