Craigb
  1. So my question remains: Is it possible to MIGRATE these locks from ISY994i Pro to EISY without disassociating them from the existing Zwave system and then having to re-associate them, along with all the programming changes that will require? If the answer is no, I'll probably stay on the ISY994iPro
  2. I do remember that the initial inclusion with the ISY was a bit of a challenge for these locks, but it did work. So to get these locks to migrate from ISY to EISY I have to exclude it from my ISY994i and then do a factory reset on the lock before adding it to the EISY? Is that what your reply says? When I loaded the data backup from the ISY into the EISY, all the zwave items came up with names (not placeholder) but had the red circle/slash icon for all the battery powered zwave devices (pretty much all of them). I did the Update and Interview on each one while waking up the device, and after several attempts on each device, they would eventually successfully interview and synchronize. The locks steadfastly refused to interview. The data in the Event Viewer on mode 3 is less than fully revealing as to what is going on in that process. When I turned off Secure inclusion on the EISY and then did the synchronize - Update and Interview for the FE599, one of the messages that came up in the event monitor (on setting 3) was "Mfr data not available". This makes me somewhat reluctant to remove the FE599 from my current ISY994i as once I do that, it will be impossible to quickly revert of the ESIY won't accept the lock for inclusion. As for the message "mfr data not available", I'd hope that the EISY would be intelligent enough to query an online database for needed info on legacy zwave devices for inclusion.
  3. I tried to migrate from ISY994iPro v 5.3.4 to EISY v 5.9.1 today. I had major issues with most battery-powered zwave devices as I expected. However I am completely unable to get the EISY with Matter zwave to recognize and interact with my Schlage FE599 and BE369/399 locks. I've tried interview with secure inclusion on and off. No difference. I tried Synchronize -> Update - didn't work. I moved the EISY to within 8 inches of the lock. No difference. Reading the forums via search, I see several threads about this problem that are rather old. None had a solution as far as I could tell. Were the issues with Schlage locks with S0 security ever solved for use with EISY? For now I've reverted to the ISY994i.
  4. I don't think this is a universal occurrence. I've run my ISY 99, ISY 994, and Polisy boxes on UPS power since 2010 while the PLM is always plugged into the house wiring with no power backup. In the more than a decade of use, and many short or long power outages, I've never had the communications between the ISY/Polisy and PLM become locked up due to a power failure. I'm not sure what's different about our respective installations, but serial comms lockup is not an expected result of a power failure to the PLM while the ISY stays powered.
  5. You can't "remove" a button from the KPL in the Admin Console. You can remove it from all scenes which will make the button non-functional (it will light on-off, but won't do anything else) - but it is always part of the KPL. After removing it from any/all scenes it was part of, then just right-click on the button in the admin console and rename it to "D". Unused buttons on included KPL's still show in the Admin console - always. Just name them somethign so you know they are unused.
  6. @tazman, Thanks! That worked.
  7. I'm trying to add my Polisy to my UD Mobile app on Ios 15.7 as a local network connection - not via portal. I DO NOT use the ISY Portal, I only use Local Network access (I use a VPN when away from home) When I try to add the Polisy local IP address (https://192.168.x.xx and port 8443) and test, I get an error that the IP address must begin with HTTP, not HTTPS. When I enter the IP address as HTTP://192.168.x.xx and port 8443, I get an error that the "App transport Security Policy requires use of a secure connection" Using various related URL's such as http://polisy.<privatedomain.pvt>, adding /desc at the end of the URL, and/or adding port to URL or not, letting UD Mobile try to connect to Polisy on Port 80 as http - all result in one of the same two errors. Anyone have a way around this seemingly Catch-22 issue? Polisy is running Ver 5.4.4 UD Mobile version for Ios is Ver 0.9.2 Again - I do not use the portal. All connections are via local network only. Note: UD mobile works fine in this config with my ISY's - but not in secure transport - as HTTP only.
  8. Many devices with noise/surge supression will kill off powerline X10 and Insteon signals. One solution I've found is to take a 14 gauge 3-wire extension cord about 6 feet long (the flat ones used for window air conditioners or appliances are good), and coil it into a coil with about a 6 to 8 inch (15-20 CM) diameter, using cable ties to secure it. The coil acts as a choke to isolate the powerline control signal from the filter in the surge/noise supressor, and then nearby X10/Insteon devices will again work. Note: powerline control devices (neither X10, Insteon nor anything else) will not work correctly when plugged into the output side of any power conditioning device (surge protector, UPS, etc.) that filters the power line noise.
  9. I see a different screen layout in Ver 5.4.4: You may be on an earlier version.
  10. For my garage door, I changed from a 2450 I/O linc after one too many "all On" events. I use a Fibaro FGBS-222 "implant" unit, coupled with a 12V brick supply and an external relay. The Implant uses a FET output, which may not handle spikes properly. So I use the implant to fire a transistor driven relay contact closure.
  11. Yes, timing is important! Read twice, execute once.
  12. I'll add that the password can be reset to the known default admin/admin without doing a full factory reset on the ISY. Procedure here: https://wiki.universal-devices.com/index.php?title=ISY-99i/ISY-26_INSTEON:Resetting_Your_Userid/Password I'd do the following: - Download launcher and locate the ISY on their network. If an issue with wifi use a direct Ethernet cable from the ISY to the router or the laptop to connect initially. - See if previous owner set the user/password to admin/admin. Reset password if they did not. - Log into the Admin Console and make a backup of the system - Then start working with the system to determine how/what needs to be changed.
  13. To answer some of your other questions: You can run Polyglot locally currently on a Raspberry Pi or on a Polisy box or in the cloud (which I understand you are not interested in cloud-based integrations) with a cloud ploy setup. To run a local polyglot server linked to your ISY, you need either of a ISY Portal account, or the Networking module for your ISY. Either opens up the access to the ISY's nodes for on-network reading/writing to the ISY. If you aren't interested in portal integrations (Alexa, etc.) then the network module will allow you to use Polyglot without any third-party Internet access to your system. To upgrade to versions 5.1.0 or later, if you are using Zwave, you also need to upgrade the Zwave hardware in the ISY to the 500 series Zwave module. Carefully read the release notes for 5.3.0 in this thread: https://forum.universal-devices.com/topic/30939-release-530-is-now-available/ as it covers all the items you need to know to update from 4.7.x to 5.1.0 or later. Version 5 introduces vastly different and improved handling of Zwave devices, and adds support for Polyglot node servers. Because it is a major change, depending on your programs, you may need to do some work to get them fully functional after the upgrade if you have Zwave devices.
  14. Upgraded from 5.1.0 to 5.3.3 yesterday. No issues. Both older Schlage locks (BE369 and BE599) work fine after a Zwave/Synchronize Polyglot nodes work fine after restarting the nodes in Polyglot server.
