whywork
Everything posted by whywork
  1. Hi, I use and enjoy my ISY devices every day. I have a Polisy Pro running 6.04 with the internal zwave/zigbee matter dongle. Background: I am looking to replace a couple of aging Remotelinc 2s. IKEA is now selling a matter capable Bilresa two button switch for $6. I got a couple and I think they are nice. I have a matter network with thread over wifi running in my house with Home Assistant. The Bilresa switches pair/add to matter OK on Home Assistant. I have Zwave and Zigbee devices paired with my Polisy. I have never tried to use matter on my Polisy; no devices added. I understand that to add an already paired matter device to an additional matter "server" is not just scanning the original QR code but requires getting a new pairing code for the matter device from the first/existing matter "server". I am unable to get my Polisy to pair with the Bilresa switch. I have tried several ways. Open Home assistant, ask to share Bilresa, get pairing code. Open UD mobile, verify Matter is enabled. Ask UD mobile to add new (this would be first matter device on Polisy) matter device. UD Mobile asks for pairing code - I enter the sharing/pairing code from home assistant. After several minutes the request times out. Bilresa not added. I have tried adding Bilresa using both UD mobile on android Pixel phone and on iOS iPad. Bilresa does not add. Tried with Bilresa within inches of Polisy. No Bilresqa added. At a different location I have successfully added/shared a different matter Bilresa to two matter "servers" ((Nest hub and Home Assistant) on the same network. Bilresa is seen and works with both matter "servers." Is Matter really running on my Polisy? What other ways should I try adding/sharing Bilresa to my Polisy? Any suggestions? Thank you for you advice.
  2. Thanks to Panda88 for your work on the yolink (local) plugin. This is a follow-up report - I have successfully implemented a 4 button on/off fob YS3605-UC as a substitute for an aging Remotelinc2. Running a local hub YS1606-UC with on/off fob YS3605-UC (bound to local hub) and Yolink local 1.6.9. The YS3605 works reliably and from longer distances than remotelinc (LoRa). Some provisos - The YS3605 is exposed in the Admin Console as a four button device, however it really functions as a two button device with long and short press messages: Green button 1 gives button 1 short press, Red button 2 gives button 1 long press, Green button 2 gives button 2 short press, Red button 2 gives button 2 long press. button 3 and button 4 do not seem to exist. Make sure programs only expect information from button 1 and 2 (not 3 or 4). Also, there seems to be a bandwidth challenge. During testing, I found that many rapid Yolink button presses seem to backup/queue and get delivered in bursts. Remotelinc does not exhibit these delays. In real-world use, the Yolink fob works well with only millisecond delay. Goodbye Remotelinc2, hello 4 button on/off fob YS3605-UC. I also like the formfactor of the Yolink fob over the remotelinc. Again thanks.
  3. Deleted one Yolink node Now running only TSTYolinkLocal(11) Current Status: Connected Current Version: 1.5.14 / Standard [Beta] Time Started: Sep 26, 2025, 10:00:39 AM Thanks
  4. Thanks for the quick reply. Happy to run only one node. Just to be sure, which node should I be deleting? What is its exact name?
  5. Hi, FYI - This is information - not a request for help (yet) Was away for a while. And perhaps with the merging of local/cloud versions of hub this issue will go away but: I now have a bunch of fobs with the same name and I seem to be missing one fob and the fobs have generic names that make them hard to differentiate. More details: I have two locations - each with a standard Yolink talking hub YS1604-UC and each with a "local" Yolink hub YS1606-UC. One location has one regular 4 button fob YS3604-UC The second location has one regular 4 button fob YS3604-UC, one 2 button small fob YS3614-UC and one 4 button on/off fob YS3605-UC I have the the two Yolink plugins Current Version: 1.5.14 (local and regular) running on Polisy with Polyglot V3 So far so good However when I ask both local and regular Yolink plugins to "add all nodes" I run in to trouble I get two nodes labeled Yolink Fob I get one node labeled Yolink Fob Small (I think I renamed it) And another two nodes named Yolink Fob with the name of my second location ( I think I renamed it) Huh! Which fobs are connected via local hub(s)? Which fobs are connected via cloud hub(s)? Anyway - I use and enjoy the Yolink plugin every day. I have a feeling when the cloud and local Yolink plugins are merged, this may resolve itself. Thanks
  6. Hi, I ues and enjoy the Yolink plugin on my Polisy every day. Yolink sensors; temperature, open closed, etc working well. I am trying to use a Yolink on/off fob YS3605 US to replace my aged Insteon Remotelinc 2444A2. But I cant seem to get it to work. Background: I added a Yolink mini on/off fob YS3614-UC (mini fob, not "regular" on off fob) This is a two button mini fob. The YS3614-UC is exposed by the Yolink plugin with four parameters: Key One, Short press, Key One Long Press, Key Two Short Press, Key Two Long Press. Configured the YS3614 so key One short press is DON, Key One long press is DOF, Key 2 short press DOF and Key 2 Long press DON. Adding the YS3614 to a to a program and using the only available "control" conditions I can turn on and off an insteon switched light. Control key 1 is on and light turns on, control key 2 is on and light turns off. I can see the last command in the Admin console tab for each of the two keys in the fob. Great except that the YS3614-UC has only two buttons. The YS3605 US has four buttons, A Green and Red and B Green and Red. And is is about the same price as the YS3614-UC They are exposed as Key One, Short press, Key One Long Press, Key Two Short Press, Key Two Long Press. Key Three Short press, Key Three long press, Key Four Short Press, Key Four Long Press. Configured in same pattern as YS3614. Key One Short Press DON, Key Two Short Press DOF, etc. Add it to the existing program Control on etc The YS3605 switch one works once, to turn on the insteon light with switch one. The YS3605 switch two never works to turn orr the insteon light. Turning off the insteon switched light by "hand" and now the YS3605 switch one creates an admin console error of inability to communicate with the insteon switched light. Also the admin console only shows last command for key 1. The others, key 2 key 3, key4 always say unknown, no matter how many times I push those fob buttons. I have to use the YS3614 to turn the insteon switched light on and off. Then the YS3605 will again turn the light on only once. Yikes! I am confused. Suggestions? I would copy/paste my actual programs/settings to the forum if I knew how.
  7. Thank you. I had missed that Polyglot plugin setting/information/action in the UD app. Still, I see no way to easily reboot Polyglot.
  8. Hi, I use and enjoy UD devices every day. I am old and cranky. Keeping plugins updated - I may be confused but: It seems I have to logon to PG3x web interface Https://mypolisy:3000, say OK to this site is not secure (no certficate), then go to logon page to enter username and then password, then click on purchases. Then have to scan display page to finally see if any plugins I have purchased/installed need to be updated. A lot of steps - how about sending me an email or at least notifying me via UD mobile app that i need to update a plugin? Rebooting Polyglot PG3x There have been times when my Polisy is running (scenes and programs working) but Polyglot plugins seem to stop working/hung. There does not seem to be a drop down menu item on the polyglot interface to reboot just polyglot. I have tried warm rebooting the "working" Polisy but I often need to cold boot Polisy to get the plugins working again. How about adding a Polyglot menu item to reboot Polyglot only (perhaps in the System tab) Suggestions, comments? Best regards
  9. Hi, Magic happened. Its working. After your note about new version yesterday, I reinstalled Polisy/Hubitat/Nodeserver and rebooted everything. Thought I was up to date. This AM I got a "message" from PGx3 that a new version of Polisy/Hubitat/Nodeserver was available. OK thought I had done that. I re-reinstalled Polisy/Hubitat/Nodeserver and magically "CONNNECTED" appeared on the Polisy Hubitat nodeserver. Current Version: 1.0.2 [Production] - seems like something got fixed. Still no Real-time Hubitat log file. But I now see six Hubitat nodes/devices that include the lights I want to control. Now lets see if I can make stuff happen to those lights. Thanks for your help
  10. Hi, In this post above https://forum.universal-devices.com/topic/43492-my-experience-with-hubitathousepanel-nodeserver-in-2024/#comment-383412 I uploaded some 2 zipped overall logfiles from Polyglot/Polisy (not hubitat nodeserver specific) that were recorded around the time I first tried to install Polisy Hubitat nodeserver - they include explicit lines mentioning hubitat nodeserver. FYI - sudo pkg python3 - returns with you have the latest version of phython3 already installed.
  11. Hi, Again thanks for your help. I tried reinstalling Polisy Hubitat Nodeserver as you suggested. No Joy. (I did get the always present error message saying the install of Polisy Hubitat Nodeserver FAILED. I am not sure I am communicating what I am experiencing on my Polisy - I think the Hubitat nodeserver is not installed/working correctly. Two reasons listed below. 1) I always get an error message from day one, saying my install of Polisy Hubitat Nodeserver FAILED. While it seems to be running, every install gives me one of those annoying popups that disappear saying something that vanishes almost immediately, telling me some message to the effect that install has FAILED. 2) Polisy Hubitat Nodeserver NEVER shows any log files. I click on the log button, the window changes, but only shows the image below Real-time Hubitat log file Scroll to BottomDownload LogDownload Log PackageDebugInfoWarningErrorCritical But NO LOG information - Blank, not even a data window is created As an example of a nodeserver (Yolink) that is working for me "data window" - see below Real-time YoLink log file Scroll to BottomDownload LogDownload Log PackageDebugInfoWarningErrorCritical AutoScroll 2024-05-20 23:14:01,722 Thread-7 udi_interface ERROR yoLink_init_V3:connect_to_broker: Exception - connect_to_broker: timed out 2024-05-20 23:14:03,726 Thread-7 udi_interface INFO yoLink_init_V3:connect_to_broker: Connecting to broker... 2024-05-20 23:14:03,727 Thread-7 udi_interface DEBUG yoLink_init_V3:request_new_token: yoAccess Token exists : True 2024-05-20 23:14:03,728 Thread-7 udi_interface INFO yoLink_init_V3:connect_to_broker: Retrieving YoLink API info 2024-05-20 23:14:03,729 Thread-7 udi_interface DEBUG yoLink_init_V3:retrieve_device_list: retrieve_device_list 2024-05-20 23:14:04,242 Thread-7 udi_interface ERROR yoLink_init_V3:retrieve_device_list: Exception - retrieve_device_list : 'devices' The Hubitat Device logs show nothing other than what I posted previously. I keep thinking that the Polisy Hubitat Nodeserver, while showing valid configuration settings, is not really installed correctly. What are the FreeBSD packages dependencies for Polisy Hubitat Nodeserver? Thanks
  12. Hi, Thanks for the follow-up. I have made some suggested changes, but still remain 192.168.1.194 Polisy/Hubitat/PGx3/nodeserver "disconnected" FYI - about logging/logs I turned on 192.168.1.197 Hubitat HousePanel logging and now see logfiles BUT - 192.168.1.194 Polisy/Hubitat/PGx3/nodeserver - I can't see any log files - when under Polyglot V3 Hubitat click on LOG Real-time Hubitat log file - Nothing - restqart Polisy Hubitat node server - NO log file Real-time Hubitat log file Scroll to BottomDownload LogDownload Log PackageDebugInfoWarningErrorCritical AutoScroll Scroll to Top So to recap - after cold boot of Polisy device and Hubitat device, and waiting 5 minutes Configurations Hubitat 192.168.1.197 device: Hubitat HousePanel webSocketHost text 192.168.1.194 webSocketPort text 9100 accessToken String xxxxxx directIP String 192.168.1.194 directPort String 9100 Polisy 192.168.1.194 device: Polisy/Hubitat/PGx3/nodeserver accessToken xxxxxxx hubEndpt http://192.168.1.197/apps/api/906 restPort 9100 LOGS Hubitat 192.168.1.197 Device app:9062024-05-20 04:46:26.311 PMinfostate changes will be posted to HP at IP: 192.168.1.194:9100 app:9062024-05-20 04:46:26.267 PMinfoHubitat Local EndPoint = http://192.168.1.197/apps/api/906 app:9062024-05-20 04:46:26.264 PMinfoAccess Token = xxxxxxx Polisy 192.168.1.194 Device NO Logs - Real-time Hubitat log file - Nothing Status Hubitat(6) Current Status: Disconnected Current Version: 1.0.10 [Production] Time Started: May 20, 2024, 5:22:10 PM Uptime: 29 minutes I remain stumped. Any suggestions?
  13. I think there is a problem with my install of Hubitat nodeserver on my Polisy. Hubitat node server generates NO log, no log window, and just a popup error message that disappears quickly, saying something about /var/logfile does not exist. In the past I have re-installed Hubitat nodeserver on my Polisy to try to correct the install error messages from the first install a week or so ago. (not really sure how to uninstall/delete a node server) Attached are the original log files captured around the time of the first install of Hubitat nodeserver on polyglot pgx3 from a week or so ago. I have not investigated them, but they might have clues. system_4-29-2024_82015_AM.zip pg3_4-29-2024_82003_AM.zip
  14. Hi, Thank you for your gracious response to my somewhat cranky post. The information you provided is helpful in moving forward, but I remain stuck. I have not been able to get my Hubitat (192.168.1.197) to communicate with my Polisy (192.168.1.194) (both have reserved/fixed IP addresses) On my Hubitat, I used Hubitat Package Manager to install HousePanel. Then added HousePanel to Hubitat via user app. Chose my three Hubitat devices I want exposed - two zigbee light bulbs and the group of the two light bulbs. Opened HUB Actions log file (not obvious which log activity to watch) and hit done to adding app. This is the only log information I received from that action. app:9062024-05-16 01:11:28.885 PMinfostate changes will not be posted to HP because no server IP was provided Went to the newly visible Hubitat HousePanel Version: 3.2.5 and then settings (gear) and saw some information including things I understand my three device names accessToken xxxxxxxxxxxx endpt String http://192.168.1.197/apps/api/906 (ip of my Hubitat) but no port?? but also things I did not understand directIP String 192.168.4.4 directIP2 String 0 directIP3 String 0 directPort String 8560 ???? this ip is not in my subnet I went to Polisy PGx3 (192.168.1.194) nodeserver HousePanel. (I get an error message every time I try to install - but it seems to be running) Current Status: Disconnected Current Version: 1.0.10 [Production] Time Started: May 16, 2024, 1:21:39 PM Uptime: 23 minutes I go to Configuration for HousePanel nodeserver (disconnected) and enter accessToken xxxxxxxxx hubEndpt http://192.168.1.197/apps/api/906 restPort 9100 (?????? why this port? - is this for Hubitat or Polisy??? if I browse to my POLISY http://192.168.1.194:9100 if everything is working should I see housepanel?) I save and restart Housepanel nodeserver and watch the Housepanel nodeserver logs Real-time Hubitat log file - EMPTY - nothing. Restart again. Real-time Hubitat log file EMPTY - and Housepanel still "running" but "disconnected" If I look at PGx3 Real-time Polyglot log file I see stuff related to HousePanel Hubitat 16/05/2024, 10:51:31 [pg3] debug: MQTT Results: [frontend/system/admin] :: {"getStoreEntry":{"id":151,"uuid":"e015d267-f9b8-4fbf-ab47-ea28c5f5830f","name":"Hubitat","version":null,"status":"active","desc":"Hubitat Node Server \nThis node server reads most device types that Hubitat supports and presents them to ISY in an appropriate format. Hints and other features are included that make this an ideal back-end tool for the HousePanel GUI, which is the most flexible GUI available for smart home devices.","docs":"https://housepanel.net","url":null,"branch":null,"language":"python3","executable":"poly.py","install":"install.sh","developer":"ken@kenw.com","nsdata":null,"oauth":null,"purchaseOptions":"[{\"recurringPeriod\":\"month\",\"price\":0,\"recurring\":1,\"edition\":\"Free\",\"id\":\"1ddc0b68-331a-4d53-94f5-d6bb95d58a71\",\"isTrial\":true,\"version\":\"1.0.10\",\"branch\":\"\",\"url\":\"https://housepanel.net/hubitat-1.0.10.zip\"},{\"price\":20,\"edition\":\"Standard\",\"id\":\"b670e70d-7d2c-4c84-97f5-0101e39f79c6\",\"isPerpetual\":true,\"version\":\"1.0.10\",\"branch\":\"\",\"url\":\"https://housepanel.net/hubitat-1.0.10.zip\"}]","author":"Ken Washington","devMode":null,"shortPoll":300,"longPoll":3600,"nsInfoPoll":0,"logLevel":"WARNING","logLevelList":null,"customParams":"{\n \"accessToken\":\"\",\n \"hubEndpt\":\"\",\n \"restPort\":\"9100\"\n}\n","persist_folder":null,"profile_version":"1.0.0","readme":"This node server is the result of more than 10 years of work on the HousePanel GUI. Over the last 6 months I worked on porting the interface to display ISY devices and as an outgrowth of that work I developed this node server that translates Hubitat native devices into ISY native data streams. Use of this node server requires the installation of the HousePanel.groovy app within the Hubitat IDE.","changelog":"1.09 adds music tiles and aqara presence types\n1.10 fixes a bug in the mode device type","store":"Production","discover":1,"authorize":0,"packageList":null,"ip_added":"209.215.18.131","ts_added":1688331436,"ts_updated":1688411261,"devd":null,"polisy":1,"eisy":1,"license":"https://housepanel.net/EULA.html","isyAccess":0,"devPath":null,"devUser":null,"fileUpload":0}} 16/05/2024, 10:51:31 [pg3] debug: MQTT Results: [frontend/system/admin] :: {"getStoreEntry":{"id":151,"uuid":"e015d267-f9b8-4fbf-ab47-ea28c5f5830f","name":"Hubitat","version":null,"status":"active","desc":"Hubitat Node Server \nThis node server reads most device types that Hubitat supports and presents them to ISY in an appropriate format. Hints and other features are included that make this an ideal back-end tool for the HousePanel GUI, which is the most flexible GUI available for smart home devices.","docs":"https://housepanel.net","url":null,"branch":null,"language":"python3","executable":"poly.py","install":"install.sh","developer":"ken@kenw.com","nsdata":null,"oauth":null,"purchaseOptions":"[{\"recurringPeriod\":\"month\",\"price\":0,\"recurring\":1,\"edition\":\"Free\",\"id\":\"1ddc0b68-331a-4d53-94f5-d6bb95d58a71\",\"isTrial\":true,\"version\":\"1.0.10\",\"branch\":\"\",\"url\":\"https://housepanel.net/hubitat-1.0.10.zip\"},{\"price\":20,\"edition\":\"Standard\",\"id\":\"b670e70d-7d2c-4c84-97f5-0101e39f79c6\",\"isPerpetual\":true,\"version\":\"1.0.10\",\"branch\":\"\",\"url\":\"https://housepanel.net/hubitat-1.0.10.zip\"}]","author":"Ken Washington","devMode":null,"shortPoll":300,"longPoll":3600,"nsInfoPoll":0,"logLevel":"WARNING","logLevelList":null,"customParams":"{\n \"accessToken\":\"\",\n \"hubEndpt\":\"\",\n \"restPort\":\"9100\"\n}\n","persist_folder":null,"profile_version":"1.0.0","readme":"This node server is the result of more than 10 years of work on the HousePanel GUI. Over the last 6 months I worked on porting the interface to display ISY devices and as an outgrowth of that work I developed this node server that translates Hubitat native devices into ISY native data streams. Use of this node server requires the installation of the HousePanel.groovy app within the Hubitat IDE.","changelog":"1.09 adds music tiles and aqara presence types\n1.10 fixes a bug in the mode device type","store":"Production","discover":1,"authorize":0,"packageList":null,"ip_added":"209.215.18.131","ts_added":1688331436,"ts_updated":1688411261,"devd":null,"polisy":1,"eisy":1,"license":"https://housepanel.net/EULA.html","isyAccess":0,"devPath":null,"devUser":null,"fileUpload":0}} 16/05/2024, 10:51:31 [pg3] debug: MQTT Message processed from topic udi/pg3/frontend/system/admin to group frontend for admin 16/05/2024, 10:51:31 [pg3] info: Received commands on topic udi/pg3/frontend/ns/admin: getCustom 16/05/2024, 10:51:31 [pg3] info: [00:0d:b9:53:36:9c_6] Retrieved customparams 16/05/2024, 10:51:31 [pg3] warn: Request for customparamsdoc. Not found in database 16/05/2024, 10:51:31 [pg3] warn: Request for customtypedparams. Not found in database 16/05/2024, 10:51:31 [pg3] warn: Request for customtypeddata. Not found in database So I have configured Hubitat and Polisy. Hubitat nodeserver on Polisy seems to be running - but disconnected with some error messages. I have moved forward but still remain stuck. I look forward to your suggestions. Thank you
  15. /rant on Hi I use and enjoy my Polisy Pro every day. I wanted to have Polisy control some lights stuck on Hubitat (more info available if interested). Paid $20 for Hubitat node server and have been unable to understand/login/configure Hubitat node server. From PG3x, installed paid for Hubitat nodeserver and got error: Plugin Install of Hubitat failed with message:udx: /rest/pg3.install.ns returned error status 500 (Peeve - this error message is one of those popup boxes that the text cannot be copied from, and once the mouse move away, it disappears) However, I do see from UD Admin - slot 6 configure Hubitat with fields for things like user id, base url, password, port, etc. Almost like it is working? Watched all the youtube housepanel tutorials from the author https://www.youtube.com/@kenontube Ken Washington Tried to browse to localpolisyip:3080 (default port for housepanel/hubitat node server) also tried localpolisyip:9100 (the port listed in the slot 6 config menu) Nothing. I am stumped. With hindsight, I should have noticed that this plugin had last activity 4 years ago. I see no easy way to contact Ken Washington, only one or two users. I am not angry about the seemingly wasted $20, but more annoyed about the wasted time. I am pessimistic about my getting this plugin to work. I hope to be shown to be wrong. Again, I use and enjoy my ISY devices every day. Perhaps ISY could remove inactive/abandoned plugins from the plugin store. AND allow error message texts to be electronically copied, not just manually transcribed. /rant off I still continue to appreciate the ISY team and community support.
  16. Went to Settings: Systems and checked UUID of retired isy-994i pro and it was correct. However when I opened the Edit System for the retired isy-994i pro, I got a POPUP - Subscription The Universal Devices Portal is waiting for your device to connect to the internet. This System has connected to UD Portal in the past but is currently not connected. Please try again. OK - This part of UD Mobile knows retired isy-994i pro is OFFLINE. However - Going back to HOME tab of UD Mobile stubbornly lists the retired isy-994i pro as CONNECTED. Clicking on the retired isy-994i pro offers Devices, Schedules, Notifications, Geofences, More If I click on the my Devices Icon, i get displayed in UD Mobile the correct/entire list of my insteon and zwave devices. Seems like the remnants of the retired isy-994i pro are still inside UD mobile. I have now deleted the retired isy-994i pro and its Icon and information are gone. Still seems like a bug that until I deleted the retired isy-994i pro, it had an icon that said Connected.
  17. Hi, I use and enjoy my ISY devices every day. I use UD mobile 1.1.55 on my ipad. I have three devices each with an active portal subscription: 1) Polisy Pro 2) Backup Polisy Pro 3) isy-994i pro (retired) The real situation as of now - reflected correctly when logged onto myisoio Polisy Pro ONLINE Backup Polisy Pro - OFFLINE (was connected to the internet once yesterday to configure and powered off yesterday) isy-994i pro - OFFLINE ( retired, unplugged and has not be connected to anything since June 2023) UD Mobile Shows: 1) Polisy Pro CONNECTED 2) Backup Polisy Pro - CLOSED/ERROR qand oAuthPortqal 503 not online -- AND this cycles over and over and over 3) isy-994i pro (retired) CONNECTED (no error messages - even though has not been connected since June 2023) ISY portal gets it right. UD Mobile is confused.
  18. Registering used Polisy Pro to portal after deleting from old account. Logged on to ISY portal. Chose - add device. Entered uuid for my used (new to me) Polisy Pro. Offered 30 day trial license, accepted. Accepted license request on local Polisy Pro admin console. Seems like I have successfully transferred used Polisy Pro to my ISY portal account.
  19. Thanks for the reply. FYI - I seem to have unlinked this used Polisy Pro from its old user portal account. Logged in to local used Polisy Pro. Selected Configuration, Portal. Chose Portal Integration Revoke. Clicked, and with nary an "are you sure? confirmation" was presented with refreshed webpage showing offline - not registered (previously showed online - registered) Cold booted used Polisy Pro and it now/continues to show portal - offline/not registered. Lets see what happens when I try to link this used Polisy Pro to my account. By the way - an annoyance: I could not find a way to select/copy/paste the Polisy uuid - everywhere the uuid was displayed I was unable to select it (for example; admin console or help about). I had to read the uuid and manually type it. Sheesh!
  20. Hi, I recently purchased a used Polisy Pro as backup for my existing Polisy Pro. I received it and would like some advice on configuration. I booted it up and can login with admin/admin. I upgraded to IoX 5.8.0 and migrated to pG3x 3.2.20. Here is where I would like advice: 1) All the old devices and programs (seems to be Zwave only) are still "installed" and running. 2) This Polisy is still actively connecting to, and registered to the prior owner on the ISY portal. What is the best way to delete all the old devices and programs and to delete the old portal registration so I might register it in the future to me (don't need to register yet, as my existing Polisy Pro is working well) Thanks for your input
  21. Hi, Maybe relates to UD Mobile and status values but: Rain/flooding here in NH took out Internet for two days. Had never set up UD Mobile 1.1.44 to use local network. Did so when no internet available. Saw local polisy pro. Connected. Tried to save local connection details. Forced to try sync. Declined. Would not save local connection details. Re-entered local connection details, allowed to sync. Got "Getting Energy Expert Files From ISY" status message and five minutes later, still stuck on Getting Energy Expert Files From ISY. I don't believe I have ever configured anything related to "energy expert." Internet restored. Sync completes with only complaints about "status variables." FYI
  22. Thanks for the reply. More info: My upgrade to PG3x was November 13 Several package updates has been successfully completed since then. - Yah PG2 still being offered Probably just cosmetic
  23. Updated to PG3x from PG2 and PG3 on my Polisy Pro. Cleared java cache, redownloaded fresh jnlp. Start admin console and am offered option to goto/logon PG2 and PG3x. I thought PG2 was removed when migrating to PG3x. Clicking on PG2 option goes nowhere. Suggestions?
  24. Hi I dont have Din Relay but do have Digital loggers web powerswitch Here is the network resource i use to turn on outlet 3 GET /outlet?3=ON HTTP/1.1 Host: 192.168.1.174:8074 User-Agent: Mozilla/4.0 Connection: Close Content-Type: application/x-www-form-urlencoded Authorization: Basic (password is requested, then saved when setting up network resource)
  25. Some closure I have a PolisyPro in production and a retired/disconnected Isy-994i pro (polisy Pro connected to USB dongle 2448A7 - which means I hope to never have PLM power supply capacitor issues - with Isy-994i pro pre-configured as backup, but I digress). With PG2 and PG3 running - both PolisyPro and Isy-994i pro were configured/had node servers assigned. PG2 and PG3 connected to the PolisyPro but happily "ignored" the missing Isy-994i pro. After the migration with just PG3x running it seems PG3x is VERY upset that the Isy-994i pro is missing! Why do I say that? I deleted Isy-994i pro from PG3x configuration and the FreeBSD CPU usage went back down to 3% (from 50% - 70% or greater) Everything started working and no more up/down starting messages. Seems like everything is working OK even after 24hrs. Perhaps PG3x could be a little more forgiving; my wife tells me I should try to be.
