MikeD
  1. Brother makes clear P-Touch labels.
  2. They appear to be in stock now, I just placed an order!
  3. Thankful I ran across this post when searching the forum. Haven't been here for a while since my ISY994 and devices has been working flawlessly for years. Recently one of my 2486D KPLs was acting up. Symptoms were the device was not displaying correct state when events happened. The device links table was corrupted and communications failed when I tried to restore it from ISY. Thought I had a spare KPL but did not! Ordered two 2486Ds from the link in the original post. Thanks MrBill! Mike
  4. Was the port to Pushover from Prowl difficult?
  5. FWIW, I tried 10000 and still no go with Prowl. Will pursue change to Pushover.
  6. I just updated to v4.9.0 and still have this error when attempting to send a push notification to Prowl.
  7. I only received the above error once. The second time I tried to test a Prowl network resource I received a different error message, something like DNS server not found I think. Every subsequent test resulted in an “n/a” error response. I rebooted my ISY just to eliminate the possibility of something hung. My ISY rebooted normally without errors, so I doubt it is a corrupted memory card. I would think we would see a different symptom if Prowl terminated their service. Don’t know what the issue could be. Maybe someone here has an idea.
  8. I seem to have the same problem with PROWL. My last Prowl notification was on 1/14/2022. ISY-994 running v4.7.3. *NOTE: Network Resources sent within my LAN function normally. Only the PROWL notifications produce an error.
  9. FYI, received my PLM today with the same revision/date code. - Rev 2.4, 4716
  10. My PLM is due to arrive tomorrow. Will probably get the same version. I placed an order for another ISY w/PLM the day after my PLM order. Will be interesting to see what version that PLM will be.
  11. Thanks for pointing the sale out. I got the email but did not see this listed at the bottom. I repaired my PLM well over a year ago and never had a spare. Placed my order for one and will post what version when received. FYI, the sale has an expiration date. At the bottom of the email is the statement “Special pricing valid through Wednesday 4/17/19(11:59pm PST); or while supplies last.”
  12. This is exactly how I am configured, PLM powered by my UPS. Been configured like this for several years. The only thing you loose by this configuration is 1 hop, since you are using an Access Point (or a SwitchLinc in my case) as the first hop, which is not a problem if you have a robust Insteon network. Lately I have been installing Z-Wave devices instead of Insteon. My only issue has been (not) implementing multi-channel devices since I have not made the jump to v5.xx yet.
  13. MikeD replied to johnjces's topic in ISY994
    I have both my ISY and PLM on a UPS. Been configured this way for years without issue. There is a dual-band SwitchLinc a few feet away and other dual-band Insteon devices nearby. I would say just try it as long as there are dual-band devices within earshot of your PLM.
  14. Is '$GarageOpen' an Integer or State variable? It needs to be a State variable to trigger program2.
  15. Although I started with Insteon, I now primarily look at z-wave solutions. Just be aware that multichannel devices will not work if you are running 'official' v4.5.x software. Multichannel is supported in v5(in alpha), and UDI is commited to z-wave, however the implementation is ongoing. I have several z-wave devices, including a Schlage lock, Aeotec doorbell, some plug-in switches, and the older MultiSensor 6. All work in v4.5.4 that I am currently running. Do a search on this forum before you purchase a z-wave device you are interested in. Someone may have posted compatibility information.
