EISY 6.0.5
@JTsao , do not upgrade. Two different issues.
Zigbee - Device Support Requests
We are getting one of these to implement the cluster. This said, most of our effort is being spent on Matter which already supports these clusters. Please stay tuned. With kind regards, Michel
EISY 6.0.5
@apostolakisl , please submit a ticket + include how many Z-Wave devices do you have? With kind regards, Michel
EISY 6.0.5
Our goal is to fully get rid of Java by the end of the year. We are about 85% there. With kind regards, Michel
EISY 6.0.5
No, the updates come directly from eisy. That said, depending on the version, UD Mobile might not get notifications that the upgrade was completed. So, it's always best to be local and using Admin Console just in case things go awry. With kind regards, Michel
Michel Kohanim started following OS 14.3/IoX 6 Release Is Now Available! , EISY 6.0.5 , Updated Software Available! and 1 other
Please submit a ticket with DH Clusters. If it's not in the energy cluster, it might not work. With kind regards, Michel
Please restart the admin console. With kind regards, Michel
Right mouse click | Zigbee | Update with Interview. With kind regards, Michel
Thanks. As you can see, it's not reporting any "energy" related clusters. With kind regards, Michel
Thank you. Please right mouse click | X-Ray, then copy/paste the contents of DH Cluster. With kind regards, Michel
@Guy Lavoie , can you please send me a link to this device? With kind regards, Michel
Hello All, I am happy to announce a set of updated software and OS for your eisy/polisy: OS v14.3p9 Security update UDX - v4.4.0_6 Support for manual static ip config Increase message queue size for mqtt Apply log viewing permission for udx/isy logs Added additional python prereq packages (jiter) Auto download Matter PAA certs IoX - v6.0.5_1 Improved Matter support Fixed programs timing during startup eisyui - v0.10.1 Navigation & Organization: Expanded the Node List to include support for Folders and Groups (Scenes). Groups/Scenes: Added a new Group Member Widget and detailed Scene Member Responder Links for improved visibility. Program Updates: Added visual identifiers with new Program Icons and Program Badges. Enhanced Program Action Details to display all available command parameters. Optimized UI for mobile devices System/Logs: Added log download Support hooks for AI (OpenAI and Claude) Bug fixes IMPORTANT NOTES: If our IoX Version is below 5.9.1, do not upgrade as your unit may get bricked Backup your unit before attempting any upgrade. This is CRUCIAL It's best to backup using eisyui. Upgrade MUST be done when you are local to your unit AND using the Admin Console If you are using Matter devices, they might not work after the upgrade. In that case, you need to restore your backup using eisyui. With kind regards, Michel
Gmail “tls error” message
Hello all, some comments: Make sure neither subject nor body are blank If you have 994, especially such old versions as 4.7.3, you are pretty much on your own because it does not support the new security suites required by google I know this is regarding gmail, but just in case you are using "Default", please note that over the years, we had to add many security/throttling/blacklisting mechanism to prevent hackers (and some customers) ruining our online mail reputation by sending mass emails. So, you might have been black listed. It's always best to use gmail If on polisy/eisy, and using gmail, please submit a ticket (https://www.universal-devices.com/my-tickets ) With kind regards, Michel
Recovery options for eisy Included in the original post. Home Assistant not starting up after upgrade: In order to support IPv6, /etc/rc.conf will be rewritten. If you had Home Assistant running, you might need to add the following lines in /etc/rc.conf: vm_list="homeassistant" vm_enable="YES" vm_dir="zfs:zudi/vms" If this still does not work, try: vm_dir="zfs:storage/vms" In short, you need to use the zfs pool name that you used during setup. eisy-ui with no status / Subscription not working With kind regards, Michel
Hello everyone, I am happy to announce the availability of OS14.3 and IoX 6. This is a major release which upgrades your OS to 14.3. WARNING: If your FreeBSD OS is below 13.2p11 (you can check via https://eisy.local:8443/WEB/sysconfig.txt for eisy and https://polisy.local:8443/WEB/sysconfig.txt for polisy) please do not attempt the upgrade. It will brick your system. Instead, backup your IoX and PG3 and then eisy: reflash your eisy using our USB stick (https://www.universal-devices.com/product/eisy-reflash-usb-stick/) Polisy: get a new SSD for your Polisy (https://www.universal-devices.com/product/polisy-os-ssd/) Do NOT attempt the upgrade if you are remote to your eisy/polisy and/or using ISY Portal. Do NOT attempt the upgrade if you are on WiFi. Make sure you're connected to your router using Ethernet. This is a major OS Upgrade. Please do NOT touch the unit till it comes back online or you're prompted to reboot. If your eisy does not come back online after 2 hours, try Recovery options for eisy at the bottom of this post. Instructions: Backup your Z-Wave if any (Z-Wave | Backup) Backup your IoX (File | Backup IoX) Backup your PG3 Click on Upgrade Packages in Admin Console | Configuration tab. Do NOT use ssh as it will brick your system. Enhancements: eisyui is now the default interface HomeKit support is now installed by default Better WiFi and Bluetooth support Dynamic profiles for better plugin support Node property history is now on by default Fixes: mqtt disconnects causes plugins to stop working misc fixes for plugin support Recovery options for eisy: Almost all issues related to this upgrade seem to be related to an interrupted upgrade especially when using UD Mobile or when eisy is on WiFi. If your eisy does not come back online after 2 hours, please do this: Press/hold the power button -> red. Attach an HDMI monitor and USB keyboard to eisy, then click the power button -> blue. Watch the monitor. If you do not get a login prompt, please submit a ticket, with a picture of the screen. Otherwise Login using admin as login and admin as password Issue the following commands. If prompted for password, type admin sudo rm /var/udx/.udx_install_cleanup sudo rm /var/udx/.upgrade_status sudo pkg install -f isy sudo service udx restart Wait for two minutes sudo service isy status If it does not show running, then submit a ticket with a picture of the screen. Otherwise Your eisy should now be available in your IoX Launcher. If it is, launch the Admin Console, go to the Configuration tab and click on Upgrade Packages button again. Wait till completion or reboot. If eisy is still not available in your IoX Launcher, then: sudo dhclient re0 sudo service udx restart Wait for two minutes sudo service isy status If it still does not show up in IoX Launcher, submit a ticket
Michel Kohanim
Administrators
Joined
Last visited
