Zwave forced rebuild of Neighbors table?
Zwave devices are self healing so you'll probably see that it will change over time.
ISY Scene duplication
It usually does but in their attempt to unify disparate technologies, it had to be done. Had they kept the system an insteon only solution, I'm sure it never would've changed. 50 is alot to duplicate like that anyway as already mentioned. When I used the isy, I would add all of my responders to the scene first and configure them. I would add the controllers last. Doing it this way would greatly speed up the process since the devices would auto link at their respective settings
ZMatter USB: Z-Wave+, Zigbee, module for EISY
You would need to contact UDI
It may be a placeholder price due to it being out of stock...not sure why they'd do that but I doubt that is correct. Can't see it costing more than the controller itself and waaaaay out of line with UDI's historical pricing strategy
Matter Thread Devices (Locks)
Any situation with RF devices can be tricky. I use Yale locks since I can change the module inside to whatever technology I want to use. I've never had an issue with signals whether its been zwave or the Control4 module which is zigbee but proprietary to C4
Zwave locks also work.
My ISY994i became very sluggish in controlling...
If you're not having problems with direct communication between devices then I would focus on the area around the plm. If it's with all of your devices when controlled from the isy, it could be the plm going bad. You can try to factory reset it just in case (unplug for 10 sec. Plug in while holding set button until beeping stops). The choose restore plm> restore devices. Make sure it's not plugged into a surge protector or one isn't around
Are these devices directly linked via scenes or controlling programs
Concerns about migrating from my isy994i
Whether upgrading will fix your issues depends on your issues. From a pure controller/programming standpoint, it probably won't since performance shouldn't change unless you've made changes or devices are going bad. From a connection standpoint between the isy and HA, you could have issues that would be addressed by upgrading. Since you'd be using pg2 which is not supported (nor is your isy) updates could have been made to HA and other devices which could potentially be causing issues. Since no details were given, there's not much we can say. There is new instruction functionality with the new systems in regard to being able to control insteons latest and greatest. Since old insteon devices don't have anything new added, there's no functions to add. It's really not our place to say whether you're right or wrong. I look at it more as a situation on wether or not you want to have a more modern setup or continue with what you have now. Personally, I only upgrade when there's a compelling reason to. Either my system has died and I need a new one or there has been a noticeable change that enhances my experience. There's a huge difference in processing programs with the eisy2 vs isy994. I last used polisy and I was shocked at the difference in speed when it came to devices triggering. I can only imagine the jump from eisy2 compared to isy994. Just basing that off my polisy experience, and yes, that alone is worth a few hundred bucks. Heads up, swapping devices has never changed. You can still swap like for like devices (2477d for 2477d). I'm not sure of previous flaws unless you're talking about Java only. Java doesn't bother me personally. Not all new shiny things are better than older stuff. Java gets the job done. If I had to run it 24/7 it would probably matter more. However, to program every so often knowing if I never open the interface again, it'll continue to work; matters much more. When I look at programming HA or habitat vs UDIs java interface, I'd take their programming anytime. Especially since the underlying system itself is rock solid.
Should I migrate from Hubitat to Eisy?
Unfortunately this is par for the course when it comes to Zwave. I helped a friend with his zwave setup zooz 800 series. I would take UDI controllers over it any day. The programming was terrible with hubitat. With that said, you'd still experience the same thing with EISY and zwave. It was so bad, he ended up ripping all of it out and going with Ra3 like I told him to do from the beginning. Be careful about swapping to insteon though. Depending on your setup, removing those can impact your mesh network. Depending on setup (sounds like the whole home is done so you should be ok), you could potential break the routing table your devices are using to communicate. With zwave being self healing, if you have enough devices, you'll be ok. To me, lighting is an experience and with how zwave works, I couldnt live with its limitations. Regardless of cost, you're paying extra for an experience that you are not getting. Its worth it to upgrade to insteon vs going through what you are dealing with. While there are work arounds, the more you go from natural operation to having to remember different presses (and explaining to people who are already overwhelmed with just the thought of using the system) detracts from enjoying your home and really isnt worth it IMO.
½ of my Z-wave devices no are not working correctly
I agree. Zwave has a place, it's just not for lighting.
You probably have a chatty device. It's been a while since Ive used UD but you should be able to check the event viewer ( set to level 3) and see what it picks up
Test Hookup Device for INSTEON Switches
When I used insteon. I had a bulb added to mine to make sure that they were operable as well.
Newbe Insteon + X10 + Zwave
It is self contained which is why yours has continued to work even though it's been over a year since support ended. The fee is for udi to manually transfer modules over from one to another since it's a device that they no longer support. With that said, if you're buying an isy that already has zwave, there would be nothing for udi to do. You would just back up and restore your isy to the new. Once done, add your zwave devices.
NEW....Hue Bridge Pro (New Black Unit)
Oh, you're fancy.
lilyoyo1
Joined
Last visited
