gamard
Everything posted by gamard
  1. I run the 4.03 beta firmware since you released it earlier this month - I have not had any problems upgrading the firmware (just followed your instructions, as usual,) and the about dialog shows version 4.03 for both the firmware and UI. All is running well. However, a couple of glitches: 1. In scenes that have multiple dimmers (2477D) the 'Apply changes to all devices' does not work - I click the check box, it groups them all, I perform some other operations and coming back to the same scene , the devices are ungrouped again and the check box is clear - this worked well before the upgrade. 2. After the upgrade, one of the 2476S switches has changed the Ramp Rate and has introduced a beep that was not there before. I've seen another post with the same outcome, so maybe there are some stray commands that are being sent during the upgrade. A factory reset cleared all that and it now works the way it did before 3. I installed some more 2477S and Ds (some in a 3-way circuit) - after the install and update of the ISY with the new devices, another 2476D and a 2444A3 stopped working altogether. I removed them from the respective scenes, restored factory defaults and they came back properly. Any thoughts? Thank you for your support.
  2. I'm interested too - I had some email exchanges the other day with Venstar - here is the summary: "Thank you for your interest in our thermostats and accessories! We are planning on releasing an Insteon module that will plug-in to the existing ColorTouch thermostats. However, we do not have a firm release date for this product. We are hoping to have something available by the end of the summer this year." - looks like they're dragging their feet on this one... "The T5900 and T6900 will incorporate Humidification and Dehumidification features and should release on or before June 1st." - 2013 that is.
  3. This may have been asked before but didn't come up in my searches. Is there any reason for the ISY Finder not having a minimize option? Even having access to multiple devices one doesn't need the dialog box open on the screen at all times. So closing it, is currently the only option I see.
  4. This is a change to programs, but will not change the behavior of your current programs at all. Previously in program actions, setting a dimmer to 'On' would always just set the dimmer to 100%, therefore, it now shows as '100%'. Now in program actions, when setting a dimmer to 'On' it actually uses the local on level for the device. Well, let me try and see if I understand that: if it's 'On' it'll show '100%'; if it's 'Off' it'll show 'Off' - and all this only happens to existing programs after the 4.02 update. All new programs (after the 4.02 update) will show 'On' for 'On' and Off' for 'Off'. Also, in the existing programs if you update any line in the 'Program Content' that now shows '100%', you hit 'Update' and then 'Save' it'll revert to 'On' - just give it a try. Consistency checks are good during alfa and beta testing they say.
  5. After the upgrade to 4.02 all programs that have 'ON' for a 'Set' command in the 'Action' field will show '100%' in the 'Program Content' field (unlike previous versions where it would also show 'On'.)
