Martinefski
  • Posts
    9
Everything posted by Martinefski
  1. Awesome that was it! I was so close, I even once used the arrow up botton once, but I was not sure of what I was doing so I deleted it. Thank you so much for all your help! The only issue now is and I could live with it is the light on the keypad does not always reflect if the fan is on or off now.
  2. Sorry for the confusion on my part that was a bad cut and past error. My program actually never was like that. I think what might be going on is the parens, I don't see how to add parens to the IF statement. Sorry for being such a noob.
  3. Also I dont think I actually ever had the program with the variable working I have a feeling I was still using the first example program when I thought I was. Maybe I am totally tring to do the varible version the wrong way, but I am not givin the chance to select what I am choosing to use for a variable, the dropdown box stays blank.
  4. Sorry for my ignorance, could you explain a bit more. Is what you posted an example of the control statments being or'ed?
  5. Thanks here they are. FIREPLACE FAN HIGH If Control 'Downstairs KPL / Downstairs KPL- D' is switched On And Control 'Downstairs KPL / Downstairs KPL- D' is switched Off And Status 'Fireplace-Fan' is Med Then Set 'Fireplace-Fan' High Else - No Actions - (To add one, press 'Action') FIREPLACE FAN HIGH-OFF If Control 'Downstairs KPL / Downstairs KPL- D' is switched On Or Control 'Downstairs KPL / Downstairs KPL- D' is switched Off And Status 'Fireplace-Fan' is High Then Set 'Fireplace-Fan' Off Else - No Actions - (To add one, press 'Action') FIREPLACE FAN LOW If Control 'Downstairs KPL / Downstairs KPL- D' is switched On Or Control 'Downstairs KPL / Downstairs KPL- D' is switched Off And Status 'Fireplace-Fan' is Off Then Set 'Fireplace-Fan' Low Else - No Actions - (To add one, press 'Action') FIREPLACE FAN MED If Control 'Downstairs KPL / Downstairs KPL- D' is switched On Or Control 'Downstairs KPL / Downstairs KPL- D' is switched Off And Status 'Fireplace-Fan' is Low Then Set 'Fireplace-Fan' Med Else - No Actions - (To add one, press 'Action') FIREPLACE FAN OFF If Control 'Downstairs KPL / Downstairs KPL- D' is switched Fast On Or Control 'Downstairs KPL / Downstairs KPL- D' is switched Fast Off Then Set 'Fireplace-Fan' Off Else - No Actions - (To add one, press 'Action')
  6. I have to leave right now but could you tell me how to post it and I will later tonight? Thank you for your help.
  7. Yes it does. One other thing to note, when trying the version with the variable. I dont see any device to select, so in the program it just states [varible 0.0]
  8. Hi, I have tried both the examples above , but in both instances the result was the same the fan only makes it to medium speed and the next botton press results in returning to low speed. For some reason the medium to high speed action never takes place. Any Ideas what I might be doing wrong?
  9. Would you please be able to tell me how? All I can do is turn on the fan to the highest speed and turn it back off. Are you running a program? I was Hoping to be able to toggle through all the speeds with one button.
  • Create New...
