Everything posted by geogecko
Venstar Thermostats and Synchronize Time Function
Hmm, ok, that's too bad. That's the only thing I don't like about Insteon products, is that the firmware is not field upgradeable.
Insteon 2450 doesn't work like garage door kit instructions
Lol, while this is in the garage, the wiring added to add the sensor looks ugly. I'm not going to run another wire to the wired remote on top of the drywall. I guess if it bothers me enough, I can take one of the wireless openers, and make some modifications, however, at some point the battery will die, and then I will lose control over the door until its replaced...unless I make a little circuit to drop the 5V output of the IOlinc down to 3V (hopefully that's what they use inside), and hard wire power to the remote... Lol. I probably have an old LM317 that I could use to do that... I did the same thing you are planning on doing. I moved the original opener to the single car door, and bought this new fancy one to use on the main door. Overall, I've been happy with it, but after about 3 years, the wireless operation has been intermittent. Sometimes we will have to be right up next to the door to get it to open or close, and it doesn't matter which car (Homelink), or remote we use. I think maybe the capacitors in the GDO are going bad...or something else...
That stinks. I just finished installing mine last night, and so far, am loving it. I like the way I have it setup, and I just have one little maintenance program that goes out and checks to see when the relay is on, and then waits 2 seconds, and queries the relay so that it has the proper status. My only complaint, is that by using this, the relay shorts out power to the LCD wall control for the garage door opener, which resets the clock on it. I am trying to remember if there is a backup battery (CR2032 maybe) inside the wall control that might be dead. Otherwise, I guess I'll just have to quit using it for a clock in the garage. My unit is a Chamberlain Liftmaster with the battery backup.
Yes, thermostats work perfectly fine, minus the time syncing. The All-In-One thermostat is brand new, about 2 weeks old. They both appear to have v.95 firmware, at least, I think that is what that means. It's listed at the top of the main node of each thermostat in the admin console.
The thermostats seem to be working great, just not the time syncing feature. Don't seem to get an error message from what I can tell, this is all I get in the diagnostic log: Sun 12/16/2012 06:06:49 PM : [ Time] 18:06:51 6(0) Sun 12/16/2012 06:06:54 PM : [ Time] 18:06:56 6(0) One for each thermostat.
I have a 7 day programmable Venstar 1700 with an Insteon Thermostat Adapter (2441V) v.95, and an All-In-One Venstar 1 day programmable (2491T) with internal adapter v.95. Are these compatible with the new commands in the beta firmware of the ISY-99i/Pro? It doesn't appear to be working. (ISY firmware 3.3.5)
Understood. Mentally, I just find it weird turning on, an already on relay. Also, it works a little different in Mobilinc. If I use the icon to toggle the state, if I don't reset it to off, I first have to cycle it to off, then back on, in order to activate the relay. If I reset the relay, every press of the Mobilinc icon for the relay, will cause action on the part of the garage door opener. Thanks for your help in understanding this operation.
Or could I just wait 2 seconds, and query the relay? Wouldn't that reset it to off? Edit: Just tried this...actually has to be status, not control, I keep forgetting that direct control by the ISY does not trigger a control command in a program.
Ok, so I guess I should just think of it like "on" always toggles the garage door. So I guess if I wanted the relay state to really be reflected, even though it doesn't really matter, I could write a program that looks for the relay being turned on, and 1-2 seconds later, I can turn it off, so that it matches it's real state. Then I just monitor the sensor to determine if the door is open/closed.
LeeG, Thanks for the assistance here. The changes from those versions of firmware is what I was talking about. I noticed that no matter what I did in 3.2.6, I could not get anything to behave differently. I also noticed that the nomenclature of some of the options changed. Currently, I have the I/O Linc connected to the green/black wires (for the sensor). When the magnet is close to the sensor, the sensor is "on," which with the way it will be installed in the garage, will indicate that the door is "closed." The I/O Linc relay normally open contact will be used to operate the garage door opener. When the door was open (magnet away from sensor), I set the following options: With Sensor "on" (door closed) Relay direct commands operate as follows (via admin console): On - Relay momentarily clicks (closes circuit), shows status "on" (door will be open now) On - Relay momentarily clicks again, shows status "on" (door will be closed now) Off - Relay does nothing, shows status "off" Off - Relay does nothing, shows status "off" (behaves the same if I go back to On commands, etc.) With Sensor "off" (door open) Relay direct commands operate as follows (via admin console): On - Relay momentarily clicks (closes circuit), shows status "on" (door will be closed now) On - Relay momentarily clicks again, shows status "on" (door will be open now) Off - Relay does nothing, shows status "off" Off - Relay does nothing, shows status "off" (behaves the same if I go back to On commands, etc.) So in other words, the relay operates the same, no matter what the sensor state is. Ideally, and I don't know if this is possible, but this is the desired operation: With Sensor "on" (door closed) Relay direct commands operate as follows (via admin console): On - Relay momentarily clicks (closes circuit), shows status "on" (door will be open now) On - Relay does nothing, shows status "on" Off - Relay momentarily clicks (closes circuit), shows status "off" (door will be closed now) Off - Relay does nothing, shows status "off" With Sensor "off" (door open) Relay direct commands operate as follows (via admin console): On - Relay momentarily clicks (closes circuit), shows status "on" On - Relay momentarily clicks again, shows status "on" Off - Relay does nothing, shows status "off" Off - Relay does nothing, shows status "off" (behaves the same if I go back to On commands, etc.) I think I have the logic right, but anyone feel free to correct me. I am guessing that if this is not possible operation to setup via direct commands, that a little program running in the background could provide this type of operation, I just wanted to be sure that the functionality didn't exist, before I start writing code.
Yes, that is also what I didn't like, that the scene itself wouldn't contain the status of the door, so I'd have to go somewhere else to verify that. I kinda like the icons mobilinc uses too. I don't plan on using a KPL to show status, so that didn't bother me. I was going to see about writing a program that would either flash a light after a given amount of time, or something like that. Also send email, in case I was away. At this time, I haven't installed mine until I figure this out, because it's a lot easier to troubleshoot with it in the same room as my computer. I'm interested in how you guys set it up. I notice the setting options keep changing in the last couple RC firmwares...
I've also just received this I/O Linc, and bought the NO/NC sensor, and am just as puzzled. It seems like the scene setup works, but I like using MobiLinc to control my stuff, and going to the My Devices page is usually what I do to control devices. I guess if there is no other way, I'll use the scene...
Bathroom Fan Timer with Shower Light Trigger
LOL, this has just gone south, really fast!
Tested it out last night, works perfectly. Thanks for simplifying my code! I am a bit surprised with how all this works, but I think I have a better grasp on it now, thanks to you all.
Ah, wow, that explains it well, thanks for that. I think I'll have to print out a copy of that post for use while programming, so I can remember this behavior. The work around is annoying, but also not that complicated, except for the fact that it requires multiple programs to accomplish.
Using the "status" condition, rather than "control", I expect the "if" clause to be triggered at any change in status, whether from off-to-on, or on-to-off (I am assuming your light switch is a relay, rather than dimmer....otherwise, one may have to emply a different type of condition). If the condition is triggered and evaluated as "true", I expect any running "else" clause to cease, and the "then" clause to initiate. If the condition is triggered and evaluated as false, I expect the "else" clause to initiate. It is easy enough to try out. Create the program and observe the program status as you toggle the light from off-to-on, and vice versa. I will for sure give that a try, because that would make a much simpler program...
At this point, I'm not sure. I'm still getting my mind around what interrupts a wait loop. In this case, I'm not sure if it would work, because you have to retrigger the if clause somehow...
apostolakisl, That is very interesting. I was not aware of that. I think this is one thing that makes programming so difficult with this thing, is that your standard C/VB/(insert programming language here) logic does not work. The programming used here almost reminds me of hardware (firmware) programming, than a software programming. Even though it would make this program easier, I don't think I like the way it behaves, as you have said... Thanks for being gentle with me, in helping me understand.
That would not meet requirement #3. The problem is, that if you put a wait statement in there for 15 minutes, it's going to wait 15 minutes before doing anything else. You're stuck in that 15 minute wait loop, until it's over, then your fan is going to go off, no matter if the light was switched back on or not. The issue is this situation: * Person 1 goes in to take a shower, turns on shower light. * Fan turns on. * Person 1 gets done, turns off shower light. * Fan is now waiting 15 minutes before turning off. * 10 minutes passes. * Person 2 goes in to take a shower, turns on shower light. * Fan is still on from previous activation, with only 5 minutes left remaining. * Person 2 gets out of the shower (5 minutes passes), and the fan turns off. You have to interrupt the wait loop somehow, and this was the only way I was able to do that, was to check every minute. Unless I'm misunderstanding how everything is interacting together... You are saying it will kill the wait, if the on trigger is met, is this true? I thought the other program would keep running, until complete...
I purchased a Togglelinc relay to control our master bathroom fan a little while back, to add to the other two lights in our bathroom that are controlled by Togglelinc dimmers. I had kind of a clunky way of doing a bathroom fan timer, which was triggered by the one Togglelinc dimmer, assigned to the shower lights...once variables came along in programming, I was able to make it more intuitive, and also more precise in what I wanted it to do. These were my requirements: * Activate the fan automatically, when the shower light is turned on * Deactivate the fan automatically, 15 minutes after the shower light is turned off * If the shower light is turned back on, before the fan goes off, cancel the delay, and do not turn off the fan That last requirement was a little tricky, and the reason for it, is that my wife and I tend to take showers right after each other, on a regular basis, so one of us would get out, turn the light off, and then the other would turn the light back on, get in the shower, and a few minutes into the shower, the fan would turn off. The reason for using the fan in the bathroom is for removing moisture, so obviously this was not ideal. Here are the programs I came up with to accomplish this task. I thought some might find it helpful, if you were trying to do a similar thing. So every minute, the program checks to see if the light has been turned back on, so within a minute of turning off the fan, this should work. If anyone has any corrections, advice, or simplifications, I'm open to suggestions as well. Master Bath Fan Cmd On (Enabled) If Control 'Master Shower Lights' is switched On Then Set Scene 'Master Bath Fan' On $MasterBathFanCount_Int Init To 0 $MasterBathFanCount_Int = 0 Else - No Actions - (To add one, press 'Action') Master Bath Fan Cmd Off (Enabled) If Control 'Master Shower Lights' is switched Off Then Wait 1 minute $MasterBathFanCount_Int += 1 Run Program 'Master Bath Shower Light Status' (If) Else - No Actions - (To add one, press 'Action') This program, in combination with [Master Bath Fan Off] (disabled), will delay turning off the fan for 15 minutes, but if the light is turned back on during that time, the program will exit, because of the [Master Bath Shower Light Status] (disabled) program, and wait for another "off" command. Master Bath Shower Light Status (Disabled) If Status 'Master Shower Lights' is On Then $MasterBathFanCount_Int = 0 Else Run Program 'Master Bath Fan Off' (If) Master Bath Fan Off (Disabled) If $MasterBathFanCount_Int >= 15 Then Set Scene 'Master Bath Fan' Off $MasterBathFanCount_Int = 0 Else Run Program 'Master Bath Fan Cmd Off' (Then Path)
Enabling/Disabling Motion Sensor with Togglelinc Program
Okay, I think I understand how they are evaluated now... Actually feel stupid for posting this, but I copied the disable program for the enable program, and forgot to switch Fast On for Fast Off on the enable, so I could never enable the programs again... Everything works now.
Hi Rand, Interesting point, I will have to look into that. But this was with my own testing. I went in there, and double toggled the switch multiple times "off" and could never get the motion reactivated. Secondly, since this is an IF statement, looking for a CONTROL function, shouldn't it only be true for that split second when the togglelinc sends the fast off command? Both of my programs are in the true state...seems confusing to me.
Had an interesting request from my wife, when I installed a Togglelinc dimmer in our master closet with a motion sensor to turn the light on and off. Sometimes, she will put our son (infant) in there when she is in the bathroom, so that she can keep an eye on him. Well, he is too small, and doesn't move enough, to keep the light from going off. To try and fix this issue, I created a program that disables/enables the programs that use the motion sensor to control that Togglelinc. The motion sensor is not directly linked to anything, I solely use programs to do what I want. So basically, I did this: Disable Motion program looks for a "Control Master Closet Lights is Fast On" and then disables my motion control programs, so the Togglelinc operates on it's own. Enable Motion program looks for a "Control Master Closet Lights is Fast Off" and enables the motion control programs. When I first tested this, it seemed to work, except then I was not able to enable the motion programs from the switch. I checked the admin console, and both enable/disable programs are true, and the motion programs are disabled...no matter what I do, I can't get the Enable Motion program to work. Any idea what is going on here?
option to access ISY from iphone?
I know, I wanted that comparison too, but it seems that too few of people are using eKeypad...to provide a review. I went with MobiLinc, and have been very happy. The developer has been very responsive to requests (he is implementing one I asked for in the next release, and we worked on another one that is going to be pretty cool for scenes). Good luck with your decision.
Can't get Motion Light Control to Work
Hmm, I may have to try that... Here is what I came up with so far, that appears to be working, although, there is the possibility, that the motion could stop near the end of a 10 minute timer (such as, it has already run the off command, so it is waiting in the 10 minute loop, without a way out, until the status shows off, so if I stopped moving around the 8th minute, the light would turn out in two minutes. What I'd like to emulate, is a 10 minute after stop of all motion, until the light turned out, but I think that would require variables (you could make the wait time one minute, count until you had 10 of them, then turn the light out, but checking the status between every minute, if at any time the status of the motion was on, you just reset the counter (that is counting 10 times), and you would be between 9 and 10 minutes after the stop of motion. 3 Programs, notice the enabled/disabled states: Motion On Cmd (enabled): If Control 'Study Motion-Sensor' is switched On Then Set Scene 'Study Lights' On Else Motion Off Cmd (enabled): If Control 'Study Motion-Sensor' is switched Off Then Wait 10 minutes Run Program 'Motion Status-Off' (If) Else Motion Status-Off (disabled): If Status 'Study Motion-Sensor' is On Then Run Program 'Motion Off Cmd' (Then Path) Else Set Scene 'Study Lights' Off I'm using this with a 2 minute wait, and it seems to be working rather well right now. I will do more testing, and see if there are any flaws...
