Vwas
Everything posted by Vwas
  1. Well, I read the release notes, checked the existing OS version and backed up the IoX and PG3 files as instructed, then held my breath and clicked "Upgrade Packages" - and waited. A half hour or so passed, then UD Mobile reported that PG3 was back up and running. The admin console and eisy ui appear to be fully functional, and all of my programs appear to be running as they should. There is one minor issue remaining, I'll report it in a separate thread. Thanks to the UDI team for making this upgrade process as easy and transparent as it was!
  2. Greetings: UD Mobile has been sending me daily reminders about firmware and package updates that are available for my eisy. This is my first attempt at updating its firmware. I'd like to move ahead with these updates, but I'm a bit apprehensive to do so for fear that I may accidentally brick the unit in the process. I have a lot of outdoor lighting automation set up for night time security purposes, and I'd hate to lose that functionality even temporarily. I think that I may be on the right path, but I'd greatly appreciate it if someone more knowledgeable than myself could have a look over my shoulder here and provide a bit of friendly oversight and guidance to help me through the process. Murphy has a tendency to show up at the wrong time and screw things up for me...! I've attached a few screen shots that show the software and package versions that I have installed currently. I'm thinking that the IoX firmware may be up to date (currently v.6.1.2), and that only the pg3x package version requires an update (currently v 3.3.22)? If this is so, will a simple click of the "Update packages" button in the java based admin console (red arrow below) get the job done for me? P.S. - If it makes any difference, my installation is currently 100% Insteon based Thanks in advance to all for your assistance!
  3. UPDATE: With the EISY 6.0.0 migration, Admin console logins were migrated to use your portal credentials. I assumed that this applied to PG3 logins as well. My PG3 login appears to have RETAINED its original credentials (i.e. my pre EISY 6.0.0. admin console login credentials). I was finally able to successfully log into PG3 by using my old Admin console username and password. I'm not sure whether something may have gone awry in my particular EISY during the 6.0.0 upgrade, or whether others may find themselves in a similar situation? It may be helpful if others could give this a try and report their findings back here. It would be nice to know whether my situation may be an outlier, or whether it's a known condition that's already been reported elsewhere and I hadn't seen it. Or maybe I've discovered something that can save others some time and aggravation in the future....
  4. It's running 6.0.0. I am using my portal credentials to successfully log into the admin console, but they're not working for PG3 login. Tried the admin/admin suggestion, but that doesn't work either.
  5. Also, I was unsure as to whether it was more appropriate to post this under Polyglot PG3 or EISY. I apologize if I posted this in the wrong place. Thanks again.
  6. I haven't attempted to log into Polyglot 3x for a while. When I attempted to do so tonight, I received the following response: I'll confess that I'm far from being an EISY power user, and I tend to use the beast in a similar manner as the ISY 994i that it replaced. I attempted to log into PG3 through the Admin console, using the Plugins>Launch Polyglot V3 (PG3) dropdown menu with the same username and password that I use to log into the admin console. This had always worked for me previously, but it appears that something has changed. I haven't been actively browsing the forum much recently, but I am aware that the Admin Console is in the process of being gradually replaced by a browser based utility. Not sure if this might be responsible for the difficulties I'm having here? Anyone have any ideas or suggestions as to what I may be doing wrong here and how to get past this? Thanks in advance to all, for any advice and assistance that you may be able to provide me with...
  7. Well, it turns out that two totally unrelated events happened concurrently, and falsely led me to believe that a firmware update had gone bad and caused my EISY to lose its Insteon control capabilities. In the end, the root cause of my problems turned out to be a failed PLM. It appears that my PLM likely failed as a result of my repeatedly switching each of the circuit breakers in my breaker panel on and off. I was attempting to identify all of the loads connected to each circuit in the panel, in preparation for installing a whole house energy monitor on the circuits with the largest loads. Presumably, a transient was created on the power line when one of the breakers was switched OFF and it damaged the PLM. I'm unsure as to whether my power cycling activities had also unknowingly kicked off a pending firmware update due to an EISY reboot, or if UD had coincidentally pushed out an update to my EISY in the midst of my circuit mapping activities. When I returned from the basement, I noticed that there were firmware update and EISY restart notifications from UD Mobile on my phone. I also noticed that none of my timer initiated lighting scenes had turned on when scheduled. I tried to turn on the same lighting manually through UD mobile and the admin console and also found them both to be non responsive. Naturally, my first inclination was to presume that this non-functionality was somehow related to the firmware update. My bigger fear was that I might have also unknowingly corrupted the firmware update by killing the power to the EISY in the midst of it. So I submitted a support ticket, Michel promptly responded, and we quickly determined that the EISY firmware and UI versions had both successfully been upgraded to 6.0.0. We also found that my PLM was non responsive. I'd purchased a new USB PLM when I migrated from ISY to EISY last December. USB PLMs are currently out of stock on the Insteon web site and aren't due back until sometime in November. Fortunately, the serial PLM that I'd been using with my ISY is still functional and had only been in service for about a year. So, I ordered a serial PLM adapter kit from UD to get things back up and running, and it arrived today. I did a factory reset on the serial PLM and connected it to the EISY earlier this evening. After doing a Restore PLM, I'm happy to report that all is back to normal and my EISY is able to properly control all of my Insteon devices once again. Thanks to Michel and the rest of the UD team for walking me through the debug and getting me up and running again!
  8. Great advice, and I wish the fix was that easy. Unfortunately the "Insteon Support" box is checked. I finally navigated around my way around the main UDI web site and figured out how to submit a support ticket. When we hopefully get things fixed, I'll post the solution here in case anyone else runs into the same situation. Thanks again.
  9. I was doing some electrical work earlier today, and the circuit that my EISY is powered from was power cycled in the process. When I flipped the breaker back on, I heard a few notification tones on my phone and assumed it was the result of my EISY rebooting. When I checked my phone later, I saw a message from UDMobile stating that an upgrade had completed, along with a notification that another upgrade was available. And as nightfall approached, I noticed that none of my indoor and outdoor timed lighting had turned on as it should. I pulled up the admin console and received a warning about available updates that were required. I also noticed that I couldn't manually turn any lighting on or off. I've had my EISY about 9 months and had not upgraded any of its firmware since I acquired it. In my case all lighting control is 100% Insteon based. After having owned an ISY for 10 years previous, and realizing that 5.9.1 had been available for some time, I was also a bit surprised that the EISY had apparently taken the liberty to do an upgrade on its own without my requesting or initiating it. And after reading the release notes that the upgrade note referred to, it sounded as if it may have only partially installed all of the updates that were required. So, I opted to dive in and upgrade all packages. After repeated upgrade attempts in the hope that they would correct the problems I continue to have, It looks as if this took me from version 5.8.4 to 5.9.1, and then finally to 6.0.0. But in spite of all these upgrades, unfortunately my EISY is no longer humming along and quietly doing its thing every day as it had been for the past 9 months or so. The admin console does appear to be fully functional, and time of day clock is correct. If I check the Programs/Summary tab, all of my programs appear to running according to schedule, but none of the scheduled Insteon ON/OFF actions appear to be occurring under program control as they should be. When I first start the admin console a few different error messages appear (see attached). And any time I attempt to manually issue an Insteon ON/OFF command a "Request Failed" error message pops up and the controlled item fails to respond. I assume the same thing is happening behind the scenes when a program attempts to turn something on or off. I'd greatly appreciate it if anyone else has any ideas of what else needs to be done to bring my EISY back to life. I've heard many others speak very positively about the quality of UDI's support and I'm confident we'll be able to correct this situation in short order once its referred to the right people. In my own case, my past experience with UDI and my ISY has been so good that I've never had a need to create and submit a support ticket. If someone could kindly advise me as to how to go about doing so, I'd greatly appreciate that as well. Thanks in advance for your assistance.
  10. Hi Bob: Well, since you're the guy who wrote the plugin, I trust that it works exactly as intended. If not, I'll let you know otherwise... 😉 Thanks for providing the keys that finally unlocked this puzzle for me. While poking around in that "action" tab previously, I've only clicked on that arrow button once, to toggle between the option to assign numbers or my predefined TRUE and FALSE constants to the variables. I never realized until now that a few additional clicks would reveal additional dropdowns. Sure enough, the list of properties provided by my weather station plugin is hidden back there. And I'm also able to freely select any of them and assign them to the variable of my choice! Also for the record, here's the reason behind my wanting to create a running average filter for this data. Here's the solar radiation data that was logged on AWN for two consecutive days last week. Unless you're willing to tolerate lighting randomly turning on and off at one minute intervals, you really need something to smooth this data to make sense of it. Thankfully, your guidance will make short work of taming this beast! Thanks again! Thanks
  11. Long time ISY user here who recently migrated to EISY. I’m currently running 5.8.4 and trying to take advantage of some of the added capabilities that EISY brings to the table. Thanks in advance to all for your insights and assistance. Is there any way that one can set variables in an IoX program to the property values returned by PG3 plugins? I’d like to calculate the running average of the solar radiation level measurements obtained from my Ambient weather station plugin. I’d be using this calculated value to determine whether or not to turn on supplemental indoor lighting on cloudy days. The running average is intended to smooth out the effects of passing clouds on measurement data, to reduce or prevent unnecessary turn on and turn offs. It would be a simple matter to calculate a running average of the last N measurement values returned by the plugin, if these values could somehow be directly stored into program variables. After poking around in the administrative console and the program content editor for a while, I couldn’t find a way to do this. It seems that any returned property values are only available for use in decision making as part of an if/then/else clause, rather than as part of any mathematical analysis/evaluation. Is this a fundamental limitation of how IoX interfaces with plugins? Can anyone provide any insight or ideas as to how I might be able to pass these returned values directly into a variable? Thanks again
  12. See related post here. It appears to be a bug in the admin console.....
  13. Now that you mention it, it seems like I also ran into this behavior with my old 994i many years ago. Coincidentally, I was tweaking a few of my lighting programs earlier today to fine tune the on timing based on the solar radiation reading that eisy pulls from my weather station. I use the time of day to establish a turn on window around the time of sunset, then fine tune lighting turn on events based on measured daylight level. That's when I realized that the sunset time shown in the console was off by an hour...
  14. My "Night Detect" program is scheduled to run 15 minutes before sunset. Admin console shows sunset as 7:43, but next scheduled run for this program is shown as 6:28. That works out to 15 minutes ahead of 6:43, as expected. If this holds true (fingers crossed), it appears that eisy has its internal sense of sunrise and sunset times correct, it's only the admin console display that's out of whack...
  15. Same problem with my eisy here in the Boston area (running version 5.8.4). Time of day appears to have adjusted correctly, it's only the sunrise and sunset times reported in the admin console that appear to be off. I have several lighting scenes that are scheduled relative to sunset time. Not sure if their run time will be similarly affected by this?, or if this is only a fluke in the admin console display. For reference, my Ambient Weather station is reporting sunset as 6:46 PM. The weather station has my exact longitude and latitude coordinates set, while the eisy has my location set to Boston. I'm actually about 30 miles west, I presume that's likely the reason for the slightly later sunset time reported by AWN. I'll check back in again around sunset to report whether my scene timings are similarly affected by this one hour shift...
  16. Did you do a "Restore Modem" from your Admin Console after you connected the new PLM? You can't just plug in a new PLM, you need to restore the links between all of your existing Insteon devices and the new PLM. Your ISY maintains a local record of this information and will download this information to the new PLM once you initiate a Restore Modem command. You can also test your ISY's ability to communicate with the new PLM with the Diagnostics>PLM Info/Status command, that should return the Insteon address of your new PLM. If that doesn't work, there's an issue with the new PLM or the comms link between the ISY and the PLM....
  17. Vwas replied to n4bos's topic in ISY994
    Well, after all the head scratching we went through together over the past few days, once I resolved my admin console issues, I was thinking that maybe I should quit while I was ahead. In hindsight, for me at least, the 4.9.0 to 5.3.4 upgrade couldn't have been any easier.... With this 5.3.4 upgrade in place, doesn't this provide me with the ability to use UD Mobile with my ISY? I know it requires a portal account, wondering if it also requires a paid subscription? My wife has been complaining about "all this stuff in this house that only YOU know how to use" for quite some time now. And that started me thinking... As for me, I bought my first X10 devices to enable automated and remote control of lighting and appliances when I was still in engineering school back in the late 70s. I've also been an avid audio video enthusiast since the days when buying your first killer audio system was regarded as a right of passage upon entering the workforce after graduating college. I've also taken more than my share of abuse over the years with regard to "how difficult it is to sit down and watch TV in this house..." I have a network accessible Pioneer Elite AV receiver in my current system. Right now I'm thinking that the EISY will provide me the ability to achieve customized one touch integration of all AV system functionality, while allowing the less technically inclined folks in the family to access it through their familiar smart phone devices. Maybe I can finally manage to walk away from all of this chaos as a hero - while having some fun in the process... 😊 Thanks again to all of those that helped along the way
  18. Vwas replied to n4bos's topic in ISY994
    OK, so I'm still not 100% sure of exactly what happened here, but my best guess is that there was a legacy shortcut on my desktop that was pointing to original launcher file with its stale cache entry. I'd renamed that shortcut "Admin Console" when I originally downloaded the launcher some time ago. Even though I thought I had downloaded a new launcher a few days ago, I was still clicking on that same old link, which continued to run that same old version with a cached certificate that was out of date. Following Steve's advice, I repeated the launcher download and noticed that it created another shortcut with a UD logo that was named "IoX launcher", After clicking on this new shortcut and running the new launcher, it finds my ISY and provides me with an Admin Console popup just as it should. Apologies for all the confusion and thanks again for all of the advice and guidance. With that behind me, I'm feeling a bit more confident about proceeding with the 5.3.4 upgrade. My system is 100% Insteon, and I don't use "Adjust Scene" in any of my programs. Upon Mr. Bill's advice, I did an ISY backup of the 4.9.0 configuration, and also created text backups of all of my ISY programs earlier today as an added measure of safety. If all goes according to plan, given my existing configuration, this upgrade should be as simple as pointing the admin console at the upgrade ZIP file, and letting it do its thing - correct? P.S. - I hedged my bets for the EISY upgrade and purchased a USB PLM for it - the mailman dropped it off at my doorstep about an hour ago.
  19. Vwas replied to n4bos's topic in ISY994
    Well Steve, note that this does get you back in - but only ONCE. On the next login attempt, you're back in the same boat: You'll need to clear the Java cache, then delete and download a new admin.jnlp file to get back in again - and REPEAT this process for every repeated login attempt. I've done this successfully 3 or 4 times so far. I haven't entered a support ticket yet - looks like you need a portal account to do so? At the moment I don't have one. I guess my ISY has led a fairly sheltered life. I've never attempted to remotely access it through the web, or connect it to voice services, so I never bothered signing up for a portal account. At this point, I'm wondering if I feel brave enough to attempt the 5.3 upgrade on my next one shot access into the admin console. It's not clear to me what if any benefits might be gained by waiting for the certificate issue to be resolved, in the event that my upgrade attempt goes bad for some reason....
  20. Vwas replied to n4bos's topic in ISY994
    Rest assured, once we've resolved this expired V4 certificate issue, I'll be upgrading to V5 ASAP, and most likely to EISY soon after it's back in stock. If anything, this experience has taught me that my ISY wasn't the "totally independent of the outside world" beast that I once thought it was. While I've only participated in this forum directly once or twice over the 10+ years that I've owned my ISY, I feel like a regular, as I've been lurking here on and off for years. Over that time, many of these posts and the replies given to them have provided me with a greater insight and understanding of the ISY's capabilities, and knowledge of how to use them most effectively. When I came home yesterday afternoon and faced a non responsive admin console, for a few moments I was totally taken aback and at a loss as to what to do next, until I showed up here. I'd like to extend my gratitude and offer kudos to all of the regulars in this community, for willingly sharing your knowledge and coming to the assistance of others like myself, in times of need. That's the main reason why I'm so confident and willing to continue my way down this UDI/EISY path going forward. Thanks again...
  21. Vwas replied to n4bos's topic in ISY994
    I am having exactly the same problem that Steve reported on my Windows 10 PC, and came here looking for help. Coincidentally, my problems started at about the same time that Steve reported he was having problems. Seems too coincidental for this to be some random occurrence, I'm wondering if the folks in Redmond pushed something out this afternoon that clobbered us... Backstory: I have a fairly large install with about 60 Insteon devices total, the oldest of which have been in service for about 10 years now. My PLM died a few months ago and it was my last spare, so my ISY was off the air until the folks at Insteon sent me a new one this week. After the PLM replacement I poked around and discovered that quite a few of my switches had stale links in them (leftovers from the previous PLM). I sat down last night and again this morning and started cleaning those up. I left the house at around noon to run a few errands and when I got back, I couldn't open the Admin Console. I've already tried all of the obvious, cleared the Java cache, rebooted the PLM, the ISY and the PC - but no luck. Even tried downloading and reinstalling the ISY finder. As Steve said, it finds my ISY OK, but it never gives me a popup from which to click and select Admin Console (see below) I also seem to be able to reach it through its UDAjax web interface just fine, from both my Android phone and this same Windows 10 PC, so I don't think it's a firewall or Ethernet comms issue. And a few interior lights that are programmed to turn on in the late afternoon have already turned on as scheduled. So it seems to be alive and its programs seem to be running OK. For the record, I'd posted a question about upgrading my ISY to version 5.x.x a few months ago (when I learned that the994i was being sunsetted - thanks to Mr. Bill for posting how to instructions). Unfortunately, my last PLM died just a few days afterward, and I never did get around to do the upgrade. So once I cleaned up the links, I'd planned to do the upgrade, then grab myself a new EISY in the near future. But then THIS happened! Murphy never seems to give me a break! AND the EISY is out of stock! I'll try a few more things - have a few laptops in the house that I may have connected to ISY in the past. I'll see if I have the same experience that Steve did (in once, then locked out). I'll post any new findings here and stay tuned to see what others have found. Hopefully, one of us can come up with a solution soon. Thanks in advance for everyone else's insight and assistance...
  22. Given the recent end of life notice, I'd like to ensure my ability to easily migrate my existing (75) ISY994i programs and Insteon system configuration (50+ devices) to EISY at some point in the future. As I understand it, one can easily migrate from ISY994i to EISY with a good backup, provided that the ISY994i is running V5.x firmware. My ISY is currently running 4.9.0. I've always auto upgraded it, and can't recall ever being given the option to upgrade to version 5. I'm assuming that I'll need to "Manually Upgrade ISY" from the Help menu in the Admin Console to upgrade to V5.x? Any advice related to how best to complete this upgrade is greatly appreciated. Thanks in advance...
  23. As others have stated, not only do some LED lamps draw substantially higher inrush currents at initial turn on, most LED lamps also draw peak currents during steady state operation that exceed the steady state current that would be drawn by an equivalent wattage incandescent lamp. This must be taken into consideration when determining how many lamps may be safely connected to a given dimmer. I've attached CREE's most recent dimmer compatibility list. If you review its content, as one example, you'll note that for Cree's 100W equivalent A21 lamp (which draws 17 watts), they recommend using no more than 5 lamps (85 watts) on Leviton's IPL06 600 watt rated incandescent dimmer. Some of the other dimmers listed on this chart can support a greater number of lamps, even though they have a lower wattage rating. Cree also states that their lamps are designed for compatibility with standard incandescent dimmers, and state that "Absence of a dimmer from this chart does not imply incompatibility". Based on this, I've always felt that I could safely connect the smallest number of lamps listed for any 600 watt rated leading edge incandescent dimmer included on this list with an Insteon dimmer. I've been using the Cree 100w A21 and PAR30LN TW lamps on this list with Insteon dimmers, with no more than 4 lamps connected per 600W dimmer, and 7 lamps per 1000W dimmer, with no performance or reliability issues. Cree_LED_Lamps_Dimming_Capability_Sheet.pdf
