Jimbo.Automates
  1. It should work, but my meter was upgraded to one that Flume did not support, and now I no longer even live there and I had a MoenFlo installed at my new home so I haven't used the Flume in a long time. If there are issues I will try to help but as far as I know it should work.
  2. There is no option I am aware of. The best option would be for @Javi to add support in UDMobile but we'd have to work thru how to configure this on the IoX side.
  3. Found some issues on my production instance fixed in PG3 Plugin for Kasa TP-Link 3.3.27. See the README and CHANGELOG for all information.
  4. The PG3 Plugin for Kasa TP-Link 3.3.25 is released. See the README and CHANGELOG for all information since 3.3.23
  5. MoenFlo Plugin 1.0.2 released to beta and production see CHANGELOG
  6. Yes, I had considered making mine free because I really write them all to work for my system, but supporting and helping other users, adding enhancements requested by users, and most of all occasionally painful debugging of issues on other peoples systems was the main reason I charge a small one time fee. Now it helps pay for my Cursor usage which helps get things fixed and enhanced faster!
  7. Just released 2.0.15 which has more improvements on searching for devices...
  8. Are you running the lastest HomeKitHub Version 2.0.14? That one had some improvements to the code which helped another user find their device. and there are some other issues mentioned here: https://github.com/jimboca/udi-poly-homekit-hub/blob/main/DEBUGGING.md#d-accessory-not-visible-on-the-lan-mdns
  9. Sorry, that was a change in a library I referenced Fixed in 3.3.23
  10. The PG3 Plugin for Kasa TP-Link 3.3.23 is released. See the README and CHANGELOG for all information since 3.3.13 release. All known issues are resolved. If you have any other issues please discuss on a new post in this sub-forum, and if no resolution is found create an issue at https://github.com/UniversalDevicesInc-PG3/udi-poly-kasa/issues and reference the forum thread.
  11. HomeKitHub 2.0.13 released for Standard and Professional: https://github.com/jimboca/udi-poly-homekit-hub/blob/production/CHANGELOG.md Please see OP for all the information on this Plugin.
  12. No feedback, but it's now released: https://forum.universal-devices.com/topic/46815-moenflo-plugin/
  13. This is the MoenFlo plugin which currently only supports the MoenFlo valve. See README, CONFIG and CHANGELOG If you have questions or issues please create a new post in this subforum. If you have a real issue add it to MoenFlo Issues
  14. Jimbo.Automates started following MoenFlo
  15. Did you do this as mentioned on the announcement post? Please make sure you have done a recent Upgrade Packages: https://github.com/jimboca/udi-poly-homekit-hub/blob/main/DEBUGGING.md#common-causes If so, review: https://github.com/jimboca/udi-poly-homekit-hub/blob/main/DEBUGGING.md#discover-does-nothing-or-adds-no-rows
  16. Try opening eisy-ui at: https://192.168.0.76 and from there you could access PG3 from the menu in the upper-left
