mlvarnell
  • Posts
    6
Everything posted by mlvarnell
  1. Upgraded from 3.1.17 to 3.2.3. Smooth as silk! Thanks!
  2. sorry for the fuss, but thanks for the info! I still have a lot to learn...
  3. It has just occurred to me that you could use an exterior ac outlet to broadcast an all on or all off, with a resulting trigger of your I/O Linc garage door controller! I haven't tried to prove this yet, but I will soon. Any thoughts?
  4. I just had a brainstorm. I have an old weather station from Oregon Scientific. When doing maintenance on it, I noticed the rain gauge was a seesaw with a magnet, a reed switch, and a small 'self dumping water bucket.' Here's the deal, the reed switch is a 'dry contact closure' which is a perfect fit for the screw terminals on a triggerlinc. voila! you connect them, count the number of closures over time, and there is your custom rainfall amount! It is also wireless with a 50' range. You could also monitor sprinkler output!
  5. How about $sSecretCode state variable with an init of 1234, then change your comparison to //Test2.C0: (initial idle state, $Test.State init to -1) If $Test.State 0> 1000 And $Test.Code is $sSecretCode Then $Test.State = 2 //Test2.C3: (failure state: just jump back to state 0) If $Test.State is 1 And $Test.Code > 1000 And $Test.Code is not $sSecretCode Then $Test.State = 0
  • Create New...
