walterross
  • Posts
    5
Everything posted by walterross
  1. I've done all of those - still only one shot with the File Chooser. Here is my terminal output from java -version: java version "1.7.0_17" Java SE Runtime Environment (build 1.7.0_17-b02) Java HotSpot 64-Bit Server VM (build 23.7-b01, mixed mode) I turned on tracing in the Java console, but nothing seems to be generated when this happens. Although the Java console also seems hung up when this happens, so perhaps any log entries are being lost? I do see entries like this in the ISY Error Log - not sure if they indicate something: Mon 2013/04/15 10:54:03 AM System -170001 [uDSockets] RSub:31 error:6 Mon 2013/04/15 10:54:08 AM System -170001 [uDSockets] RSub:31 error:6 Mon 2013/04/15 10:54:13 AM System -170001 [uDSockets] RSub:31 error:6 Mon 2013/04/15 10:54:18 AM System -170001 [uDSockets] RSub:31 error:6
  2. After installing 4.0.3 on my 994i I also have issues with the File Chooser dialog. I have a Mac running 10.8.3 with Java 7.17 using either Safari or Firefox as the browser. I have cleared the Java cache and tried either via the admin.jnlp file from http://isy.universal-devices.com/99i/4.0.3/admin.jnlp or using the ISY I/P address: http:///admin For me, I can use the File Chooser dialog exactly once via either the Backup or Error Log menu choices. The 2nd attempt gets a spinning blue ball and the gui is otherwise hung. I can close the browser normally without resorting to Force Quit. One difference in 4.0.3 perhaps of interest: - when the File Chooser dialog does work on the Mac, the initial directory is always the '/' root directory and I need to navigate into my /Users// directory as the destination folder. Running on Windows (and on Mac with versions 4.0.2 and earlier) the initial directory is the last used destination directory.
  3. I recently installed a new 2478D SwitchLinc Dimmer, Dual-Band, 120/240V, 50/60Hz 600W. When I linked it to my ISY 99i running 3.1.17 it reported as "Unsupported Device:1.49" I presume this is because this is a new SwitchLinc model from Smarthome? Regardless, the ISY is able to control it except for setting a specific on level percentage in a program. Let me know if there is some additional information I can collect to help add this to the list of devices that ISY supports. Thanks
  • Create New...
