ShawnW
  1. Hi. I looked everywhere for a 'requests' page for change requests to the App, but couldn't find one (I could have sworn there used to be??) I would really love the ability to have multiple Favourites pages or Tabs or whatever - would be much better than having a super-long Fav's page where you have to scroll up and down looking for a specific node. Please and Thank you! Shawn
  2. This is actually "common" for me - not every day but often enough that I have to sit here for hours changing nodes in programs. Mind numbing. I'm REALLY hoping the new User Interface will allow more typical Copy & Paste of both line items and whole chunks from Programs.
  3. ShawnW replied to jkraus's topic in IoX Support
    @apostolakisl - that's not surprising to me - UDI may order some different custom/specific internals such as memory, blank operating system, etc. - they do have some labelling changes, a custom label on the bottom, completely different packaging needs, etc. Also, they likely need to purchase them in large batches of at least hundreds at a time to keep the price as low as possible for us. I can assure you that they are not simply ordering the exact retail products as-is and doing all the changes afterwards. MeLE also makes dozens of different variants themselves so the production line is likely batch-building as well, so orders must be scheduled and slotted in to align with all other production needs.
  4. ShawnW replied to jkraus's topic in IoX Support
    Hi @brians - Noone appeared to answer your last question. Yes, you can plug a monitor mouse and keyboard into eISY to use AC & PG3X. I have not personally done it, but several posts and pictures from Michel after eISY launched showed and talked about just that. In case you're curious, the eISY box is actually a purchased mini-computer by MeLE (available on Amazon) which comes with Windows that UDI has replaced with all its custom software (probably a little more complicated than that...).
  5. @pjjameso - I had the (nearly) same issue with several programs when I transitioned my ISY to my Polisy.
  6. @mmb - In Canada as well, but I need the humidity higher in the house, so I have little 4"dia computer fans sitting on the window sill blowing across the bottom of the window (good for about a 2-foot-wide window) which are actuated automatically when the outside temp drops below -2'C. I've had these for ~4 years now and even into the -20'C's I still have no moisture on any window sills. Some people love this solution, but some also hate it. But it works very well as you do not need much air movement to evaporate the moisture before it ever makes it to the bottom.
  7. ShawnW replied to ShawnW's topic in VUE
    Thank you @tazman and @bpwwer for your info. From what I can see, they only now sell the Gen3 so I would expect to start seeing more of them. I would not have guessed them to be much different - from what I know, the CT's have been redesigned "for better accuracy", and the control box is a new shape with an added Ethernet port for those who have signal trouble with the wi-fi. Other than that I believe all the "functions" are unchanged, so I was hopeful. But again, great news. Thanks!
  8. ShawnW posted a topic in VUE
    Hi All, @bpwwer I would like to buy a new Vue3 but only if it works (or can easily/quickly work with some tweaks) with the Node Server. Please let me know ASAP as I need to take advantage of a current sale price. Thanks! Shawn
  9. ShawnW replied to Rocarico's topic in eisy
    I DO have to say that it DOES bother me, as an eISY/UDI fan, that the device has Wi-Fi, but it/we can't "do" anything automation-wise with it......
  10. ShawnW replied to Hawkspoint's topic in eisy
    Awesome. They make a bunch of TINY and inexpensive items.
  11. Hi. I had a very difficult recovery of my Polisy last month after a power outage that required days of support from UDI and a partial rebuilding of all my Zigbee devices and programming. It was painful. And yes, my Polisy was plugged in to a UPS, but the outage was several hours long. Anyways, I'd LOVE to not repeat this. How the heck do I "properly" shut down my Polisy??? I see no options / tabs / buttons in the AC other than rebooting. Any help would be appreciated. Thanks! Shawn
  12. Hi @pjjameso I've had to do this twice, once very recently when my sump pump's float died (pump still good) during a high-volume week. For this one I found a very cool way as I needed it to run once every 48 seconds for 9 seconds. This is what I did: If statement: Schedule: Time Is - 45sec - After - Last Run - <Name of THIS Program> - Check "Daily" Box Then I literally plugged my Sump Pump into an Insteon Appliance Switch Then: Set 'Appliance Switch' On Wait 9 seconds Set 'Appliance Switch' Off So the only issue with this method is that you have to manually "start" the sequence after a reboot - just right-click on the Program Name in your list and Select "Run Then", and that will start it. However, for your application and your larger time frames, I would do something a bit more reliable and simply schedule it to run on a schedule that merely lists all 24 hours of the day. I do this now for resetting of my Hourly Counts (Variables). If statement: Schedule: Time Is - 7 AM - Time OR Schedule: Time Is - 8 AM - Time OR Schedule: Time Is - 9 AM - Time OR Schedule: - ETC. Your Then of course would again be to turn it on, WAIT for 20 min, Then turn it off. I hope that helps with a few other interesting options. Let me know if you need some screenshots of the actual programs from the examples above. Good luck! Shawn
  13. Hi @Techman - Thank you for your suggestions - ALSO, thank you for your suggestions on another forum post - you led me to some new knowledge. At first I too thought the PLM as it is fairly old-ish (for a plm), it shows its a 2413S V2.1 1505. However, the light is on and blinks with Insteon traffic (tested) even though the Event Viewer does not show any (during the crashed time). I ran a PLM Link Table Count and it came to 226. In both my "Insteon crashes" (again Z-Wave & Zigbee remained working), it took a Polisy Reboot to get Insteon working again. I have not yet tried to do a Restore Device on an Insteon device...what would this possibly show? I hope to try this tomorrow. For everyone else, I am still suffering other annoying problems like every other backup (while saving one) freezing at the same point - 56% at when it gets to the file: 'ebaa83a2-DevicesData.xml', so I Upgraded again today just in case and have received IoX 5.8.0_1 - it had only one Release Note: "- Fixed reboot on polisy when using ZMatter in original mode" Thanks. Shawn OH - forgot to mention that after upgrading to 5.8.0_1 I had to unplug my PolisyPro ZMatter-Internal to get it to let me login again.
  14. Installed update 5.8.0 tonight (Jan 2nd) around 9pm or so as I experienced a network-wide Insteon-only crash 2 days ago and saw in someone's notes above about that issue being fixed. Well, it's barely 5 hours later and even with 5.8.0 installed I am now experiencing another Insteon-only 'crash'. Ie nothing Insteon works and the Polisy doesn't notice. All Z-Wave and Zigbee continue to work as usual. Can't deal with this again tonight, going to bed. Maybe someone will have some info tomorrow on this specific issue (hint UD). Thank you. Shawn Added: Event Viewer shows all Insteon traffic just ending @ 1:56am eastern. No hints as to why. I have the log saved if anyone cares to review it.
  15. Hi All, Recently @Geddy told me that I should not leave the Admin Console running for long periods or overnight. However, I know of no other way to keep the Event Viewer Log running so that I can go back later and look for issues at certain times. Are there other methods? I have several weird issues happening for the last few months that I'm trying to trace ie random objects turning on or off when they shouldn't be. Any other thoughts on traceability would be appreciated. Thanks! Shawn
