johnmsch
Everything posted by johnmsch
  1. Wow, thanks guys! If these don't work, I can just delete "Office" and create from scratch. Just doubled-checked and there are only two programs that control that switch
  2. Excellent! Thank you kind sir
  3. The new switch is on the way. When it arrives, what is the best way to replace it in the admin console? The togglelinc will be replacing the "Office" item in the console. Is there some shortcut to having the new switch use that slot?
  4. Been a LONG time since I've been in my Admin Console! When I fired it up, I got this error: I then went through the factory reset process and restore. Within about 2 minutes, the off/on flicker returned. Restarted the console and again got the error above again on startup. I guess its safe to assume this old switch is toast. Looks like Insteon has a $59 on/off switch, ordering now. Thanks guys for all the help and stroll down memory lane. Being back in the console reminded me I meant to setup a couple more scenes back in the day... 😁
  5. DOH! Now I remember that process and thanks for not telling me to go RTFM. 😁
  6. Thanks guys for all the help. Finally got some time to look at this situation again. Tried the restore but still having the issue.. Please refresh my memory as to how I factory reset on this device? One other issue I just noticed in my troubleshooting. This flaky switch is in a room in a corner of my basement. The rest of the basement lights are all controlled by a 8-button dimmer pad and a couple of scenes. I just happened to notice that when I turn off one of the scenes (which controls 8 separate basement lights), when each light in the scene goes off, so does the light in the corner room, for about a second, then immediately goes back on. This happens with the rest of the lights in sequence in the scene. Not the kind of light show I want to see!
  7. One of my old switches (pic attached) has recently starting randomly switching off and a few seconds later turns back on. It can be anywhere from a a few minutes to 20 to 30 minutes and it happens again. I have about 25 of these and this is the only one with this issue. I'm a LONG time Insteon user and am stumped what the problem could be. Any ideas what could be causing this?
  8. Trying to figure out how to automatically turn off my front & garage door lights for Halloween. Those lights, along with many other exterior lights are programmed to turn on at varying times before dusk. Due to some physical issues, I can no longer keep going to the front door for trick-or-treaters at this time. I don't see anything in the documentation about Halloween being some kind of special flag in the ISY programming. The ideal situation would be for those 2 lights not even come on at dusk on Halloween, but then come on at, say, midnight. Any ideas?
  9. @oberkc Got everything setup, just one annoying issue remains. On the admin console, I created a new scene. To that, added a few switches and a couple scenes already on the keypad. Then added the new scene to the MobiLinc dashboard. With everything turned on, brought up MobiLinc dashboard and hit the new scene. Everything went off as expected, but the lights on the existing keypad stayed on. This issue sounds familiar but my searches here are not finding anything. Does this sound familiar?
  10. Thank you sir! I knew there had to be some way to do this.
  11. Haven't messed with any of my Insteon stuff in about a hundred 😁 years - it just always works! I have an 8-button keypad in my garage. Each one of them is programmed to multiple devices throughout the house, which were all setup ages ago in the Admin Console on my PC. I now would like to access one of the buttons with my MobiLinc Pro on iOS (iPhone 15). I added one of the buttons to the Devices Dashboard in MobiLinc, but when I bring up that device, it shows as Status Only Device. Is there any way around that? Some way to directly access that button as on/off in MobiLinc? Sorry if this is a dumb question, but again, I haven't make any changes in my Insteon/MobiLinc setup in a very long time! Hopefully I'm just a bit rusty and forgot 99% of what I used to know Thanks
  12. Thanks guys, that was easy enough. Added the new device in Admin Console, deleted the old one, updated the two programs that reference the device and took a new backup.
  13. Since my old 2466DW is fried, I ordered a new 2477D. Should be arriving today. Been wondering about how I should handle this in the ISY99i Admin Console. Once the switch is installed, I'd like it keep the same program that is currently running the 2466DW. How would I go about this? Probably an obvious question I'm just not seeing, but its been at least 4-5 years since I've changed/added any new hardware and I very rarely even go into the Admin Console any more. Thanks
  14. Yep, ordering one now. Had quite a scare last night. Went to try the Power down & factory reset one more time but the module was so hot I couldn't even touch it for a second! Had to power down the circuit, let it sit for an hour, then remove the switch. Yikes!!!
  15. Thanks guys, just got back from a trip and went through the troubleshooting: Shut off the breaker to kill the power Waited about 10 minutes, turned breaker on Looking at the switch, I could see a faint/slow blink in the set button, once per second Tried the factory reset (pull out set button, wait 10 seconds, pushed the set button in and held it, but never got the long beeping sound) Waited a little while and release the set button (Just in case...) Still no sound at all and the switch still has that faint/slow blink Turned the switch on and off a few times, nothing happens I guess its time to order a new 2477D. Thank you all for the info!
  16. I have 5 PAR38 halogen floodlights spread out over my back yard, controlled by a Rev 4.2 2466DW that goes on an sunset, off at sunrise. Just noticed last week that 3 of the lights were out. Since the big box stores no longer carry those bulbs, I went with Ecosmart PAR38 dimmable LEDs. Yesterday, I was outside when the lights came on and they just blink, on for a second, off for a second on for second, etc... Thinking it was these new bulbs, I found the old-style halogen bulbs and ordered them online. Just got them and replaced all 5, but its doing the same on, off, on... Any ideas what is going on here?
  17. Wow, now I feel like a complete maroon, the answer was right in front of my eyes. After 50+ years of software development, I can't believe I missed something so basic. When I did the download of start.jnlp, and as you can see in my screenshot in the OP, the file was indeed associated with Firefox as noted by the icon in front of it. Once I associated it with Java, the launcher worked. DOH! The only issue was when I started it up, it could not find my ISY. Rather than wasting more time trying to figure that out, I just added the entry and now I'm in business. What piece is missing that would have allowed the new Launcher from finding my ISY? Thanks guys for your responses. Always appreciate the help we all get from you guys!!!
  18. Thanks @kzboray, but as I mentioned in the OP, I did download the latest version.
  19. Just built a new Win 10 PC and I can't get IoX launcher installed. Been using the Admin Console on my old Win 7 PC for as long as I can remember and rarely had any issues. Even upgraded to IoX Launcher last year and the process went perfectly. I downloaded the latest Java version and when installing, got the prompt to delete the existing version. I then cleared the Java cache (all 3 check boxes) and went to https://isy.universal-devices.com/start.jnlp. Instead of starting up, I got this prompt: I saved the file, then double-clicked on it and it opened a new tab in Firefox that only said this: IoX Launcher Universal Devices This utility finds ISY Services and launches the correct version of the UI/Admin Console/Dashboard IoX Launcher I waited and waited, but nothing happens. I've cleared the cache and tried installing about 5 times, but still no joy. What am I missing here?
  20. johnmsch replied to johnmsch's topic in ISY994
    Hi @sjenkins, thanks for chiming in. As I mentioned, I was just looking for a way to integrate water sensors in my Insteon system. I've looked at Polisy and Eisy, but just don't have the need (or do I?) to go beyond my old faithful 994i. Would you please expand on how you integrate the Yolink sensors with Polisy & Eisy? The Yolink comes with its own hub and app, so I'm very curious!
  21. johnmsch replied to johnmsch's topic in ISY994
    Thanks guys, but doesn't look like this is going to work for me. About 90% of my setup is just 2466x switches and they are not on the Dual Band Wireless list. The few things I have that are on that list are nowhere near where I'd need the water sensors. I did get excited for a brief moment when I discovered the #2443 Dual Band Access Point, but my hopes were completely dashed when I found that these aren't around any more. The only one I could find was a used one one on eBay. I guess, for the time being anyway, I'm stuck with my YoLink water sensors. I test them regularly and they seem to work as intended, but I really wanted to integrate this with my Insteon system.
  22. johnmsch replied to johnmsch's topic in ISY994
    Thanks for the quick reply @Techman, but how exactly would this work with the ISY994i? With the antenna on the sensor, would this somehow connect to my WiFi and the ISY sees it there?
  23. johnmsch posted a topic in ISY994
    Just received the Ken Update – Jan 10 and things are starting to look promising! In it, he mentions the Water Leak Sensors (2852-222) and I'd really like to get a few of these. However, when checking out the item, there is the phrase Receive leak alerts via email and push notifications and/or emails when used with the Insteon Hub or other compatible software. Does anyone know what is meant by "other compatible software"? I've never had, nor do I want to buy a Hub now. Any reference to a Hub just gives me chills, given what happened not so long ago.
  24. johnmsch replied to johnmsch's topic in ISY994
    Very interesting. I've heard nothing but good things about ASUS routers from all of my geek buddies. After many years of using Netgear routers with not-always good results, I thought to give ASUS a try after my R700 bricked itself yesterday. Looks like my initial thought of using the old router's DHCP settings was the correct way to go. I'll do this tonight. Thank you!
  25. johnmsch replied to johnmsch's topic in ISY994
    Bingo, after rebooting the ISY, it has an IP and is showing in the device table. I'm also able to fire up the Launcher and get to the admin console. The thought had crossed my mind of rebooting the ISY or even assigning the previous IP as a static IP, but wanted to run this by you guys first. I was stumped on why all other devices on my network, except the ISY, automatically got IPs on the new router. Thanks, as always, for your help
