tommyv
Everything posted by tommyv
  1. I have tried to do this multiple times but I am hung up in the Plugins Store. The screen shot shows what I am seeing. When I try to get the 3.2.5 Beta, the store wants to charge me. It is also showing a nes Production version there but in trying to get it, the purchase window shows it is actually 3.2.4 Perhaps I am missing something in the process. How can I proceed?
  2. Jimbo, any progress? It's been a while. I am happy to send you logs or lists of the nodes from each version - both beta and production - to show the differences if that helps. Tom
  3. I sent that a while back. Have you found anything? Do you need more logs? All my Kasa is working fine except that one switch. Tom
  4. Jimbo, I am running eisy with current software. PG3x Version 3.3.18 Status: Connected Frontend Version: 3.3.18 IoX Version: 5.9.1 Connected It is primarily Insteon but I recently added KASA support with your node server. My system works well but with the following issue. I have some older HS200 that are Hardware version 5 and firmware 1.0.11 I just installed a newer HS200 that is Hardware version 6.6 and firmware 1.0.3 Build 240723 Rel 192630 Both identify as current firmware. When running the KASA production node server 3.1.4, everything else is fine including a few dimmable Kasa HS220. But the new HS200 is not found. I cannot add it by IP or by name in the Polyglot interface and the node server doesn’t discover it. I was able to add it in the ISY configuration under Plugins using the device id and the controller id and it appears, but it doesn’t work. As a test, I loaded and ran the current beta version. I added the Kasa login information and the newer HS200 was discovered and ran great. Unfortunately, none of my HS220 dimmable switches are discovered in the Beta set up. Am I missing something in setup or is there a difference in the production vs Beta? Tom
  5. Thank you. I will work on this after the holiday and report back. Fingers crossed for my PLM.
  6. My system us stable and working well. I would like to switch from Mobilinc to UD Mobile. Its my first step in moving toward eisy. Currently I am only using Insteon devices and like everyone, I am concerned for my PLM. Reading the Current Release guide, I think that I should upgrade to 5.3.4. That's OK for me since I don't have Z-Wave However, there seem to be a lot of conditions to that upgrade and the changes are small. So I look back to 5.0.16C. It has big banners that say don't use it any more unless you have Z-Wave (I don't). However, I see a lot of the same manual intervention warnings there too. My questions is this: What is the safest, least problematic and most direct path to allow me to use UD Mobile? Thanks, Tom
  7. Thanks for the clarification. I had no idea that was possible. I’ll write those tomorrow and report back. Tom
  8. That is where I am stuck. What is an IF statement for a program that is only designed for manual (Alexa) control? It is not based on responding a time or ISY event.
  9. I have 22 Insteon switches and modules, 2 leak sensors and one RemoteLinc 2 Keypad running on my ISY. All of the switches are programmed with various instructions including random, sunrise, wait and other if/then controls. My goal is to have a scene or program that will allow me to turn on multiple lights (downstairs, for example) in a specific sequence with a short (15 second) wait between events. A separate scene/program would turn them all off in a similar manner. Adding the devices and wait periods is no problem. I can do that. My question is, how can write something that will allow me to use Alexa to activate the process? In other words, what is the if statement or scene design to start initiate the program? Alexa:"Turn all downstairs lights on" ISY 994i Pro / v 4.9.0 / X10 and Mobilinc Portal Tom
