Joe Casullo
Everything posted by Joe Casullo
  1. Never mind, it working now. I read the instructions more carefully and I didn't reinstall the node server after the Update Packages. Cheers,
  2. I have the a disconnected status too. I just installed the trial version, 2.0.17 and performed an update packages, so I am at PG3x Version 3.4.19. I have tried a few things to resolve this issue but I am stumped, can you assist with troubleshooting. I have attached the log package. Thank you in advance. HomeKitHub_7-25-2026_80606_AM.zip
  3. Thank you everyone, I didn't know there was a Java installation for Apple silicon. I have installed it and I'm good to go.
  4. No, it's not an older Intel Mac, I have an Apple silicon M1 Pro. I am getting the same message for other apps too, Apple will stop supporting any app that was designed for the Intel Mac, the apps currently work because Apple translates them with their Rosetta app. I don't know when this will happen, all I want is to be able to create and modify programs without Java, so I'm hoping the IOX web app will do this soon. Joe
  5. I got a message today on my Apple MacBook Pro stating that Apple will not support Intel based programs on the next OS upgrade, I guess the Java IoX Admin console will stop working at that point. Will the eisy-ui be ready to take over from Java when Apple's support ends? Currently the eisy-ui does not create or modify programs. An update on the eisy-ui status would be appreciated. Thanks, Joe
  6. Thanks guys for your responses. I tried factory reseting the device and re-including it, this worked but when I closed the admin console and reopened it the green IOIO icons were back. JSchumann - I don't think it's the PLM failing because the affected device is Zwave. I always have trouble with battery operated devices, something always goes wrong during the inclusion process. I've taken a break from it for now because the device seems to work fine. Cheers,
  7. Thank you very much for the explanation and quick response, I will keep trying to resolve the issue.
  8. I have been waking the devices. What does the green icon mean, is it that the EISY has not received the full data from the device?
  9. I have a few wireless Zwave devices that show the green IOIO icons, I have tried Zwave rewrite and “write changes” many times and nothing has worked to remove the icons. Does anyone know how to fix this?
  10. I was on firmware 5.8.0 and upgraded to 5.8.3 and my UD Mobile is at 1.1.64. Nothing changed, my favourites do not update and I cannot connect to the Admin/ Plugins (BETA) to see the Node Servers, I get the following error (see attached image). Thank you.
  11. Sorry, I should have mentioned that I use an iPhone. I've also noticed that when I am on my local WiFi only the first in the list of Local Networks works. The other WiFi networks in the list are on the same VLAN and therefore my iPhone has the same IP address. Only the ELK node server does not respond when on these other WiFi networks. Thanks,
  12. When I am away from home and therefore connected via the cloud, ELK nodes do not update on my favourites screen nor can I connect to the PG3 node server on the Plugins (BETA). Anyone else having the same issues?
  13. Thank you for the information, I guess I'll be making more programs.
  14. I unplugged one of my Aeotec Z-Wave power plugs and I didn't get an alert on the Admin console. It's been unplugged for days. With Insteon power plugs, I would get an alert if they were unplugged. Does this mean I have to run a program to monitor the status of all the Z-Wave devices? Does anyone know how to be alerted for unresponsive, always awake modules? Thanks, Joe
  15. I monitor the online status of this node server with a program and the node server briefly goes offline a few times a day. Here are a couple of errors I say in the log that coincides with the offline. 2023-08-22 16:51:20,218 Thread-1613 udi_interface ERROR station:Query: Parsing failed: string indices must be integers 2023-08-22 16:51:20,218 Thread-1613 udi_interface INFO station:setState: ecfabc15d6 status set to 0 2023-08-22 16:51:20,218 Thread-1613 udi_interface INFO station:setState: 8caab5c78f status set to 0 2023-08-22 16:51:20,340 MQTT udi_interface.interface INFO interface:_message: Successfully set 8caab5c78f :: ST to 0 UOM 2 2023-08-22 16:51:35,473 MQTT udi_interface.interface INFO interface:_message: Successfully set ecfabc15d6 :: ST to 0 UOM 2 2023-08-22 16:29:19,882 Thread-1588 udi_interface ERROR station:Query: Parsing failed: string indices must be integers 2023-08-22 16:29:19,882 Thread-1588 udi_interface INFO station:setState: ecfabc15d6 status set to 0 2023-08-22 16:29:19,882 Thread-1588 udi_interface INFO station:setState: 8caab5c78f status set to 0 2023-08-22 16:29:20,005 MQTT udi_interface.interface INFO interface:_message: Successfully set 8caab5c78f :: ST to 0 UOM 2 2023-08-22 16:29:35,025 MQTT udi_interface.interface INFO interface:_message: Successfully set ecfabc15d6 :: ST to 0 UOM 2 Any idea what's causing these parsing errors? Thank you in advance.
  16. Correct, my program was looking for a logical status change, normal or violated, so I changed it to look for a Control ON and now it works. Thank you, Jimbo.
  17. I have two zones with physical contacts, when they change state to Violated (open contacts) the Elk Node Server "Send On For" sends a signal and I trigger a program. But when they change state to Normal (closed contacts) the Elk Node Server "Send Off For" sends a signal even though I have the "Send Off For" set to None. I have tried different configurations, but "Send Off For" set to none always sends a signal. Is anyone else experiencing this symptom or is it a bug? Thanks in advance.
  18. Thank you for the info, I'll wait for a response from the team.
  19. I was able perform the inclusion process for this sensor but it remains in the write updates mode, it has the green 101010 icon next to it. I cannot query it or read configuration parameters. I've excluded and included a few time but not change. I appreciate any help with this issue. Thank you.
  20. I stopped using Elk lights a long time ago, probably when I got my first ISY.
  21. I would like to use the Clip command and play an MP3 file as per the jishi API documentation. The documentation says the MP3 files should be stored in the static/clips folder, do we have access to this folder? I did ssh into the EISY and could not find any folders for this node server. I used to use the jishi API on another server and it worked great for presets etc. I would like to do the same with the node server. Thanks
  22. Fixed the HDMI issue, I opened a ticked and Michel said I needed a BIOS update. Did the BIOS update and now my HDMI ports work and I can get the the desktop. Thanks all.
  23. I opened a ticket and they said I just need a BIOS update, I’ll let you know.
  24. I guess there is no solution to this problem and I say the HDMI hardware is defective. I will open a service ticket and go from there. Thanks for all the help.
