phenneberry
Everything posted by phenneberry
  1. I upgrade to PG3x 3.2.2 and Ecobee problem went away. Much appreciated.
  2. Using 3.1.23 PG3. Power in house failed yesterday and when Polyglot came back up, 6 nodeservers were all fine, but the Ecobee complained, and wouldn't start. I attempted to restart, tried restarting Polisy - both to no avail. Removed Ecobee. Then installed. Shows status as Disconnected. When I slick start which should give me the PIN, the node starts, waits 2-3 seconds and then stops 2023-08-26 20:57:25,113 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2023-08-26 20:57:27,554 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.1.0 Starting... 2023-08-26 20:57:27,624 MainThread udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2023-08-26 20:57:27,625 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db9593250_1/./ecobee-poly.py", line 7, in <module> 2023-08-26 20:57:27,626 MainThread udi_interface ERROR udi_interface:write: from nodes import VERSION,Controller 2023-08-26 20:57:27,627 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db9593250_1/nodes/__init__.py", line 5, in <module> 2023-08-26 20:57:27,627 MainThread udi_interface ERROR udi_interface:write: from .Thermostat import Thermostat 2023-08-26 20:57:27,628 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/000db9593250_1/nodes/Thermostat.py", line 1 2023-08-26 20:57:27,628 MainThread udi_interface ERROR udi_interface:write: ormat(name)) 2023-08-26 20:57:27,629 MainThread udi_interface ERROR udi_interface:write: ^ 2023-08-26 20:57:27,629 MainThread udi_interface ERROR udi_interface:write: SyntaxError 2023-08-26 20:57:27,630 MainThread udi_interface ERROR udi_interface:write: : 2023-08-26 20:57:27,630 MainThread udi_interface ERROR udi_interface:write: unmatched ')' Thoughts?
  3. I purchased two, Insteon Garage Door sensors #74551. They work perfectly, allowing me to open /close either door remotely, and I've linked them to a keypad, so that inside the house, I can see the door status, as well as push the keypad button to activate the door. The one downside, whenever ISY is rebooted, it triggers both doors to open, and stay open. Anyone have a workaround for this?
  4. Much appreciated Michel for the info. One additional question on this, is there any plan for integration between ISY and GE Nucleus, so that I can use ISY to report and manage rather than two separate devices. Thanks again, Peter
  5. I just contacted the Arizona Power Service (APS) to obtain the PAM code, and they had no idea what an ISY, Zigbee Brueltech monitoring or PAM code is. Has anyone else been successful in configuring the ISY here in Northern Arizona with APS? Or is there something that I should be communicating with APS, as they acknowledge it is a smart meter (elster meter)? Thanks for any assistance, Peter
  6. I upgraded to 3.1.10, and attempted to add my six 2444a28 Remote 2 controllers, but every attempt fails, with the following message: Node not added - failed reading links (Insteon address) [-200000/-8] I don't have any links as I was going to add it to the ISY, and than add scenes to each button, as all my lights are SwitchLink 2476D, and in order to add the SwitchLink Dimmers directly they need to be 2477. Suggestions?
  7. I upgraded from 3.1.2 to 3.1.3, when I click on Administrative page, I receive Java error: Applet com.universaldevices.client.ui.UDClientApplet notinited, resulting in the admin page failing to load. I tried the basic Java that ISY recommends on a 'clean' machine - JRE 6U5, as well as the current version - both product the same error. How do I roll back to 3.1.2 when I cannot log into the admin console?
  8. Both Insteon controlled thermostats continue to loose connection. I disable them, and then re-enable them. That works until I restart the ISY admin, or until I perform a query of devices.
