mango
  1. Plenty of ISYs on ebay, some will have working network module.
  2. mango replied to MikeB's topic in Amazon Echo
    Also, it's Amazon..... take from that what you will. Good luck everybody.
  3. mango replied to MikeB's topic in Amazon Echo
    Our Alexa works through SONOS Ones, and it's a bit clunky. Now we use Alexa very little (timers and info).
  4. mango replied to MikeB's topic in Amazon Echo
    Never had much luck with Alexa and ISY automation. Hit and miss.
  5. Regards the x10/A10 module, I didn't experience any issues moving config to a pro unit that did not have the module installed. I used to use X10 as virtual devices which was handy for controlling stuff from UD Mobile / Mobilinc. The device tree still showed the X10 device but it was presented as exclamations. They were delete-able.
  6. Late to the party. I may be able to help you. I have quite a few ISY994s I don't really need most of them. I acquired quite a few when I bought Insteon lots over the last few years, they came with everything. Let me know if interested I could probably find one spec'd the same as you use now. I live in Canada if shipping is a concern.
  7. Sorry to hijack this thread, but I'm interested in this method. Care to explain a bit further?
  8. Not wishing to ever disservice UD and the excellent products and services they provide, there are ways to connect to the ISY securely / remotely without using the portal for UDI mobile and mobilinc. I have some 994i's that are still currently subscribed to the portal but also have a backup configured that uses Wireguard VPN and works very well.
  9. Copy to clipboard is a function that helps. Paste to a text file with chunks of others then once tweaked, import into new program.
  10. It's relatively easy to reinstall regular switches and dimmers, the wiring should be traditional and power everything the circuits are wired to.
  11. I have some hardly used new appearance 2466SW toggle switches at the cottage. If you're interested, hit me up. Shipping would be from Canada.
  12. Perfecto thank you so much.
  13. Hey Javi, https://fonts.google.com/icons?icon.set=Material+Symbols&selected=Material+Symbols+Outlined:door_open:FILL@0;wght@400;GRAD@0;opsz@48&icon.query=door&icon.platform=web door_open
  14. For @Javi If possible please add the google door_open icon Both icons together (door filled and door open) would work well for door sensor status.
