Everything posted by peterathans
ZMatter USB Firmware Update 7.32 to 7.46
Slightly off-topic but generally related to discussions in this thread - does anyone know for certain how the Zwave dongle will behave if your system has a combination of 700 and 800 devices? From what I understand, 700-series devices are designed to work in a mesh configuration, whereas 800 devices operate as a star network (each device communicates with the dongle directly). I believe 800 devices can also fall back to behave like a 700 device, so they can all work together in the same system. But this loses the range improvements some people are hoping for with a point-to-point 800-series device. So would the ZMatter dongle use 700 and 800 communications simultaneously (allowing for both a mesh and a star network together), or would it expect all 700 and 800 devices to behave as part of a 700-series mesh network as long as there's at least one 700-series device present? (Interestingly, due to the star nature of 800-series communications, you actually lose out on the direct association features of ZWave - since none of the nodes talk to each other, there's no way to set them up with a truly independent link that can operate separately from the hub)
Zwave firmware update available in eisy-ui?
I'm running 1.3.8 and can't find where to update the firmware in a Zwave device, does this feature exist yet?
To add a data point: I just completed this update from 7.32 to 7.46 (with a stop at 7.42 to update the bootloader). Aside from a couple of hiccups (connection failures and retries), everything worked well and my Polisy (running 6.1.2) is back up and working great. I have no need for the 800LR capabilities as I have a mixture of 700 and 800 devices, but appreciate the bug fixes and stability with later releases. (In the past few weeks I've been updating a lot of my Zooz devices, many of which have new firmware out this month updating their API from 7.19 to 7.24, and have noticed improved performance)
Great stuff, thanks for the post! A few questions: You mention Firmware Update, is this actually the API you're updating? As shown in Protocols / Z-Wave / X-Ray / DH Controller: String DATA controller.data.APIVersion = "07.32" Integer DATA controller.data.APIVersionMajor = 7 (0x00000007) Integer DATA controller.data.APIVersionMinor = 32 (0x00000020)Now that you completed this update, have you noticed any changes or improvements in operation? And finally, I assume this update can be made regardless of the controller being used (EISY vs. Polisy)?
New release out today.....Does this work on Polisy?
Last thing I tried was a full power cycle, followed by another upgrade attempt ("Your packages are up to date"). I'm seeing FreeBSD both at /WEB/sysconfig.txt *** OS *** FreeBSD polisy 14.1-RELEASE-p6 FreeBSD 14.1-RELEASE-p6 releng/14.1-n267727-74b6c983723c POLISY amd64and when I ssh into the unit Last login: Thu Sep 17 12:36:27 2026 from 192.168.160.126 FreeBSD 14.1-RELEASE-p6 (POLISY) releng/14.1-n267727-74b6c983723cI've opened a ticket, although your help has been very much appreciated (and a lot more responsive)
So it turned out I did need to install eisyui rather than upgrade, but after sudo reboot I still don't see a change. I just did a power-cycle reboot and it still shows FreeBSD 14.1, with no web access. Doing another sudo repo.util prod and then sudo pkg upgrade udx isy eisyui pg3x just results in Updating udi repository catalogue... udi repository is up to date. All repositories are up to date. Checking integrity... done (0 conflicting) Your packages are up to date.And strangely, at the same time my Finder can no longer see the Polisy, and I can't add it. But UDMobile can see it fine, and everything appears to be working.
Ok it seems IoX is now on 6.1.2, but FreeBSD is still on 14.1 - should this update too? Also, should I now be able to go directly to the controller's http interface rather than using Java? I'm getting This site can’t be reached / 192.168.160.xxx refused to connect
I followed the procedure in this thread for my Polisy (IoX 5.9.1, FreeBSD polisy 14.1) and it looks like a lot of files were downloaded and updated, but then the SSH prompt came back and it's just sitting there. Should it reboot automatically? Also, I noticed one of the messages during the upgrade was "pkg: eisyui is not installed, therefore upgrade is impossible", - I assume this is expected since it's a Polisy?
Scene with Insteon and ZWave as controllenot working
I'm curious, is this an issue with the Z-Wave standard (Z-Wave products are not supposed to publish controls, therefore UDI will have to find a way to work around that), or is it an issue with some specific Z-Wave vendors not implementing the standard correctly?
Polisy upgrade from 5.9.1 - is it worth it?
Precisely - hence the reason I started this thread. This sounds like good news. I've never used an eisy, but imagine it's faster than a Polisy. So for 6.x to run slower on Polisy than it does on an eisy is pretty much expected. And it sounds like (due to the way the admin console loads) 6.1 on Polisy may actually perform faster than 5.9.1 does on Polisy.
This is something I'm particularly interested in - if it were really true that this update is all good stuff, why didn't UDI make it possible to automatically update from 5.9.x? What's the reason for needing to do a manual update? I saw mention of Polisy running on slower hardware and therefore 6.x.x might seem sluggish, is this true? If so, has anyone who has done the update noticed? Is it "minor annoyance" sluggish or "almost unusable"?
@Javi Is the issue mentioned above (ID: /udi-tasks/issues/12) something that we can view, or is it internal to UDI?
I've got a Polisy running IoX 5.9.1 (FreeBSD 14.1-RELEASE-p6). It's got maybe 50 programs and 50 devices. I'm seeing lots of posts about 6.x.x versions, and that they're primarily meant for eisy products, but also that a Polisy update is "possible". I'm wondering if it's worth it to update. Honestly my system is running fine, but it would be nice to get rid of the Java interface. Aside from that, I'm wondering what other benefits 6.x.x would give me -- and, what other possible hiccups I could encounter with a newer version.
I had always assumed that Scene control was meant to be peer-to-peer (for example, ZWave devices both using basic association 2 to talk to each other) - this would imply that you can't do scene control between different technologies, such as Insteon <-> ZWave, since they don't speak the same language.
Do all If values need to be state variables?
I've got a simple program looking at some values to trigger the Then, but it's not triggering: If $ShadeLowerDesiredHour is $Hour And $ShadeLowerDesiredMin is $Minute And $AnybodyHome is 0 Then...All values on the first two lines are Integer variables, and $AnybodyHome is a State variable. I can watch the values as the desired time approaches, and they do match at the appropriate time - but nothing happens. Is the fact that the first two lines don't include State variables causing the program to never evaluate as true?
New version just downloaded on iOS Sync errors
I think I just ran into the same problem - at home on wifi, did a sync. Half of my favorites disappeared and if I go to devices under the Home tab it will show the devices but I can't control them. Do I need to drop wifi and re-sync using cellular? UD Mobile 4.4.25, IoX 5.9.1 Update... Rebooted controller, turned off wifi, and synchronized. Favorites are still missing but I regained control over my devices.
Looking for an elegant way to self-latch a program
I'm trying to use a short event pulse to trigger a program and self-latch it so that the Then condition will keep running for several seconds (the Then events have a series of Wait statements that cause it to take this long). I assume the IF condition needs to remain true for this entire duration to allow all of the Then commands to run, so I'm looking for a simple and elegant way to have the IF remain true until all the Then events have completed. I tried adding an "OR Program is True" to the IF and a "Stop program" as the last Then command, but I think the IF program condition remains true forever. I need the IF conditions to go false at the end so the program can be re-triggered in the future. I'm sure I'm not the only one to come across this scenario, any ideas?
Issue using Zooz ZEN17 to monitor power status
I have a Zen17 and use it to monitor a N/C contact in a rain sensor, never had any issues over several years now. I don't recall if I changed any config parameters, but I definitely did not exclude/include the device - maybe just did an Interview after? Anyway, not sure what's going on with yours, but is it possible to get back to square 1 and start over (factory reset)?
Zwave forced rebuild of Neighbors table?
@hart2hart I've got some follow up questions - you mentioned "I had to run it many times to get mine sorted", can you expand on this? What made you discover that you had to do this multiple times? What were your metrics for success? Did you have some specific performance issues that you were trying to correct? How did you measure or check that each Heal process was making an improvement or change? I followed my process by watching the Level 3 event viewer, but you can also see each device's link table in the X-Ray viewer (although keeping track of these tables for all devices can get very cumbersome). Did you have cases where the Heal process just didn't work for specific devices, and if so, how did you fix those? Sorry to pester with so many questions, thanks for any help you can provide!
Time change
Remember, the time officially changes at 2am, so any sunrise/sunset calculations made at midnight (if this is how the controller works) will be off by an hour that day. Not trying to excuse this behavior, just pointing out one possibility. I'm also in the camp of "this has been going on for years, why can't the controller take it into account?".
Zooz ZEN55
Zooz ZEN55
Yes it pairs no problem. I have hardwired and interconnected First Alert smoke and CO detectors in my house, and the ZEN55 outputs signals for both types of alarm.
Zooz ZEN55
Yes I have one, it works very well. Any specific questions?
Looking for help troubleshooting ZWave responses
I've got three switches acting as a 4-way switch, linked in a scene using basic association 2. I'm noticing some strange responses in the event viewer when using Polisy to turn the scene on or off. When I turn the scene off, what I'm seeing below is that three Turn Off commands go out to the switches (first three lines transmit, next three lines transmit done), then two of the switches respond with a D2D EVENT status=0 (switches turning off) and then the second switch also responds with D2D-CMP responses. The third switch never responds, which is what led me to look at the logs (probably a different issue). I'm wondering why the responses differ, these three switches are all the same Zooz Zen71 On/Off switches and are all running the latest 3.70 firmware. I have also confirmed their configuration parameters match, with the only non-default parameter being parameter 7 set to 1. Wed 02/11/2026 10:31:55 AM : [ZW-TX-A 00017 33.0 ] [ZY033_1] Binary Switch Set val=0 duration=255 Wed 02/11/2026 10:31:55 AM : [ZW-TX-A 00018 34.0 ] [ZY034_1] Binary Switch Set val=0 duration=255 Wed 02/11/2026 10:31:55 AM : [ZW-TX-A 00019 19.0 ] [ZY019_1] Binary Switch Set val=0 duration=255 Wed 02/11/2026 10:31:55 AM : [ZW-DONE 00017 33.0 ] [ZY033_1] Binary Switch Set val=0 duration=255 Wed 02/11/2026 10:31:55 AM : [ZW-DONE 00018 34.0 ] [ZY034_1] Binary Switch Set val=0 duration=255 Wed 02/11/2026 10:31:55 AM : [ZW-DONE 00019 19.0 ] [ZY019_1] Binary Switch Set val=0 duration=255 Wed 02/11/2026 10:31:55 AM : [D2D EVENT ] Event [ZY019_1] [ST] [0] uom=78 prec=0 Wed 02/11/2026 10:31:55 AM : [ZY019_1 ] ST 0 (uom=78 prec=0) Wed 02/11/2026 10:31:55 AM : [D2D EVENT ] Event [ZY033_1] [ST] [0] uom=78 prec=0 Wed 02/11/2026 10:31:55 AM : [ZY033_1 ] ST 0 (uom=78 prec=0) Wed 02/11/2026 10:31:55 AM : [D2D-CMP 0030] STS [ZY033_1] ST op=1 Event(val=0 uom=78 prec=0) is Condition(val=100 uom=78 prec=0) --> false Wed 02/11/2026 10:31:55 AM : [D2D-CMP 0006] STS [ZY033_1] ST op=1 Event(val=0 uom=78 prec=0) is Condition(val=100 uom=78 prec=0) --> false
IOX6 for Polisy?
I know IOS 6 came out a month or two ago and was waiting for others to be the guinea pigs before upgrading, but since then haven't heard much about it. I'm running Polisy 5.9.1 and am wondering if it's worth it (and safe) to upgrade to 6.0?
