bcdavis75
  1. Deleting and then re-adding the nodes worked. Thanks!
  2. Noticed a couple things. The NS actually does work on some of my players still. Overtime, I have changed the name of some players in SONOS and moved them around the house etc. In the AC, the player names never update though. I wonder if this has caused the issues. New log attached. I attempted to send text-to-speech to several zones from the AC. It worked on some but not on others. Question: Since using "Discover" does not seem to update my sones node names Can I delete a single sonos zone in the NS Nodes tab? And then try discover to add it back? If not, can I fully delete the NS and then re-install? ST-Sonos_1-14-2026_121451_PM.zip
  3. OK. I confirmed that the JishiAPI is running AND I can send commands via my browser to sonos and it works.
  4. Thanks for the reply. I appreciate you looking into it. Unfortunately, I'm no closer to resolution though. @simplextech any assistance would be greatly appreciated.
  5. About a week ago, the node server stopped working. usually a simple restart sets it straight--but not this time. Today I tried re-installing it all together but no luck. Whats strange is that in the AC, it appears to be registering volume and volume changes correctly and instantaneously. But I cannot send commands to sonos from the AC at all. Log attached. Any help is appreciated. ST-Sonos_1-3-2026_24015_PM.zip
  6. I guess I fail to understand see the value of the big Matter / thread release if it’s still not possible to add Matter devices to the platform seamlessly. Wasn’t that the whole point? As it relates to the plugin to make iox devices work in HomeKit, all I can can say is that it’s totally unreliable and, as far as I I can tell, unsupported. I also opened tickets on the plugin and was redirected back to the forum.
  7. Sure... but it's nine months later.
  8. bcdavis75 posted a topic in ZMatter
    I opened a ticket with UDI on thon this months ago and unfortunately, I'm just not gettin helpful responses. Very unUDI like. Anyway, I'm got issues with just about about every matter device I've tried to add to eisy. They in include: https://lafaer.co/products/human-presence-sensor-lwr01?srsltid=AfmBOorCFXidsUazjUtxOk-MLQ3xqtMHKF_AoFFVwW4ttwzwoHKx8U8O This device adds to the system but shows up in the AC but with no controls at all. Then I tried to add a bunch of Smartwings matter over thread smart blinds. Same problem. They add to the system but no controls to actually operate them. Lastly I tried to a a matter over thread innovelli Dimmer. This just freezes while adding and never appears in the AC. If anyone has any advice, thanks in advance.
  9. Are you on iOS? It looks like I’m on version 1.3 but I’m not seeing 1.3.4 in the App Store.
  10. Anyone else having this issue?
  11. Ok, I assume I'm dense but how exactly do we access the new dashboard? I don't see a link to it in the eisy finder after upgrade. Also, the announcement said something about Homekit integration now be included--but what does this mean and how do we actually use it? Thanks!
  12. Worked! Thanks.
  13. Updates... I took down the unit and went through the process of of reflashing it with the newer version of the node server. That worked fine. However, I cannot get it to connect to the new node server (purchased). Log attached. They are on the same network. ratgdo_8-29-2025_62823_PM.zip
  14. I'm at a loss. It's always been a bit flaky for me, but I cannot get it working at all anymore. It is correctl reading the door state in the AC, so it is connected properly and getting information through the NS. There's nothing to my eye that looks odd in the logs (attached). I've rechecked the wiring to make sure it's secure. It simply will not open/close the door though. Any help much appreciated. ratgdo_8-29-2025_53522_PM.zip
  15. bcdavis75 replied to SHM's topic in ratgdo
    Mine has also stopped working. Except I didn't change anything like SHM. The AC seems to correctly read the state of the garage door and the light. However, open and close commands no longer do anything. Not entirely sure when this started but sometime in the last month.
