MDoughney
Everything posted by MDoughney
  1. After upgrading to 5.9.1_18, I'm having partial success in adding a Matter 2 channel switch module. The process seems to get rather far along before failing with these errors in the Matter log: [2025-03-25 01:59:46.758] [E] [chip] [CTL] Failed to perform commissioning step 29 [2025-03-25 01:59:47.157] [E] [iox] Cannot get Matter BLE Rx Data at offset 2849, offset is greater than length available (24) [2025-03-25 01:59:47.457] [E] [iox] Cannot get Matter BLE Rx Data at offset 2849, offset is greater than length available (24) [2025-03-25 01:59:48.191] [E] [iox] Cannot get Matter BLE Rx Data at offset 2849, offset is greater than length available (35) I've attached the full log file and a photo of the device. Clearly plenty of progress has been made on getting Matter to work! 202503250200-zmat
  2. I'm likewise having difficulty adding a Zooz Zen16 device. I only see a power switch and three 'basic association' nodes, when with the 500 series dongle on the ISY I had the expected three inputs and three outputs which worked properly. Z-Wave X-ray shows "Interview Not done" for each attempt to add the device though I'm able to set parameters. Hoping this gets fixed in the next update, this is one of the most important devices in my system. edit: After restoring from the ISY 994i backup and attempting to add this device, as the afternoon progressed Insteon functionality just stopped working, and then I could no longer find the eisy in the finder. This seems to mirror some of the reports I've seen in other threads. I think I'll go back to my original functioning setup and come back to this project in a few months once some of these bugs are worked out.
  3. I picked up one of these and connected it to my USB ZMatter dongle in place of the ZWave antenna. Waterproof Replacement 5.8dBi Long Range Cellular 915MHZ LoRa Gateway Antenna with 3M/10FT Cable https://smile.amazon.com/dp/B09J49ZF16?ref=ppx_yo2ov_dt_b_product_details&th=1 I've just started the process of transferring from an ISY994i and have only set up the eISY and the ZMatter dongle for testing, which is in the depths of my basement. My home has always had serious problems with anything involving RF, it's as if the home soaks up all signals. Using the factory antenna, I attempted to add one device (with no intervening devices to create a mesh) on the other side of the house without success. With this replacement the device could be added. It's mounted vertically in the basement rafters near the center of the home's footprint. I should know more once I start adding the rest of the ZWave devices likely this weekend.
