Everything posted by Vince
Deadbolt Lock Operated by Amazon Echo
Yes, very helpful. Thank you.
Thank you for the reply. So it sounds like I can do what I want to do with the Echo. When you say really short, how short are we talking?
Hi, I have have an ISY 994i and an Amazon Echo. I want to install a deadbolt lock on a gate and be able to open it via the Echo. I know I probably need to install the Z Wave module on the 994i and get a Z Wave lock. Do I need to do anything else? Can I have a program to re-lock the gate after a certain amount of time passes? Thanks for the help.
- Lock the door program
Is there something else I can use?
I have a Insteton door deadbolt. I want a program to lock the door after x minutes if the door is unlocked. I tried an "if" statement of "Status - lock off - responding". Not sure of what "responding" means. My then statement is "Insteon- on- lock door". I think my if statement is the problem. Can anyone help?
Recommendations on Home Video Surveillance System
Any update on this topic? New equipment?
Program Does Not Finish
Changing Status to Control seems to have worked this time. MWareman, I do have other programs that operate that way. I'll try that if I have anymore problems. Thank you guys.
Yes, that is the case. I had it working at one point, now I don't know what is different. I had it set for 10 seconds for testing purposes and it seemed to work.
Hi Folks, I am using the Insteon Hidden Door Sensor. The program will turn the light on when the door opens but it does not turn the light out after a minute. What am I missing? Thanks.
Android Interface
The answer to my problem ended up being simple. I changed the settings to two columns and it looks fine. I would suggest you eliminate the words "on" and "off" to make the red and green symbols larger for sausage finger people like me. Thanks for looking into it Michel.
- Android Interface
- Android Interface
Having Trouble With Programs Still
Thanks Lee.
Greetings, I'm new to the "If,Then, Else" language used for programs. But,I'm willing to learn. Is there a primer anyone can recommend? Thanks.
Android Interface
Michael, It looks fine on Firefox and it looks good on Safari on the Ipad. It just does not scale correctly on the phone. I'm running firmware v 2.3.5 on the phone.
Android Interface
Hi, When I access ISY99i via my Samsung Galaxy S, the words "on" and "off" get overlaid with the red and green symbols. It makes using the interface a bit difficult. I'm never sure which button I'm pushing. Is there a way to straighten this out? If not, Moblinc Pro or Conductor?
MorningStar Linc ? What is the purpose of -On -Off device?
Simply elegant. I tried doing it at first with an "if" statement about if the door was not locked. Your solution seems to work fine. Thanks again Lee.
Lee, Can you help me with a program to lock the door at 8 pm if it is unlocked. I'm still learning the logic but have not stumbled upon what I need to make this work. Thanks.
Thank you Lee. I'll try that when I have some time to work on it.
thanks Lee
Lee, The program worked perfectly. Thank you. Any thoughts on my problem writing to the device (RemoteLinc)?
Hi Lee, The morninglinc firmware is v 3.A The ISY firmware is 2.8.16 The unsupported message for the outletlinc is 1.33 I'm also having a problem when I click "Write Update to Device" for the remotelinc. I get error message [-200000/-51] Failed Writing Device Link - Remotelinc. Any thoughts on that? Does everyone have this many issues or is it just my inexperience? Lee, thanks for you patience and willingness to help the uninitiated like me.
Hi Lee, The firmware on the MorningLinc is Rev 1. So if I want to use the RemoteLinc to operate the lock I'll need to program it manually? A bit off topic, do you know anything about the OutletLinc 2472D. ISY says it is an unsupported device. It will turn it on and off but it does not have the dimming feature. Is there a workaround?
Email Notifications
It says NTP server not responding.
