brians
  1. Where is 6.0.3 announcement?
  2. To watch the update progress, ssh to it and type tail -f /var/log/messages If it pauses for too long, login to admin console and see if notification requires a reboot. Nice if they would have some sort of status in web UI.. .I just updated (was already on version 6) and the new version has upgrade packages button in the eisy-ui so I will check that out next time.
  3. I just updated my Polisy - no issues. However It is still prompting for my local credentials which work. When I login to new web eisy-ui I have to use my portal login. I reboot Polisy and still is prompting for local credentials. It is working but I am wondering why everyone else seems to be prompting for portal credentials now? UPDATE: I figured it out. If I use https://x.x.x.x:8080 then it uses local My Lighting credentials. If I use https:// then uses Portal. I am used to using hardcoded IP since MDNS was broken in previous versions (seems to be fixed now). Therefore the way I was connecting did not prompt to use portal login and I also did not have issue with Home Assistant Integration credentials since I use http://x.x.x.x:8080 in my config. Here is screenshot which shows better... the first one will use My Lighting credentials. The two bottom portal credentials...
  4. brians replied to vbPhil's topic in eisy-ui
    Maybe this then http://ewaste.fka.wtf
  5. brians replied to Ristin's topic in ZMatter
    No I don’t use google stuff I got rid of it years ago. I don’t think we should have to do workarounds like this - can’t be that difficult to add into the app. But I sorta hearing that iOS app doesn’t work anyways but no official clarification also
  6. brians replied to Ristin's topic in ZMatter
    I can’t even try the app because only matter device I have gives a code in the app. The iOS app only has option to scan with camera.
  7. brians replied to jkraus's topic in IoX Support
    @Andy PYes UD Mobile has come a long way. However I think it still has some limitations with some programs not supporting editing.
  8. brians replied to jkraus's topic in IoX Support
    Since they mention EISY only, I am presuming this will not work on Polisy. I wonder if it is going to be a near-exact web based replica of the Java AC, and difference is no requirement to install Java ? Or maybe it is going to be the actual AC access from client using RDP/XRDP? I do not have an EISY, but is it possible to directly run AC, and PG3x etc. running on EISY with a monitor/keyboard/mouse attached.
  9. Where have you heard this latest from?
  10. I wouldn't worry about windows 10, just leave it internal on LAN and have it run DSCLink. Microsoft end of support does not mean it will stop working. Does NodeLink work on Windows 11 though?
  11. Homekit support was supposed to come out “next week” last month.
  12. Matter devices I have setup require scanning QR code and using a phone app. Apple HomeKit and Home assistant mobile app both worked for me. Although I don’t think it is 100% necessary for a matter device to require using a phone to enroll, it is pretty much the way everyone does it. In most matter devices they have BLE with allows your phone to communicate to do initial setup and it hands off your wifi or sets up on thread or whatever. This is very common to use BLE for lots of things now (eg. Not matter but another example is I can setup a UniFi router and adopt using my phone and BLE). UD even said their phone app would be used to scan QR code but I think they also hinted at other method direct with EISY using its BLE but I may be misunderstanding this. I have not used a cync bulb but what you describe sounds like you can use their app/ecosystem or a matter system. Their app probably allows more advanced control of bulbs and maybe things like scenes, dim rates etc. whereas matter would just be basic settings.
  13. It uses BLE for device setup using a phone app. And yes you have to keep those codes - sometimes they are stamped right in the device. If you don’t have the code you have a nice paper weight. In some cases the device app can generate a code for you but this is normally older devices that have been upgraded to matter eg. Older wiz bulbs. If you are using something like Philips hue the bulbs themselves are not matter and instead use the matter bridge. Aqara bridge does something similar where can bridge its devices to matter using their hub and then some devices are actual matter. But most advanced features still require use of an app.
  14. Every device has an IPv6 link local address. derived from MAC address with prefix fe80. Matter can use this.
  15. Matter uses ipv6 local addresses. No need to enable IPv6 on router.
