agoltz
Everything posted by agoltz
  1. Bought the Zooz 800 Zwave stick and plugged in - restarted with the setting on Auto. Nothing. In the wiki it says they are migrating to ISY only Zmatter USB - but its out of stock Really frustrating. If Ihave to use the ISY one (ok with me) - then at least have it available
  2. Looking at the UDI store I dont see that their dongle is in stock. Im going to get the Zooz 800 series USB and see how it goes
  3. Dumb question but Im an insteon user. Have an eisy running 6.0.4 but am not seeing how to add Z-wave (its set to auto on the config screen) Reason is that I just bought the Zooz Titan valve actuator to turn the water supply on and off and need to figure out how to connect to it. I am a TOTAL Z-wave newbie and dont recall anymore if the EISY came with Z-wave. Thanks and be patient with a Zwave newbie
  4. So I had a tech support session and Michel did some console updates. Now things appear to be working, and interestingly I can only access PG3 through chrome (safari cannot find it). Oh well were back up.
  5. Quick question - I have a PG3 that I cannot log into. Asks for credentials and nothing when I hit return. Wont autofind IOX or manually..... Is this something similar?
  6. Ok - now when I do an individual restore on that switch, the program runs........ Ugh - I did a RESTORE DEVICES three times, you would think this is not something that needs to be done each reboot. Still wondering whats going on as the old 994 was rock solid. So far Id rate this a 2/10 for experience. Should not be that hard.
  7. Did that. Still nothing. I am trying to turn on a bathroom light, which in turn triggers a program to turn on the bathroom fan for 5 minutes. Worked perfectly on the 994 and now it wont even register the light as on. If I turn it on from the console (not the light switch) - the program runs. Checked the switches and they have been updated to point to the new PLM
  8. I will say though, that at least the New PLM (usb) now has a complete links table, so at the very least the PLM now sees all the devices. IOX does not register state changes (so when I turn a switch on, it does not show on on the Java App Console, but when I query it it will give a correct state)
  9. Update - spoke to tech support. Did a restore and it worked for about an hour (programs). Then tried (unsuccessfully) to log into Polyglot 3 and IOX is no longer working. So frustrating. Three full days doing this and it works for a bit, then dies. Full restore, works for a bit, then dies.
  10. Running 5.6.2 of IOX, I did clear the cache and download the new IOX finder. (it actually wont let you start IOX otherwise). The more I think about it - the more im focusing on why the devices dont have the new PLM address. Am going to rerun (again) the restore devices procedure (pain in the butt as I have to get a ladder and go get all the motion sensors down)
  11. It would appear that all the devices dont have a link corresponding to the new PLM - even though I have tried restore devices. When I do one individually - I appears to store the new PLM in its links table. Strange
  12. ScreenShot 2023-06-18 at 2.37.49 PM.pdf Three screenshots if that helpsScreenShot 2023-06-18 at 2.38.24 PM.pdfScreenShot 2023-06-18 at 2.38.49 PM.pdf I have over 50 devices.
  13. Hi Everyone, Wanted to see if anyone had any suggestions. I had an ISY 994 and bought an EISY. Followed the migration wiki (no zwave, only insteon), and backed up the 994 - restored to the eisy. Since I had a Serial PLM, I bought a new one from the Insteon store (USB) and replaced the old one, did a Restore Modem and am not in a situation where the ISY does not see the insteon devices turning on and off. However when I query the device, it updates to the correct status (light on / off). When I look at the PLM links table it only has two links??? Which is weird. I have tried to reset and restore the PLM twice, and both times dont see more than two links. When I open the event viewer, it does not show events like lights turning on (and hence no programs run). But when I query the device, I get the correct status. Im stumped. (also the Polyglot V3 on the eisy wont connect to the IOX server automatically, or when I enter the loopback address....) there is something going on that I cannot figure out (I did transfer all the module licenses on the portal from my old ISY to the new one, so no going back.) Support ticket has been opened, but wondering what else I haven't thought of. (THis is the part where you realize how useful programs like turn the lights on at dark, lower the curtains really are) Thanks
  14. thank you so much!!! This is great news.
  15. So I have the same issue as above. Utility voltage is 0 Log file follows - I see a number for Utility Voltage.... But on the summary screen it shows 0 as EVICTORY posted above. Run-in NodeLink Server v0.10.6 Any chance we can address this? Thanks Alex 2021-02-03 13:03:08 - GenMon Raw Data: {"Status": [{"Engine": [{"Switch State": "Auto"}, {"Engine State": "Off - Ready"}, {"Battery Voltage": "14.70 V"}, {"RPM": "0 "}, {"Frequency": "0.00 Hz"}, {"Output Voltage": "0 V"}, {"Active Rotor Poles (Calculated)": "0 "}]}, {"Line": [{"Utility Voltage": "237 V"}, {"Utility Max Voltage": "246 V"}, {"Utility Min Voltage": "232 V"}, {"Utility Threshold Voltage": "144 V"}]}, {"Last Log Entries": {"Logs": {"Alarm Log": "08/22/20 10:12:15 Inspect Air Filter ", "Run Log": "01/30/21 10:12:13 Stopped - Auto "}}}, {"Time": [{"Monitor Time": "Wednesday February 3, 2021 13:03:08"}, {"Generator Time": "Wednesday February 3, 2021 13:03"}]}]}EndOfMessage [genmon1] 2021-02-03 13:03:09 - GenMon Raw Data: {"Monitor": [{"Generator Monitor Stats": [{"Monitor Health": "OK"}, {"Controller": "Nexus, Liquid Cooled"}, {"Run time": "Generator Monitor running for 3:20:46."}, {"Generator Monitor Version": "V1.15.17"}, {"Update Available": "No"}]}, {"Communication Stats": [{"Packet Count": "M: 385976, S: 385975"}, {"CRC Errors": "0 "}, {"CRC Percent Errors": "0.00%"}, {"Timeout Errors": "0"}, {"Timeout Percent Errors": "0.00%"}, {"Modbus Exceptions": 0}, {"Validation Errors": 0}, {"Sync Errors": 0}, {"Invalid Data": 0}, {"Discarded Bytes": "0"}, {"Comm Restarts": "0"}, {"Packets Per Second": "64.08"}, {"Average Transaction Time": "0.0306 sec"}]}, {"Platform Stats": [{"CPU Temperature": "97.70 F"}, {"Pi Model": "Raspberry Pi 3 Model A Plus Rev 1.0"}, {"Pi CPU Frequency Throttling": "OK"}, {"Pi ARM Frequency Cap": "OK"}, {"Pi Undervoltage": "OK"}, {"CPU Utilization": "3.02%"}, {"OS Name": "Raspbian GNU/Linux"}, {"OS Version": "10 (buster)"}, {"System Uptime": "3:21:29"}, {"Network Interface Used": "wlan0"}, {"WLAN Signal Level": "-80 dBm"}, {"WLAN Signal Quality": "30/70"}, {"WLAN Signal Noise": "-256 dBm"}, {"WLAN ESSID": "DEV_2"}, {"System Time": "Wednesday February 3, 2021 13:03:09"}]}, {"Weather": [{"Current Temperature": "63.25 F"}, {"Conditions": "Clear Sky"}]}]}EndOfMessage [genmon1] 2021-02-03 13:03:24 - GenMon Raw Data: {"Status": [{"Engine": [{"Switch State": "Auto"}, {"Engine State": "Off - Ready"}, {"Battery Voltage": "14.70 V"}, {"RPM": "0 "}, {"Frequency": "0.00 Hz"}, {"Output Voltage": "0 V"}, {"Active Rotor Poles (Calculated)": "0 "}]}, {"Line": [{"Utility Voltage": "239 V"}, {"Utility Max Voltage": "246 V"}, {"Utility Min Voltage": "232 V"}, {"Utility Threshold Voltage": "144 V"}]}, {"Last Log Entries": {"Logs": {"Alarm Log": "08/22/20 10:12:15 Inspect Air Filter ", "Run Log": "01/30/21 10:12:13 Stopped - Auto "}}}, {"Time": [{"Monitor Time": "Wednesday February 3, 2021 13:03:24"}, {"Generator Time": "Wednesday February 3, 2021 13:04"}]}]}EndOfMessage [genmon1] 2021-02-03 13:03:25 - GenMon Raw Data: {"Monitor": [{"Generator Monitor Stats": [{"Monitor Health": "OK"}, {"Controller": "Nexus, Liquid Cooled"}, {"Run time": "Generator Monitor running for 3:21:02."}, {"Generator Monitor Version": "V1.15.17"}, {"Update Available": "No"}]}, {"Communication Stats": [{"Packet Count": "M: 386488, S: 386488"}, {"CRC Errors": "0 "}, {"CRC Percent Errors": "0.00%"}, {"Timeout Errors": "0"}, {"Timeout Percent Errors": "0.00%"}, {"Modbus Exceptions": 0}, {"Validation Errors": 0}, {"Sync Errors": 0}, {"Invalid Data": 0}, {"Discarded Bytes": "0"}, {"Comm Restarts": "0"}, {"Packets Per Second": "64.08"}, {"Average Transaction Time": "0.0306 sec"}]}, {"Platform Stats": [{"CPU Temperature": "98.60 F"}, {"Pi Model": "Raspberry Pi 3 Model A Plus Rev 1.0"}, {"Pi CPU Frequency Throttling": "OK"}, {"Pi ARM Frequency Cap": "OK"}, {"Pi Undervoltage": "OK"}, {"CPU Utilization": "3.03%"}, {"OS Name": "Raspbian GNU/Linux"}, {"OS Version": "10 (buster)"}, {"System Uptime": "3:21:45"}, {"Network Interface Used": "wlan0"}, {"WLAN Signal Level": "-81 dBm"}, {"WLAN Signal Quality": "29/70"}, {"WLAN Signal Noise": "-256 dBm"}, {"WLAN ESSID": "DEV_2"}, {"System Time": "Wednesday February 3, 2021 13:03:25"}]}, {"Weather": [{"Current Temperature": "63.25 F"}, {"Conditions": "Clear Sky"}]}]}EndOfMessage [genmon1] 2021-02-03 13:03:40 - GenMon Raw Data: {"Status": [{"Engine": [{"Switch State": "Auto"}, {"Engine State": "Off - Ready"}, {"Battery Voltage": "14.70 V"}, {"RPM": "0 "}, {"Frequency": "0.00 Hz"}, {"Output Voltage": "0 V"}, {"Active Rotor Poles (Calculated)": "0 "}]}, {"Line": [{"Utility Voltage": "236 V"}, {"Utility Max Voltage": "246 V"}, {"Utility Min Voltage": "232 V"}, {"Utility Threshold Voltage": "144 V"}]}, {"Last Log Entries": {"Logs": {"Alarm Log": "08/22/20 10:12:15 Inspect Air Filter ", "Run Log": "01/30/21 10:12:13 Stopped - Auto "}}}, {"Time": [{"Monitor Time": "Wednesday February 3, 2021 13:03:40"}, {"Generator Time": "Wednesday February 3, 2021 13:04"}]}]}EndOfMessage [genmon1] 2021-02-03 13:03:41 - GenMon Raw Data: {"Monitor": [{"Generator Monitor Stats": [{"Monitor Health": "OK"}, {"Controller": "Nexus, Liquid Cooled"}, {"Run time": "Generator Monitor running for 3:21:18."}, {"Generator Monitor Version": "V1.15.17"}, {"Update Available": "No"}]}, {"Communication Stats": [{"Packet Count": "M: 387001, S: 387001"}, {"CRC Errors": "0 "}, {"CRC Percent Errors": "0.00%"}, {"Timeout Errors": "0"}, {"Timeout Percent Errors": "0.00%"}, {"Modbus Exceptions": 0}, {"Validation Errors": 0}, {"Sync Errors": 0}, {"Invalid Data": 0}, {"Discarded Bytes": "0"}, {"Comm Restarts": "0"}, {"Packets Per Second": "64.08"}, {"Average Transaction Time": "0.0306 sec"}]}, {"Platform Stats": [{"CPU Temperature": "97.70 F"}, {"Pi Model": "Raspberry Pi 3 Model A Plus Rev 1.0"}, {"Pi CPU Frequency Throttling": "OK"}, {"Pi ARM Frequency Cap": "OK"}, {"Pi Undervoltage": "OK"}, {"CPU Utilization": "3.03%"}, {"OS Name": "Raspbian GNU/Linux"}, {"OS Version": "10 (buster)"}, {"System Uptime": "3:22:01"}, {"Network Interface Used": "wlan0"}, {"WLAN Signal Level": "-78 dBm"}, {"WLAN Signal Quality": "32/70"}, {"WLAN Signal Noise": "-256 dBm"}, {"WLAN ESSID": "DEV_2"}, {"System Time": "Wednesday February 3, 2021 13:03:41"}]}, {"Weather": [{"Current Temperature": "63.25 F"}, {"Conditions": "Clear Sky"}]}]}EndOfMessage [genmon1] 2021-02-03 13:03:56 - GenMon Raw Data: {"Status": [{"Engine": [{"Switch State": "Auto"}, {"Engine State": "Off - Ready"}, {"Battery Voltage": "14.70 V"}, {"RPM": "0 "}, {"Frequency": "0.00 Hz"}, {"Output Voltage": "0 V"}, {"Active Rotor Poles (Calculated)": "0 "}]}, {"Line": [{"Utility Voltage": "236 V"}, {"Utility Max Voltage": "246 V"}, {"Utility Min Voltage": "232 V"}, {"Utility Threshold Voltage": "144 V"}]}, {"Last Log Entries": {"Logs": {"Alarm Log": "08/22/20 10:12:15 Inspect Air Filter ", "Run Log": "01/30/21 10:12:13 Stopped - Auto "}}}, {"Time": [{"Monitor Time": "Wednesday February 3, 2021 13:03:56"}, {"Generator Time": "Wednesday February 3, 2021 13:04"}]}]}EndOfMessage [genmon1] 2021-02-03 13:03:57 - GenMon Raw Data: {"Monitor": [{"Generator Monitor Stats": [{"Monitor Health": "OK"}, {"Controller": "Nexus, Liquid Cooled"}, {"Run time": "Generator Monitor running for 3:21:34."}, {"Generator Monitor Version": "V1.15.17"}, {"Update Available": "No"}]}, {"Communication Stats": [{"Packet Count": "M: 387513, S: 387512"}, {"CRC Errors": "0 "}, {"CRC Percent Errors": "0.00%"}, {"Timeout Errors": "0"}, {"Timeout Percent Errors": "0.00%"}, {"Modbus Exceptions": 0}, {"Validation Errors": 0}, {"Sync Errors": 0}, {"Invalid Data": 0}, {"Discarded Bytes": "0"}, {"Comm Restarts": "0"}, {"Packets Per Second": "64.08"}, {"Average Transaction Time": "0.0306 sec"}]}, {"Platform Stats": [{"CPU Temperature": "99.68 F"}, {"Pi Model": "Raspberry Pi 3 Model A Plus Rev 1.0"}, {"Pi CPU Frequency Throttling": "OK"}, {"Pi ARM Frequency Cap": "OK"}, {"Pi Undervoltage": "OK"}, {"CPU Utilization": "3.03%"}, {"OS Name": "Raspbian GNU/Linux"}, {"OS Version": "10 (buster)"}, {"System Uptime": "3:22:17"}, {"Network Interface Used": "wlan0"}, {"WLAN Signal Level": "-80 dBm"}, {"WLAN Signal Quality": "30/70"}, {"WLAN Signal Noise": "-256 dBm"}, {"WLAN ESSID": "DEV_2"}, {"System Time": "Wednesday February 3, 2021 13:03:57"}]}, {"Weather": [{"Current Temperature": "63.25 F"}, {"Conditions": "Clear Sky"}]}]}EndOfMessage [genmon1] 2021-02-03 13:04:12 - GenMon Raw Data: {"Status": [{"Engine": [{"Switch State": "Auto"}, {"Engine State": "Off - Ready"}, {"Battery Voltage": "14.70 V"}, {"RPM": "0 "}, {"Frequency": "0.00 Hz"}, {"Output Voltage": "0 V"}, {"Active Rotor Poles (Calculated)": "0 "}]}, {"Line": [{"Utility Voltage": "238 V"}, {"Utility Max Voltage": "246 V"}, {"Utility Min Voltage": "232 V"}, {"Utility Threshold Voltage": "144 V"}]}, {"Last Log Entries": {"Logs": {"Alarm Log": "08/22/20 10:12:15 Inspect Air Filter ", "Run Log": "01/30/21 10:12:13 Stopped - Auto "}}}, {"Time": [{"Monitor Time": "Wednesday February 3, 2021 13:04:12"}, {"Generator Time": "Wednesday February 3, 2021 13:04"}]}]}EndOfMessage [genmon1] 2021-02-03 13:04:13 - GenMon Raw Data: {"Monitor": [{"Generator Monitor Stats": [{"Monitor Health": "OK"}, {"Controller": "Nexus, Liquid Cooled"}, {"Run time": "Generator Monitor running for 3:21:50."}, {"Generator Monitor Version": "V1.15.17"}, {"Update Available": "No"}]}, {"Communication Stats": [{"Packet Count": "M: 388026, S: 388025"}, {"CRC Errors": "0 "}, {"CRC Percent Errors": "0.00%"}, {"Timeout Errors": "0"}, {"Timeout Percent Errors": "0.00%"}, {"Modbus Exceptions": 0}, {"Validation Errors": 0}, {"Sync Errors": 0}, {"Invalid Data": 0}, {"Discarded Bytes": "0"}, {"Comm Restarts": "0"}, {"Packets Per Second": "64.08"}, {"Average Transaction Time": "0.0306 sec"}]}, {"Platform Stats": [{"CPU Temperature": "98.60 F"}, {"Pi Model": "Raspberry Pi 3 Model A Plus Rev 1.0"}, {"Pi CPU Frequency Throttling": "OK"}, {"Pi ARM Frequency Cap": "OK"}, {"Pi Undervoltage": "OK"}, {"CPU Utilization": "3.03%"}, {"OS Name": "Raspbian GNU/Linux"}, {"OS Version": "10 (buster)"}, {"System Uptime": "3:22:33"}, {"Network Interface Used": "wlan0"}, {"WLAN Signal Level": "-80 dBm"}, {"WLAN Signal Quality": "30/70"}, {"WLAN Signal Noise": "-256 dBm"}, {"WLAN ESSID": "DEV_2"}, {"System Time": "Wednesday February 3, 2021 13:04:13"}]}, {"Weather": [{"Current Temperature": "63.25 F"}, {"Conditions": "Clear Sky"}]}]}EndOfMessage [genmon1] 2021-02-03 13:04:28 - GenMon Raw Data: {"Status": [{"Engine": [{"Switch State": "Auto"}, {"Engine State": "Off - Ready"}, {"Battery Voltage": "14.70 V"}, {"RPM": "0 "}, {"Frequency": "0.00 Hz"}, {"Output Voltage": "0 V"}, {"Active Rotor Poles (Calculated)": "0 "}]}, {"Line": [{"Utility Voltage": "237 V"}, {"Utility Max Voltage": "246 V"}, {"Utility Min Voltage": "232 V"}, {"Utility Threshold Voltage": "144 V"}]}, {"Last Log Entries": {"Logs": {"Alarm Log": "08/22/20 10:12:15 Inspect Air Filter ", "Run Log": "01/30/21 10:12:13 Stopped - Auto "}}}, {"Time": [{"Monitor Time": "Wednesday February 3, 2021 13:04:28"}, {"Generator Time": "Wednesday February 3, 2021 13:05"}]}]}EndOfMessage [genmon1] 2021-02-03 13:04:29 - GenMon Raw Data: {"Monitor": [{"Generator Monitor Stats": [{"Monitor Health": "OK"}, {"Controller": "Nexus, Liquid Cooled"}, {"Run time": "Generator Monitor running for 3:22:06."}, {"Generator Monitor Version": "V1.15.17"}, {"Update Available": "No"}]}, {"Communication Stats": [{"Packet Count": "M: 388539, S: 388538"}, {"CRC Errors": "0 "}, {"CRC Percent Errors": "0.00%"}, {"Timeout Errors": "0"}, {"Timeout Percent Errors": "0.00%"}, {"Modbus Exceptions": 0}, {"Validation Errors": 0}, {"Sync Errors": 0}, {"Invalid Data": 0}, {"Discarded Bytes": "0"}, {"Comm Restarts": "0"}, {"Packets Per Second": "64.08"}, {"Average Transaction Time": "0.0306 sec"}]}, {"Platform Stats": [{"CPU Temperature": "99.68 F"}, {"Pi Model": "Raspberry Pi 3 Model A Plus Rev 1.0"}, {"Pi CPU Frequency Throttling": "OK"}, {"Pi ARM Frequency Cap": "OK"}, {"Pi Undervoltage": "OK"}, {"CPU Utilization": "3.03%"}, {"OS Name": "Raspbian GNU/Linux"}, {"OS Version": "10 (buster)"}, {"System Uptime": "3:22:49"}, {"Network Interface Used": "wlan0"}, {"WLAN Signal Level": "-81 dBm"}, {"WLAN Signal Quality": "29/70"}, {"WLAN Signal Noise": "-256 dBm"}, {"WLAN ESSID": "DEV_2"}, {"System Time": "Wednesday February 3, 2021 13:04:29"}]}, {"Weather": [{"Current Temperature": "63.25 F"}, {"Conditions": "Clear Sky"}]}]}EndOfMessage [genmon1] 2021-02-03 13:04:44 - GenMon Raw Data: {"Status": [{"Engine": [{"Switch State": "Auto"}, {"Engine State": "Off - Ready"}, {"Battery Voltage": "14.70 V"}, {"RPM": "0 "}, {"Frequency": "0.00 Hz"}, {"Output Voltage": "0 V"}, {"Active Rotor Poles (Calculated)": "0 "}]}, {"Line": [{"Utility Voltage": "240 V"}, {"Utility Max Voltage": "246 V"}, {"Utility Min Voltage": "232 V"}, {"Utility Threshold Voltage": "144 V"}]}, {"Last Log Entries": {"Logs": {"Alarm Log": "08/22/20 10:12:15 Inspect Air Filter ", "Run Log": "01/30/21 10:12:13 Stopped - Auto "}}}, {"Time": [{"Monitor Time": "Wednesday February 3, 2021 13:04:44"}, {"Generator Time": "Wednesday February 3, 2021 13:05"}]}]}EndOfMessage [genmon1] 2021-02-03 13:04:45 - GenMon Raw Data: {"Monitor": [{"Generator Monitor Stats": [{"Monitor Health": "OK"}, {"Controller": "Nexus, Liquid Cooled"}, {"Run time": "Generator Monitor running for 3:22:22."}, {"Generator Monitor Version": "V1.15.17"}, {"Update Available": "No"}]}, {"Communication Stats": [{"Packet Count": "M: 389050, S: 389049"}, {"CRC Errors": "0 "}, {"CRC Percent Errors": "0.00%"}, {"Timeout Errors": "0"}, {"Timeout Percent Errors": "0.00%"}, {"Modbus Exceptions": 0}, {"Validation Errors": 0}, {"Sync Errors": 0}, {"Invalid Data": 0}, {"Discarded Bytes": "0"}, {"Comm Restarts": "0"}, {"Packets Per Second": "64.08"}, {"Average Transaction Time": "0.0306 sec"}]}, {"Platform Stats": [{"CPU Temperature": "99.68 F"}, {"Pi Model": "Raspberry Pi 3 Model A Plus Rev 1.0"}, {"Pi CPU Frequency Throttling": "OK"}, {"Pi ARM Frequency Cap": "OK"}, {"Pi Undervoltage": "OK"}, {"CPU Utilization": "3.04%"}, {"OS Name": "Raspbian GNU/Linux"}, {"OS Version": "10 (buster)"}, {"System Uptime": "3:23:05"}, {"Network Interface Used": "wlan0"}, {"WLAN Signal Level": "-79 dBm"}, {"WLAN Signal Quality": "31/70"}, {"WLAN Signal Noise": "-256 dBm"}, {"WLAN ESSID": "DEV_2"}, {"System Time": "Wednesday February 3, 2021 13:04:45"}]}, {"Weather": [{"Current Temperature": "63.25 F"}, {"Conditions": "Clear Sky"}]}]}EndOfMessage [genmon1] 2021-02-03 13:05:00 - GenMon Raw Data: {"Status": [{"Engine": [{"Switch State": "Auto"}, {"Engine State": "Off - Ready"}, {"Battery Voltage": "14.70 V"}, {"RPM": "0 "}, {"Frequency": "0.00 Hz"}, {"Output Voltage": "0 V"}, {"Active Rotor Poles (Calculated)": "0 "}]}, {"Line": [{"Utility Voltage": "238 V"}, {"Utility Max Voltage": "246 V"}, {"Utility Min Voltage": "232 V"}, {"Utility Threshold Voltage": "144 V"}]}, {"Last Log Entries": {"Logs": {"Alarm Log": "08/22/20 10:12:15 Inspect Air Filter ", "Run Log": "01/30/21 10:12:13 Stopped - Auto "}}}, {"Time": [{"Monitor Time": "Wednesday February 3, 2021 13:05:00"}, {"Generator Time": "Wednesday February 3, 2021 13:05"}]}]}EndOfMessage [genmon1] 2021-02-03 13:05:01 - GenMon Raw Data: {"Monitor": [{"Generator Monitor Stats": [{"Monitor Health": "OK"}, {"Controller": "Nexus, Liquid Cooled"}, {"Run time": "Generator Monitor running for 3:22:38."}, {"Generator Monitor Version": "V1.15.17"}, {"Update Available": "No"}]}, {"Communication Stats": [{"Packet Count": "M: 389564, S: 389563"}, {"CRC Errors": "0 "}, {"CRC Percent Errors": "0.00%"}, {"Timeout Errors": "0"}, {"Timeout Percent Errors": "0.00%"}, {"Modbus Exceptions": 0}, {"Validation Errors": 0}, {"Sync Errors": 0}, {"Invalid Data": 0}, {"Discarded Bytes": "0"}, {"Comm Restarts": "0"}, {"Packets Per Second": "64.08"}, {"Average Transaction Time": "0.0306 sec"}]}, {"Platform Stats": [{"CPU Temperature": "101.48 F"}, {"Pi Model": "Raspberry Pi 3 Model A Plus Rev 1.0"}, {"Pi CPU Frequency Throttling": "OK"}, {"Pi ARM Frequency Cap": "OK"}, {"Pi Undervoltage": "OK"}, {"CPU Utilization": "3.05%"}, {"OS Name": "Raspbian GNU/Linux"}, {"OS Version": "10 (buster)"}, {"System Uptime": "3:23:21"}, {"Network Interface Used": "wlan0"}, {"WLAN Signal Level": "-80 dBm"}, {"WLAN Signal Quality": "30/70"}, {"WLAN Signal Noise": "-256 dBm"}, {"WLAN ESSID": "DEV_2"}, {"System Time": "Wednesday February 3, 2021 13:05:01"}]}, {"Weather": [{"Current Temperature": "63.25 F"}, {"Conditions": "Clear Sky"}]}]}EndOfMessage [genmon1] 2021-02-03 13:05:16 - GenMon Raw Data: {"Status": [{"Engine": [{"Switch State": "Auto"}, {"Engine State": "Off - Ready"}, {"Battery Voltage": "14.70 V"}, {"RPM": "0 "}, {"Frequency": "0.00 Hz"}, {"Output Voltage": "0 V"}, {"Active Rotor Poles (Calculated)": "0 "}]}, {"Line": [{"Utility Voltage": "237 V"}, {"Utility Max Voltage": "246 V"}, {"Utility Min Voltage": "232 V"}, {"Utility Threshold Voltage": "144 V"}]}, {"Last Log Entries": {"Logs": {"Alarm Log": "08/22/20 10:12:15 Inspect Air Filter ", "Run Log": "01/30/21 10:12:13 Stopped - Auto "}}}, {"Time": [{"Monitor Time": "Wednesday February 3, 2021 13:05:16"}, {"Generator Time": "Wednesday February 3, 2021 13:05"}]}]}EndOfMessage [genmon1] 2021-02-03 13:05:17 - GenMon Raw Data: {"Monitor": [{"Generator Monitor Stats": [{"Monitor Health": "OK"}, {"Controller": "Nexus, Liquid Cooled"}, {"Run time": "Generator Monitor running for 3:22:54."}, {"Generator Monitor Version": "V1.15.17"}, {"Update Available": "No"}]}, {"Communication Stats": [{"Packet Count": "M: 390075, S: 390074"}, {"CRC Errors": "0 "}, {"CRC Percent Errors": "0.00%"}, {"Timeout Errors": "0"}, {"Timeout Percent Errors": "0.00%"}, {"Modbus Exceptions": 0}, {"Validation Errors": 0}, {"Sync Errors": 0}, {"Invalid Data": 0}, {"Discarded Bytes": "0"}, {"Comm Restarts": "0"}, {"Packets Per Second": "64.08"}, {"Average Transaction Time": "0.0306 sec"}]}, {"Platform Stats": [{"CPU Temperature": "101.48 F"}, {"Pi Model": "Raspberry Pi 3 Model A Plus Rev 1.0"}, {"Pi CPU Frequency Throttling": "OK"}, {"Pi ARM Frequency Cap": "OK"}, {"Pi Undervoltage": "OK"}, {"CPU Utilization": "3.05%"}, {"OS Name": "Raspbian GNU/Linux"}, {"OS Version": "10 (buster)"}, {"System Uptime": "3:23:37"}, {"Network Interface Used": "wlan0"}, {"WLAN Signal Level": "-79 dBm"}, {"WLAN Signal Quality": "31/70"}, {"WLAN Signal Noise": "-256 dBm"}, {"WLAN ESSID": "DEV_2"}, {"System Time": "Wednesday February 3, 2021 13:05:17"}]}, {"Weather": [{"Current Temperature": "63.25 F"}, {"Conditions": "Clear Sky"}]}]}EndOfMessage [genmon1] 2021-02-03 13:05:32 - GenMon Raw Data: {"Status": [{"Engine": [{"Switch State": "Auto"}, {"Engine State": "Off - Ready"}, {"Battery Voltage": "14.70 V"}, {"RPM": "0 "}, {"Frequency": "0.00 Hz"}, {"Output Voltage": "0 V"}, {"Active Rotor Poles (Calculated)": "0 "}]}, {"Line": [{"Utility Voltage": "239 V"}, {"Utility Max Voltage": "246 V"}, {"Utility Min Voltage": "232 V"}, {"Utility Threshold Voltage": "144 V"}]}, {"Last Log Entries": {"Logs": {"Alarm Log": "08/22/20 10:12:15 Inspect Air Filter ", "Run Log": "01/30/21 10:12:13 Stopped - Auto "}}}, {"Time": [{"Monitor Time": "Wednesday February 3, 2021 13:05:32"}, {"Generator Time": "Wednesday February 3, 2021 13:06"}]}]}EndOfMessage [genmon1] 2021-02-03 13:05:33 - GenMon Raw Data: {"Monitor": [{"Generator Monitor Stats": [{"Monitor Health": "OK"}, {"Controller": "Nexus, Liquid Cooled"}, {"Run time": "Generator Monitor running for 3:23:10."}, {"Generator Monitor Version": "V1.15.17"}, {"Update Available": "No"}]}, {"Communication Stats": [{"Packet Count": "M: 390587, S: 390586"}, {"CRC Errors": "0 "}, {"CRC Percent Errors": "0.00%"}, {"Timeout Errors": "0"}, {"Timeout Percent Errors": "0.00%"}, {"Modbus Exceptions": 0}, {"Validation Errors": 0}, {"Sync Errors": 0}, {"Invalid Data": 0}, {"Discarded Bytes": "0"}, {"Comm Restarts": "0"}, {"Packets Per Second": "64.08"}, {"Average Transaction Time": "0.0306 sec"}]}, {"Platform Stats": [{"CPU Temperature": "99.68 F"}, {"Pi Model": "Raspberry Pi 3 Model A Plus Rev 1.0"}, {"Pi CPU Frequency Throttling": "OK"}, {"Pi ARM Frequency Cap": "OK"}, {"Pi Undervoltage": "OK"}, {"CPU Utilization": "3.06%"}, {"OS Name": "Raspbian GNU/Linux"}, {"OS Version": "10 (buster)"}, {"System Uptime": "3:23:53"}, {"Network Interface Used": "wlan0"}, {"WLAN Signal Level": "-80 dBm"}, {"WLAN Signal Quality": "30/70"}, {"WLAN Signal Noise": "-256 dBm"}, {"WLAN ESSID": "DEV_2"}, {"System Time": "Wednesday February 3, 2021 13:05:33"}]}, {"Weather": [{"Current Temperature": "63.25 F"}, {"Conditions": "Clear Sky"}]}]}EndOfMessage [genmon1] 2021-02-03 13:05:48 - GenMon Raw Data: {"Status": [{"Engine": [{"Switch State": "Auto"}, {"Engine State": "Off - Ready"}, {"Battery Voltage": "14.70 V"}, {"RPM": "0 "}, {"Frequency": "0.00 Hz"}, {"Output Voltage": "0 V"}, {"Active Rotor Poles (Calculated)": "0 "}]}, {"Line": [{"Utility Voltage": "239 V"}, {"Utility Max Voltage": "246 V"}, {"Utility Min Voltage": "232 V"}, {"Utility Threshold Voltage": "144 V"}]}, {"Last Log Entries": {"Logs": {"Alarm Log": "08/22/20 10:12:15 Inspect Air Filter ", "Run Log": "01/30/21 10:12:13 Stopped - Auto "}}}, {"Time": [{"Monitor Time": "Wednesday February 3, 2021 13:05:48"}, {"Generator Time": "Wednesday February 3, 2021 13:06"}]}]}EndOfMessage [genmon1] 2021-02-03 13:05:49 - GenMon Raw Data: {"Monitor": [{"Generator Monitor Stats": [{"Monitor Health": "OK"}, {"Controller": "Nexus, Liquid Cooled"}, {"Run time": "Generator Monitor running for 3:23:26."}, {"Generator Monitor Version": "V1.15.17"}, {"Update Available": "No"}]}, {"Communication Stats": [{"Packet Count": "M: 391099, S: 391098"}, {"CRC Errors": "0 "}, {"CRC Percent Errors": "0.00%"}, {"Timeout Errors": "0"}, {"Timeout Percent Errors": "0.00%"}, {"Modbus Exceptions": 0}, {"Validation Errors": 0}, {"Sync Errors": 0}, {"Invalid Data": 0}, {"Discarded Bytes": "0"}, {"Comm Restarts": "0"}, {"Packets Per Second": "64.08"}, {"Average Transaction Time": "0.0306 sec"}]}, {"Platform Stats": [{"CPU Temperature": "100.58 F"}, {"Pi Model": "Raspberry Pi 3 Model A Plus Rev 1.0"}, {"Pi CPU Frequency Throttling": "OK"}, {"Pi ARM Frequency Cap": "OK"}, {"Pi Undervoltage": "OK"}, {"CPU Utilization": "3.06%"}, {"OS Name": "Raspbian GNU/Linux"}, {"OS Version": "10 (buster)"}, {"System Uptime": "3:24:09"}, {"Network Interface Used": "wlan0"}, {"WLAN Signal Level": "-79 dBm"}, {"WLAN Signal Quality": "31/70"}, {"WLAN Signal Noise": "-256 dBm"}, {"WLAN ESSID": "DEV_2"}, {"System Time": "Wednesday February 3, 2021 13:05:49"}]}, {"Weather": [{"Current Temperature": "63.25 F"}, {"Conditions": "Clear Sky"}]}]}EndOfMessage [genmon1] 2 ScreenShot 2021-02-03 at 1.21.11 PM.pdf
  16. I use this - its the same as the old 240V Insteon controller https://innovativehomesys.com/collections/b-wired-in-devices/products/heavy-duty-120-277v-insteon-load-controller-assembly-1470
  17. @scyto I have a question - the RS232 board is so not It burns fingers to the touch. How are you dealing with that? The raspberry is running about 115F according to genmon
  18. hi @Scyto I wanted to THANK YOU very much for your helpful post. I managed to assemble and get this working on almost the first try (which is amazing). Now my generator is monitored and Im happy. Really really appreciate your taking the time to post this. I followed your instructions and really have nothing more to add. Worked as advertised. Thanks Alex
  19. I am waiting to hear about the new enclosure - just gearing up to do the same. Have a nexus controller (says siemens on it but looks the same) - keep us posted and if you don't mind, share the enclosure
  20. FYI 14.97.2A - is a Motion Sensor - it does not communicate with the network - it only sends signals
  21. Good question - Im not finding that number in my ISY devices screen and its not the PLM either
  22. OK - here goes the post. 1) I pressed the ENTRY (INSTEON 1D.9A.B1) button (and the light went on) 2) I pressed it again (and the light went off) 3) I pressed the CL2R button (INSTEON 2B.BF.11) (load, light went on, but keypad ENTRY did not) 4) I pressed the CL2R button (load, light went out, nothing on keypad) Here is the log Mon 11/27/2017 12:06:20 PM : [iNST-SRX ] 02 50 1D.9A.B1 00.00.02 C7 11 00 LTONRR (00) Mon 11/27/2017 12:06:20 PM : [std-Group ] 1D.9A.B1-->Group=2, Max Hops=3, Hops Left=1 Mon 11/27/2017 12:06:20 PM : [D2D EVENT ] Event [1D 9A B1 2] [DON] [0] uom=0 prec=-1 Mon 11/27/2017 12:06:20 PM : [ 1D 9A B1 2] DON 0 Mon 11/27/2017 12:06:20 PM : [D2D EVENT ] Event [1D 9A B1 2] [sT] [255] uom=0 prec=-1 Mon 11/27/2017 12:06:20 PM : [ 1D 9A B1 2] ST 255 Mon 11/27/2017 12:06:20 PM : [D2D EVENT ] Event [2B BF 11 1] [sT] [255] uom=0 prec=-1 Mon 11/27/2017 12:06:20 PM : [ 2B BF 11 1] ST 255 Mon 11/27/2017 12:06:20 PM : [iNST-SRX ] 02 50 1D.9A.B1 2B.96.B4 41 11 02 LTONRR (02) Mon 11/27/2017 12:06:20 PM : [std-Cleanup ] 1D.9A.B1-->ISY/PLM Group=2, Max Hops=1, Hops Left=0 Mon 11/27/2017 12:06:20 PM : [iNST-DUP ] Previous message ignored. Mon 11/27/2017 12:06:20 PM : [iNST-SRX ] 02 50 1D.9A.B1 2B.96.B4 47 11 02 LTONRR (02) Mon 11/27/2017 12:06:20 PM : [std-Cleanup ] 1D.9A.B1-->ISY/PLM Group=2, Max Hops=3, Hops Left=1 Mon 11/27/2017 12:06:20 PM : [iNST-DUP ] Previous message ignored. Mon 11/27/2017 12:06:24 PM : [iNST-SRX ] 02 50 1D.9A.B1 00.00.02 C7 13 00 LTOFFRR(00) Mon 11/27/2017 12:06:24 PM : [std-Group ] 1D.9A.B1-->Group=2, Max Hops=3, Hops Left=1 Mon 11/27/2017 12:06:24 PM : [D2D EVENT ] Event [1D 9A B1 2] [DOF] [0] uom=0 prec=-1 Mon 11/27/2017 12:06:24 PM : [ 1D 9A B1 2] DOF 0 Mon 11/27/2017 12:06:24 PM : [D2D EVENT ] Event [1D 9A B1 2] [sT] [0] uom=0 prec=-1 Mon 11/27/2017 12:06:24 PM : [ 1D 9A B1 2] ST 0 Mon 11/27/2017 12:06:24 PM : [D2D EVENT ] Event [2B BF 11 1] [sT] [0] uom=0 prec=-1 Mon 11/27/2017 12:06:24 PM : [ 2B BF 11 1] ST 0 Mon 11/27/2017 12:06:24 PM : [iNST-SRX ] 02 50 1D.9A.B1 2B.96.B4 41 13 02 LTOFFRR(02) Mon 11/27/2017 12:06:24 PM : [std-Cleanup ] 1D.9A.B1-->ISY/PLM Group=2, Max Hops=1, Hops Left=0 Mon 11/27/2017 12:06:24 PM : [iNST-DUP ] Previous message ignored. Mon 11/27/2017 12:06:24 PM : [iNST-SRX ] 02 50 1D.9A.B1 2B.96.B4 47 13 02 LTOFFRR(02) Mon 11/27/2017 12:06:24 PM : [std-Cleanup ] 1D.9A.B1-->ISY/PLM Group=2, Max Hops=3, Hops Left=1 Mon 11/27/2017 12:06:24 PM : [iNST-DUP ] Previous message ignored. Mon 11/27/2017 12:06:31 PM : [iNST-SRX ] 02 50 2B.BF.11 00.00.01 C7 11 00 LTONRR (00) Mon 11/27/2017 12:06:31 PM : [std-Group ] 2B.BF.11-->Group=1, Max Hops=3, Hops Left=1 Mon 11/27/2017 12:06:31 PM : [D2D EVENT ] Event [2B BF 11 1] [DON] [0] uom=0 prec=-1 Mon 11/27/2017 12:06:31 PM : [ 2B BF 11 1] DON 0 Mon 11/27/2017 12:06:31 PM : [D2D EVENT ] Event [1D 9A B1 2] [sT] [255] uom=0 prec=-1 Mon 11/27/2017 12:06:31 PM : [ 1D 9A B1 2] ST 255 Mon 11/27/2017 12:06:31 PM : [D2D EVENT ] Event [2B BF 11 1] [sT] [255] uom=0 prec=-1 Mon 11/27/2017 12:06:31 PM : [ 2B BF 11 1] ST 255 Mon 11/27/2017 12:06:31 PM : [iNST-SRX ] 02 50 2B.BF.11 00.00.01 CB 11 00 LTONRR (00) Mon 11/27/2017 12:06:31 PM : [std-Group ] 2B.BF.11-->Group=1, Max Hops=3, Hops Left=2 Mon 11/27/2017 12:06:31 PM : [iNST-DUP ] Previous message ignored. Mon 11/27/2017 12:06:33 PM : [iNST-SRX ] 02 50 2B.BF.11 2B.96.B4 41 11 01 LTONRR (01) Mon 11/27/2017 12:06:33 PM : [std-Cleanup ] 2B.BF.11-->ISY/PLM Group=1, Max Hops=1, Hops Left=0 Mon 11/27/2017 12:06:33 PM : [iNST-DUP ] Previous message ignored. Mon 11/27/2017 12:06:33 PM : [iNST-SRX ] 02 50 2B.BF.11 11.02.01 CB 06 01 (01) Mon 11/27/2017 12:06:33 PM : [std-Group ] 2B.BF.11-->11.02.01, Max Hops=3, Hops Left=2 Mon 11/27/2017 12:06:33 PM : [iNST-INFO ] Previous message ignored. Mon 11/27/2017 12:06:38 PM : [iNST-SRX ] 02 50 2B.BF.11 00.00.01 C7 13 00 LTOFFRR(00) Mon 11/27/2017 12:06:38 PM : [std-Group ] 2B.BF.11-->Group=1, Max Hops=3, Hops Left=1 Mon 11/27/2017 12:06:38 PM : [D2D EVENT ] Event [2B BF 11 1] [DOF] [0] uom=0 prec=-1 Mon 11/27/2017 12:06:38 PM : [ 2B BF 11 1] DOF 0 Mon 11/27/2017 12:06:38 PM : [D2D EVENT ] Event [1D 9A B1 2] [sT] [0] uom=0 prec=-1 Mon 11/27/2017 12:06:38 PM : [ 1D 9A B1 2] ST 0 Mon 11/27/2017 12:06:38 PM : [D2D EVENT ] Event [2B BF 11 1] [sT] [0] uom=0 prec=-1 Mon 11/27/2017 12:06:38 PM : [ 2B BF 11 1] ST 0 Mon 11/27/2017 12:06:39 PM : [iNST-SRX ] 02 50 2B.BF.11 2B.96.B4 41 13 01 LTOFFRR(01) Mon 11/27/2017 12:06:39 PM : [std-Cleanup ] 2B.BF.11-->ISY/PLM Group=1, Max Hops=1, Hops Left=0 Mon 11/27/2017 12:06:39 PM : [iNST-DUP ] Previous message ignored. Mon 11/27/2017 12:06:40 PM : [iNST-SRX ] 02 50 2B.BF.11 13.02.01 CB 06 01 (01) Mon 11/27/2017 12:06:40 PM : [std-Group ] 2B.BF.11-->13.02.01, Max Hops=3, Hops Left=2 Mon 11/27/2017 12:06:40 PM : [iNST-INFO ] Previous message ignored. Mon 11/27/2017 12:06:53 PM : [iNST-SRX ] 02 50 14.97.2A 00.00.01 C3 11 01 LTONRR (01) Mon 11/27/2017 12:06:53 PM : [std-Group ] 14.97.2A-->Group=1, Max Hops=3, Hops Left=0 Mon 11/27/2017 12:06:53 PM : [D2D EVENT ] Event [14 97 2A 1] [DON] [1] uom=0 prec=-1 Mon 11/27/2017 12:06:53 PM : [ 14 97 2A 1] DON 1 Mon 11/27/2017 12:06:53 PM : [D2D-CMP 0003] CTL [14 97 2A 1] DON op=1 Event(val=1 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true Mon 11/27/2017 12:06:53 PM : [iNST-SRX ] 02 50 14.97.2A 00.00.01 C3 11 01 LTONRR (01) Mon 11/27/2017 12:06:53 PM : [std-Group ] 14.97.2A-->Group=1, Max Hops=3, Hops Left=0 Mon 11/27/2017 12:06:53 PM : [iNST-DUP ] Previous message ignored. Mon 11/27/2017 12:06:54 PM : [iNST-TX-I1 ] 02 62 00 00 22 CF 13 00 Mon 11/27/2017 12:06:54 PM : [D2D EVENT ] Event [14 97 2A 1] [sT] [255] uom=0 prec=-1 Mon 11/27/2017 12:06:54 PM : [ 14 97 2A 1] ST 255
  23. I do have a follow up question............. Devices in Scene are CL2R (switch dimmable - controller and load) ENTRY - E (8 button keypad - controller) When I press the CL2R button - the ENTRY button does do NOT light up When I press the ENTRY button - the CL2R button does work So why does CL2R - a controller and the Load not send a LIGHT ON to ENTRY????? This is confusing and making me wonder if the keypad is the one that is bad/
  24. So I only have LEDs in the house (except for an incandescent chandelier I can't reach). The light in question is a MR16 LED...... My game plan is going to be 1) Take the load off the switch 2) Since I have a newer one, change the 8 button keypad for a newer one (the old one is 2011 I think) Well see what happens
  25. What Im confused about is the following Say the scene is called "FRONT HOUSE" Devices in Scene are CL2R (switch dimmable - controller and load) ENTRY - E (8 button keypad - controller) GARAGE - A (8 Button keypad - controller) So I have three controllers for the scene, one of which is the switch with the load. What I have is a command to TURN OFF THE SCENE - at 10PM, this works irregularly. My idea was to simply change it to send an OFF command to CL2R - which in theory should turn off the light, and because its a controller, the other two keypads as well???? Or am I missing something?
