So I have the same issue as above. Utility voltage is 0
Log file follows - I see a number for Utility Voltage.... But on the summary screen it shows 0 as EVICTORY posted above.
Run-in NodeLink Server v0.10.6
Any chance we can address this?
Thanks
Alex
2021-02-03 13:03:08 - GenMon Raw Data: {"Status": [{"Engine": [{"Switch State": "Auto"}, {"Engine State": "Off - Ready"}, {"Battery Voltage": "14.70 V"}, {"RPM": "0 "}, {"Frequency": "0.00 Hz"}, {"Output Voltage": "0 V"}, {"Active Rotor Poles (Calculated)": "0 "}]}, {"Line": [{"Utility Voltage": "237 V"}, {"Utility Max Voltage": "246 V"}, {"Utility Min Voltage": "232 V"}, {"Utility Threshold Voltage": "144 V"}]}, {"Last Log Entries": {"Logs": {"Alarm Log": "08/22/20 10:12:15 Inspect Air Filter ", "Run Log": "01/30/21 10:12:13 Stopped - Auto "}}}, {"Time": [{"Monitor Time": "Wednesday February 3, 2021 13:03:08"}, {"Generator Time": "Wednesday February 3, 2021 13:03"}]}]}EndOfMessage [genmon1]
2021-02-03 13:03:09 - GenMon Raw Data: {"Monitor": [{"Generator Monitor Stats": [{"Monitor Health": "OK"}, {"Controller": "Nexus, Liquid Cooled"}, {"Run time": "Generator Monitor running for 3:20:46."}, {"Generator Monitor Version": "V1.15.17"}, {"Update Available": "No"}]}, {"Communication Stats": [{"Packet Count": "M: 385976, S: 385975"}, {"CRC Errors": "0 "}, {"CRC Percent Errors": "0.00%"}, {"Timeout Errors": "0"}, {"Timeout Percent Errors": "0.00%"}, {"Modbus Exceptions": 0}, {"Validation Errors": 0}, {"Sync Errors": 0}, {"Invalid Data": 0}, {"Discarded Bytes": "0"}, {"Comm Restarts": "0"}, {"Packets Per Second": "64.08"}, {"Average Transaction Time": "0.0306 sec"}]}, {"Platform Stats": [{"CPU Temperature": "97.70 F"}, {"Pi Model": "Raspberry Pi 3 Model A Plus Rev 1.0"}, {"Pi CPU Frequency Throttling": "OK"}, {"Pi ARM Frequency Cap": "OK"}, {"Pi Undervoltage": "OK"}, {"CPU Utilization": "3.02%"}, {"OS Name": "Raspbian GNU/Linux"}, {"OS Version": "10 (buster)"}, {"System Uptime": "3:21:29"}, {"Network Interface Used": "wlan0"}, {"WLAN Signal Level": "-80 dBm"}, {"WLAN Signal Quality": "30/70"}, {"WLAN Signal Noise": "-256 dBm"}, {"WLAN ESSID": "DEV_2"}, {"System Time": "Wednesday February 3, 2021 13:03:09"}]}, {"Weather": [{"Current Temperature": "63.25 F"}, {"Conditions": "Clear Sky"}]}]}EndOfMessage [genmon1]
2021-02-03 13:03:24 - GenMon Raw Data: {"Status": [{"Engine": [{"Switch State": "Auto"}, {"Engine State": "Off - Ready"}, {"Battery Voltage": "14.70 V"}, {"RPM": "0 "}, {"Frequency": "0.00 Hz"}, {"Output Voltage": "0 V"}, {"Active Rotor Poles (Calculated)": "0 "}]}, {"Line": [{"Utility Voltage": "239 V"}, {"Utility Max Voltage": "246 V"}, {"Utility Min Voltage": "232 V"}, {"Utility Threshold Voltage": "144 V"}]}, {"Last Log Entries": {"Logs": {"Alarm Log": "08/22/20 10:12:15 Inspect Air Filter ", "Run Log": "01/30/21 10:12:13 Stopped - Auto "}}}, {"Time": [{"Monitor Time": "Wednesday February 3, 2021 13:03:24"}, {"Generator Time": "Wednesday February 3, 2021 13:04"}]}]}EndOfMessage [genmon1]
2021-02-03 13:03:25 - GenMon Raw Data: {"Monitor": [{"Generator Monitor Stats": [{"Monitor Health": "OK"}, {"Controller": "Nexus, Liquid Cooled"}, {"Run time": "Generator Monitor running for 3:21:02."}, {"Generator Monitor Version": "V1.15.17"}, {"Update Available": "No"}]}, {"Communication Stats": [{"Packet Count": "M: 386488, S: 386488"}, {"CRC Errors": "0 "}, {"CRC Percent Errors": "0.00%"}, {"Timeout Errors": "0"}, {"Timeout Percent Errors": "0.00%"}, {"Modbus Exceptions": 0}, {"Validation Errors": 0}, {"Sync Errors": 0}, {"Invalid Data": 0}, {"Discarded Bytes": "0"}, {"Comm Restarts": "0"}, {"Packets Per Second": "64.08"}, {"Average Transaction Time": "0.0306 sec"}]}, {"Platform Stats": [{"CPU Temperature": "98.60 F"}, {"Pi Model": "Raspberry Pi 3 Model A Plus Rev 1.0"}, {"Pi CPU Frequency Throttling": "OK"}, {"Pi ARM Frequency Cap": "OK"}, {"Pi Undervoltage": "OK"}, {"CPU Utilization": "3.03%"}, {"OS Name": "Raspbian GNU/Linux"}, {"OS Version": "10 (buster)"}, {"System Uptime": "3:21:45"}, {"Network Interface Used": "wlan0"}, {"WLAN Signal Level": "-81 dBm"}, {"WLAN Signal Quality": "29/70"}, {"WLAN Signal Noise": "-256 dBm"}, {"WLAN ESSID": "DEV_2"}, {"System Time": "Wednesday February 3, 2021 13:03:25"}]}, {"Weather": [{"Current Temperature": "63.25 F"}, {"Conditions": "Clear Sky"}]}]}EndOfMessage [genmon1]
2021-02-03 13:03:40 - GenMon Raw Data: {"Status": [{"Engine": [{"Switch State": "Auto"}, {"Engine State": "Off - Ready"}, {"Battery Voltage": "14.70 V"}, {"RPM": "0 "}, {"Frequency": "0.00 Hz"}, {"Output Voltage": "0 V"}, {"Active Rotor Poles (Calculated)": "0 "}]}, {"Line": [{"Utility Voltage": "236 V"}, {"Utility Max Voltage": "246 V"}, {"Utility Min Voltage": "232 V"}, {"Utility Threshold Voltage": "144 V"}]}, {"Last Log Entries": {"Logs": {"Alarm Log": "08/22/20 10:12:15 Inspect Air Filter ", "Run Log": "01/30/21 10:12:13 Stopped - Auto "}}}, {"Time": [{"Monitor Time": "Wednesday February 3, 2021 13:03:40"}, {"Generator Time": "Wednesday February 3, 2021 13:04"}]}]}EndOfMessage [genmon1]
2021-02-03 13:03:41 - GenMon Raw Data: {"Monitor": [{"Generator Monitor Stats": [{"Monitor Health": "OK"}, {"Controller": "Nexus, Liquid Cooled"}, {"Run time": "Generator Monitor running for 3:21:18."}, {"Generator Monitor Version": "V1.15.17"}, {"Update Available": "No"}]}, {"Communication Stats": [{"Packet Count": "M: 387001, S: 387001"}, {"CRC Errors": "0 "}, {"CRC Percent Errors": "0.00%"}, {"Timeout Errors": "0"}, {"Timeout Percent Errors": "0.00%"}, {"Modbus Exceptions": 0}, {"Validation Errors": 0}, {"Sync Errors": 0}, {"Invalid Data": 0}, {"Discarded Bytes": "0"}, {"Comm Restarts": "0"}, {"Packets Per Second": "64.08"}, {"Average Transaction Time": "0.0306 sec"}]}, {"Platform Stats": [{"CPU Temperature": "97.70 F"}, {"Pi Model": "Raspberry Pi 3 Model A Plus Rev 1.0"}, {"Pi CPU Frequency Throttling": "OK"}, {"Pi ARM Frequency Cap": "OK"}, {"Pi Undervoltage": "OK"}, {"CPU Utilization": "3.03%"}, {"OS Name": "Raspbian GNU/Linux"}, {"OS Version": "10 (buster)"}, {"System Uptime": "3:22:01"}, {"Network Interface Used": "wlan0"}, {"WLAN Signal Level": "-78 dBm"}, {"WLAN Signal Quality": "32/70"}, {"WLAN Signal Noise": "-256 dBm"}, {"WLAN ESSID": "DEV_2"}, {"System Time": "Wednesday February 3, 2021 13:03:41"}]}, {"Weather": [{"Current Temperature": "63.25 F"}, {"Conditions": "Clear Sky"}]}]}EndOfMessage [genmon1]
2021-02-03 13:03:56 - GenMon Raw Data: {"Status": [{"Engine": [{"Switch State": "Auto"}, {"Engine State": "Off - Ready"}, {"Battery Voltage": "14.70 V"}, {"RPM": "0 "}, {"Frequency": "0.00 Hz"}, {"Output Voltage": "0 V"}, {"Active Rotor Poles (Calculated)": "0 "}]}, {"Line": [{"Utility Voltage": "236 V"}, {"Utility Max Voltage": "246 V"}, {"Utility Min Voltage": "232 V"}, {"Utility Threshold Voltage": "144 V"}]}, {"Last Log Entries": {"Logs": {"Alarm Log": "08/22/20 10:12:15 Inspect Air Filter ", "Run Log": "01/30/21 10:12:13 Stopped - Auto "}}}, {"Time": [{"Monitor Time": "Wednesday February 3, 2021 13:03:56"}, {"Generator Time": "Wednesday February 3, 2021 13:04"}]}]}EndOfMessage [genmon1]
2021-02-03 13:03:57 - GenMon Raw Data: {"Monitor": [{"Generator Monitor Stats": [{"Monitor Health": "OK"}, {"Controller": "Nexus, Liquid Cooled"}, {"Run time": "Generator Monitor running for 3:21:34."}, {"Generator Monitor Version": "V1.15.17"}, {"Update Available": "No"}]}, {"Communication Stats": [{"Packet Count": "M: 387513, S: 387512"}, {"CRC Errors": "0 "}, {"CRC Percent Errors": "0.00%"}, {"Timeout Errors": "0"}, {"Timeout Percent Errors": "0.00%"}, {"Modbus Exceptions": 0}, {"Validation Errors": 0}, {"Sync Errors": 0}, {"Invalid Data": 0}, {"Discarded Bytes": "0"}, {"Comm Restarts": "0"}, {"Packets Per Second": "64.08"}, {"Average Transaction Time": "0.0306 sec"}]}, {"Platform Stats": [{"CPU Temperature": "99.68 F"}, {"Pi Model": "Raspberry Pi 3 Model A Plus Rev 1.0"}, {"Pi CPU Frequency Throttling": "OK"}, {"Pi ARM Frequency Cap": "OK"}, {"Pi Undervoltage": "OK"}, {"CPU Utilization": "3.03%"}, {"OS Name": "Raspbian GNU/Linux"}, {"OS Version": "10 (buster)"}, {"System Uptime": "3:22:17"}, {"Network Interface Used": "wlan0"}, {"WLAN Signal Level": "-80 dBm"}, {"WLAN Signal Quality": "30/70"}, {"WLAN Signal Noise": "-256 dBm"}, {"WLAN ESSID": "DEV_2"}, {"System Time": "Wednesday February 3, 2021 13:03:57"}]}, {"Weather": [{"Current Temperature": "63.25 F"}, {"Conditions": "Clear Sky"}]}]}EndOfMessage [genmon1]
2021-02-03 13:04:12 - GenMon Raw Data: {"Status": [{"Engine": [{"Switch State": "Auto"}, {"Engine State": "Off - Ready"}, {"Battery Voltage": "14.70 V"}, {"RPM": "0 "}, {"Frequency": "0.00 Hz"}, {"Output Voltage": "0 V"}, {"Active Rotor Poles (Calculated)": "0 "}]}, {"Line": [{"Utility Voltage": "238 V"}, {"Utility Max Voltage": "246 V"}, {"Utility Min Voltage": "232 V"}, {"Utility Threshold Voltage": "144 V"}]}, {"Last Log Entries": {"Logs": {"Alarm Log": "08/22/20 10:12:15 Inspect Air Filter ", "Run Log": "01/30/21 10:12:13 Stopped - Auto "}}}, {"Time": [{"Monitor Time": "Wednesday February 3, 2021 13:04:12"}, {"Generator Time": "Wednesday February 3, 2021 13:04"}]}]}EndOfMessage [genmon1]
2021-02-03 13:04:13 - GenMon Raw Data: {"Monitor": [{"Generator Monitor Stats": [{"Monitor Health": "OK"}, {"Controller": "Nexus, Liquid Cooled"}, {"Run time": "Generator Monitor running for 3:21:50."}, {"Generator Monitor Version": "V1.15.17"}, {"Update Available": "No"}]}, {"Communication Stats": [{"Packet Count": "M: 388026, S: 388025"}, {"CRC Errors": "0 "}, {"CRC Percent Errors": "0.00%"}, {"Timeout Errors": "0"}, {"Timeout Percent Errors": "0.00%"}, {"Modbus Exceptions": 0}, {"Validation Errors": 0}, {"Sync Errors": 0}, {"Invalid Data": 0}, {"Discarded Bytes": "0"}, {"Comm Restarts": "0"}, {"Packets Per Second": "64.08"}, {"Average Transaction Time": "0.0306 sec"}]}, {"Platform Stats": [{"CPU Temperature": "98.60 F"}, {"Pi Model": "Raspberry Pi 3 Model A Plus Rev 1.0"}, {"Pi CPU Frequency Throttling": "OK"}, {"Pi ARM Frequency Cap": "OK"}, {"Pi Undervoltage": "OK"}, {"CPU Utilization": "3.03%"}, {"OS Name": "Raspbian GNU/Linux"}, {"OS Version": "10 (buster)"}, {"System Uptime": "3:22:33"}, {"Network Interface Used": "wlan0"}, {"WLAN Signal Level": "-80 dBm"}, {"WLAN Signal Quality": "30/70"}, {"WLAN Signal Noise": "-256 dBm"}, {"WLAN ESSID": "DEV_2"}, {"System Time": "Wednesday February 3, 2021 13:04:13"}]}, {"Weather": [{"Current Temperature": "63.25 F"}, {"Conditions": "Clear Sky"}]}]}EndOfMessage [genmon1]
2021-02-03 13:04:28 - GenMon Raw Data: {"Status": [{"Engine": [{"Switch State": "Auto"}, {"Engine State": "Off - Ready"}, {"Battery Voltage": "14.70 V"}, {"RPM": "0 "}, {"Frequency": "0.00 Hz"}, {"Output Voltage": "0 V"}, {"Active Rotor Poles (Calculated)": "0 "}]}, {"Line": [{"Utility Voltage": "237 V"}, {"Utility Max Voltage": "246 V"}, {"Utility Min Voltage": "232 V"}, {"Utility Threshold Voltage": "144 V"}]}, {"Last Log Entries": {"Logs": {"Alarm Log": "08/22/20 10:12:15 Inspect Air Filter ", "Run Log": "01/30/21 10:12:13 Stopped - Auto "}}}, {"Time": [{"Monitor Time": "Wednesday February 3, 2021 13:04:28"}, {"Generator Time": "Wednesday February 3, 2021 13:05"}]}]}EndOfMessage [genmon1]
2021-02-03 13:04:29 - GenMon Raw Data: {"Monitor": [{"Generator Monitor Stats": [{"Monitor Health": "OK"}, {"Controller": "Nexus, Liquid Cooled"}, {"Run time": "Generator Monitor running for 3:22:06."}, {"Generator Monitor Version": "V1.15.17"}, {"Update Available": "No"}]}, {"Communication Stats": [{"Packet Count": "M: 388539, S: 388538"}, {"CRC Errors": "0 "}, {"CRC Percent Errors": "0.00%"}, {"Timeout Errors": "0"}, {"Timeout Percent Errors": "0.00%"}, {"Modbus Exceptions": 0}, {"Validation Errors": 0}, {"Sync Errors": 0}, {"Invalid Data": 0}, {"Discarded Bytes": "0"}, {"Comm Restarts": "0"}, {"Packets Per Second": "64.08"}, {"Average Transaction Time": "0.0306 sec"}]}, {"Platform Stats": [{"CPU Temperature": "99.68 F"}, {"Pi Model": "Raspberry Pi 3 Model A Plus Rev 1.0"}, {"Pi CPU Frequency Throttling": "OK"}, {"Pi ARM Frequency Cap": "OK"}, {"Pi Undervoltage": "OK"}, {"CPU Utilization": "3.03%"}, {"OS Name": "Raspbian GNU/Linux"}, {"OS Version": "10 (buster)"}, {"System Uptime": "3:22:49"}, {"Network Interface Used": "wlan0"}, {"WLAN Signal Level": "-81 dBm"}, {"WLAN Signal Quality": "29/70"}, {"WLAN Signal Noise": "-256 dBm"}, {"WLAN ESSID": "DEV_2"}, {"System Time": "Wednesday February 3, 2021 13:04:29"}]}, {"Weather": [{"Current Temperature": "63.25 F"}, {"Conditions": "Clear Sky"}]}]}EndOfMessage [genmon1]
2021-02-03 13:04:44 - GenMon Raw Data: {"Status": [{"Engine": [{"Switch State": "Auto"}, {"Engine State": "Off - Ready"}, {"Battery Voltage": "14.70 V"}, {"RPM": "0 "}, {"Frequency": "0.00 Hz"}, {"Output Voltage": "0 V"}, {"Active Rotor Poles (Calculated)": "0 "}]}, {"Line": [{"Utility Voltage": "240 V"}, {"Utility Max Voltage": "246 V"}, {"Utility Min Voltage": "232 V"}, {"Utility Threshold Voltage": "144 V"}]}, {"Last Log Entries": {"Logs": {"Alarm Log": "08/22/20 10:12:15 Inspect Air Filter ", "Run Log": "01/30/21 10:12:13 Stopped - Auto "}}}, {"Time": [{"Monitor Time": "Wednesday February 3, 2021 13:04:44"}, {"Generator Time": "Wednesday February 3, 2021 13:05"}]}]}EndOfMessage [genmon1]
2021-02-03 13:04:45 - GenMon Raw Data: {"Monitor": [{"Generator Monitor Stats": [{"Monitor Health": "OK"}, {"Controller": "Nexus, Liquid Cooled"}, {"Run time": "Generator Monitor running for 3:22:22."}, {"Generator Monitor Version": "V1.15.17"}, {"Update Available": "No"}]}, {"Communication Stats": [{"Packet Count": "M: 389050, S: 389049"}, {"CRC Errors": "0 "}, {"CRC Percent Errors": "0.00%"}, {"Timeout Errors": "0"}, {"Timeout Percent Errors": "0.00%"}, {"Modbus Exceptions": 0}, {"Validation Errors": 0}, {"Sync Errors": 0}, {"Invalid Data": 0}, {"Discarded Bytes": "0"}, {"Comm Restarts": "0"}, {"Packets Per Second": "64.08"}, {"Average Transaction Time": "0.0306 sec"}]}, {"Platform Stats": [{"CPU Temperature": "99.68 F"}, {"Pi Model": "Raspberry Pi 3 Model A Plus Rev 1.0"}, {"Pi CPU Frequency Throttling": "OK"}, {"Pi ARM Frequency Cap": "OK"}, {"Pi Undervoltage": "OK"}, {"CPU Utilization": "3.04%"}, {"OS Name": "Raspbian GNU/Linux"}, {"OS Version": "10 (buster)"}, {"System Uptime": "3:23:05"}, {"Network Interface Used": "wlan0"}, {"WLAN Signal Level": "-79 dBm"}, {"WLAN Signal Quality": "31/70"}, {"WLAN Signal Noise": "-256 dBm"}, {"WLAN ESSID": "DEV_2"}, {"System Time": "Wednesday February 3, 2021 13:04:45"}]}, {"Weather": [{"Current Temperature": "63.25 F"}, {"Conditions": "Clear Sky"}]}]}EndOfMessage [genmon1]
2021-02-03 13:05:00 - GenMon Raw Data: {"Status": [{"Engine": [{"Switch State": "Auto"}, {"Engine State": "Off - Ready"}, {"Battery Voltage": "14.70 V"}, {"RPM": "0 "}, {"Frequency": "0.00 Hz"}, {"Output Voltage": "0 V"}, {"Active Rotor Poles (Calculated)": "0 "}]}, {"Line": [{"Utility Voltage": "238 V"}, {"Utility Max Voltage": "246 V"}, {"Utility Min Voltage": "232 V"}, {"Utility Threshold Voltage": "144 V"}]}, {"Last Log Entries": {"Logs": {"Alarm Log": "08/22/20 10:12:15 Inspect Air Filter ", "Run Log": "01/30/21 10:12:13 Stopped - Auto "}}}, {"Time": [{"Monitor Time": "Wednesday February 3, 2021 13:05:00"}, {"Generator Time": "Wednesday February 3, 2021 13:05"}]}]}EndOfMessage [genmon1]
2021-02-03 13:05:01 - GenMon Raw Data: {"Monitor": [{"Generator Monitor Stats": [{"Monitor Health": "OK"}, {"Controller": "Nexus, Liquid Cooled"}, {"Run time": "Generator Monitor running for 3:22:38."}, {"Generator Monitor Version": "V1.15.17"}, {"Update Available": "No"}]}, {"Communication Stats": [{"Packet Count": "M: 389564, S: 389563"}, {"CRC Errors": "0 "}, {"CRC Percent Errors": "0.00%"}, {"Timeout Errors": "0"}, {"Timeout Percent Errors": "0.00%"}, {"Modbus Exceptions": 0}, {"Validation Errors": 0}, {"Sync Errors": 0}, {"Invalid Data": 0}, {"Discarded Bytes": "0"}, {"Comm Restarts": "0"}, {"Packets Per Second": "64.08"}, {"Average Transaction Time": "0.0306 sec"}]}, {"Platform Stats": [{"CPU Temperature": "101.48 F"}, {"Pi Model": "Raspberry Pi 3 Model A Plus Rev 1.0"}, {"Pi CPU Frequency Throttling": "OK"}, {"Pi ARM Frequency Cap": "OK"}, {"Pi Undervoltage": "OK"}, {"CPU Utilization": "3.05%"}, {"OS Name": "Raspbian GNU/Linux"}, {"OS Version": "10 (buster)"}, {"System Uptime": "3:23:21"}, {"Network Interface Used": "wlan0"}, {"WLAN Signal Level": "-80 dBm"}, {"WLAN Signal Quality": "30/70"}, {"WLAN Signal Noise": "-256 dBm"}, {"WLAN ESSID": "DEV_2"}, {"System Time": "Wednesday February 3, 2021 13:05:01"}]}, {"Weather": [{"Current Temperature": "63.25 F"}, {"Conditions": "Clear Sky"}]}]}EndOfMessage [genmon1]
2021-02-03 13:05:16 - GenMon Raw Data: {"Status": [{"Engine": [{"Switch State": "Auto"}, {"Engine State": "Off - Ready"}, {"Battery Voltage": "14.70 V"}, {"RPM": "0 "}, {"Frequency": "0.00 Hz"}, {"Output Voltage": "0 V"}, {"Active Rotor Poles (Calculated)": "0 "}]}, {"Line": [{"Utility Voltage": "237 V"}, {"Utility Max Voltage": "246 V"}, {"Utility Min Voltage": "232 V"}, {"Utility Threshold Voltage": "144 V"}]}, {"Last Log Entries": {"Logs": {"Alarm Log": "08/22/20 10:12:15 Inspect Air Filter ", "Run Log": "01/30/21 10:12:13 Stopped - Auto "}}}, {"Time": [{"Monitor Time": "Wednesday February 3, 2021 13:05:16"}, {"Generator Time": "Wednesday February 3, 2021 13:05"}]}]}EndOfMessage [genmon1]
2021-02-03 13:05:17 - GenMon Raw Data: {"Monitor": [{"Generator Monitor Stats": [{"Monitor Health": "OK"}, {"Controller": "Nexus, Liquid Cooled"}, {"Run time": "Generator Monitor running for 3:22:54."}, {"Generator Monitor Version": "V1.15.17"}, {"Update Available": "No"}]}, {"Communication Stats": [{"Packet Count": "M: 390075, S: 390074"}, {"CRC Errors": "0 "}, {"CRC Percent Errors": "0.00%"}, {"Timeout Errors": "0"}, {"Timeout Percent Errors": "0.00%"}, {"Modbus Exceptions": 0}, {"Validation Errors": 0}, {"Sync Errors": 0}, {"Invalid Data": 0}, {"Discarded Bytes": "0"}, {"Comm Restarts": "0"}, {"Packets Per Second": "64.08"}, {"Average Transaction Time": "0.0306 sec"}]}, {"Platform Stats": [{"CPU Temperature": "101.48 F"}, {"Pi Model": "Raspberry Pi 3 Model A Plus Rev 1.0"}, {"Pi CPU Frequency Throttling": "OK"}, {"Pi ARM Frequency Cap": "OK"}, {"Pi Undervoltage": "OK"}, {"CPU Utilization": "3.05%"}, {"OS Name": "Raspbian GNU/Linux"}, {"OS Version": "10 (buster)"}, {"System Uptime": "3:23:37"}, {"Network Interface Used": "wlan0"}, {"WLAN Signal Level": "-79 dBm"}, {"WLAN Signal Quality": "31/70"}, {"WLAN Signal Noise": "-256 dBm"}, {"WLAN ESSID": "DEV_2"}, {"System Time": "Wednesday February 3, 2021 13:05:17"}]}, {"Weather": [{"Current Temperature": "63.25 F"}, {"Conditions": "Clear Sky"}]}]}EndOfMessage [genmon1]
2021-02-03 13:05:32 - GenMon Raw Data: {"Status": [{"Engine": [{"Switch State": "Auto"}, {"Engine State": "Off - Ready"}, {"Battery Voltage": "14.70 V"}, {"RPM": "0 "}, {"Frequency": "0.00 Hz"}, {"Output Voltage": "0 V"}, {"Active Rotor Poles (Calculated)": "0 "}]}, {"Line": [{"Utility Voltage": "239 V"}, {"Utility Max Voltage": "246 V"}, {"Utility Min Voltage": "232 V"}, {"Utility Threshold Voltage": "144 V"}]}, {"Last Log Entries": {"Logs": {"Alarm Log": "08/22/20 10:12:15 Inspect Air Filter ", "Run Log": "01/30/21 10:12:13 Stopped - Auto "}}}, {"Time": [{"Monitor Time": "Wednesday February 3, 2021 13:05:32"}, {"Generator Time": "Wednesday February 3, 2021 13:06"}]}]}EndOfMessage [genmon1]
2021-02-03 13:05:33 - GenMon Raw Data: {"Monitor": [{"Generator Monitor Stats": [{"Monitor Health": "OK"}, {"Controller": "Nexus, Liquid Cooled"}, {"Run time": "Generator Monitor running for 3:23:10."}, {"Generator Monitor Version": "V1.15.17"}, {"Update Available": "No"}]}, {"Communication Stats": [{"Packet Count": "M: 390587, S: 390586"}, {"CRC Errors": "0 "}, {"CRC Percent Errors": "0.00%"}, {"Timeout Errors": "0"}, {"Timeout Percent Errors": "0.00%"}, {"Modbus Exceptions": 0}, {"Validation Errors": 0}, {"Sync Errors": 0}, {"Invalid Data": 0}, {"Discarded Bytes": "0"}, {"Comm Restarts": "0"}, {"Packets Per Second": "64.08"}, {"Average Transaction Time": "0.0306 sec"}]}, {"Platform Stats": [{"CPU Temperature": "99.68 F"}, {"Pi Model": "Raspberry Pi 3 Model A Plus Rev 1.0"}, {"Pi CPU Frequency Throttling": "OK"}, {"Pi ARM Frequency Cap": "OK"}, {"Pi Undervoltage": "OK"}, {"CPU Utilization": "3.06%"}, {"OS Name": "Raspbian GNU/Linux"}, {"OS Version": "10 (buster)"}, {"System Uptime": "3:23:53"}, {"Network Interface Used": "wlan0"}, {"WLAN Signal Level": "-80 dBm"}, {"WLAN Signal Quality": "30/70"}, {"WLAN Signal Noise": "-256 dBm"}, {"WLAN ESSID": "DEV_2"}, {"System Time": "Wednesday February 3, 2021 13:05:33"}]}, {"Weather": [{"Current Temperature": "63.25 F"}, {"Conditions": "Clear Sky"}]}]}EndOfMessage [genmon1]
2021-02-03 13:05:48 - GenMon Raw Data: {"Status": [{"Engine": [{"Switch State": "Auto"}, {"Engine State": "Off - Ready"}, {"Battery Voltage": "14.70 V"}, {"RPM": "0 "}, {"Frequency": "0.00 Hz"}, {"Output Voltage": "0 V"}, {"Active Rotor Poles (Calculated)": "0 "}]}, {"Line": [{"Utility Voltage": "239 V"}, {"Utility Max Voltage": "246 V"}, {"Utility Min Voltage": "232 V"}, {"Utility Threshold Voltage": "144 V"}]}, {"Last Log Entries": {"Logs": {"Alarm Log": "08/22/20 10:12:15 Inspect Air Filter ", "Run Log": "01/30/21 10:12:13 Stopped - Auto "}}}, {"Time": [{"Monitor Time": "Wednesday February 3, 2021 13:05:48"}, {"Generator Time": "Wednesday February 3, 2021 13:06"}]}]}EndOfMessage [genmon1]
2021-02-03 13:05:49 - GenMon Raw Data: {"Monitor": [{"Generator Monitor Stats": [{"Monitor Health": "OK"}, {"Controller": "Nexus, Liquid Cooled"}, {"Run time": "Generator Monitor running for 3:23:26."}, {"Generator Monitor Version": "V1.15.17"}, {"Update Available": "No"}]}, {"Communication Stats": [{"Packet Count": "M: 391099, S: 391098"}, {"CRC Errors": "0 "}, {"CRC Percent Errors": "0.00%"}, {"Timeout Errors": "0"}, {"Timeout Percent Errors": "0.00%"}, {"Modbus Exceptions": 0}, {"Validation Errors": 0}, {"Sync Errors": 0}, {"Invalid Data": 0}, {"Discarded Bytes": "0"}, {"Comm Restarts": "0"}, {"Packets Per Second": "64.08"}, {"Average Transaction Time": "0.0306 sec"}]}, {"Platform Stats": [{"CPU Temperature": "100.58 F"}, {"Pi Model": "Raspberry Pi 3 Model A Plus Rev 1.0"}, {"Pi CPU Frequency Throttling": "OK"}, {"Pi ARM Frequency Cap": "OK"}, {"Pi Undervoltage": "OK"}, {"CPU Utilization": "3.06%"}, {"OS Name": "Raspbian GNU/Linux"}, {"OS Version": "10 (buster)"}, {"System Uptime": "3:24:09"}, {"Network Interface Used": "wlan0"}, {"WLAN Signal Level": "-79 dBm"}, {"WLAN Signal Quality": "31/70"}, {"WLAN Signal Noise": "-256 dBm"}, {"WLAN ESSID": "DEV_2"}, {"System Time": "Wednesday February 3, 2021 13:05:49"}]}, {"Weather": [{"Current Temperature": "63.25 F"}, {"Conditions": "Clear Sky"}]}]}EndOfMessage [genmon1]
2
ScreenShot 2021-02-03 at 1.21.11 PM.pdf
