Questions after update to IoX v.6.0.0
This is the follow-up from my post on 2025-10-02 “Ticket opened 2025-09-01. I will update when it is closed.” I closed this ticket, subject “Problem with nodedefs”, on 10/03. This resolved the nodedefs issues by restoring a v5.9.1 backup. I was only able to successfully restore an earlier backup after connecting to the isy locally, not through the portal (https://) connection which was the only connection showing in the IoX finder after the v6.0 auto update. This is the error I was receiving when attempting to restore a backup connecting to the eisy through https: Once I was able to connect locally (http://) to the Administrative Console the restore performed normally. I then, as instructed, proceeded to “Upgrade Packages” from the Admin Console Configuration page. It should be noted on the eisy-ui site I was running 0.6.0 prior to running “Upgrade Packages” which changed to 0.6.1 after upgrade. My eisy-ui is now showing 0.6.3 as I have “Upgrade Packages” at least once since in an attempt to resolve on-going issues. I've been working on what I can only call v6.0 issues for the past 10 days: As I remarked in an earlier post “This UI (v6) is ‘Bleeding Edge’ PAINFUL!” and I stand by that comment. I feel I must be missing something or doing something wrong. Programs that ran fine prior to v6 no longer run and issues with Z-wave defy any logical resolution. At times, usually after I have made changes to a program or after adding a Z-wave device, I will attempt a restart of the eisy and receive the popup error . This has been causing me a world of hurt to where I now backup after every change. Here is 1 example of an issue I am unable to find a resolution for… I’ve include an image of my IoX Finder incase I have done something wrong here: If I connect with an http connection all my battery-operated Z-wave device nodes display with a “Write Changes” icon. If connecting with an https URL the nodes appear to display correctly. One issue at a time… if anyone has any insight into what I’m experiencing please reply. I’ll add this last thought… There appears to be a difference between backups and restores made with http or https connections. So much for the wiki line “Everything that worked before continues to work the same way: (https://wiki.universal-devices.com/Eisy:User_Guide#Changes_introduced_with_eisy-ui)”
Based on what UD support is telling me, regarding my open ticket, the problems I'm experiencing are not related to ports but to issues caused when UD moved some profile data into new database tables and apparently my data only partially transferred correctly. :(
I think there are several items which are causing v.6.0 users’ confusion… at least I have been confused on some of what has been posted in this forum. Below is one example of what is causing me (and maybe others) some confusion When I use IoX Finder… Whether I choose “Admin Console (LAN) or Admin Console (Cloud) the only login option for the "Admin Console" is with my Portal credentials… But according to wiki… Wiki link https://wiki.universal-devices.com/Eisy:User_Guide#Changes_introduced_with_eisy-ui states: Everything that worked before continues to work the same way: · IoX will respond to API requests on port 8080/8443 and require the same local username & password · PG3x/Plugins can still be used using https://eisy.local:3000, using your local username & password Now wmcneil posted this… Great having multiple ways to access but what about the wiki “Everything that worked before continues to work the same way:” Can we have some consistency and establish “best practices”? Just asking.
Good to know. I knew this to be a local connection just didn't understand why others were posting the eisy URL as an https:. Thanks for the clarification.
While attempting to resolve my issues with the new UI I noticed I am unable to establish a secure connection to my eisy... http: but not https:. Anyone with thoughts on this? Am I missing something? While attempting to resolve my issues with the new UI I noticed I am unable to establish a secure connection to my eisy... http: but not https:. Anyone with thoughts on this? Am I missing something?
Tks
I will follow your suggestion and open a ticket. Where do I find/access the outputs you suggest I include in ticket? Tks.
Ditto!
I don't see "Reinstall all plugins" in Main Menu/Settings.
I'll give that a shot. Thanks Athlon!
I somewhat agree with Geddy. The UI does not yet have the flexibility of the Admin Console but its early in development and non (or few) of us are comfortable with it as yet. I'll keep an open mind and wait to see what potentially develops... I won't miss Java!
Understand these are 2 different UI's but they both share many of the same devices and programs. Just wishful thinking that the favorites in UD Mobile might potentially be sync-able with eisy UI someday. I'm still working through the "Tile" option. I have a plugin working as a tile but I'm not having much success at adding other nodes, singularly or in combination. Think the UD folks have done a great job at developing this product but it's not working well for me at this time... could be me and/or could be the interface needing further development. Think we both need some work. Thanks for your input.
Alright, think I'm good with the UI but I'll wait until it's developed a bit further, I just don't find it very useful at the moment but the potential is promising. Still trying to work through the PG3 "Notification Notices:". One reads "ERROR: 09/29/2025 13:21:59 See log for: Please verify your portal_api_key value". Another, "HolidaysGoogle Notices:" states "Not authenticated or invalid authentication". I don't recall seeing these before the v.6 update and both plugins show "connected" and appear to be working. Digging deeper into the "HolidaysGoogle Notices:" I get this screen...
