Everything posted by CLipman
		Setup Failed on Last Step
		@Kentinada have you managed to get it working yet? I just tried again, even creating a new account, and the resideo auth from the azure server continues to fail each time.
		eISYIR Setup - Learning Codes
		So i've made progress. Using myHarmony, I've setup the remote using the old ISY994 IR codes. Using the FLIRC software on a PC, I then taught the USB IR receiver the codes for keyboard presses 1-9, by clicked the screen prompts on the remote for IR001-IR040 - and now my USB receiver has codes in it! I then plugged the IR dongle into the eisy and, using the log feature in the PG3 window for eisyIR, I figured out which code corresponds to which value on the remote's screen. Better yet, in the eisy admin console, I see the eisy respond when I press the corresponding screen option on the remote - so I now have the remote interfacing with the eisy and using the screen prompts that I wanted. thanks for the help from this forum!
		First Time Setup
		good to know… let’s hope things get back on line soon- thanks for the update!
		Original 40 ISY994 IR mapped
		Using my PC, I connected to the FLIRC and used the FLIRC software to load the config. When I plug the FLIRC into my eisy, how do I get the codes to load in the eisy? I've restarted the node server, clicked load config from the polyglot 3 page, and I don't see any nodes displayed in UD admin console. I'm trying to recreate my ISY994 setup where pressing buttons from my IR remote would toggle off lights/ etc, and I'm not having any luck auto-learning the IR codes I created with the ISY code table, so this is my last(?) try to get the FLIRC working for my needs....! Thanks
		So... when I plugged the FLIRC into my PC and used the FLIRC software, I worked it alot more, including the command line and clearing the FLIRC config. That seemed to help, as ONE IR command was learned when connected to eisy. But, not all commands are being detected from my harmony remote. I ended up with only the really basic commands (up/down/left/right/enter/ etc). From what I can best tell, the FLIRC only recognizes some IR commands, and not all. ISY994 had a great IR setup and worked really well with harmony remotes, easy to use/ setup/ etc. At this point seems that the FLIRC just does things differently (and it won't detect the ISY994 codes that were used with the MyHarmony remotes ). If anyone has had luck with the FLIRC learning the IR codes from the ISY994 (with MyHarmony), please share! Ciff
		Thanks again @gzahar!! 'Really appreciate the quick replies. I've already confirmed the remote works when plugged in to the PC (I had tested this based on one of your replies to an old post ). I used the PC software to learn the basic up/ down/ left right/ etc commands by pressing the buttons on the remote. Q for you - it's not clear to me **where** the commands will show once they are properly loaded... Will I see them in the UD Admin Console, PG3 web UI, or? Can you send a screen shot of how they show?
		Thanks, @tazman - and i have to admit, your response definitely made me think twice here... But I double-checked that my remote is the Harmony Elite which is IR. Thinking a bit more on this, it's the same remote that worked with the ISY994 which was also IR-based (not RF).
		First Time Setup
		Working with a new eisy for the first time. I've been using HoneywellHome Total Connect Comfort for months via the honeywell ios app Total Connect Comfort. No issues. It's controlling my thermostat via Honeywell Home RedLINK to Internet Gateway and Ethernet Cable and Power Cord (THM6000R7001). I'm now trying to connect that to the HoneywellHome NS on PG3/ eisy. I wonder if I'm getting lost between Honeywell and whatever Resideo is... Going through the setup, I created the API key and successfully entered into to the azure webpage. Then I get stumped - I'm prompted with a Resideo authentication page. I use the same credentials that I use with Total Connect Comfort and it fails. I enter my developer credentials that i used for to generate the API keys and that fails. I enter an account I setup from https://www.resideo.com/us/en/ and it fails also (I think that is only an account for purchases). What credentials should I use for the second auth on the azure site? Any other ideas of what I can do to resolve this? Note that i did create my developer account today, so could it be that the account is not yet visible to the azure app? As always, TIA. Cliff
		Reaching out for some help in setting up eISYIR for the first time. I've been using ISY994 for a long time, 'just moved to eisy. 'Really want to restore the old 994 IR functionality using eISYIR + FLIRC - in other words, send commands to the eisy using my harmony remote (without the harmony hub). But I need help. I'm stumped. TBH, feeling a bit humbled in what feels like should be a simple process, and I'm a pretty techy kinda guy. But I'm not feeling very techy right now, cause I can't get this to detect the IR commands. I'm feeling a bit of a lesser person right now, so I'm hoping I can get some help here. I think therapists might also be able to help here, but I'm in the wrong forum for that - so I'll revert back to the tech q. It seems like everything is working correctly - but "Once you trigger key press with your remote, node server will create a node for that key" isn't working from what I can tell. eISYIR is installed and UD admin console shows the controller is online. From PG3 dashboard, I go to details and eISYIR seems to be fine (recent log file attached). I've installed the FLIRC software on my PC and have loaded the profile from this forum post (and updated the FLIRC firmware): No change. So it's either not working, or I'm not seeing that it is working... stumped. So, some questions: once it's working properly and the commands have been learned, where will I see the list of commands? Will it be only via the PG3 interface, or should I also see branches in the UD Admin console (assume the latter, but maybe both?) - can anyone share some screen shots of how it shows in their system? Is anything needed to put the FLIRC into learning mode? When I placed my IR in front of the FLIRC, I don't see any response from the eISYIR (I have confirmed my remote is working - my TV responds). The eISYIR instructions did not say SSH commands are needed when used with eisy... so I didn't... should I? Any other ideas? I'd really appreciate any/ all the help I can get here! TIA Cliff eISYIR_12-30-2023_40631_PM.zip
		Command Display status not Updating
		Thanks, Javi - that worked - sometimes it's the simple things.....!! Have a great new year!
		This is my first time posting on UD Mobile and I wanted to say that this app is generally working great, by far the best app i've found for ISY. But, I do have an issue that may or may not be a bug. I'm using UD Mobile v0.60 on IOS 15.2, ISY firmware 5.3.4. I have created a Command Favorite that uses a state variable for the display node. The variable's value is used for the command's Display status. The command runs a simple program to toggle the variable value between 0 and 1. I have mapped values for 0 and 1 to change the command's color, icon and text appropriately (this is a really nice feature, btw!). The problem: when I start UD Mobile, all of the favorite icons are colored properly indicating their correct status, except for this command icon - the color for the command shows the null color. But, the color will change when I read the variable in the app, or toggle the button positive/ zero... When I navigate to the variable in the tree from the Home button, the color of the variable icon also shows the null color. When I open the variable, the correct value value is shown. When I close the Variable window, the icon colors are fixed - both the variable and command icon colors show the correct color. Another way to "fix" the colors is when I press the command - color/ icon/ label will change correctly to "positive", and pressing it again shows the correct "zero" color/ icon/ label. It appears the app is not acting on the variable value correctly until I "force" it to read it. Is there something I can do so it automatically reads it and shows the proper state on the icon? TIA
