Everything posted by AlexE
Writing energy monitor output to csv file
Yes, this works. Writes the actual values into the spreadsheet. Thanks!
<nodeInfo> <node flag="0" nodeDefId="ZY014_143"> <address>ZY014_143</address> <name>ZY 014 Energy Meter</name> <family>12</family> <parent type="3">36911</parent> <type>4.16.1.0</type> <enabled>true</enabled> <deviceClass>0</deviceClass> <wattage>0</wattage> <dcPeriod>0</dcPeriod> <startDelay>0</startDelay> <endDelay>0</endDelay> <pnode>ZY014_1</pnode> <rpnode>ZY014_1</rpnode> <sgid>143</sgid> <custom flags="128" val1="0"/> <devtype> <gen>4.16.1</gen> <mfg>634.257.13</mfg> <cat>143</cat> </devtype> </node> <properties> <property id="CC" value="0" formatted="0.000 Amps" uom="1" prec="3"/> <property id="CPW" value="0" formatted="0.000 Watts" uom="73" prec="3"/> <property id="CV" value="124871" formatted="124.871 Volts" uom="72" prec="3"/> <property id="TPW" value="4988" formatted="4.988 kWh" uom="33" prec="3"/> </properties> </nodeInfo> That's the output using the web browser That would mean ${sys.node.ZY014_143_33_3.tpw}, ${sys.node.ZY014_143_72_3.cv} should work? Still only writes node[ZY014_143_33_3] node[ZY014_143_72_3] into the csv file. Thanks again
ok - bracket was wrong: ${sys.date},${sys.time},${sys.node.ZY014_143_33_3.ST} now it writes: node[ZY014_143_33_3]
I got it to write a csv file but I am struggling with writing the actual value for the file for the power. so my custom notification reads: ${sys.date},${sys.time},$(sys.node.ZY014_143_33_3.ST} it outputs day and time correctly but the actual energy output just reads : "$(sys.node.ZY014_143_33_3.ST}" I guess I am missing somehting? Thanks
This is exactly what I was looking for, Thanks. would be great if those charts could be put back to the wiki archives.
I was wondering whether it is possible to write the query results from an esiy program to a csv file (or similar). I have several zooz plug with energy monitor and do not really need a sophisticated online solution, but a rather a simple data dump into a spreadsheet of some sorts. I was browsing the forum etc but could not really find an answer whether this is possible? Thanks for any help in advance
ZEN15 not adding Energy Meter - eisy 5.5.9
not really - it's in a quite central open spot - I added the other devices from the same original location before moving and it worked. My guess it's that ZEN15.
Thanks a lot - I moved the plug a little closed to the eisy (it was pretty close already anyway - just moved it 6ft) but that did the trick. Could have tried that earlier .... Thanks again!
Yes I did - I am not sure whether Synchronize with interview actually does anything - is there supposed to be some progress feedback? Thanks for helping.
Before upgrading to IoX 5.5.9 I successfully added two ZOOZ ZEN15 plugs with energy meter to my eisy. I was trying to add another one today and the Energy Meter is missing. I tried several times with the same result. I could add it to my polisy which does not have z-matter enabled and the energy meter shows up so I assume the device is ok. I was wondering whether I am the only one encountering this issue? Thanks
Polisy PG3 Migration - IoX Version Query
I am running IoX v.5.5.2 with pg3 3.0.16 on my polisy and it works as is did before upgrading from IoX v.5.4.5. The upgrade was not necessarily intentionally just did a 'Upgrade Packages' apparently about the same time when it was posted. Not sure I would do it again after seeing how the eisy upgrade went (see below). pg3 seems to work as before. I received my eisy a few days back and this seems to be a very different story. Same versions, but pg3 does only connect intermittently (mostly not) - as you mentioned it looks like eisy PG3 is not ready. All the insteon connections together with the usb PLM work fine. I don't have any z-wave devices so I can't tell.
pg3 missing directory
http://<eisy.ip.ad.here>:3000 was what resulted in the described error. Uninstalling / Reinstalling pg3 via the terminal and a eisy restart fixed the access issues. I still have problems with the node servers, but it seems a lot of other users report similar issues, so being patient will probably solve a lot of issues over time. Thanks for checking -
I have everything running on my eisy except pg3. When I go to the web interface I get the following error: ENOENT: no such file or directory, stat '/var/polyglot/node_modules/@universaldevices/pg3x/public/index.html' As far as I can tell pg3 is installed and running.
Help! Cannot get the IoX Launcher to start
Thanks that's what I thought. Had done all the java cache cleaning and also installed the launcher on a different PC. I would assume that this this is not only me since I just downloaded the launcher from the UD page.
AC 5.5.1 / FW 5.5.0 ?
Not exactly the same problem but also IoX launcher related. Just got my eisy hooked it up and downloaded the latest launcher. If I request firmware update nothing is happening.
ISY 5.1.1 Is Now Available
Never mind found it sudo pkg update && sudo pkg upgradecat /usr/local/etc/udx.d/static/update13.sh | sudo bashsudo shutdown -r now
I am stuck when upgrading my polisy to V13 [admin@polisy ~]$ sudo pkg update && sudo pkg upgrade Updating FreeBSD-base repository catalogue... FreeBSD-base repository is up to date. Updating udi repository catalogue... udi repository is up to date. All repositories are up to date. Updating FreeBSD-base repository catalogue... FreeBSD-base repository is up to date. Updating udi repository catalogue... udi repository is up to date. All repositories are up to date. Checking for upgrades (0 candidates): 100% Processing candidates (0 candidates): 100% Checking integrity... done (0 conflicting) Your packages are up to date. [admin@polisy ~]$ uname -a FreeBSD polisy 12.2-RELEASE-p6 FreeBSD 12.2-RELEASE-p6 r369564 POLISY amd64 [admin@polisy ~]$ I am pretty sure I am missing something Thanks is advance
