fasttimes
Everything posted by fasttimes
  1. I replaced a couple of switches and want to swap the links out with the admin tool. But now my windows won’t launch internet explorer. How am I supposed to run jnlp downloads?
  2. As an Insteon user, this limit sounds really low. It sounds odd you can’t group more than 5 switches together. Do you know if you can “chain” devices? If you have two groups: ABCX XYZ And you press Z, will that fire off ABC?
  3. Does anyone know if there is a protocol defined limit to the number of devices in a group? I hear it’s 5, but I haven’t found any documentation on this.
  4. I’m really frustrated about this too. I’ve spent thousands of dollars and many hours on Insteon devices and all I want is a reasonable price for buying in quantity.
  5. My dad lost his password to login to his ISY locally (via browser/ip address). However his ISY is on the portal. Is there a way he can reset his username/password with the portal instead of using Telnet and the MAC address method?
  6. Could you point me to any documentation on this?
  7. With lock management and scheduling?
  8. With lock management and scheduling?
  9. They implemented Zwave lock support?
  10. Have you by any chance ever used Home Assistant? Set it up up a small Zwave Network and you can do things with the Schlage lock you couldn’t imagine were possible. With the following integration installed, you can setup up to 30 users, such as your family, housekeeping, pet sitters, etc. All using date/time access schemes and programmable from a web UI. You will never have to use the Schlage programming scheme again. Keymaster Integration
  11. I just logged into my folks ISY, and there are only a couple of sensors showing. Is there a way to "load" the existing network from the current insteon devices?
  12. @Michel Kohanim Is it your intention that the ISY will be eventually replaced by Polisy? Would that not require adding PLM support? I can only imagine the hell it must be to produce a hardware product. Is there something special about this new product that couldn’t be replicated on an existing hardware platform? With container systems like docker, it would be fairly easy to have your code run on many platforms. Licensing shouldn’t be a problem either. In fact, I’d rather UD spend their time on developing kick *** software instead of hardware. I tell people they buy an ISY not for the box, but for what goes in the box. I don’t even really need the ISY Portal anymore, but I keep renewing just as a “thank you” for the constant software updates.
  13. This sensor looks like it does a lot of stuff. Unfortunately I can’t figure out how to do something really simple. I just want the sensor to report ON after motion is detected and report OFF after no more motion is detected for 300 seconds. In in other words the sensor reports ON and stays on while any motion occurs, and there must be 300 seconds of no motion for it to turn off. Does anyone know how to make this happen? Is a higher number for sensitivity more or less sensitive?
  14. @Michel Kohanim, if you’re talking about the ISY Component, that is what is painfully slow. I’m not the only person with this issue. In fact it seems to be the norm rather than the exception.
  15. Is there a way to tell or sure without guessing?
  16. fasttimes posted a topic in ISY994
    I suspect my woes are due to my PLM. Those things are notorious. Every time I have one die, I end up ordering the wrong thing. What do I need to get that works with the ISY994?
  17. I’ve a feeling my PLM has gone tango uniform. It’s just so slow, even in the ISY admin. I should have never done that PLM restore yesterday. Nothing works now.
  18. You hit the nail on the head. The ISY component is super slow. I’ll see what the debug logs say. I know I always get those “took over 10 seconds to load ISY”
  19. I’m not sure you understand me, or I understand you. What I’d like to do is be able to link Home Assistant to the ISY Portal, not the ISY directly so anything exposed by the portal can be sucked into HA. For some reason controlling devices from HA to the ISY directly is really slow. Google/Alexa is fast.
  20. I’d like to expose devices defined on the ISY Portal to my instance of Home Assistant. Would this be difficult to implement?
  21. I’ve had a couple switches die on me. Not too important, but I’d like to replace them. And I definitely don’t want to pay full price. Does smarthome or anyone else have any sales that you expect coming soon?
  22. You should be able to have both installed
  23. Once I figured out how to get the ISY to recognize the door opener (I guessed and added the node manually) it was surprisingly easy to do. I created 2 programs in the ISY, one for OpenGarage and CloseGarage. I’m fairly certain the “if” conditions are NOT necessary, but I didn’t want to issue an “Open” command to a garage that is already open or in the process of opening. I also wanted the ability to make a door that was stopped half way (open or closed, depending if you’re an optimist or pessimist I suppose) would respond to the command correctly. OpenGarage: If Garage IsNot Open AND Garage IsNot Opening then Set Garage = Open CloseGarage: If Garage IsNot Closed AND Garage IsNot Closing then Set Garage = Close I then wrote a program called: GarageAlarm: If Garage IsNot Closed then Wait 15 minutes Send email/SMS Works perfectly.
  24. I got my RPI today, so before I get started, what will I need to do on the ISY (besides upgrading to 5) in order to do the following: Hey Google, open the garage (which only opens if it is closed) Hey Google, close the garage (which only closes if it is not closed, eg it’s stuck halfway open) Get an email/SMS if the garage has been opened for 15 minutes? i assume I have to write a series of programs?
  25. Chamberlain won’t allow their doors to be opened with IFTTT becuase of “security”, yet they will with their lame app. I just want to open my garage doors with an arm full of trash. I take it the MyQ and Polygot solution allows you to do so without any new hardware? MyQ reports the door opened and time status, which is available?
