mjrush
Everything posted by mjrush
  1. mjrush replied to Techman's topic in eisy
    I have the same problem with eisy-ui not loading nodes and reporting an "Error: Internal server error." Everything else seems ok.
  2. I use the Web Server Module to save data to files. https://wiki.universal-devices.com/ISY-994i_Series_INSTEON:Networking#Web_Server_Module I create my own log files if I want to keep track of something or record errors. It's like sending an email but it goes to a file. The file can be viewed in a web browser or you can copy it from eisy to another computer to view in Excel.
  3. 3.2.4 works. I can control the KP125M now. The power nodes populate but the voltage and current are 0. I don't see these in the Kasa app so I assume it doesn't report them. Thank you.
  4. Now it seams to be looking for: 2024-12-22 21:15:15.640 MainThread udi_interface ERROR udi_interface:write: No module named 'async_timeout' I will send a log package.
  5. I installed 3.2.2 in a new slot. Seems to be stuck in a loop with this error: 2024-12-22 16:31:31.319 MainThread udi_interface ERROR udi_interface:write: No module named 'mashumaro' I created a debug log file (maybe) should I attach it here or send another way?
  6. I get this before the PayPal window. The version is 3.2.2 here.
  7. When I activate, I get this. The version shows 3.2.1 but I activated 3.2.2.
  8. I was trying 3.2.2 but my view is different. I have Activate, not Install. My PG3x is 3.2.27. My installed version is 3.1.4.
  9. @Jimbo.Automates@bmercier I have 3.1.4 installed, which I purchased a while ago. The non-production store shows 3.2.1 and 3.2.2. 3.2.2 is listed as free but when I push the activate button it takes me to the portal and PayPal to buy it for $30. Do I need to install 3.2.1 first since the button is install? From the popup window: You currently do not have a valid license for this version of Kasa. Please click on the purchase button below. NOTE: After completing your purchase return here and click on Install. Purchase takes me to the portal and PayPal.
  10. @Jimbo.Automates I have been traveling so I haven't had a chance to try this. I went to the non-production store to install 3.2.2 and there is an activate button. When I press the button, it wants me to purchase a license. The description says free trial. Am I doing something wrong? Also do I need to do an update of PG3x 3.2.27? IoX is 5.8.4. Can the old and new versions coexist? Thanks for supporting this.
  11. I have some tp-link Kasa KL125 WiFi bulbs and I use the Kasa plugin to talk to them. I tried the MagicHome plugin but the bulbs I tried didn't work very well.
  12. I think you need to link the devices by creating a scene with the ISY994. If you link the devices using the paddles on the devices, the ISY994 doesn't know what is linked. I hope I got this correct. I don't know if it's possible to import links.
  13. I tried searching for programs again. When it does find a program it seems to be a program that's called by another program. It finds the text in a program, not the actual program. Maybe it's not really looking for programs but references to programs. I never used this feature before. When I see something in the forum that I haven't tried before, sometimes I will try it. Learned a lot of things from the forum.
  14. I've never used the Find/Replace on programs before. I just tried it and there appears to be a lot of programs it can't find. This is on eisy v5.8.0.
  15. mjrush replied to Panda88's topic in YoLink
    Works for me too.
  16. mjrush replied to Panda88's topic in YoLink
    I'm not very familiar with logs. I did Log, selected Debug, Start. Then I tried to download the Log Package. I received a red popup with file not found. I tried some other Log options and never did get a log window.
  17. mjrush replied to Panda88's topic in YoLink
    I'm having the same problem. eisy, PG3x 3.2.8. The installed version is 0.9.63, status is disconnected. Tried Update Packages, reboot, power cycle, reinstall, stop, start. The YoLink nodes show in PG3x but not in the AC.
  18. Thank you. I see the new version now.
  19. I'm seeing the same behavior. I tried updating, reinstalling, starting and stopping but the displayed version changes back to 3.0.22. I seems like the new version is installed, there are new timeout options.
  20. The OS didn't update so I tried the update again. The message said the OS would update. The OS didn't seem to update but the programs are now enabled. Trying the update again.
  21. I updated Polisy this morning and all the programs were disabled. I sent the requested output to Chris.
  22. I tried a KP125M plug and the NS doesn't find it. The Kasa app does find it. I have some Kasa bulbs that work fine with the NS.
  23. I have a message in PG3x 3.1.27 that says an update to 0.8.97 is available. I tried the update and an install from the store but the Yolink version still shows as 0.8.90 and the update available message returns.
  24. I added two programs to query a zooz door sensor and tilt sensor. These devices don't seem to update the battery level. The documentation says they should wake up and send the level every 12 hours but it doesn't seem to work. Some time after I added the programs, the log started to fill and lights stopped responding to motion sensors. I believe that checking to see if the sensor was awake caused the problems. I don't think the programs were constantly running.
  25. I didn't see any -199 events. I search the error log for -199 and didn't find anything.
