Introducing eisy-ai !!!
@Michel Kohanim For what it's worth, I compacted 3 times with no funny business.
I have been working and I have exchanged over a dozen prompts so far. I am currently only at 60% for compaction. In my experience so far, this is unheard of! Compaction was occurring every two - three prompts. I was just going to compact, but maybe I will hold off.........lol
I can confirm, these settings drastically reduced cost!
getting an error when trying to backup using EISY-UI
I see this in the log: 2026-11-18 19:57:21 [info] proxy: Backup completed successfully.
@Michel Kohanim Glad to hear this! Do we need to make any adjustments to the Configuration Json? A quick check shows that there is a setting "max_turns": 20? Also, what is the current recommendation for history_token_budget? From reading your posts, it looks like <50000 - 20000?
On the same page as upgrading, there is a tab that says Services. Are they all running? Try clearing browser cache and try backing up again. Is there anything is the various logs?
NOAA Tides Plugin
NOAA Tides Plugin has been upgraded to v1.3.8. to fix: Next Tide In, Next High In and Next Low In to now show 0 once for every tide, so Programs using “is 0” run reliably. Please see the README for a detailed description and setup information. If you have issues or questions create a new post in the sub-forum. This Plugin was developed and tested in eisy-ui. While it should work on Polisy, it has not been tested.
Is there a specific place you are suggesting? The program ID number is already displayed in eisy-ui, right after Next Scheduled Run Time when on the main Program folder line.
"The latest", doesn't really tell us anything. The latest eisy-ui was 1.4.11, with 1.4.12 just released. So, what version are you on?
If you are using Claude, token usage appears to be available from the Dashboard - Token Volume.
@Michel, Thanks for your reply. I received the following this morning from Anthrop: Your prompt cache hit rate dropped Individual Org's prompt cache hit rate dropped 39% compared with the previous week. Check recent changes to your system prompt or cache_control placement.
I am not having any issues. I am on version 2.3.0.
AI in UD Mobile?
According to what was said and displayed during the Roadmap presentation, a new eisy-ui app is being worked on. While there is no release date available, it is in the works.
Verizon email to text is being shutdown.
Exactly why i use Pushover with the Notification Plugin. Last I checked, Pushover was still one time $5 per platform (ie: Android, IOS), don't know if that has changed. Plus you get the advantage of history. Them come over as push notifications, just like texts.
I add Pushover to that list through the Notification plugin. Haven't had a failure yet.
DennisC
Joined
Last visited
