waleedelmandouh
Everything posted by waleedelmandouh
  1. How about from Android to iPhone. I tried importing the file, it said it was imported successfully and asked me to restart app. Then every time I try to restart the app it crashes right away.
  2. I'm very happy there is now (hopefully) a straight forward was to use MODBUS with eISY, the plugin I found on Polyglot is ModbusTCP Modbus TCP allows you to define your Modbus registers in a JSON file, upload it and leave the rest to IoX. No coding is necessary. Make sure the file is named modbus.iox_plugin.json Now I cannot find ant help or examples or documentation on how to configure this JSON file, or how to actually access the registers in the admin console or tie them to command/statuses. This plugin is built by UD, so I expect some guidance. I understand it's free, but at least and example please. Thank you so much.
  3. Hello, I recently got the Eisy and now using the notification controller and it was working great, then suddenly stopped working. I kept digging until I noticed REST status in the Admin portal says Not Running. I went inside Polyglot and restarted the node. REST status became running and notification started working again. So I made a program that checks on the node status and automatically reboot the Eisy if the node has issues, this didn't help. What i found out is the Node REST fails to run with Eisy reboot, and I have to manually go in the polyglot and restart it. Anyone faced same issue and have a solution for this?
  4. This is so true, ISY Portal is a masterpiece, it made life way more fun and easier.
  5. Michel, Thank you sooooo much. This did it with a simpler code than I expected. Problem solved.
  6. From the portal as it's easier to access as Html in my v# code. But I'm open for any suggestions
  7. Michel, I don't need devices status. Only the ISY status, I need to know if it is online or offline (connected to the portal or not).
  8. I'm trying to add the ability to get my ISY status from the portal to one of my windows forms software. I know there is an API for REST interface https://wiki.universal-devices.com/index.php?title=ISY_Developers:API:REST_Interface and another API called soup https://wiki.universal-devices.com/index.php?title=ISY_Developers:API:Soap that has this command GetCurrentSystemStatus (string SID) The problem it shows no syntax on actually how to call the REST command or how to point it to the ISY portal. the examples only show the response to the REST calls. I would probably also need a way to set the API in the code and an API key. Any idea how to get that? Any suggestions will be of great help.
