mbrett
Everything posted by mbrett
  1. I have had the exact same problem with my temp linc's I beleive it is a software glitch in the thermostat hardware and had nothing to do with being hacked.
  2. mbrett replied to garybixler's topic in ISY994
    theubi, actually maybe I was not clear in the above post, but the above commands ARE WORKING. I am not sure what changed, but it does issue the commands and the devices successfully turn on and off. Michael
  3. mbrett replied to garybixler's topic in ISY994
    The format is the exact same, the only difference is you replace the Insteon ID with the scene number, which you can find in the ISY admin panel. You can find the ID # at the top of the screen below the scene name. scene id : 1411 replace /B 21 BC 1/ with /1411/ commands you can find in the wiki for rest: http://wiki.universal-devices.com/index ... _Interface make sure you use the correct on/off commands for each device. I had issues at first trying to use /CMD/DON (device on) when I should have been using /CMD/DFON (device fast on). my recommendation is to initially test all devices with the /DFON since they all accept it, and not all devices will respond to the /DON. one last thing. be sure to issue all commands in capital letters, I found that made a difference as well. I have not messed with dimming or thermostats yet, thats next.
  4. mbrett replied to garybixler's topic in ISY994
    Hi Guys, Over the past few days I was working with Leor from UBI to figure out why the Rest commands were not working correctly. Bottom line is Leor was extremely accommodating and helpful, below is the URL to send as a "Get" command. username: michael pass: smellydog website: ihatecats.com ISY Port: 8082 Insteon ID: 0B.21.BC 1 notice the "1" after the ID, you must have it. Format: http://username:pass@yourwebsite.com:Po ... es/insteon address/cmd/DFON Http://michael:smellydog@ihatecats.com: ... st/nodes/B 21 BC 1/cmd/DFON Hopefully this will help.
  5. Looks right except put the "mode heat" line above the set temperatures line
  6. How about using an ezio sprinkler module, it allows you to control 8 separate zones, each zone represents an led on your board. The other thing is you can try "growl" to send push notifications, just not sure if there is an app that allows the notifications to be added to a list. Might be an easier option on an android tablet as opposed to an Idevice.
  7. mbrett replied to mbrett's topic in ISY994
    Okay never mind I just came across a few topics. I am always late to the party Sent from my iPad using Tapatalk HD
  8. mbrett replied to mbrett's topic in ISY994
    Sorry guys I forgot the links http://myube.co/ http://theubi.com/ Sent from my iPad using Tapatalk HD
  9. mbrett posted a topic in ISY994
    I have been spending a lot of time on kickstarter.com and came across the following 2 gadgets. Curious if anyone else has seen them or has any thoughts. Ubi is a tiny self contained computer that seems to have some pretty cool features built in (hopefully at release will) and with an open API this might solve or offer a good solution to bringing a voice to ISY. Not only for output but for input as well. It seems to have an always open mic that listens for its name to be called and then executes the following statement. It also has motion, light, temperature and sound sensors built in so it can provide a lot of feedback as well. I purchased 2 UBIs and emailed the company as well to find out their automation thoughts if any. UBE is a different set of devices from another company the offers dimmers and other devices. They are "Lutron" style dimmers that use wifi to communicate with each other . Some of the cool features are: Motion sensors built into the switch, they backlight the switch when someone approaches, I would imagine they could also be accessed to use for security feedback as well. Provide energy consumption of each device being controlled Since the switches use a capacitive touchscreen they can be programmed for multi gesture. 1finger dim single, 2 finger dim group,etc They are also developing other solutions as well, appliance style plugin as well as an outlet to replace existing ones. This company also makes the API available for free. I checked the forums and didn't see these devices mentioned anywhere else, if this has already been covered somewhere else, sorry... Both devices look pretty cool and I hope can be integrated into ISY. Thoughts.... Sent from my iPad using Tapatalk HD
  10. mbrett posted a topic in ISY994
    Hi All, I have seen a few posts about linking the SHN EZIO6i, and the issues people were having. I do not see a definitive answer on weather it works or not or how to link it. Can someone tell me if it is possible or not and how to do it. I have tried entering the address directly while selecting the EZIO6 from the drop down device list, I have also tried the button linking method and neiter work for me. I am using ISY99 3.1.1 thanks
  11. Okay so maybe after reading this post I might be able to now figure out why I am having issues. when I load the ISY web interface, and I view any of my 4 Venstar Thermos, the version that appears is 2441v.. v.91 can anyone tell me what I should or shouldn't expect from this version of the software? what is the current version, and how do I get it?
  12. Hi, Had anyone had anyluck adding them to the ISY device.. I cant seem to get them to recognize eachother. any tips?
  13. sent earlier.. please confirm
  14. there are not any other names I would have purchased under, and google history confirms the same, that I only had one order with you.. if I had another google account I have long forgotten it.. is there a way you can check from my ISY id?
  15. Hey Michael. okay very strange... I remember buying the modules.. and they show installed, however I cannot find the google receipt.. nor can I repurchase the modules.. I can send you screen shots if you would like.. what to do?
  16. HEy Michael, thanks for the reply.. So I have up0graded to ver 2.7.12.. I have also confirmed that I have accessed my ISY from the correct links (which I have always have) I used both the /admin and /admin.jnlp and nothing has changed.. I still dont have the above mentioned tabs visible on my device.. is there anyway to force an update of these.. If I click on the manage modules I get a box stateing that all of my modules are up to date.. This is very frustrating.
  17. I Have some images I would like to attach showing what I see... cant figure out how to do it... can someone help... boy I feel totally inept. but bottom line I have a 99i (1020) v 2.7.10 I currently own weather bug, netwrok, upgrade pro.. none of which appear on my tabs... the only tabs I have are system, notifications, electricy... sorry I was not more detailed before I was reply from my BB.. wife and mom (2 seperate people, I dont live in Arkansas) had me at a street fair.. I was looking for the "shoot me in the head booth" MB [/img]
  18. The only tabs I have are email, electicity programs devices... No ir (would be nice) and no climate..
  19. I have checked all of the tabs in the interface and I only have the energy tab, I do not have any weatherbug tabs nothing even close to it.. Is there away to reinstall it?
  20. HI Guys, O purchased the weatherbug module and I cant find where to configure it or how to use it.. When I goto the manage modules under help, it says they are all uptodae. When I click on the purchase modules under help, it takes me to a web screen that says weather bug was purchase on ...... however I cant see it anywhere in the program..
  21. It has been 3 days and the chatter has not stopped.. Is there anyway I can check a log or somethign to see what is actually causing the leds on the insteon devices to flash?
  22. HI All, I have been using ISY for over a year with almost no issues, not that I think this is an ISY issue I think it is an insteon issue. yesterday without any ideas of what could be causing this, I started noticing that the lights on my Insteon devices started flashing very rappidly like there was a ton of communication happening. I Have over 80 devices, and I am not sure where to start the trouble shooting, I have rebooted the ISY to no avail, I can log into ISY, I have rebooted Homeseer I have checked the Home seer logs and dont see anything out of the ordnary... Some of the switched that are linked to each other will respond after like a 10-15 second delay... Can someone please help..
  23. I tired your settings and they worked great... when I try Mine they dont... Can I use your email account
  24. Hi All, after a little more testing (playing), I have noticed that the email feature in the admin panel is not sending out emails for me. I am getting a [-50001 mail server failure[password not accepted]], however I know for a fact that it is the correct password. I am using a Verison Fios Connection and have tried the default port as well as 80 for the SMTP ports. MB
  25. Hey Guys, I just wanted to say, that at first I was trying to update my ISY to 2.7.8 via wifi, and it kept crashing, so then I decided to follow the warning about only updating via wired network, and guess what, it worked.. I have now successfully upgraded to 2.7.8 and relinked 5 ver thermostats and it works great within the ISY admin panel. I also upgraded to the new ISY-HS plugin from the HS forums, and all seems to be going perfect... thanks for including me in the Alpha and I will post my results as they arise...
