biredale
  1. biredale replied to Grizzy's topic in ISY994
    Right, I was referring to status tests not control, thanks for the clarification. Further, when testing against time or variables I assume the logic follows the same as status tests? For example; If Time is 18:00 then ..... else ..... Thanks! Brian
  2. biredale replied to Grizzy's topic in ISY994
    I am not sure both the ON and OFF conditions need to be tested. My assumption is that whenever there is a state change (ON or OFF) this condition will be tested therefore a simple ON test (to the THEN branch) and the OFF (to the ELSE branch) should be suffice. Please let us know if anyone else has understanding other than this. Thanks! Brian
  3. biredale posted a topic in ISY994
    When I have used the ISY to create scenes, and set devices as controllers and responders do the devices retain their controller and responder relationships even if the ISY goes offline or is unplugged? Thanks! Brian
  4. I have the same experience.. I would like press once open, next press close etc. but have never gotten it quite right. Thanks! Brian
  5. Same.. Will not work with a blank body. Thanks! Brian
  6. biredale replied to bmiller's topic in ISY994
    I hooked up three strands of those new dripping icicles outside to an Insteon switched outlet (outlet is wired to an inside wall switch) the first strand lights no problem but the second and third do not light. When I connect all three to a different in switched wall outlet everything works fine. The strands are low wattage led lights. Any thoughts on this? Thanks! Brian
  7. biredale replied to flemingmike's topic in ISY994
    I need to replace an ip security cam and was looking at two; SmartHome and Foscam both have an indoor pan / tilt for around a hundred bucks. Does anyone have experience or comments on these models? Thanks! Brian
  8. We have all likely been burned on this at first.. Welcome to the club! Thanks! Brian
  9. NOISE. Thanks! Brian
  10. Has anybody used the ISY to gmail to Prowl iPhone notification with a 'Emergencies' message level? I am trying to figure out how to create exceptions to the 'Quiet Time' setting in Prowl. Thanks! Brian
  11. Got it thanks! Thanks! Brian
  12. Can you provide configuration instructions for having the ISY send to Prowl for this newbie? Thanks! Brian
  13. Thanks! Brian
  14. biredale replied to vbsafire1's topic in ISY994
    And the body cannot be empty, if it is the message will NOT be sent.. Thanks! Brian
  15. biredale replied to vbsafire1's topic in ISY994
    Did you set up messages in config? Thanks! Brian
