markgam
Everything posted by markgam
  1. I didn't ask a general question, my question was actually very specific.
  2. I have been doing some reading on the issues that some poeple were having with the EZFlora and the ISY. My thinking is to see what other options are available.
  3. That is interesting but I thought that the actual controller functionality is the same "under the hood"?
  4. All -- What are the Pros and Cons to using a regular Output Relay controller (such as the Smartenit EZIO40 INSTEON 4 Output Relay Load Controller) instead of using a dedicated sprinkler controller (such as the Smartenit INSTEON 8-Zone Sprinkler Controller)
  5. After a full 8 hours of working on this today, I was finally able to get my ISY back up and running. Thanks for your help!
  6. I get an Error message box and then the Insteon Finder form opens. I added the ip Address of my ISY and then I get the following errors again:
  7. I issued "FS" via ISY Shell but I didn't receive the GoodBye response. I am assuming that it shouldn't take more than a few minutes to format a 512mb SD Card, correct?
  8. Michel, The link did NOT work but I'm still able to Telnet into the ISY. I pulled out the SD Card and ran a scan on it and here are the results:
  9. Michel, Ok, thanks so if I replace the SD card how do I go about adding the necessary software? Also, is the SD Card a standard card?
  10. Michel, Thanks for your suggestions. I did switch back to DHCP but now I am receiving the following Errors when I try to log into my ISY: http://forum.universal-devices.com/download/file.php?mode=view&id=767 I can no longer access the ISY via a browser but I am able to access the ISY Shell via Telnet. Would I be better off doing a Factory Reset, I do have a good backup available. Any thoughts??
  11. All -- I started to notice problems connecting to my ISY via the MobilLinc iPhone App last Wednesday (Dec 12th) but I figured it just needed a re-boot so I pulled the plug and plugged it back in after about 20 seconds or so. That seemed to fix the problem then the next two days I have not been able to connect to the ISY via a browser or the MobiLinc App. After examining the error log I noticed that something has been happening since December 3, 2012. The only way I can access the ISY Admin screen is to unplug the ISY and then I can log in. Upon logging in the ISY starts to scan all of the linked devices after which I get the following message box: and then I get this message box: Any thoughts?? Here is a screen shot of my About Page: Java Runtime Version - 1.7.0_4 Here is a printout of the error log: Mon 2012/12/03 02:04:49 System -140000 datafeed.weatherbug.com Mon 2012/12/03 02:05:49 System -140000 datafeed.weatherbug.com Mon 2012/12/03 08:21:43 System -5012 162 Tue 2012/12/04 00:39:07 System -60006 n/a Tue 2012/12/04 00:39:22 System -60006 n/a Tue 2012/12/04 00:39:37 System -60006 n/a Tue 2012/12/04 02:00:46 System -140000 datafeed.weatherbug.com Tue 2012/12/04 02:01:46 System -140000 datafeed.weatherbug.com Tue 2012/12/04 02:02:46 System -140000 datafeed.weatherbug.com Tue 2012/12/04 02:03:45 System -140000 datafeed.weatherbug.com Tue 2012/12/04 02:04:45 System -140000 datafeed.weatherbug.com Tue 2012/12/04 02:05:45 System -140000 datafeed.weatherbug.com Tue 2012/12/04 12:40:08 System -60006 n/a Tue 2012/12/04 12:40:08 System -60006 Stopping retries/next cycle Wed 2012/12/05 00:40:40 System -60006 n/a Wed 2012/12/05 00:40:55 System -60006 n/a Wed 2012/12/05 00:41:10 System -60006 n/a Wed 2012/12/05 02:00:40 System -140000 datafeed.weatherbug.com Wed 2012/12/05 02:01:40 System -140000 datafeed.weatherbug.com Wed 2012/12/05 02:02:40 System -140000 datafeed.weatherbug.com Wed 2012/12/05 02:03:40 System -140000 datafeed.weatherbug.com Wed 2012/12/05 02:04:40 System -140000 datafeed.weatherbug.com Wed 2012/12/05 02:05:40 System -140000 datafeed.weatherbug.com Wed 2012/12/05 12:41:39 System -60006 n/a Wed 2012/12/05 12:41:54 System -60006 n/a Wed 2012/12/05 12:41:54 System -60006 Stopping retries/next cycle Thu 2012/12/06 00:42:27 System -60006 n/a Thu 2012/12/06 02:00:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:01:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:02:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:03:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:04:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:05:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:06:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:07:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:08:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:09:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:10:37 System -170001 [Network] Failed DNS 11 Thu 2012/12/06 02:10:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:11:37 System -170001 [Network] Failed DNS 12 Thu 2012/12/06 02:11:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:12:36 System -170001 [Network] Failed DNS 13 Thu 2012/12/06 02:12:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:13:36 System -170001 [Network] Failed DNS 14 Thu 2012/12/06 02:13:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:14:36 System -170001 [Network] Failed DNS 15 Thu 2012/12/06 02:14:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:15:36 System -170001 [Network] Failed DNS 16 Thu 2012/12/06 02:15:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:16:36 System -170001 [Network] Failed DNS 17 Thu 2012/12/06 02:16:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:17:36 System -170001 [Network] Failed DNS 18 Thu 2012/12/06 02:17:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:18:36 System -170001 [Network] Failed DNS 19 Thu 2012/12/06 02:18:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:19:36 System -170001 [Network] Failed DNS 20 Thu 2012/12/06 02:19:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:20:36 System -170001 [Network] Failed DNS 21 Thu 2012/12/06 02:20:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:21:36 System -170001 [Network] Failed DNS 22 Thu 2012/12/06 02:21:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:22:36 System -170001 [Network] Failed DNS 23 Thu 2012/12/06 02:22:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:23:36 System -170001 [Network] Failed DNS 24 Thu 2012/12/06 02:23:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:24:35 System -170001 [Network] Failed DNS 25 Thu 2012/12/06 02:24:35 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:25:35 System -170001 [Network] Failed DNS 26 Thu 2012/12/06 02:25:35 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:26:35 System -170001 [Network] Failed DNS 27 Thu 2012/12/06 02:26:35 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:27:36 System -170001 [Network] Failed DNS 28 Thu 2012/12/06 02:27:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:28:36 System -170001 [Network] Failed DNS 29 Thu 2012/12/06 02:28:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:29:36 System -170001 [Network] Failed DNS 30 Thu 2012/12/06 02:29:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:30:36 System -170001 [Network] Failed DNS 31 Thu 2012/12/06 02:30:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:31:36 System -170001 [Network] Failed DNS 32 Thu 2012/12/06 02:31:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:32:36 System -170001 [Network] Failed DNS 33 Thu 2012/12/06 02:32:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:33:36 System -170001 [Network] Failed DNS 34 Thu 2012/12/06 02:33:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:34:36 System -170001 [Network] Failed DNS 35 Thu 2012/12/06 02:34:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:35:36 System -170001 [Network] Failed DNS 36 Thu 2012/12/06 02:35:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:36:36 System -170001 [Network] Failed DNS 37 Thu 2012/12/06 02:36:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:37:36 System -170001 [Network] Failed DNS 38 Thu 2012/12/06 02:37:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:38:36 System -170001 [Network] Failed DNS 39 Thu 2012/12/06 02:38:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:39:36 System -170001 [Network] Failed DNS 40 Thu 2012/12/06 02:39:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:40:36 System -170001 [Network] Failed DNS 41 Thu 2012/12/06 02:40:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:41:36 System -170001 [Network] Failed DNS 42 Thu 2012/12/06 02:41:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:42:36 System -170001 [Network] Failed DNS 43 Thu 2012/12/06 02:42:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:43:36 System -170001 [Network] Failed DNS 44 Thu 2012/12/06 02:43:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:44:36 System -170001 [Network] Failed DNS 45 Thu 2012/12/06 02:44:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:45:36 System -170001 [Network] Failed DNS 46 Thu 2012/12/06 02:45:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:46:36 System -170001 [Network] Failed DNS 47 Thu 2012/12/06 02:46:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:47:36 System -170001 [Network] Failed DNS 48 Thu 2012/12/06 02:47:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:48:36 System -170001 [Network] Failed DNS 49 Thu 2012/12/06 02:48:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:49:36 System -170001 [Network] Failed DNS 50 Thu 2012/12/06 02:49:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:50:36 System -170001 [Network] Failed DNS 51 Thu 2012/12/06 02:50:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:51:36 System -170001 [Network] Failed DNS 52 Thu 2012/12/06 02:51:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:52:37 System -170001 [Network] Failed DNS 53 Thu 2012/12/06 02:52:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:53:37 System -170001 [Network] Failed DNS 54 Thu 2012/12/06 02:53:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:54:37 System -170001 [Network] Failed DNS 55 Thu 2012/12/06 02:54:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:55:37 System -170001 [Network] Failed DNS 56 Thu 2012/12/06 02:55:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:56:37 System -170001 [Network] Failed DNS 57 Thu 2012/12/06 02:56:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:57:37 System -170001 [Network] Failed DNS 58 Thu 2012/12/06 02:57:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:58:37 System -170001 [Network] Failed DNS 59 Thu 2012/12/06 02:58:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:59:37 System -170001 [Network] Failed DNS 60 Thu 2012/12/06 02:59:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:00:37 System -170001 [Network] Failed DNS 61 Thu 2012/12/06 03:00:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:01:37 System -170001 [Network] Failed DNS 62 Thu 2012/12/06 03:01:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:02:36 System -170001 [Network] Failed DNS 63 Thu 2012/12/06 03:02:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:03:36 System -170001 [Network] Failed DNS 64 Thu 2012/12/06 03:03:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:04:36 System -170001 [Network] Failed DNS 65 Thu 2012/12/06 03:04:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:05:36 System -170001 [Network] Failed DNS 66 Thu 2012/12/06 03:05:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:06:36 System -170001 [Network] Failed DNS 67 Thu 2012/12/06 03:06:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:07:36 System -170001 [Network] Failed DNS 68 Thu 2012/12/06 03:07:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:08:36 System -170001 [Network] Failed DNS 69 Thu 2012/12/06 03:08:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:09:36 System -170001 [Network] Failed DNS 70 Thu 2012/12/06 03:09:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:10:36 System -170001 [Network] Failed DNS 71 Thu 2012/12/06 03:10:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:11:36 System -170001 [Network] Failed DNS 72 Thu 2012/12/06 03:11:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:12:36 System -170001 [Network] Failed DNS 73 Thu 2012/12/06 03:12:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:13:36 System -170001 [Network] Failed DNS 74 Thu 2012/12/06 03:13:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:14:36 System -170001 [Network] Failed DNS 75 Thu 2012/12/06 03:14:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:15:36 System -170001 [Network] Failed DNS 76 Thu 2012/12/06 03:15:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:16:36 System -170001 [Network] Failed DNS 77 Thu 2012/12/06 03:16:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:17:36 System -170001 [Network] Failed DNS 78 Thu 2012/12/06 03:17:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:18:36 System -170001 [Network] Failed DNS 79 Thu 2012/12/06 03:18:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:19:36 System -170001 [Network] Failed DNS 80 Thu 2012/12/06 03:19:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:20:36 System -170001 [Network] Failed DNS 81 Thu 2012/12/06 03:20:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:21:36 System -170001 [Network] Failed DNS 82 Thu 2012/12/06 03:21:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:22:36 System -170001 [Network] Failed DNS 83 Thu 2012/12/06 03:22:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:23:36 System -170001 [Network] Failed DNS 84 Thu 2012/12/06 03:23:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:24:36 System -170001 [Network] Failed DNS 85 Thu 2012/12/06 03:24:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:25:36 System -170001 [Network] Failed DNS 86 Thu 2012/12/06 03:25:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:26:36 System -170001 [Network] Failed DNS 87 Thu 2012/12/06 03:26:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:27:37 System -170001 [Network] Failed DNS 88 Thu 2012/12/06 03:27:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:28:37 System -170001 [Network] Failed DNS 89 Thu 2012/12/06 03:28:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:29:37 System -170001 [Network] Failed DNS 90 Thu 2012/12/06 03:29:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:30:37 System -170001 [Network] Failed DNS 91 Thu 2012/12/06 03:30:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:31:37 System -170001 [Network] Failed DNS 92 Thu 2012/12/06 03:31:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:32:37 System -170001 [Network] Failed DNS 93 Thu 2012/12/06 03:32:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:33:37 System -170001 [Network] Failed DNS 94 Thu 2012/12/06 03:33:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:34:37 System -170001 [Network] Failed DNS 95 Thu 2012/12/06 03:34:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:35:37 System -170001 [Network] Failed DNS 96 Thu 2012/12/06 03:35:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:36:37 System -170001 [Network] Failed DNS 97 Thu 2012/12/06 03:36:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:37:37 System -170001 [Network] Failed DNS 98 Thu 2012/12/06 03:37:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:38:37 System -170001 [Network] Failed DNS 99 Thu 2012/12/06 03:38:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:39:37 System -170001 [Network] Failed DNS 100 Thu 2012/12/06 03:39:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:40:37 System -170001 [Network] Failed DNS 101 Thu 2012/12/06 03:40:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:41:37 System -170001 [Network] Failed DNS 102 Thu 2012/12/06 03:41:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:42:36 System -170001 [Network] Failed DNS 103 Thu 2012/12/06 03:42:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:43:36 System -170001 [Network] Failed DNS 104 Thu 2012/12/06 03:43:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:44:36 System -170001 [Network] Failed DNS 105 Thu 2012/12/06 03:44:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:45:36 System -170001 [Network] Failed DNS 106 Thu 2012/12/06 03:45:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:46:36 System -170001 [Network] Failed DNS 107 Thu 2012/12/06 03:46:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:47:36 System -170001 [Network] Failed DNS 108 Thu 2012/12/06 03:47:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:48:36 System -170001 [Network] Failed DNS 109 Thu 2012/12/06 03:48:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:49:36 System -170001 [Network] Failed DNS 110 Thu 2012/12/06 03:49:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:50:36 System -170001 [Network] Failed DNS 111 Thu 2012/12/06 03:50:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:51:36 System -170001 [Network] Failed DNS 112 Thu 2012/12/06 03:51:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:52:36 System -170001 [Network] Failed DNS 113 Thu 2012/12/06 03:52:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:53:36 System -170001 [Network] Failed DNS 114 Thu 2012/12/06 03:53:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:54:36 System -170001 [Network] Failed DNS 115 Thu 2012/12/06 03:54:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:55:36 System -170001 [Network] Failed DNS 116 Thu 2012/12/06 03:55:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:56:36 System -170001 [Network] Failed DNS 117 Thu 2012/12/06 03:56:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:57:36 System -170001 [Network] Failed DNS 118 Thu 2012/12/06 03:57:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:58:36 System -170001 [Network] Failed DNS 119 Thu 2012/12/06 03:58:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:59:36 System -170001 [Network] Failed DNS 120 Thu 2012/12/06 03:59:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:00:36 System -170001 [Network] Failed DNS 121 Thu 2012/12/06 04:00:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:01:36 System -170001 [Network] Failed DNS 122 Thu 2012/12/06 04:01:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:02:36 System -170001 [Network] Failed DNS 123 Thu 2012/12/06 04:02:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:03:36 System -170001 [Network] Failed DNS 124 Thu 2012/12/06 04:03:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:04:36 System -170001 [Network] Failed DNS 125 Thu 2012/12/06 04:04:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:05:36 System -170001 [Network] Failed DNS 126 Thu 2012/12/06 04:05:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:06:36 System -170001 [Network] Failed DNS 127 Thu 2012/12/06 04:06:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:07:37 System -170001 [Network] Failed DNS 128 Thu 2012/12/06 04:07:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:08:37 System -170001 [Network] Failed DNS 129 Thu 2012/12/06 04:08:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:09:37 System -170001 [Network] Failed DNS 130 Thu 2012/12/06 04:09:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:10:37 System -170001 [Network] Failed DNS 131 Thu 2012/12/06 04:10:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:11:37 System -170001 [Network] Failed DNS 132 Thu 2012/12/06 04:11:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:12:37 System -170001 [Network] Failed DNS 133 Thu 2012/12/06 04:12:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:13:37 System -170001 [Network] Failed DNS 134 Thu 2012/12/06 04:13:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:14:37 System -170001 [Network] Failed DNS 135 Thu 2012/12/06 04:14:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:15:37 System -170001 [Network] Failed DNS 136 Thu 2012/12/06 04:15:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:16:37 System -170001 [Network] Failed DNS 137 Thu 2012/12/06 04:16:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:17:37 System -170001 [Network] Failed DNS 138 Thu 2012/12/06 04:17:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:18:37 System -170001 [Network] Failed DNS 139 Thu 2012/12/06 04:18:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:19:36 System -170001 [Network] Failed DNS 140 Thu 2012/12/06 04:19:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:20:36 System -170001 [Network] Failed DNS 141 Thu 2012/12/06 04:20:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:21:36 System -170001 [Network] Failed DNS 142 Thu 2012/12/06 04:21:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:22:36 System -170001 [Network] Failed DNS 143 Thu 2012/12/06 04:22:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:23:36 System -170001 [Network] Failed DNS 144 Thu 2012/12/06 04:23:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:24:36 System -170001 [Network] Failed DNS 145 Thu 2012/12/06 04:24:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:25:36 System -170001 [Network] Failed DNS 146 Thu 2012/12/06 04:25:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:26:36 System -170001 [Network] Failed DNS 147 Thu 2012/12/06 04:26:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:27:37 System -170001 [Network] Failed DNS 148 Thu 2012/12/06 04:27:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:28:37 System -170001 [Network] Failed DNS 149 Thu 2012/12/06 04:28:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:29:37 System -170001 [Network] Failed DNS 150 Thu 2012/12/06 04:29:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:30:37 System -170001 [Network] Failed DNS 151 Thu 2012/12/06 04:30:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:31:37 System -170001 [Network] Failed DNS 152 Thu 2012/12/06 04:31:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:32:37 System -170001 [Network] Failed DNS 153 Thu 2012/12/06 04:32:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:33:37 System -170001 [Network] Failed DNS 154 Thu 2012/12/06 04:33:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:34:37 System -170001 [Network] Failed DNS 155 Thu 2012/12/06 04:34:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:35:37 System -170001 [Network] Failed DNS 156 Thu 2012/12/06 04:35:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:36:37 System -170001 [Network] Failed DNS 157 Thu 2012/12/06 04:36:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:37:36 System -170001 [Network] Failed DNS 158 Thu 2012/12/06 04:37:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:38:36 System -170001 [Network] Failed DNS 159 Thu 2012/12/06 04:38:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:39:36 System -170001 [Network] Failed DNS 160 Thu 2012/12/06 04:39:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:40:36 System -170001 [Network] Failed DNS 161 Thu 2012/12/06 04:40:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:41:36 System -170001 [Network] Failed DNS 162 Thu 2012/12/06 04:41:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:42:36 System -170001 [Network] Failed DNS 163 Thu 2012/12/06 04:42:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:43:36 System -170001 [Network] Failed DNS 164 Thu 2012/12/06 04:43:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:44:36 System -170001 [Network] Failed DNS 165 Thu 2012/12/06 04:44:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:45:36 System -170001 [Network] Failed DNS 166 Thu 2012/12/06 04:45:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:46:36 System -170001 [Network] Failed DNS 167 Thu 2012/12/06 04:46:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:47:37 System -170001 [Network] Failed DNS 168 Thu 2012/12/06 04:47:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:48:37 System -170001 [Network] Failed DNS 169 Thu 2012/12/06 04:48:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:49:37 System -170001 [Network] Failed DNS 170 Thu 2012/12/06 04:49:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:50:37 System -170001 [Network] Failed DNS 171 Thu 2012/12/06 04:50:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:51:37 System -170001 [Network] Failed DNS 172 Thu 2012/12/06 04:51:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:52:37 System -170001 [Network] Failed DNS 173 Thu 2012/12/06 04:52:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:53:37 System -170001 [Network] Failed DNS 174 Thu 2012/12/06 04:53:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:54:37 System -170001 [Network] Failed DNS 175 Thu 2012/12/06 04:54:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:55:37 System -170001 [Network] Failed DNS 176 Thu 2012/12/06 04:55:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:56:37 System -170001 [Network] Failed DNS 177 Thu 2012/12/06 04:56:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:57:37 System -170001 [Network] Failed DNS 178 Thu 2012/12/06 04:57:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:58:37 System -170001 [Network] Failed DNS 179 Thu 2012/12/06 04:58:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:59:36 System -170001 [Network] Failed DNS 180 Thu 2012/12/06 04:59:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:00:36 System -170001 [Network] Failed DNS 181 Thu 2012/12/06 05:00:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:01:36 System -170001 [Network] Failed DNS 182 Thu 2012/12/06 05:01:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:02:36 System -170001 [Network] Failed DNS 183 Thu 2012/12/06 05:02:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:03:36 System -170001 [Network] Failed DNS 184 Thu 2012/12/06 05:03:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:04:36 System -170001 [Network] Failed DNS 185 Thu 2012/12/06 05:04:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:05:36 System -170001 [Network] Failed DNS 186 Thu 2012/12/06 05:05:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:06:36 System -170001 [Network] Failed DNS 187 Thu 2012/12/06 05:06:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:07:37 System -170001 [Network] Failed DNS 188 Thu 2012/12/06 05:07:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:08:37 System -170001 [Network] Failed DNS 189 Thu 2012/12/06 05:08:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:09:37 System -170001 [Network] Failed DNS 190 Thu 2012/12/06 05:09:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:10:37 System -170001 [Network] Failed DNS 191 Thu 2012/12/06 05:10:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:11:37 System -170001 [Network] Failed DNS 192 Thu 2012/12/06 05:11:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:12:37 System -170001 [Network] Failed DNS 193 Thu 2012/12/06 05:12:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:13:37 System -170001 [Network] Failed DNS 194 Thu 2012/12/06 05:13:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:14:37 System -170001 [Network] Failed DNS 195 Thu 2012/12/06 05:14:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:15:37 System -170001 [Network] Failed DNS 196 Thu 2012/12/06 05:15:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:16:37 System -170001 [Network] Failed DNS 197 Thu 2012/12/06 05:16:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:17:36 System -170001 [Network] Failed DNS 198 Thu 2012/12/06 05:17:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:18:36 System -170001 [Network] Failed DNS 199 Thu 2012/12/06 05:18:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:19:36 System -170001 [Network] Failed DNS 200 Thu 2012/12/06 05:19:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:20:36 System -170001 [Network] Failed DNS 201 Thu 2012/12/06 05:20:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:21:36 System -170001 [Network] Failed DNS 202 Thu 2012/12/06 05:21:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:22:37 System -170001 [Network] Failed DNS 203 Thu 2012/12/06 05:22:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:23:37 System -170001 [Network] Failed DNS 204 Thu 2012/12/06 05:23:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 12:42:54 System -60006 n/a Thu 2012/12/06 12:43:10 System -60006 n/a Thu 2012/12/06 12:43:25 System -60006 n/a Thu 2012/12/06 12:43:40 System -60006 n/a Thu 2012/12/06 12:43:40 System -60006 Stopping retries/next cycle Thu 2012/12/06 14:10:18 System -10 n/a Thu 2012/12/06 18:25:44 System -140005 CLI-WBug Fri 2012/12/07 00:44:10 System -60006 n/a Fri 2012/12/07 00:44:25 System -60006 n/a Fri 2012/12/07 00:44:40 System -60006 n/a Fri 2012/12/07 00:44:55 System -60006 n/a Fri 2012/12/07 02:00:34 System -140000 datafeed.weatherbug.com Fri 2012/12/07 02:01:34 System -140000 datafeed.weatherbug.com Fri 2012/12/07 02:02:33 System -140000 datafeed.weatherbug.com Fri 2012/12/07 02:03:33 System -140000 datafeed.weatherbug.com Fri 2012/12/07 02:04:33 System -140000 datafeed.weatherbug.com Fri 2012/12/07 02:05:33 System -140000 datafeed.weatherbug.com Fri 2012/12/07 02:06:33 System -140000 datafeed.weatherbug.com Fri 2012/12/07 12:45:24 System -60006 n/a Fri 2012/12/07 12:45:24 System -60006 Stopping retries/next cycle Sat 2012/12/08 00:45:58 System -60006 n/a Sat 2012/12/08 00:46:13 System -60006 n/a Sat 2012/12/08 00:46:28 System -60006 n/a Sat 2012/12/08 00:46:43 System -60006 n/a Sat 2012/12/08 00:46:58 System -60006 n/a Sat 2012/12/08 00:47:13 System -60006 n/a Sat 2012/12/08 00:47:13 System -60006 Stopping retries/next cycle Sat 2012/12/08 02:00:38 System -140000 datafeed.weatherbug.com Sat 2012/12/08 02:01:38 System -140000 datafeed.weatherbug.com Sat 2012/12/08 02:02:38 System -140000 datafeed.weatherbug.com Sat 2012/12/08 02:03:38 System -140000 datafeed.weatherbug.com Sat 2012/12/08 02:04:38 System -140000 datafeed.weatherbug.com Sat 2012/12/08 02:05:38 System -140000 datafeed.weatherbug.com Sat 2012/12/08 02:06:38 System -140000 datafeed.weatherbug.com Sat 2012/12/08 12:47:43 System -60006 n/a Sat 2012/12/08 12:47:58 System -60006 n/a Sat 2012/12/08 12:48:13 System -60006 n/a Sat 2012/12/08 12:48:28 System -60006 n/a Sat 2012/12/08 12:48:43 System -60006 n/a Sat 2012/12/08 12:48:58 System -60006 n/a Sat 2012/12/08 12:48:58 System -60006 Stopping retries/next cycle Sun 2012/12/09 02:00:25 System -140000 datafeed.weatherbug.com Sun 2012/12/09 02:01:25 System -140000 datafeed.weatherbug.com Sun 2012/12/09 02:02:25 System -140000 datafeed.weatherbug.com Sun 2012/12/09 02:03:24 System -140000 datafeed.weatherbug.com Sun 2012/12/09 02:04:24 System -140000 datafeed.weatherbug.com Sun 2012/12/09 02:05:24 System -140000 datafeed.weatherbug.com Sun 2012/12/09 02:06:24 System -140000 datafeed.weatherbug.com Sun 2012/12/09 12:49:39 System -60006 n/a Sun 2012/12/09 12:49:55 System -60006 n/a Sun 2012/12/09 12:50:10 System -60006 n/a Sun 2012/12/09 12:50:25 System -60006 n/a Sun 2012/12/09 12:50:40 System -60006 n/a Sun 2012/12/09 12:50:40 System -60006 Stopping retries/next cycle Sun 2012/12/09 23:38:30 System -170001 [uDSockets] HTTP:24 error:6 Sun 2012/12/09 23:38:35 System -170001 [uDSockets] HTTP:24 error:6 Sun 2012/12/09 23:38:40 System -170001 [uDSockets] HTTP:24 error:6 Sun 2012/12/09 23:38:45 System -170001 [uDSockets] HTTP:24 error:6 Mon 2012/12/10 00:51:11 System -60006 n/a Mon 2012/12/10 00:51:26 System -60006 n/a Mon 2012/12/10 00:51:41 System -60006 n/a Mon 2012/12/10 00:51:56 System -60006 n/a Mon 2012/12/10 00:52:11 System -60006 n/a Mon 2012/12/10 00:52:07 System -60006 Stopping retries/next cycle Mon 2012/12/10 02:00:21 System -140000 datafeed.weatherbug.com Mon 2012/12/10 02:01:21 System -140000 datafeed.weatherbug.com Mon 2012/12/10 02:02:21 System -140000 datafeed.weatherbug.com Mon 2012/12/10 02:03:21 System -140000 datafeed.weatherbug.com Mon 2012/12/10 02:04:21 System -140000 datafeed.weatherbug.com Mon 2012/12/10 02:05:21 System -140000 datafeed.weatherbug.com Mon 2012/12/10 02:06:21 System -140000 datafeed.weatherbug.com Mon 2012/12/10 12:52:39 System -60006 n/a Mon 2012/12/10 12:52:54 System -60006 n/a Mon 2012/12/10 12:53:09 System -60006 n/a Tue 2012/12/11 02:00:17 System -140000 datafeed.weatherbug.com Tue 2012/12/11 02:01:17 System -140000 datafeed.weatherbug.com Tue 2012/12/11 02:02:17 System -140000 datafeed.weatherbug.com Tue 2012/12/11 02:03:17 System -140000 datafeed.weatherbug.com Tue 2012/12/11 02:04:16 System -140000 datafeed.weatherbug.com Tue 2012/12/11 02:05:16 System -140000 datafeed.weatherbug.com Tue 2012/12/11 02:06:16 System -140000 datafeed.weatherbug.com Tue 2012/12/11 08:25:21 System -140005 CLI-WBug Tue 2012/12/11 08:29:18 System -140005 CLI-WBug Tue 2012/12/11 08:37:20 System -140005 CLI-WBug Tue 2012/12/11 08:39:17 System -170001 [TCP-Conn] -1/-140002, CLI-WBug Tue 2012/12/11 08:41:18 System -140005 CLI-WBug Tue 2012/12/11 08:54:17 System -170001 [TCP-Conn] -1/-140002, CLI-WBug Tue 2012/12/11 08:55:17 System -170001 [TCP-Conn] -1/-140002, CLI-WBug Tue 2012/12/11 12:53:57 System -60006 n/a Tue 2012/12/11 12:53:57 System -60006 Stopping retries/next cycle Tue 2012/12/11 22:36:20 System -140000 datafeed.weatherbug.com Wed 2012/12/12 00:54:32 System -60006 n/a Wed 2012/12/12 00:54:47 System -60006 n/a Wed 2012/12/12 02:00:12 System -140000 datafeed.weatherbug.com Wed 2012/12/12 02:01:12 System -140000 datafeed.weatherbug.com Wed 2012/12/12 02:02:12 System -140000 datafeed.weatherbug.com Wed 2012/12/12 02:03:12 System -140000 datafeed.weatherbug.com Wed 2012/12/12 02:04:12 System -140000 datafeed.weatherbug.com Wed 2012/12/12 02:05:12 System -140000 datafeed.weatherbug.com Wed 2012/12/12 02:06:12 System -140000 datafeed.weatherbug.com Wed 2012/12/12 11:35:14 System -140005 CLI-WBug Wed 2012/12/12 12:55:17 System -60006 n/a Wed 2012/12/12 12:55:32 System -60006 n/a Wed 2012/12/12 12:55:47 System -60006 n/a Wed 2012/12/12 12:55:47 System -60006 Stopping retries/next cycle Thu 2012/12/13 00:56:19 System -60006 n/a Thu 2012/12/13 00:56:34 System -60006 n/a Thu 2012/12/13 00:56:49 System -60006 n/a Thu 2012/12/13 00:57:04 System -60006 n/a Thu 2012/12/13 00:57:19 System -60006 n/a Thu 2012/12/13 00:57:34 System -60006 n/a Thu 2012/12/13 00:57:34 System -60006 Stopping retries/next cycle Thu 2012/12/13 02:00:16 System -140000 datafeed.weatherbug.com Thu 2012/12/13 02:01:16 System -140000 datafeed.weatherbug.com Thu 2012/12/13 02:02:16 System -140000 datafeed.weatherbug.com Thu 2012/12/13 02:03:16 System -140000 datafeed.weatherbug.com Thu 2012/12/13 02:04:16 System -140000 datafeed.weatherbug.com Thu 2012/12/13 02:05:16 System -140000 datafeed.weatherbug.com Thu 2012/12/13 02:06:16 System -140000 datafeed.weatherbug.com Thu 2012/12/13 12:58:06 System -60006 n/a Thu 2012/12/13 12:58:21 System -60006 n/a Thu 2012/12/13 12:58:36 System -60006 n/a Thu 2012/12/13 12:58:51 System -60006 n/a Thu 2012/12/13 12:59:06 System -60006 n/a Thu 2012/12/13 12:59:21 System -60006 n/a Thu 2012/12/13 23:16:04 System -5 Start Thu 2012/12/13 23:16:08 System -170001 [Network] Established Thu 2012/12/13 23:16:18 System -60006 n/a Thu 2012/12/13 23:16:24 System -140000 datafeed.weatherbug.com Fri 2012/12/14 16:28:46 System -5 Start Fri 2012/12/14 16:28:50 System -170001 [Network] Established Fri 2012/12/14 16:29:00 System -60006 n/a Fri 2012/12/14 16:29:19 System -10011 n/a Fri 2012/12/14 16:43:58 System -5 Start
  12. markgam replied to jmed999's topic in ISY994
    Depending upon the age and condition of you house, it shouldn't cost you more than $50-$100 to have an electrician come in and add a quad outlet in that closet. Just by your description it seems that you may have too many items running off of that single outlet as it is.
  13. All -- I just wanted to post this just in case some else finds themselves in the same quandary. I had a TriggerLinc (2421) that I purchased a few months ago but never added into my network. SO stupidly I apply the double face tape to the rear of the TriggerLinc without noting the device's address (Personally, I think the any device's address for any device should not be located in any surface that will be potentially covered with double faced tape but that is a discussion for another day). when I tried taking off the tape after realizing my error but the Address label was stuck to the tape and all efforts to retrieve the address were fruitless. So I tried linking the TriggerLinc by using the Auto linking (Start Linking) feature under the Link Management item in the ISY Admin Console but no luck. So I am racking my brain trying to figure out and I remembered that I can query a Device's link table (Tools --> Diagnostics) by using the ISY Admin Console. So I simply linked the TriggerLinc to a LampLinc Module that had no other linked devices and viola I found the address. Needless to say my SOP will be to record the Device's address in some other location on the device other than any surfaces that could potentially be covered for any reason. I hope this solution maybe helpful to some else in the future.
  14. markgam posted a topic in ISY994
    All -- I am getting error concerning my PLM and I am wondering if the cable between the PLM and the ISY is a regular Cat 5 Patch cable?
  15. That did the trick, thanks Michel!
  16. Lee - I used the following link to access the Admin Console: http://www.universal-devices.com/99i/2.8.11/ and on the About Form the version is still saying v.2.8.10
  17. Exactly the same outcome on a Mac; I had to apply the update twice. That is strange, Michel can you advise? BTW I used a Windows 7 machine to apply the update.
  18. I also just upgraded from v2.8.10 rc5 to v2.8.11 and my About Screen is still showing v2.8.10 (see below). I removed all Universal Devices certificates from Java and I cleared the Java Cache. Any ideas?
  19. Thanks! I love the changes especially being able to "run" the program from the program details tab. Keep up the great work!
  20. Michel, I just upgraded to v2.8.10 (RC-5) and I am impressed! Just one minor item involving teh new CUstom Notification Feature, when creating a new notification it would be nice if this form behaved similiar to the manner in which Outlook behaves specifically when you are in the Subject Field and press the tab key the cursor should be moved to the body field.
  21. markgam replied to rtt3821's topic in ISY994
    One other thing to consider especially if you are trying to access your public facing (ie extremal) ip address, make sure that there aren't filters that maybe forbidding access to external NAT'ed address from internal clients.
  22. It is working fine, but I just wanted to make sure that I hooked it up to the correct RS terminal on the T1800.
  23. I just purchased two Venstar T1800 Thermostat http://www.smarthome.com/2491T7/Venstar-Thermostat-INSTEON-Remote-Control-Thermostat-7-Day-Programmable/p.aspx and they were very simple to install on my 5 wire system. I also purchased the Venstar Indoor/Outdoor Remote Temperature Wired Sensor http://www.smarthome.com/30421/Venstar-Indoor-Outdoor-Remote-Temperature-Sensor/p.aspx. The instructions for the sensor weren't very clear so I have a question that I hope someone can answer, I originally hooked the remote sensor to the RS1 terminal of the T1800 but when I wanted to check the outside temperature it wasn't registering anything, so I decided to try the RS2 terminal and it seems to work fine. I just wanted to make sure that this is the correct way of connecting the sensor. Thanks!
  24. In addition to the AP's each Insteon device that you add acts as a repeater in addition to it's intended function. Are you having problem with problems controlling devices furtherest away from your PLM? Other things to look at is that you may have conflicting programs (ie one program turns on a light while another turns off the same light). Have you tried doing a factory reset on the controls that are giving you issues?
  25. Rick, You don't need to link the Access Points (AP) to the ISY but you do need to link them together. From the Smart Home website: The AP basically are used to repeat the Insteon commands across the different electrical branches in your house. You can however add as many AP as you wish as this will tend to increase the coverage of you Insteon Network. I hope this helps.
