AT&T to end email-to-text ×
jwarner964
  • Posts
    114
Everything posted by jwarner964
  1. Hi Stu The PLM does not have a pass through outlet but I will try using a cord plugged into a outlet on the same circuit as the PLM Ill report back my out come thanks
  2. jwarner964
    replaced plm
    Hi All After more than 3 years my PLM failed, smarthome replaced it for free. I installed the new one, following the instructions in this forum. All went fine except I have one device that won't rewrite. its a switchlinc dimmer turning on some lights in my kitchen the switch is not connected to a load I've tried many times still not rewriting. what do I do next ? Thanks
  3. jwarner964
    PLM
    Hi Thanks for the replies. I think I will get one to have on hand, it's good to know it only affects programs because I don't have any critical ones
  4. jwarner964
    PLM
    Hi All Just a question about the life span of the plm. Mine is 2.5 yrs old works fine , should I be expecting to replace it soon and if so would it be wise to buy one and have it wait for this one to fail Thanks, Jeff
  5. jwarner964
    Thermostat
    The isy only changes every 2 degrees, the display changes every degree
  6. jwarner964
    Thermostat
    Hi My thermostat only up dates after 2 degrees, it won't change after each degree change
  7. Hi I do have one door sensor to turn a light on and off for a laundry room
  8. Hi Stu I don't know whats happening that why I posted my problem, was hoping someone could lead me in a direction to figure out how it is happening
  9. Hi All I have a outletlinc dimmer in a scene with a 6 button keypad button to turn on and off a lamp that works fine, I also have a stair light that has 2 switchlinc on/ off switches V.43. when you turn off the stair light using the switch at the top of the stairs, it is not the switch that feeds the load it turns off the outletlinc dimmer. but only after sunset. it will also turn it on. the status of the outlet dimmer does not change in the ISY. I do have some programs that run after sunset that include the outlet dimmer but the stair light switches are not in any programs. the switch that affects the outletlinc is pretty close to the outletlinc about 5 ft, everything has been working fine until lately can't seem to fix the problem, any help would be great, thanks
  10. Hi Stu I do have a program that sends me a text when the house drops below a certain temp, It gets cold here in MN and if I'm gone and the heat goes out it good to know.
  11. Hi Stu If I query it it will update to what the thermostat says
  12. Hi All I have installed a new thermostat, Insteon . the other one quit working the current temp doesn't seen to be updating to the ISY, the humidity does. the house is 72 the ISY shows 74 I think I remember that it doesn't update every degree but how often should it Thanks
  13. Hi It looks like to me that the power is in the light box and the cable coming from the light is a switch loop
  14. Hi I like to use more than 1 program, If 6 pm then set xxx to 100 % Program 2 If 8pm Then set xxx to 50 % Ect.
  15. Hi You should always link your devices in the isy, not manually. The isy would not know those links
  16. Hi kissfan Try signing off of your girl friends phone in iTunes than sign in to iTunes with your iTunes acct on her phone, then down load the app to her phone, thats what I did Jeff
  17. Thanks Teken Will they start showing status on there own ? It doesn't come up on the ISY or mobilinc, One is easy to get at , in the basement, other is under the dishwasher and have to take the front panel to get to it
  18. jwarner964
    Leak sensors
    Hi I just updated my ISY and now the leak sensors are not showing there status, do I have to reset them ? Thanks Jeff
  19. Thanks everyone for the input I will get some outlets and start controlling my Xmas lights Thanks, Jeff
  20. Hi everyone I live in MN and wanted to use the on-off outlets to control my Xmas lights outside. Do they work in the cold ? Thanks, Jeff
  21. Hi Paul Thanks for the info, I will be getting one soon then. Do you think the 10 year batteries would be worth trying ? Jeff
  22. Hi All I wanted to get a MS and install it outside to detect anyone one walking up to my front door and also one for the back door. Living in MN it's pretty cold in the winter I was wondering how they performed in the winter. Anyone from a cold weather state have any insight for me Thanks Jeff
  23. Hi What I did was to have the status, if status of KLP is 100 % then , that works for me, you must have the KLP in a scene. then you can turn the scene from your phone or from the push of the KLP Jeff
  24. baabm you can go in to programs in the Mobilinc and change it manually in the state Vars
  25. Hi LeeG Thanks for responding. I don't understand where you would find the ISY program code for the on level change Jeff
  • Create New...
