capsterx
  1. capsterx posted a topic in ISY994
    Few questions 1) For the load ON/OFF buttons for the 6 button KPL configuration, is the a difference between "toggle on" and "toggle off". They both cause the off button to not be light up when it's off, which I want, just wondering if toggle on vs toggle off did anything differently. 2) I've read (in a few places on this forum/faq) that a secondary button cannot turn off the load with an ON scene command. I tested this and it seem to work (button D set to always toggle on, with the 'main' button in the scene and it set to goto 0%). Is this something that works now or did I misread understand? 3) I assume I cannot have a ON scene turn the button for itself off? (be a responder for the scene when it's controlling it I guess) Thanks.
  2. Add both the device 'module for an end table light' and 'module for an end table light linked button.' Give them some voice command you wont use. In smart home skills add a Group, put them both in the group and name it what you want to say to control it. Use the group command to control both devices (or more).
  3. I know there are other topic on this, but I wanted to share what I had discovered. 1) Dimming/Brighten from the ISY console does not issue the same commands as 'Echo dim <scene>' The console seems to use 'LTMCON (UP)' or 'LTMCON (DOWN)' followed by 'LTMCOFF' I assume this is the same as <begin hold dimmer>/<finish hold dimmer> Echo via the portal uses LTDIM 3x or LTBRITE 3x 2) ISY, Switchlinc and Keypad don't always agree on how much things were increased/decreased by. Setup A: 2 switchlinc dimmers v.37, 1 6 button Keypadlinc Dimmer v.41 Setup B: 1 switchlinc dimmer v.37, 1 8 button keypadlinc dimmer v.37 When using the console: Scene A: ISY and the 2 switches tend to agree pretty closely, the switches themselves seem to agree all the time. The keypadlinc very much disagrees. Scene B: None of them really agree. 2 Brightens/Dim from console gives ~16% each time. If you query the scene, they are quite out of sync. Now since the console uses fadeup/cancel fade semantics, I assumed it was just a timing issue. Now, this is much more reproducible then above, seems to be pretty reliable. When using Echo Portal (3x dim/brighten): Off -> 1 brighten command Scene A: Isy thinks both switches and keypad at 9%. Query all. Both switches are at 10%. Keypad at 9%. Scene B: Isy thinks both switch and keypad at 9%. Query both. Switch 10%. Keypad 19%. I assume some of this may be to the version of hardware of my switchlincs or keypadlincs. I know my keypadlincs are pretty old and dont respond to all the commands I'd like to use with them (have to have programs work around some of it) Method 1: Now for the solutions I have used. As someone else said in another post, you can add all devices for a scene as a spoken command you wont use, then group them all together as the spoken word you will use. Basically re-do the scene as individual devices and the group is the same as the scene. Kinda suboptimal as the scene device list is duplicated in 2 places, but easy and quick to setup. Though when I have had to make changes and 'forget all devices' due to structure changes, I have had to redo the groups. Method 2: (the more complex method and might not be useful to anyone...but this is what I did) This is pretty much the same as Method 1, except on/off uses a scene command. Where as Dim/Brighten/Set use individual commands. This was more of a 'can I make this work' project. I figured I could write a custom alexa shim to do what I wanted. My first thought was to have a program folder like: "MyVirtualDeviceFolder" where it had programs of dimup, dimdown, setdim, turnon, turnoff (could even have the temp settings). While it looks like this might be doable in v5, I couldn't find a way in v4 programming to set dim of device based on variable. If I could set scene based on variable, this would be a great future feature for the isy portal and opens up a simple way of letting someone do whatever they wanted with scenes or devices or whatever. I'm using 4, so I dropped this idea. I wanted to be able to OAuth to the isy portal and then issue direct commands to isy, but I could not find any posts on how to do it. If anyone knows how, let me know. For now I used user/password auth to the ISY portal -> ISY url. While I coded this to work with the isy portal, pretty sure it should work directly with ISY without a portal if your ISY is exposed to the internet. This took me a while to get everything setup, but it my first time using any of the amazon web/lambda/etc services. I found the amazon documentation to be very lacking and/or scattered all around. I had to create 3 different amazon accounts and link them all in various ways just to get a test up and running that did nothing. It took me even longer to make echo -> cloud watch log. I'm still not sure what I did that allowed it to work. Here is my best memory of the steps I used, I may of forgotten a few. They are based on the instructions https://github.com/auchter/haaska and https://developer.amazon.com/public/solutions/alexa/alexa-skills-kit/docs/steps-to-create-a-smart-home-skill. 1) Create alexa developer account. Log into amazon developer porta, click Alexa on top menu, get started with Skill, create new Skill. give it a name and choose 'smart home skill' then save and copy 'App ID'. Ignore the rest of the configuration for now. 2) Create an AWS account, you will need a CC for this but shouldnt get charged for the amount. Log into AWS, select LAMBDA. Click functions, create new function. search for 'smart' and select the 'alexa-smart-home-skill-adapter' The template only exists for javascript, so dont change your language to search for. paste in your app ID that came from the alexa smart home skill, select enable trigger you may now change your code to python, which is what I did create a role from template and give it a name paste your code in (my code is at bottom of this post) next Now click 'functions' from the left hand side menu, select your function (via just the circle, if you click anywhere else it takes you to configuration) Goto actions and show ARN, you will need this later. 3) This step is only because smart home skills require OAuth to somewhere, I used amazon, I'd like to use isy portal in the future. goto login.amazon.com and create an account Goto 'App Console' then 'Register a new application' give it a name/desc/url (i used amazon.com for privacy url). Goto 'Web Settings' and then edit. Now flip back to Alexa developer portal, on your skill, on Configuration. Grab the URLs under 'Redirect URLs' You want to add these to the login settings under web settings/Allowed Return URLs 4) Fill out rest of configuration for your skill Goto Configuration of your Skill in Alexa portal Endpoint: Click North America (or wherever you are) and in the box enter your 'ARN' found from the lambda function. Authorization URL: https://www.amazon.com/ap/oa Client Id: From login.amazon.com Web Settings Domain: I left blank Scope: Add one with 'profile' (it demands at least one, this says give access to your email/name on amazon. We wont actually use this other than it requires it) Access Token URI: https://api.amazon.com/auth/o2/token Client Secret: from login.amazon.com Web Settings Privacy URL: some url, it requires it click save 5) Okie dokie, you can now add the skill to your Alexa app. I was unable to do this from the web page, I'm not sure why, but it worked from my phone app. The method is the same as adding ISY portal, goto smart home skills search for whatever you named it. You will need to auth it to amazon then you can 'discover devices' Now for the code I used. This is very hacky, first run something I did last night. It has a hash of 'scene name' to info. The info describes the 'master'. This would be the device that you are actually dimming (the switch hooked up to power). The code uses the scene info to get the rest of the nodes and stores it in discovery. Because of this, if you change the scene, for now, it would have to be rediscovered. The 'config' supports naming a scene more than one thing, but I didn't finish the code that would allow that. Each device needs a unique id, they are not generated as of now. Most of the stuff just was copied from their example. The code does the following: For on/off: scene on For dim/brighten: Grab the status of 'master' +/- the amount, set absolute For set: grab status of 'master' take X percent of 255, set absolute It sets the absolute by setting first the master to X (0-255) then setting all the 'slave' nodes to the same value. I'm sure there are much better ways, but this was fun for me to play around with. ------ snip snip---------------- import logging logger = logging.getLogger() logger.setLevel(logging.INFO) import urllib, urllib2, base64 import xml.etree.ElementTree as ET PORTAL_URL="https://my.isy.io/isy/BIG_LONG_HASH/rest" AUTH=('user@email.com', 'password') SCENES = { '<scene name>': { 'master': '<device that physically controls light>', 'names': ['Name to Name it'], 'device_info': { "applianceId":"uniqueID001", "manufacturerName":"yourManufacturerName", "modelName":"model 01", "version":"your software version number here.", "friendlyDescription":"Your name Here to show up in Alexa Smart Home", "isReachable":True, "actions": ["turnOn", "turnOff", "setPercentage", "incrementPercentage", "decrementPercentage"] } } } def lambda_handler(event, context): context.log_group_name = "/aws/lambda/handler" logger.info('got event{}'.format(event)) access_token = event['payload']['accessToken'] if event['header']['namespace'] == 'Alexa.ConnectedHome.Discovery': logger.info("discovery") return handleDiscovery(context, event) elif event['header']['namespace'] == 'Alexa.ConnectedHome.Control': logger.info('Control') return handleControl(context, event) def read_page(page): request = urllib2.Request(PORTAL_URL + page) base64string = base64.encodestring('%s:%s' % (AUTH[0], AUTH[1])).replace('\n', '') request.add_header("Authorization", "Basic %s" % base64string) result = urllib2.urlopen(request) text = result.read() root = ET.fromstring(text) return root def handleDiscovery(context, event): payload = '' header = { "namespace": "Alexa.ConnectedHome.Discovery", "name": "DiscoverAppliancesResponse", "payloadVersion": "2" } if event['header']['name'] == 'DiscoverAppliancesRequest': root = read_page('/nodes') appliances = [] for name, settings in SCENES.iteritems(): master_node = root.findall("./node/[name=%s]/pnode" % settings['master'])[0].text nodes = [x.text for x in root.findall("./group/[name=%s]/members" % name)[0] if x.text != master_node] scene_address = root.findall("./group/[name=%s]/address" % name)[0].text for name in settings['names']: appliance = { 'friendlyName': name, 'additionalApplianceDetails': { 'master_node': master_node, 'nodes': ','.join(nodes), 'scene_address': scene_address, } } appliance.update(settings['device_info']) appliances.append(appliance) payload = { "discoveredAppliances": appliances } context.log(payload) return { 'header': header, 'payload': payload } def setPercentage(details, amount): nodes = [details['master_node']] nodes.extend(details['nodes'].split(',')) for node in nodes: page = '/nodes/%s/cmd/DON/%d' % (urllib.pathname2url(node), amount) logger.info("Reading page: %s" % page) read_page(page) def handleControl(context, event): payload = {} device_id = event['payload']['appliance']['applianceId'] message_id = event['header']['messageId'] details = event['payload']['appliance']['additionalApplianceDetails'] if event['header']['name'] == 'TurnOnRequest': name="TurnOnConfirmation" read_page('/nodes/%s/cmd/DON' % details['scene_address']) elif event['header']['name'] == 'TurnOffRequest': name="TurnOffConfirmation" read_page('/nodes/%s/cmd/DOF' % details['scene_address']) elif event['header']['name'] == 'SetPercentageRequest': name="SetPercentageConfirmation" percent=event['payload']['percentageState']['value'] amount = int(255 * (percent / 100.0)) setPercentage(details, amount) elif event['header']['name'] == 'IncrementPercentageRequest': name="IncrementPercentageConfirmation" percent=event['payload']['deltaPercentage']['value'] data = read_page("/status/%s" % (urllib.pathname2url(details['master_node']))) current_amount = int(data.findall('./property')[0].attrib['value']) amount = min(255, current_amount + int(255 * (percent / 100.0))) setPercentage(details, amount) elif event['header']['name'] == 'DecrementPercentageRequest': name="DecrementPercentageConfirmation" percent=event['payload']['deltaPercentage']['value'] data = read_page("/status/%s" % (urllib.pathname2url(details['master_node']))) current_amount = int(data.findall('./property')[0].attrib['value']) amount = max(0, current_amount - int(255 * (percent / 100.0))) setPercentage(details, amount) else: return header = { "namespace":"Alexa.ConnectedHome.Control", "name":name, "payloadVersion":"2", "messageId": message_id } return { 'header': header, 'payload': payload }
  4. Interesting. My fix for ISY not knowing the correct fan state was to have a program issue a fan motor query on the fanlinc, which seems to work.
  5. Yes, it was added under 3.2.2. You were correct, I did set the value to medium/low/etc for both the scene and the button. However, while the buttons do what I expect them to, ISY still always shows the fan as off.
  6. I have a fanlinc v.41, 6 button dimmer kepadlinc v.40. I set buttons A-D to toggle on. I created 4 scenes, fan off/low/med/high, with A,B,C,D as controller and fan as responder with the scene setting of off/low/med/high. Now, all buttons A-D put the fan to high and isy always sets the fanlinc status to off when any buttons is pressed (which i then have to tell isy to query the device so it can figure out the fanlinc is actually on). I've worked around this by removing the scenes and just using programs to set the status to high/medium/low/off, but this seems sub-optimal.
  7. It installed fine from my windows machine, my mac timed out with socket error each time.
  8. capsterx posted a topic in ISY994
    I was able to set dim resume on my switchlinc by hitting off and then set, but I did not see an option in isy to set it, and when I change settings it seems to undo dim resume. Also, is there anyway to have a virtual 3-way setup that uses dim resume the same on all the lights?
  9. Both the isy and the switch in question are on the same circuit. I do also have access points on both phases (one attached to the same circuit as isy, the other on the other phase).
  10. I just got a isy 99i pro/ir. I have been seeing a repeated issue with using the ir toggle programs. I hit the button on the remote, isy sees it, executes the correct program, changes it's internal status correctly, but the switch does not change. I have not seen this issue with keypads or 3-way switches working in scenes (everything is same-phase, I don't have any isteon yet on the 2nd pannel). here is a more concrete example: So, I have a SwitchLinc Relay v.35 hooked up to my den fan. Then I have program 1: If IR 'fan ir' is Pressed And Status 'den fan' is Off Then Set Scene 'den fan' On Else - No Actions - (To add one, press 'Action') and program 2: If IR 'fan ir' is Pressed And Status 'den fan' is On Then Set Scene 'den fan' Off Else - No Actions - (To add one, press 'Action') Sometimes when the light is on, I press it, isy thinks it goes off, the light stays on. The reverse being true if the light is off. When Set Scene is called, does it wait for the ack from the plm or the ack back from 'den fan'? Is there a log of all the events in order, so I can see "IR received, executed program X, sent insteon command, received ack from plm, received ack from 'den fan', setting 'den fan' to on 100%" The tools/log shows some of this, but enough detail for me to understand where the issue might be. My thought also might be to add a query after the on, and then execute another program to set it on again if the status is still off. When the "query" statement finishes, has isy received all status of that device or is it more asyncronous in the execution of the command and the recept from the device?
