SteveT
Everything posted by SteveT
  1. Thanks - so I assume that devices that act as repeaters will not work, but instead a range extender is needed?
  2. Thanks @Techman - turned out to be distance from the hub! I was thinking that another zwave device could do the inclusion, but I guess not. So I end up running long ethernet cables across the house temporarily - Not sure what type of repeater also allows for new devices to be added...
  3. I am trying to temporarily user an older ISY994 and have issues getting the Zooz Zen71 switches to join my Z- Wave network.. I was able to get an older Aotech binary switch online, but these do not seem to be visible within discovery even when the other switch is close - ideas? For association, the directions indicate 3x the top paddle. I also tried excluding, etc. no dice. The ISY994 just does not see it. I have the Z-wave board (500 series - I believe) - without the antenna. Thank you! Steve
  4. Onto the next issue - after doing the factory reset - and trying to do the upgrade, or save programs I get a "tcp client DNS error" [my.isy.io] -- With the upgrade, I get a "Upgrade failed: failed uploading file (reported written size is invalid)... Java.io broken pipe. Previously it had been on the portal, and since expired, but i deleted and rebooted in case that was the issue. Related error: ? "Could not open config file to read /CONF/HZWNDKEY.TXT", Could not open file "/CONF/PORTALS.PSF" stuck! thanks, Steve
  5. great- thank you I will try that.
  6. Hi - brought the old unit out of retirement - and after the factory reset was able to get into the box. However, I will not be using Insteon, only Z-Wave but the unit is booting to safe mode. In my policy, I see the option to disable Insteon under system but not under 5.3.4 which is the last firmware? Anyone else have success? Thank you-Steve
  7. SteveT replied to SteveT's topic in EnvisaLink-DSC
    ..and the other issue is the keypads and other accessories. Old tech that works is more expensive than the new stuff. Good luck.
  8. SteveT replied to SteveT's topic in EnvisaLink-DSC
    I think it’s online only programming from what I found out- not for me ..
  9. SteveT replied to SteveT's topic in EnvisaLink-DSC
    Thanks @apostolakisl, I have been doing further research and it’s really not looking good. The work-around that eyez-on has is very limited it seems. I have been emailing them also. A >$200 risk and maybe it will do arm and disarm and zone status with more parallel modules. But no details like exit delay/partition status. It’s unfortunate, as the DSC Neo looks to be a decent system and wireless “PowerG” as well- but without the management and integration - it’s backwards as you say. Steve
  10. SteveT replied to SteveT's topic in EnvisaLink-DSC
    yes- I have been looking into it. Looks like I am going to test :). Don't have a choice - need to keep the integration with my home setup.. and the older 433 MHz stuff is hard to find for the DSC 1832... Wish me luck. I will report back.
  11. SteveT posted a topic in EnvisaLink-DSC
    Hi - I am looking to upgrade from my DSC 832 to the DSC Neo, and was wondering if anyone has the EYEZ-ON board setup in Universal mode with this plug-in? I trigger routines for arm/disarm mostly. Not sure I will get that status without full bus integration. thank you, Steve
  12. Z-Matter board within Policy also not responding!! Ugh. UPDATE: Since I was basically hard down, I followed @DennisC , @Geddy recommendation, and upgraded to PG3x. The issues w/ZMatter board and other failures were resolved with the upgrade. I was then able to migrate my PG2 and PG3 nodeservers to PG3x flawlessly by installing in the same slots! Amazing. I am relieved. Nice programming work. Up and running - phew.
  13. I am kind of hesitant if it deletes something in the PG2 configuration that i will need. I see that article, and read through it - should be a non-issue, but then again, so was this upgrade supposed to be something quick!! LOL.
  14. It was working fine w/ v5.8.0, PG2 and PG3 - FYI. I wish there was a warning - I know it was in the forum, but messaging in the upgrade. Will do - thank you!
  15. yes- I have not upgraded to PG3x as I have a PG2 node server that i am still using. I guess I may be stuck now as I cannot even get to the PG2 or PG3 interfaces. More problems... Node server is blank. I will open a ticket, and revert. thanks all-Steve
  16. Hi folks, I am having the same issue- read through, and did not see a solution. I am running polisy. thank you- Steve
  17. Here is the tail of the log from the file system - as I cannot get it from the UI. Thanks @Goose66 ModuleNotFoundError: No module named 'schlagens' 4/10/2024, 17:40:06 [pg3] info: [Schlage(20)] :: Exit cause code: 1 - signal: null 4/10/2024, 17:40:06 [pg3] info: startNs:: Schlage starting polls 4/10/2024, 17:40:06 [pg3] info: Starting Schlage Expire Check timer 4/10/2024, 17:40:06 [pg3] info: Checking if Schlage has expired 4/10/2024, 17:40:06 [pg3] info: Starting Schlage Info timer 0 4/10/2024, 17:40:06 [pg3] info: Starting Schlage Version Check timer 4/10/2024, 17:40:07 [pg3] info: set to expire on 2024-04-16T02:51:32.000Z 4/10/2024, 17:40:07 [pg3] info: EXPIRE CHECK: Schlage subscription expires in 5 days 4/10/2024, 17:40:21 [pg3] info: set to expire on 2024-04-16T02:51:32.000Z 4/10/2024, 17:40:21 [pg3] info: EXPIRE CHECK: Schlage subscription expires in 5 days
  18. @Goose66 - i will try, thanks. Nope, no dice, still getting the issue where i cannot even view the log.
  19. Hi - trying this node server, after installation - I enter in credentials, but the Node server does not start. When I try to open the log for the NS, i get the following: Any ideas? Thank you, Steve https://192.168.1.15:3000/logs/00:0d:b9:5d:95:f0_12: 404 Not Found Here is additional info from the pg3 log- 3/15/2024, 21:14:27 [pg3] info: checkLicense:: Schlage Valid subscription license found. Expires: 2024-04-16T02:51:32.000Z 3/15/2024, 21:14:27 [pg3] info: startNs:: Schlage finished update check 3/15/2024, 21:14:27 [pg3] info: [Schlage(12)] :: Starting NodeServer - Version 3.0.1 3/15/2024, 21:14:27 [pg3] info: startNs:: Schlage updating database (enabled, timestarted) 3/15/2024, 21:14:27 [pg3] error: [Schlage(12)] :: STDERR: Traceback (most recent call last): File "/var/polyglot/pg3/ns/000db95d95f0_12/./main.py", line 9, in <module> 3/15/2024, 21:14:27 [pg3] error: [Schlage(12)] :: STDERR: from schlagens import SchlageNS ModuleNotFoundError: No module named 'schlagens'
  20. Finally unboxed Zooz ZEN34 scene switch, but not what I expected. Question #1- Finally was able to get 5 nodes to show up: Wall Controller, Scene Button 1, 2, Wake-up and basic control. However, I cannot get the device to accept "writes" for params. The green battery icon does not go away in the console -- nor can I get any parameters to update / write to the device after inclusion. The manual states 7 clicks to keep awake, but as others have mentioned, it does not seem to accept multiple commands, etc. Need to set param 4 to solve this, but cannot get the writes - lol. Anyone else able to solve the problems with this device ? thanks, Steve
  21. @Geddy - thank you for the additional info - nothing in UDI mobile which I use. I am on Polisy, and today I left the admin console alone - didnt change tabs or anything. I have cleared settings in it before- not aware of anything that would impact though. On UDI mobile, I get the lost connection / re-connected to portal, so notification are working. Steve
  22. @Techman - I have done 5-6 updates over months, have never seen a pop-up at the end! I am using the MacOS Java console if that matters. Most recently, the console remains running after the upgrade "completes" - aka the traffic in that log stops. Still seems off to me. Steve
  23. Upgraded successfully to 5.7.1_7 and confirmed by checking the sysconfig.txt on Polisy. In the admin console when performing updates, I never receive any messages after complete. I have read there is a pop-up or something, or am I mistaken? I feel like I should reboot to fully complete the process? I monitor the process via /var/udx/logs/log (to make me feel better I guess)!! Steve
  24. Same issue where all programs were disabled - a big deal for me actually as i have 100s. I am searching for a script to re-enable in the forums, if someone has, please highlight here.. thanks, Steve
  25. Is there a way to see on the file system if the upgrade is pending? I was reading one of the threads, and accidentally clicked on the link - but still need PG2 node servers. I believe safari stopped me with an HTTPS warning - but just wanted to be sure before my PG2 is nuked! Thanks, Steve
