doogledb
  1. The error is this: oo?
  2. Do you know what mode to use? Seems like it would use the same code I use from iRule.
  3. No luck
  4. Here are 2 versions of sending IR Code and another to what I call sending Raw code. For Raw Code I tried with and without commas, with and without \r\l and to all the difference modes...
  5. I cannot get the screen capture of my resource posted here. Looks like I need to load it in "My Media"? I cannot find where to load files to My Media
  6. I get a response like this: oo? Thanks
  7. I have 2 Samsung TVs (different models but the Remote Control Power Toggle works on both TVs, so same IR code). One use iTach IR and the other uses iTach Serial. The iTach IR TV successfully powers on/off using ISY. Now I am trying to get ISY to Power on/off the Serial controlled TV. Here is how I have the Network Resources setup for the Serial: Protocol: TCP Port: 4999 IP Address: 192.168.0.4 (for the iTach Serial connected to this TV) Time out (MS): 500 Mode: C-Escape Body for the Code: sendir,1:2,1,38000,3,1,170,168,22,62,22,62,22,62,22,19,22,19,22,19,22,19,22,19,22,62,22,62,22,62,22,19,22,19,22,19,22,19,22,19,22,19,22,62,22,19,22,19,22,19,22,19,22,19,22,19,22,62,22,19,22,62,22,62,22,62,22,62,22,62,22,62,22,3800\r\n This is the same code that works for controlling the iTach IR TV... When I test sending this code, based on the above setup, to the serial TV I get a response that looks something like this: oo? oo? I am currently controlling the Serial TV with iRule and it uses Network Codes. Here is the Power Toggle iRule sends to this TV: \x08\x22\x00\x00\x00\x00\xD6\x0D I guess there is no way for ISY to send this type of code? Thanks for all the help, Doug
  8. Jon, I could not get sending the IR directly to the RS232/Serial to work. I have 2 Samsung TVs (different models but the Remote power toggle will works on both). 1 TV is controlled by iTach IPtoIR and another is controlled by iTach IPtoSerial. Currently using iRule which sends Hex codes to the Serial controlled TV. I tried sending IR codes to Serial (via ISY) but did not work. I don't understand why you would not use the Raw Code mode for Serial. Do you know what Raw mode is for? Thanks for all your help
  9. Ahhh - did not know you could do that... Makes sense... Thanks again...
  10. Thanks Jon, Will try this later tonight... My TV is connected via Serial and not IR. Will this work for a Serial connection which I believe needs to go to Port 4999 on the GC100-6?
  11. Thank you for this jerlands, I am not real polished at understanding how to use the codes. I've tried several attempts/combinations and cannot get to work. The Raw Code for power toggle is: 08 22 00 00 00 00 D6.... I guess I cannot just put this in and use "Raw Text" Mode. If it is not too much trouble can you convert this code to what I need to use? Thanks again
  12. I downloaded the codes here from the Tivo Wiki and I assumed it was direct network codes since it was written for that application. But what confused me is that the codes have IR in it.... Example for the number 6 it is: IRCODE NUM6\r Can you point me to where the proper codes are published? thanks, Doug
  13. Thanks Michael, that is what I started with and is for IR setup. So the IR and Serial setup are the same?
  14. Has anyone successfully gotten iTach serial to work? - Is it TCP Protocol? - Use C-Escaped mode? - What is the port? 4999 or 5000? - my raw code for Samsung Power toggle looks like this: \x08\x22\x00\x00\x00\x00\xD6\x0D Do I need to append anything to this? Thank you for any help....
  15. accd, are you using the Tivo IR commands on Romio? I can get the codes to work on the prior version of the Tivo box but not the Romio. I am using the same Network setup in isy for both Tivo units, except using the specific IP address for each Tivo. Thanks
